FPGA
FPGA
Forum FPGAs you can buy
  • Replies 14 replies
  • Subscribers 582 subscribers
  • Views 4600 views
  • fpga
FPGAs you can buy
michaelkellett
michaelkellett over 4 years ago
I know  a lot of you are busy with the Sparty 7 board so there may be a lack of bandwidth.
Many parts are unobtainable now: Farnell list 541 Xilinx FPGAs of whcih two are in stock:
These are nice enough parts but no good for playing with at home ! (and anyway they only have one of each)
Lattice and Altera used to be good for simple parts in reasonable packages but have also becom impossible to buy.
I've been keeping an eye on the market and especially on Gowin and Efnix.
For simple prototyping and projects you need packages you can solder by hand or with simple gear (TQFP or QFN).
And for small budget (home or commercial) projects you need simple dev software, small gate counts and low cost.
Digikey currently have Efnix T8 and T20 parts in 144 pin TQFP in stock at £5.73 and about £10 each in small numbers. They have thousands.
The T8 gives you 8k LUTs, 8 18x18 multipliers and not a lot else, but it is low power and quite big enough for all sorts of good work (about half of my commercial designs have used less than 8k LUTs)
I've ordered a dev board £74 and a few chips.
Mouser have some Gowin parts but the prices are a bit high.
    michaelkellett over 4 years ago in reply to ajmorin369 +2
    You really don't need hot air to solder 0.5mm (or even 0,4mm) pitch pins on TQFP packages or pads on QFN packages. I try to do new boards with solder paste applied with a stainless stencil and reflowed…
    shabaz over 4 years ago +1
    Hi Michael, From the screenshots the Efinity software looks nice. I've not heard of this manufacturer before, it's great that TQFP parts are available! The dev board is a reasonable price too. I still…
  • scottiebabe
    scottiebabe over 4 years ago +1
    lcsc appears to have odds and sods in stock... https://www.lcsc.com/products/Programmable-Logic-Device-CPLDs-FPGAs_11330.html
  • jure
    jure over 4 years ago
    There are also Microsemi/Microchip FPGAs. Theese seem to be quite comparable to the Efinix ones. As far as i know the IGLOO lineup also features NVM to store the bitstream inside. I think that the software used to program Microchip FPGAs is very simmilar to Vivado.
    Sometimes buying modules can be quite beneficial since they typically feature all of the power supplies, memory etc. In total these can be also cheaper. Looking around i have found quite a few with Lattice ics, that are in stock. There are also options like MKR Vidor 4000 from arduino.
    michaelkellett over 4 years ago in reply to jure
    Microchip have a wide range of FPGAs, from their acquisitions of Atmel and Microsemi. Digikey do have several in stock in small numbers, some in TQFP packages. They are quite  a bit more expensive than Efinix but several are quite reasonably priced.
    The free toolset offered is Libero Soc Silver. I have not looked at the Libero tools for quite a while, earlier versions were a good deal easier to get into than Vivado.
    Definitely can add Microchip as a source of FPGAs you can actually buy, at least in small numbers.
  • bhfletcher
    bhfletcher over 4 years ago
    As part of our ongoing ZUBoard 1CG project, Avnet now also has XCZU1CG-1SBVAE devices in stock as well.
    http://avnet.me/Buy-XCZU1
    • 81K programmable logic cells
    • Dual-core Arm  Cortex -A53 MPCore
    • Dual-core Arm Cortex-R5F MPCore
    This is the exact same part that we are using on ZUBoard 1CG. You can read more about that board here:
    /products/devtools/avnetboardscommunity/b/blog/posts/zuboard-compared-to-minized
    Bryan
    michaelkellett over 4 years ago in reply to bhfletcher
    Thanks, for the info. At $221 and in 484 pin BGA you'll need to have deep pockets and a pretty neat prototype workshop !
    I'm hoping that this part being in stock will be the first of many Slight smile
