Internet of Things
Internet of Things
Blog Quadcopter Charge Notifier using Particle Photon
  • Author Author: fvan
  • Date Created: 2 Jan 2016 10:44 PM Date Created
  • Views 3006 views
  • Likes 8 likes
  • Comments 20 comments
  • particle
  • particle_boards
  • photon
  • iot
  • notification
  • quadcopter
fvan
fvan
2 Jan 2016
I received my first quadcopter for Christmas, a XS Nano Quad from Revell. It’s a tiny quadcopter, which I find extremely fun to play with. Unfortunately, the battery lasts only about 5 minutes (3.7V 100mAh) and the charge time is between 30 and 40 minutes.
Because I regularly forget I put it to charge, I decided to make a simple device which can notify me as soon as the battery is fully charged, allowing me to maximise play time!
Using a Particle Photon and a photoresistor, changes in light intensity from the charge indicator LED can be measured and used to trigger a notification via the IFTTT service.
As usual, all details including code are available on my blog: Quadcopter Charge Notifier using Particle Photon – Frederick Vandenbosch
Let me know what you think! What would you use such a notification system for?
  • gadget.iom
    gadget.iom over 10 years ago +2
    Nice little hack! :)
    mcb1 over 10 years ago +2
    That's a great non invasive method of checking and notifying. I'm sure it has many other applications, especially for small toys. Mark
  • crjeder
    crjeder over 10 years ago in reply to DAB +2
    That's the same with all rotary wings. The just need a lot of energy to stay in the air. For an example to the more extreme end see this: www.youtube.com/watch You need more batteries to have more fun
  • gadget.iom
    gadget.iom over 10 years ago in reply to fvan
    Hopefully image
  • tomaja
    tomaja over 10 years ago in reply to mcb1
    I think I understand your point, thanks.
    Dragan
    mcb1 over 10 years ago in reply to tomaja
    Google search returns this:
    And who/what did they reference to.?
    I was fortunate to have also had a battery guru give our club a talk on Lixx batteries.
    The do's, don't's and myths were all covered and he did admit that it was embarrasing how much of the below site he knew from his experiences/eduction.
    http://batteryuniversity.com/learn/article/charging_lithium_ion_batteries
    Increasing the charge current does not hasten the full-charge state by much. Although the battery reaches the voltage peak quicker, the saturation charge will take longer accordingly. With higher current, Stage 1 is shorter but the saturation Stage 2 takes longer. A high current charge will, however, quickly fill the battery to about 70 percent.
    Apparently it's not the rate of charge but the final voltage that counts, and regardless of the rates full charging takes around 2C.
    He also decribed any charged Lixx battery as a Hand Grenade, and how far the the pin was pulled was relative to how close to the maximum voltage the cells were designed for.
    You are right that any battery designed to be discharged above 1C will not have electronics.
    These need to be treated with care, especially if they suffer a major G force shock.
    DAB over 10 years ago
    Yes, that was the problem I found with my first copter.
    You spend 20-30 minutes getting the battery charged for about 5 minutes of fun.
    Definitely not my idea of a good toy.
  • fvan
    fvan over 10 years ago in reply to gadget.iom
    Yeah, me too image Should ship this month, right?
