FPGA
FPGA
Forum UltraScale+ use OCM as shared memory between PetaLinux on A53 and Bare metal on R5
  • Subscribers 580 subscribers
  • Views 5440 views
  • fpga
  • ultrascale+
  • OCM
psd0
psd0 over 4 years ago
I am interested in using OCM, 0xFFFC0000-0xFFFFFFFF as a shared memory region between the A53 running Linux and a bare metal application on the R5.  This particular implementation does not require mutual exclusion.  On the bare metal side, I clear and invalidate the cache using Xilinx API calls, then read/write to/from OCM using Xil_In32 and Xil_Out32.  I can read back what I write, so I know the data (4-byte data chunks) is being written correctly.
On the Linux side I'm getting stale data or garbage when I try to read back what I wrote from the R5.  I was thinking perhaps something to do with caching on the Linux side, but handling that is much different than on bare metal.
I was interested in using OCM as its there and already mapped, and I thought it'd be an easier solution, for a very simplistic implementation, than messing around with device trees and shm settings.
  • psd0
    psd0 over 4 years ago in reply to psd0 +1
    Replying to myself. I got it sorted out. Some API calls I was missing on the bare metal side.
  • minimartian
    minimartian over 2 years ago in reply to psd0 +1
    Hi, Please may you explain how your sorted it? I'm trying to do the same and I am in the same situation on the baremetal side. Thanks
  • dyessgg
    dyessgg over 4 years ago
    Make sure you marke the memory on A53 side as noncacheable.
    Are you setting a flag on the R5 side and reading it on the A53 side?  If so, you've likely fallen into the "out of order execution" trap most V8-A bare metal newbies hit.  Make sure you put a DSB instruction/API call between reading your flag and accessing the shared memory.
    Make sure the OCM is correctly mapped in the MMU on the A53.  IIRC, there are some OCM regions that map to different PAs depending upon which processor.
    Greg
  • psd0
    psd0 over 4 years ago in reply to dyessgg
    Thank you for the response Greg.  I don't know how to do any of the above.  I've looked up the DSB instruction and I think I get what you mean by out of order execution.  Is there any sample code that does the above that you know of?  My searches have not been very successful in this area.
  • psd0
  • minimartian
