Open Source Hardware
Blog How to make PCB Layout On EasyEDA?
  • Author Author: hadleywhite
  • Date Created: 9 Nov 2015 10:07 AM Date Created
  • Views 8290 views
  • Comments 22 comments
  • board
  • layout
  • pcb
  • Design
hadleywhite
hadleywhite
9 Nov 2015
  To draw PCB layout is an essential ability for electronic engineer .
  We could use many tools for PCB Layout , Altium Designer, Kicad, PADS,and so forth .But for a reason that these software are all desktop-based , you need to install it on your PC or may need to pay for the software .EasyEDA provides a feasible way to draw schematic and PCB online ,without installing a software on your PC , and you could also save it on the cloud server and share it to all the internet users in the meantime .You could utilize all the internet components Lib and PCB Lib on the internet , you could edit the Libs and add them to your Part. You could also utilize the accomplished module in the System Design or the User’s Design. That really accelerates your speed to accomplish a Project . Furthermore, you could add the PCB Layout to Your CART and pay for it with low cost for the PCB order . That is an easy way to accomplish your Project from Concept Design ,Schematic Design to PCB Design and PCB order .
  Let me introduce how to make PCB Layout out of an online schematic design on EasyEDA , an free online schematic design Tool ,spice simulation tool, PCB Design tool .
  We need to Firstly create a Schematic .
  Let us create e a DC/DC Converter schematic as followed.
  https://easyeda.com/GerryChen/LM2596_Module__Adjustable_DC_DC_Power_Converter_1_25V_35V_3A-4y4YgarJD
      The schematic consists of a power management IC LM2596s-ADJ ,A DC-DC Step-Down Power IC
  A feedback circuit including R2&R1 ,a resistor R2 and an adjustable resistor R1 , Vin and Vout Filter Capacitor C1&C2. A led Indicator circuit of output.
  Choose package for every component .
  Then convert the schematic into PCB by clicking “Convert To PCB ”ICON on the Toolbar.
  Then it will transfer to New PCB file
  Press”Ctrl+S” to save the New PCB and rename it .
  On the external frame , click the arc and delete it . Close the external frame with right angle .
  ——Change the arc on the left top side to right angle .
  Click every component and drag them to the inside of the frame .
  Put every component on the proper position .
  Then start to route it as followed .
  1、Auto route
  2、Route manually .
  1、You could choose to auto route the circuit by clicking the auto route .
  After clicking “Auto Router” ICON ,the interface will pop up with Auto Router Config .You could modify the track width , General clearance ,and so on .Click run to execute auto routing .
  ——Auto Router Config dialog.
  ——Effect of Auto Routing .
  2、However , even the tool provides function to auto route, for most of the completed circuits or special circuits , you need to route it manually .
  3、Use the PCB tools and the layers tools and use the track on the PCB Tool to connect every flying line .
  4、Remember to check the DRC Routing Rule and then make the PCB Layout to make sure that it support power integrity .After you route the wire , change the size of Toplayer Silklayer .
  5、Pour the Copper Area through the icon on the PCB tool. image
  6、Press ”M” or click the “Dimension ”ICON on the PCB tool to measure the width and the length of the PCB board. image
  ——Result of manual routing and measure the width or length of the circuit board .
  7、Commonly we pour copper on the bottom layer as ground network ,pour the copper to the Top layer as the power network .
  8、After you have route the PCB ,you could click the Designer Manager on the right hand side .
  9、Then it will transfer to Properties .Click DRC Errors and Refresh .There are no DRC Errors in the PCB Layout .Click the components and nets , you could make every components or net bright. For example , choose C2 and The capacitor C2 will become bright .
  10、Let us manually make an error . For Example , move MDC wire and there will be a big bright X and DRC Errors track2pad error.
  Move the track to its previous location and then then big X and the DRC errors will disappear.
  Once you have finished the PCB Layout , Click photo view to produce the Gerber file .
  ——PCB photo preview
  11、If you want to order the PCB board ,Click the Fabrication Output icon in the Toolbar to order the PCB ,Then go to the Add to Cart Interface .
  There are items like Numbers of Layers ,PCB Dimension Width and Height ,PCB Thickness ,PCBQTY,PCB Color,Surface Finish ,Copper Weight ,And Penalized PCB .
  When you fill in all the Items above ,save it to cart. Then go the Network Payment Interface .
  Delete the useless Gerber file .
  Fill in your country ,your name ,your address ,your Post/Zip Code ,your Telephone ,Choose Delivery Method ,Network Payment Items ,and Click to send Request .
  OK , then just wait for your PCB Order at home .
  • jc2048
    jc2048 over 10 years ago
    hadleywhite,
    I can understand that you just wanted to demonstrate the use of the on-line tool, but there are people viewing here at many different levels of ability and I think you have a responsibility to them to present a schematic that works and to show a good layout.
    Some observations:
    1) The circuit won't work as it is. Without the slider of the pot connected, your feedback is asking for 124V out of a down converter with 12V as the input. That doesn't make sense. I don't know what the converter would do - it will probably just give you 12V out. 100k is an odd value anyway (even assuming you attach the slider) - a tenth of the rotation range would adjust the voltage and the rest wouldn't. A 10k pot [attach the slider to whichever side you want depending on whether you want the voltage to increase or decrease when you turn it clockwise] with R2 as 1k1 would allow adjustment from 1.2V up to 12V.
    2) This is not the way to lay out a switching converter. The datasheet for the part has a whole long section devoted to layout considerations. The person who wrote it knew what they were talking about and it's a good idea to follow their recommendations or at least use them as a starting point.
    3) Some of the component footprints you've chosen don't make sense. The footprint for a 680uF or 220uF electrolytic capacitor is much bigger than that and would be marked to indicate the orientation of the component. The coil is an odd choice too - I think you may need something a bit more substantial.
    balearicdynamics over 10 years ago in reply to hadleywhite
    What you are pointing Hadley, is almost what I though. This software seems not supporting interchangeability of formats. My question is: what about if I don't use this tool and you will send me your pcb ? Send a text file? If you send me for example a gerber format - that IMHO is not the better format in the world in terms of simplicity but is highly exportable - I can import it without difficult on Eagle, correct it and send back to you in Gerber format again. Or after corrections convert to gerber again following the producer standard and send it to - for example - a PCB producer that works with Orca and can only accept this format from me.
    In a open source approach what if you should make your circuit open hardware and freely distributable? you can't limit to publish PDF or PNG images of your schematics and layout to avoid that other users will keep your images and redesign by themselves the circuit then rout the layout again...
    Enrico
    Anyway, to have a real scenario I suggest you to spend some time to check off line programs and see the difference.
    Just for knowledge.
  • hadleywhite
    hadleywhite over 10 years ago in reply to balearicdynamics
    Enrico ,
         i have not compared   so many tools but have ever used altium designer  ,  one of  my friend strongly recommend  easyeda to me  and hope  me to introduce it to others .I expercience it and  feel it is really a good online Schematic and PCB design tool and I am  willing to recommend it to others .
    Hadley
    Hi Hadley,
    just a question, s you are promoting with so emphasis this online tool; what other online and offline did you tried before making your choice ?
    Enrico
