Passive Components
Passive Components
Documents capacitor help
Join Passive Components to participate - click to join for free!
  • Date Created: 18 Apr 2016 12:18 PM Date Created
  • Last Updated Last Updated: 6 Oct 2021 8:49 PM
  • Views 1247 views
  • Comments 8 comments
capacitor help
need some  help with a capacitor there is so much information on this cap but it does not come out and tell you the  capacitance so I'm having a hard time figuring out the value to be able to replace it in the circuit I found a data sheet but it's not clear on the data sheet what the value is either so I've come here to possibly help me out with what I need to replace this  capacitor I will provide photos
    shabaz over 10 years ago +1
    If the distance between the two pins is 22.5mm, then ILLINOIS CAPACITOR 474MKP275KB is a suitable replacement:
    e14 Contributor over 10 years ago in reply to michaelwylie
    Thank you very much   lol ill let you know if it explodes lol have a good one
  • michaelwylie
    michaelwylie over 10 years ago in reply to e14 Contributor
    Could be wrong but I don't see any markings in the datasheet that indicate it is polarized
    i wasnt sure because the new cap has two little marks on one side and the old one has no marks on it and the pcb has no marks either  i guess because it is an input Suppression cap on ac there would be not positive or negative correct?
  • michaelwylie
    That does not look like a polarized cap. Any polarized cap would have the negative or positive clearly marked. Shouldn't matter what way it goes in.
    e14 Contributor over 10 years ago in reply to shabaz
    I know im a total noob but is this cap  polarized does it have to go a certain way in the circuit I just wondered because it has no Discerning Mark to say if it is or not
    shabaz over 10 years ago in reply to e14 Contributor
    If pin spacing is 15mm then F862BY474K310ALR0L is a suitable replacement (and take care not to purchase any 0,47uF cap - this one has similar ratings to yours).
    The data sheet usually covers multiple values. Yours happens to be 0.47uF, but the datasheet will also cover 0.1uF, 0.22uF, etc..
    This is what has me confused when i look on the data sheet i see some info that says 0.1uF and i found another one that said 0.47uF the distence is 15mm
