Internet of Things
Internet of Things
Forum Air Pollution Monitoring IOT Kit
  • Subscribers 521 subscribers
  • Views 1139 views
  • iot-starter-kit
  • frontpage
  • air pollution monitoring kit
  • iot
Hi All!
I am new to IOT. We are planning to make an Air Pollution Monitoring Kit. We are beginners, we don't even know the basics.
We googled things and found components for developing Air Pollution Monitoring IOT Kit.
Below components we figured out:-
  • Arduino Kit
  • 16x2 LCD for Arduino
  • Header pins for LCD
  • Seeed/Grove sensors
  • and HCHO sensor
  • Grove Base Shield II
Is there anything else we should buy?
Or we should buy as mentioned in Intel website https://software.intel.com/en-us/articles/exploring-air-quality-monitoring-using-intel-edison
  • IntelRegistered Edison Compute Module
  • IntelRegistered Edison Arduino Breakout Board
  • Common Cathode RGB LED + 3 x 1kΩ resistors
  • GP2Y1010AU0FGP2Y1010AU0FOptical Dust Sensor 150Ω resistor 220 F electrolytic capacitor
  • MQ-135 Gas Sensor
  • K-30 CO2 Sensor
  • PIR Motion Sensor
Sensors are not our concern. Main thing is Compute Module,Arduino Breakout Board, Arduino Kit, Grove Base Shield II. Whats the difference ? What to buy?
Because both lists are not matching.
suggestions?
Thank you in advance
    shabaz over 10 years ago +1
    Hi Swati, Google for 'In the Air Challenge' - should have all the information you need.
  • kas.lewis
    kas.lewis over 10 years ago +1
    Hey tibmeister , swati91 , If you want to have a look at a finished product you can check out the LiV Pi (I hope to have a review out shortly) or you could check out my review on the VisualAir Node both…
    Hi Swati,
  • amgalbu
    amgalbu over 10 years ago
    I thibk you should focus on design decisions Luke
    . power supply (battery? Solar cell? Energy harvesting? Wall plug?)
    . connectivity: how data will ne pushed to the cloud /gateway? WiFi? LAN? GPRS? Bluetooth?
    Then you will ne abile to male a pondered decisione on the modulea to buy
  • tibmeister
    tibmeister over 10 years ago
    Echoing Ambrogios comment; let the purpose drive the design. I am biased towards AVR but am delving into TI uCU's. For stuff I'm doing that has one or two inputs and no wifi I tend torward the ATTiny chips. If I only need one input and wifi then I go with the classic ESP-01 and if I need more IO then I tend torward the ESP-12e. If I use BLE or GPRS then the AT328P is my choice. From there you can choose the sensor(s) needed. At this point you should have a good power budget in mind so then you can decide how you want to source power; battery, solar charging, AC, wind, etc. now you should have everything you need to determine the specifics of your power source.
  • kas.lewis
    Hey tibmeister, swati91,
    If you want to have a look at a finished product you can check out the LiV Pi (I hope to have a review out shortly) or you could check out my review on the VisualAir Node both are pretty cool. For my data stream from my LiV Pi you can look here.
    Kas
