Internet of Things
Internet of Things
Blog Set up Elecrow TTN LoRaWAN gateway on Raspberry Pi - Pt. 1: build and test
  • Date Created: 28 Dec 2023 9:20 PM Date Created
  • Views 8057 views
  • Likes 8 likes
  • Comments 37 comments
  • raspberry
  • the things network
  • lorawan
  • ttn
  • gateway
  • iot
28 Dec 2023
I installed the software for the Elecrow LoRaWAN gateway (see  Low-Cost LoRaWAN Gateways! ), and enabled the gateway on The Things Network (TTN). I used Raspberry OS bullseye 32-bit lite on a Raspberry Pi  A+. I tested this on a B+ with the same OS too.
epic
Instructions from Elecrow: https://www.elecrow.com/wiki/index.php?title=LR1302_LoRaWAN_Gateway_Module
Preparation
sudo apt-get update
sudo apt install -y git
cd ~
run sudo raspi-config to enable
  • i2c,
  • SPI and
  • Serial Port. For Serial Port, do not allow console (question 1: no), but allow enabling of the port (question 2: yes).
Build the software
The following section is different than the vendor's instructions:
clone https://github.com/Elecrow-RD/LR1302_loraWAN.git
cd LR1302_loraWAN
cd LR1302_HAL
cd sx1302_hal
back to the existing instruction
make
Create new TTN Gateway
If you don't have an account yet, create one. Select the suggested settings for your location. Once logged in, navigate to the console. Select Gateways
Register your new Gateway. Accept the suggested frequency and setup. I used https://descartes.co.uk/CreateEUIKey.html to generate an ID
Then download the json file that's created for you. It holds some of the settings you 'll need to update in the gateway's config file later.
Configure the packet_forwarder
cd packet_forwarder
nano global_conf.json.sx1250.EU868
I had to change this line extra, not in instructions:
"gps_tty_path": "/dev/ttyS0",
change the EUI in the config file, and check the TTN server URL. Save
chmod +x reset_lgw.sh
Test
./lora_pkt_fwd -c global_conf.json.sx1250.EU868
You will get a log of what's happening:
The TTN console confirms it found you:
And after some time, you will appear on the maps: https://ttnmapper.org/heatmap/
I've tested with an Arduino MKR 1310, and all worked fine:
Proper install of all software (covered fully in the next blog)
There's more than this. To install all software in a location of your choice, check the instructions on git: https://github.com/Elecrow-RD/LR1302_loraWAN/blob/master/LR1302_HAL/sx1302_hal/readme.md
first edit target.cfg, and set your user name and location where to install (must exist)
Then
make install
make install_conf
Full install post:  Set up Elecrow TTN LoRaWAN gateway on Raspberry Pi - Pt. 2: full install and run as service
Enjoy
    Jan Cumps over 1 year ago in reply to DaniLecx +1
    In the github issue you are referring to, there is a replacement reset script attached ( here ). If you overwrite sx1302_hal/bin/reset_lgw.sh with those contents, it should work with a sysfs-less linux…
    Jan Cumps over 1 year ago in reply to Jan Cumps +1
    the USE_LIBGPIOD setting in docker does the same : (see start file ) if [[ ${USE_LIBGPIOD} -eq 0 ]]; then cp /app/reset.sh.legacy ${RESET_FILE} else cp /app/reset.sh.gpiod ${RESET_FILE} fi /app…
  • DaniLecx
    DaniLecx over 1 year ago
    I get this error on my Raspberry Pi 4 64bit, looks like the issue is that GPIO sysfs is deprecated and superseded by libgpiod.
    github.com/.../120
    After this I tried using basicstation-docker, it's better but now it gives me another error:
    After adding this parameter in docker compose, it solved my issue :)
    USE_LIBGPIOD: 1
    In the github issue you are referring to, there is a replacement reset script attached (here). If you overwrite sx1302_hal/bin/reset_lgw.sh with those contents, it should work with a sysfs-less linux. As long as gpiod is installed.
    the USE_LIBGPIOD setting in docker does the same : (see start file)
            else
            fi
    /app/reset.sh.legacy uses the old school sysfs approach
    /app/reset.sh.gpiod uses gpiod
  • DaniLecx
    DaniLecx over 1 year ago in reply to Jan Cumps
    Yes you are right ! I had tried using reset_lgw.sh.gpiod but it told me gpiod wasn't installed so I gave up ( a bit fast indeed ).
    Using docker compose with basicstation was a bit more familiar and simple for me, that's a good alternative even though both approaches work :)
    After installing, I had to do a few extra steps, to
    • run as a service and
    • avoid that the log filled the disk space
    I don't know if that could be an issue with docker. If yes, it's worth checking the follow-up blogs. They deal with that.
