Internet of Things
Internet of Things
Forum IoT privacy: Can it be?
  • Subscribers 523 subscribers
  • Views 855 views
  • security
  • privacy
  • iot
clem57
clem57 over 11 years ago
I read this blog recently and see some bad news for us. As in USA!image Seems like the capitalists and money changers get the say before the common folks. This article points out the real issue is privacy more than security. If the information lands on a secure server, who controls what happens next? Is the backups secure? Is the data at rest secure? Is the data sold? Big questions to be answered beyond the transmission of data.
The politics of IoT privacy | Bits & Pieces from the Embedded Design World
Read and weep or find the light at the end of this tunnel. your take?
  • johnbeetem
    johnbeetem over 11 years ago +1
    My take: buy "dumb" appliances now while you still can. The Internet of Digital Things (IDioT) is not to be trusted. JMO/YMMV
    mcb1 over 11 years ago in reply to johnbeetem +1
    The Internet of Digital Things (IDioT) is not to be trusted I've used the example of a single device that reports 'whatever' only when the occupants are home. You don't need to see the data, just when…
  • johnbeetem
    You don't need to see the data, just when it sent, to work out a pattern.
    As long as that data is going somewhere, the ability to monitor it is still there.
    Secure servers can be had, and hacked as many larger organisations have discovered.
    No offense .... but it seems security is always one step behind the clever hacker and will continue to going forward.
    I've yet to see a compelling reason why you need these intelligent devices in the home.
    Mostly they aren't "absolutely necessary" they just represent convenience, or are used for other purposes.
    My belief is that everyone should have an off button since the days of the ethernet plug have been replaced by WiFi.
  • clem57
    I have bad news! I found on google that an attack based on physical access to the hardware can break AES encryption. It was only time.
  • Robert Peter Oakes
    Robert Peter Oakes over 11 years ago in reply to clem57
    listen to the latest AMP Hour pod cast and or lookup the Chip Whisperer and you will find out that is so true image
    http://hackaday.io/project/956-chipwhisperer-security-research
    or you can own one if you like
    https://www.kickstarter.com/projects/coflynn/chipwhisperer-lite-a-new-era-of-hardware-security
