Internet of Things
Internet of Things
Blog Quadcopter Charge Notifier using Particle Photon
  • Author Author: fvan
  • Date Created: 2 Jan 2016 10:44 PM Date Created
  • Views 3017 views
  • Likes 8 likes
  • Comments 20 comments
  • particle
  • particle_boards
  • photon
  • iot
  • notification
  • quadcopter
fvan
fvan
2 Jan 2016
I received my first quadcopter for Christmas, a XS Nano Quad from Revell. It’s a tiny quadcopter, which I find extremely fun to play with. Unfortunately, the battery lasts only about 5 minutes (3.7V 100mAh) and the charge time is between 30 and 40 minutes.
Because I regularly forget I put it to charge, I decided to make a simple device which can notify me as soon as the battery is fully charged, allowing me to maximise play time!
Using a Particle Photon and a photoresistor, changes in light intensity from the charge indicator LED can be measured and used to trigger a notification via the IFTTT service.
As usual, all details including code are available on my blog: Quadcopter Charge Notifier using Particle Photon – Frederick Vandenbosch
Let me know what you think! What would you use such a notification system for?
  • gadget.iom
    gadget.iom over 10 years ago +2
    Nice little hack! :)
    mcb1 over 10 years ago +2
    That's a great non invasive method of checking and notifying. I'm sure it has many other applications, especially for small toys. Mark
  • crjeder
    crjeder over 10 years ago in reply to DAB +2
    That's the same with all rotary wings. The just need a lot of energy to stay in the air. For an example to the more extreme end see this: www.youtube.com/watch You need more batteries to have more fun
  • gadget.iom
    gadget.iom over 10 years ago in reply to fvan
    Looking forward to my Electron board arriving. image
  • neilk
    neilk over 10 years ago
    Nice! image
    Neil
  • tomaja
    tomaja over 10 years ago in reply to mcb1
    I use LiPo (not Li-Ion) batteries regularly for my RC multi rotors and airplanes. Most of them are rated at least 20C discharge and none of them includes built-in electronics.
    For example, one of my 3 cell batteries is rated 30C with capacity of 2200mAh. Three motors on my tricopter draw ~45A when run at full speed (that's ~20C discharge for that battery).
    Yes, Frederic's battery is being discharged at around 12C. And, yes, it takes more than 100mA for 1h to push 100mAh into battery that's why I included the "~" sign image
    I don't see what wrong with what I said about 1C charge rate.
    Google search returns this:
  • fvan
    fvan over 10 years ago in reply to mcb1
    This approach could be used with anything having an indicator LED for status. It may not be the best solution, but the goal was, as you said, to be non-invasive.
  • fvan
    fvan over 10 years ago in reply to gadget.iom
    Thanks Paul image
