FPGA
FPGA
Forum What resistor value do I need?
  • Replies 20 replies
  • Subscribers 584 subscribers
  • Views 3935 views
andywest
andywest over 8 years ago
I have an 8 ohm, 0.5 watt speaker that I want to drive directly from an IO pin of an FPGA. I just want to generate simple square wave beeps, so I think I can connect like this:
FPGA IO pin -> resistor -> speaker -> ground
The IO pin is set to 3.3V LVTTL, and I can choose between 4mA and 8mA.
My question is what resistor values would I need for 4mA and 8mA to get the loudest volume without drawing too much current?
Thanks!
    jw0752 over 8 years ago +6
    Hi Andy, You can try a 470 ohm which will limit the current to the speaker to 8 mA. The problem is that most of the power will be across the resistor and the speaker may not be loud enough to hear. You…
    dougw over 8 years ago +5
    3.3v / 8mA = 412.5 ohms total 412.5 - 8 = 404.5 ohms for the extra resistor You might get double the effective voltage across your speaker by using a bridge tied load configuration. (use 2 output pins…
    dougw over 8 years ago in reply to andywest +4
    You still need the resistor on one pin but no ground.
  • andywest
    andywest over 8 years ago in reply to jw0752
    No problem at all! Thanks for all your suggestions... it looks like this is the one I'm going with.
  • gecoz
    gecoz over 8 years ago in reply to andywest
    Hi Andy,
    If you interested, Murata has published a nice document on its piezoelectric sound components, which also includes some notes on the way they are connected. Although your piezo is from a different maker, you might still find some useful information that apply to your case.
    Fabio
    I like jw0752 piezo speaker idea. You can still get double the voltage and correspondingly more volume by using it in a bridge-tied-load configuration.
  • andywest
    andywest over 8 years ago in reply to gecoz
    Thanks! I welcome the opportunity to learn new things.
  • michaelwylie
    michaelwylie over 8 years ago
    If you just want a square wave, why not use a transistor as a switch and draw your current from your power supply instead? Basically, use an appropriate transistor and drive its gate or base with your FPGA signal to drive the speaker.
  • andywest
    andywest over 8 years ago in reply to michaelwylie
    Thanks for the idea.I think this is basically the same as using a logic level MOSFET, and it sounds like one good approach.
  • michaelwylie
    michaelwylie over 8 years ago in reply to andywest
    You can use a MOSFET as long as it can handle the current. Any time I drive a high current device using a microcontroller or FPGA I use a transistor unless it's a lot of current, then a relay can be used.
  • johnbeetem
    johnbeetem over 8 years ago in reply to andywest
    Michael's approach works very nicely.  Be sure to include a flyback diode across the speaker.  With a square wave, you are switching the speaker's coil on and off.  Inductive loads (motors, relays, speakers) cannot change current instantaneously and if you try to switch off the current with a transistor (or worse, an IC output) you get a large voltage spike that turns your transistor (or IC) into a fuse.  The flyback diode gives the current somewhere to go, preventing the voltage spike.
    What voltage/current do you have available and what audio power to you want?
  • andywest
    I've got the piezo element now and it works great! It's simple, inexpensive (less than $1!) and plenty loud.
    Thanks again to everyone who offered their ideas. I'm learning a lot from the community.
