FPGA
FPGA
Forum Ultra96-V2 – VART not found / Unable to run .xmodel
  • Subscribers 580 subscribers
  • Views 307 views
wael_gu
wael_gu 9 months ago
Hello everyone,
I am working with an Ultra96-V2 (Zynq UltraScale+ MPSoC) board and trying to deploy an AI model using Vitis AI.
Here is my current situation:
  • I successfully quantized and compiled my model on my PC using Vitis AI Docker (CPU version 2.5.0).
  • I transferred the generated .xmodel file (resnet50.xmodel) to the Ultra96-V2 board.
  • The board is running a Linux image (ultra96v2-2020-1).
  • When I try to run:
vart-runner
I get:
command not found
  • I also checked for VART libraries using:
find / -name "libvart.so"
No results were found.
It seems that Vitis AI Runtime (VART) is not installed in the current image.
My questions are:
  1. What is the recommended Vitis AI image for Ultra96-V2?
  2. Is there a prebuilt SD card image that includes VART and DPU support?
  3. If manual installation is required, what is the correct procedure for installing VART on Ultra96-V2 (aarch64)?
Any help or guidance would be greatly appreciated.
Thank you.
  • iksevas
    iksevas 9 months ago
    Could you start with a Ultra96v2 BSP and add the necessary libraries to that?
