Passive Components
Passive Components
Documents capacitor help
Join Passive Components to participate - click to join for free!
  • Date Created: 18 Apr 2016 12:18 PM Date Created
  • Last Updated Last Updated: 6 Oct 2021 8:49 PM
  • Views 1252 views
  • Comments 8 comments
capacitor help
need some  help with a capacitor there is so much information on this cap but it does not come out and tell you the  capacitance so I'm having a hard time figuring out the value to be able to replace it in the circuit I found a data sheet but it's not clear on the data sheet what the value is either so I've come here to possibly help me out with what I need to replace this  capacitor I will provide photos
    shabaz over 10 years ago +1
    If the distance between the two pins is 22.5mm, then ILLINOIS CAPACITOR 474MKP275KB is a suitable replacement:
    e14 Contributor over 10 years ago in reply to shabaz
    This is what has me confused when i look on the data sheet i see some info that says 0.1uF and i found another one that said 0.47uF the distence is 15mm
    shabaz over 10 years ago in reply to e14 Contributor
    If pin spacing is 15mm then F862BY474K310ALR0L is a suitable replacement (and take care not to purchase any 0,47uF cap - this one has similar ratings to yours).
    The data sheet usually covers multiple values. Yours happens to be 0.47uF, but the datasheet will also cover 0.1uF, 0.22uF, etc..
    I know im a total noob but is this cap  polarized does it have to go a certain way in the circuit I just wondered because it has no Discerning Mark to say if it is or not
  • michaelwylie
    michaelwylie over 10 years ago in reply to e14 Contributor
    That does not look like a polarized cap. Any polarized cap would have the negative or positive clearly marked. Shouldn't matter what way it goes in.
    e14 Contributor over 10 years ago in reply to michaelwylie
    i wasnt sure because the new cap has two little marks on one side and the old one has no marks on it and the pcb has no marks either  i guess because it is an input Suppression cap on ac there would be not positive or negative correct?
  • michaelwylie
    Could be wrong but I don't see any markings in the datasheet that indicate it is polarized
    Thank you very much   lol ill let you know if it explodes lol have a good one
