Internet of Things
Internet of Things
Forum Which sensor to use for detection of Humans Climbing Poles
  • Replies 14 replies
  • Subscribers 523 subscribers
  • Views 2391 views
  • frontpage
  • proximity sensors
  • aurdino
  • ras pi 3
davetechnosis
davetechnosis over 9 years ago
My Use Case
Our client is in Power Generation business. There have more than 3000 poles to transfer power from production to power grid. The distance between each pole is 400 meters. Most of the wires are having active current, but the ones at the low level are used for earthing and dont have any power supply.
The line passes through remotest areas of India and consequently, the locals cut the Earthing wire (no active current) and sell them in market. Motion detection camera is one of the option but that creates false alarms. I am looking for a sensor where in any human is trying to climb the pole, the camera gets active and takes snap of the user trying to climb.
What kind of sensor can be used for this use case? We need to detect it from the proximity of 5 meters.
The image of the pole is here: https://blogs-images.forbes.com/stevensalzberg/files/2014/08/670px-power_lines.jpg
  • michaelwylie
    michaelwylie over 9 years ago +3
    This is already done in industry. The presence of the electric fields means the best solution will be fiber optic sensing. Fiber is immune to EMI. If you are serious about it, you can message me on here…
  • kas.lewis
    kas.lewis over 9 years ago +2
    The motion scene camera connected to image recognition to look for a person. That may be one solution. Also if you cap sense where you are looking for a signature of a human body, this would take some…
  • davetechnosis
    davetechnosis over 9 years ago in reply to dougw +2
    Ya, I wish, but the issue with IR is that it makes false alarms as even birds are routine visitors.
    dougw over 9 years ago
    An infrared motion detector should work day or night.
  • kas.lewis
    The motion scene camera connected to image recognition to look for a person. That may be one solution. Also if you cap sense where you are looking for a signature of a human body, this would take some algorithm training but possible.
    Kas
  • michaelwylie
    Do you want to detect it before or after the wire is cut?
    DAB over 9 years ago
    It might be easy to establish a capacitive sensing system, but I am not sure they could detect at the 5 m range.
    It might be possible to set up a ground grid capacitive sensor, but I am not sure it would be cost effective.
  • makerj2017
    makerj2017 over 9 years ago
    What about using vibration or sound based with a signature for matching and excluding?
  • davetechnosis
  • davetechnosis
    davetechnosis over 9 years ago in reply to kas.lewis
    Thats right, but the processing time for such image recognition requires good computing, I believe. The connectivity out there is just 2G. To climb up, cut the wires and run back would take approx 45 minutes. By that time, the patrol team can be at the incident place and catch them red-handed. But yes, as a last resort, can be used for sure.
  • davetechnosis
    davetechnosis over 9 years ago in reply to michaelwylie
    Yes, because the whole process of climbing, cutting from two poles and then moving back would ideally take 45 minutes. If the alert is generated while the intruder is climbing, that will really help us to move patrol team to the incident place.
  • davetechnosis
    davetechnosis over 9 years ago in reply to DAB
    Sounds like a good idea. Shall try and do the pilot. Lets see.
  • makerj2017
    The issue at hand is how to accomplish the detection of intruders in a timely manner so that you can intercept them before they damage your peoperty. That being said , the father out the detection happens from the target the greater the risk of false positives. The answer is to use more than one method to determine and verify your intruders before scrambling your team. Multiple sensors to accomplish this goal in order to give the intended reliable results. Not that we need to be overly complex but that it would need to be able to be verified consistently for performance over long period of time.
