Internet of Things
Internet of Things
Blog Quadcopter Charge Notifier using Particle Photon
  • Author Author: fvan
  • Date Created: 2 Jan 2016 10:44 PM Date Created
  • Views 3020 views
  • Likes 8 likes
  • Comments 20 comments
  • particle
  • particle_boards
  • photon
  • iot
  • notification
  • quadcopter
fvan
fvan
2 Jan 2016
I received my first quadcopter for Christmas, a XS Nano Quad from Revell. It’s a tiny quadcopter, which I find extremely fun to play with. Unfortunately, the battery lasts only about 5 minutes (3.7V 100mAh) and the charge time is between 30 and 40 minutes.
Because I regularly forget I put it to charge, I decided to make a simple device which can notify me as soon as the battery is fully charged, allowing me to maximise play time!
Using a Particle Photon and a photoresistor, changes in light intensity from the charge indicator LED can be measured and used to trigger a notification via the IFTTT service.
As usual, all details including code are available on my blog: Quadcopter Charge Notifier using Particle Photon – Frederick Vandenbosch
Let me know what you think! What would you use such a notification system for?
  • gadget.iom
    gadget.iom over 10 years ago +2
    Nice little hack! :)
    mcb1 over 10 years ago +2
    That's a great non invasive method of checking and notifying. I'm sure it has many other applications, especially for small toys. Mark
  • crjeder
    crjeder over 10 years ago in reply to DAB +2
    That's the same with all rotary wings. The just need a lot of energy to stay in the air. For an example to the more extreme end see this: www.youtube.com/watch You need more batteries to have more fun
    mcb1 over 10 years ago in reply to tomaja
    LiPo batteries are usually declared as capable of 1C charge
    Not quite.
    1C is the recommended discharge rate, and sometimes they have electronics that disconnects if it's exceeded.
    LiPo (and any Lixx) battery have varying methods of charging, but ultimately for most batteries you usually need about 140% of the battery capacity to recharge it.
    So a 100mAH battery can be discharged at 100mA for 1hour
    You 5 min run time is probably 75% discharged which is works out at around 12C or 900mA drain.
    There is much more info here.
    http://batteryuniversity.com/learn/article/charging_lithium_ion_batteries
    I suspect the 30-40 mins is to err on the safe side, and allow the motors to cool.
    I have one that plugs into the USB socket on a computer.
    Lithium batteries can catch fire if overcharged (the easist way to put them out is cover with sand).
    Your idea is a great way to prolong the life, and these toys do become addictive.
  • gadget.iom
  • tomaja
    tomaja over 10 years ago in reply to clem57
    Hi,
    As far as I know, LiPo batteries are usually declared as capable of 1C charge which means that they should be charged for ~1h.
    1C denotes current of 1 battery capacity / 1h
  • clem57
    clem57 over 10 years ago
    Why does it take longer to recharge?
    Clem
