FPGA
FPGA
Forum Communicate serial data with ethernet on Arty-Z7
  • Replies 8 replies
  • Subscribers 580 subscribers
  • Views 3096 views
  • ethernet
  • serial data
Jonathan101
Jonathan101 over 3 years ago
Hi!
I build custom board which consist of Xilinx SOC but i ask now specifically about Arty-z7 board.
On that board I always use built in usb-uart JTAG in order to program, and communicate to/from
the board and see the serial data on the terminal.
Is it possible to communicate serial data traffic via ethernet [rj45]?
  • flyingbean
    flyingbean over 3 years ago in reply to flyingbean +3
    HI Johnthan101: Vitis uses TCF agent for debugging tool chain now. Here is one of HOWTOs for this topic: Building and Debugging Linux Applications ¶ https://xilinx.github.io/Embedded-Design-Tutorials…
  • flyingbean
    flyingbean over 3 years ago +1
    The short answer is YES. However, you need to add more codes at u-boot layer and possible kernel if you need to debug Linux. I did not do this flow, but I knew Xilinx supports it.
  • flyingbean
    flyingbean over 3 years ago in reply to Jonathan101 +1
    Will this picture from the UG908 be helpfule for Johnthan101: Glad that I am taking my vacation at home to help this topic now.
  • flyingbean
    0 flyingbean over 3 years ago
  • Jonathan101
    0 Jonathan101 over 3 years ago in reply to flyingbean
    Ok that is something.
    I am not familiar with those high technical subjects.
    1. Can you suggest background material on them?
     2. You mention Linux. Is it difference between implement this on Linux vs Standalone?
    Thanks!
  • flyingbean
    0 flyingbean over 3 years ago in reply to Jonathan101
    Check this document: Vivado Design Suite User Guide: Programming and Debugging (UG908)
    0 Jan Cumps over 3 years ago in reply to flyingbean
    That's a 455 page document. At a level that will not help anything Jonathan101 asked.
  • flyingbean
    Happy Holidays!
  • flyingbean
    0 flyingbean over 3 years ago in reply to flyingbean
    HI Johnthan101:
    Building and Debugging Linux Applications¶
    https://xilinx.github.io/Embedded-Design-Tutorials/docs/2022.1/build/html/docs/Introduction/ZynqMPSoC-EDT/6-build-linux-sw-for-ps.html
    UG908 can let you download/debug FPGA PL via Ethernet and TCF agent can give you  an option for Linux applications debug via Ethernet.
    Enjoy your learning journey.
  • Jonathan101
    Thanks Thumbsup
