FPGA
FPGA
Forum I’m running into a recurring problem with Zynq designs and I’m curious how others handle this.
  • Subscribers 580 subscribers
  • Views 636 views
micheal.embedded
micheal.embedded 10 months ago
On paper, using the PL for acceleration always looks like the right move. In practice, I keep finding that the integration cost—AXI plumbing, cache coherency, DMA setup, and tool friction—ends up dominating the project far more than the accelerator itself.
I’ve had projects where the hardware worked, but performance was still disappointing because the PS–PL interface became the bottleneck, or where workflow choices (Vivado vs Vitis) boxed me into painful rework later.
So my question is: at what point do you personally decide that moving functionality into the PL is worth it on Zynq, and when do you step back and keep things in software instead?
I’d really like to hear what decision signals or failure experiences others use to make that call.
  • venkat01
    venkat01 10 months ago +2 verified
    Well, I mostly deal with the designs targeting the PL only and I prefer using Microblaze instead of the PS, power profile and the latency are the key factors for the designs in my line of work. For resolving…
  • wolfgangfriedrich
    wolfgangfriedrich 10 months ago +1 verified
    The only way to win the performance game is, when the data is entering the PL side directly from external sources. I have fast ADCs connected straight to the PL through QSPI, do the expensive filtering…
  • embeddedguy
    0 embeddedguy 10 months ago
    For me TBH reaching at the point where you are with these FPGA is itself challenging. So congratulations that you have reached that point.
    I have some Xilinx boards and I reach a point where I have to give up..!
  • micheal.embedded
    0 micheal.embedded 10 months ago in reply to embeddedguy
    JoyJoyJoy
    thought we all like a challange
  • wolfgangfriedrich
    +1 wolfgangfriedrich 10 months ago
    The only way to win the performance game is, when the data is entering the PL side directly from external sources. I have fast ADCs connected straight to the PL through QSPI, do the expensive filtering in the PL side and the pipe it through a AXI-FIFO to the PS side for storage.
    As you said, moving data PS -> PL -> processing -> PS is not efficient.
  • venkat01
    +1 venkat01 10 months ago
    For resolving the latency issues it's preferable to move onto the US/US+ MPSoC's , the throughput over the PS-PL bridge is much better with min optimisations.
