FPGA
FPGA
Forum How much hands-on FPGA practice is actually needed before applying for entry-level roles?
  • Subscribers 583 subscribers
  • Views 398 views
  • pcb
  • fpga
  • embedded
GyanNidhi
GyanNidhi 1 month ago
I’ve been looking at how students usually learn FPGA design, and there seems to be a big difference between understanding Verilog/SystemVerilog concepts and being able to work confidently on an actual board.
For example, writing RTL is one thing, but working with constraints, clocks, synthesis, implementation, debugging, and verifying behavior on hardware feels like a different level of learning.
For students targeting FPGA or digital design roles, what kind of practical experience do you think is enough before applying?
Would a few well-structured projects on a real FPGA board be more useful than doing many simulation-only exercises?
Also curious to know which skills beginners usually struggle with the most: RTL coding, testbenches, timing constraints, interfacing peripherals, or hardware debugging?
    DAB 1 month ago
    It really depends upon the individual student.
    I have seen some students pick up the ideas and quickly progress after just one project.
    For others, you can have them run a hundred projects and they just do not really understand what they are doing.
  • Qbit
    Qbit 1 month ago
    Spot on from DAB. For entry-level roles, quality beats quantity 1 or 2 solid hardware projects where you actually deal with timing constraints and use an integrated logic analyzer  to debug real hardware behavior go much further than 10 clean simulations.
  • dang74
    dang74 1 month ago in reply to Qbit
    Yes, the importance of an integrated logic analyzer cannot be overstated.  Thumbsup
  • veluv01
    veluv01 1 month ago
    Yes, getting the RTL Design to infer the resources on the FPGA is the key factor, it differs from vendor to vendor and also with the family of FPGA's selected.
    Most of the issues in the design would only show up after the Synthesis and Implementation(AMD)/Fitting(Altera) stages so, it's better to deploy the design on the FPGA.
    Setting timing constraints for the design, it kinda makes or breaks the whole design and often ignored.
  • fpgaguru
    fpgaguru 5 days ago
    For the AMD case, I think a tutorial for beginners showing how to install and then use Ross AI would give you the most bang for your training/learning buck.
