Sensors
Sensors
Sensor Forum fire sensors
  • Subscribers 350 subscribers
  • Views 1330 views
fire sensors
juanarysantana
juanarysantana over 11 years ago
Anybody interested in discussing about fire sensors for long distance range (~500m)?
Available technologies?
Prices?
Research?
  • vsluiter
    vsluiter over 11 years ago
    What about light spectroscopy: http://www.avantes.com/applications/application/item/695-avaspecs-used-in-forest-fire-finders
    I just saw this product today: https://www.tindie.com/products/PureEngineering/arduino-c12666ma-micro-spectrometer-/ but probably it's not in the right spectral range.
    DAB over 11 years ago
    You can probably use the RPi camera with an IR filter.
    Slap a 500-mm lens on it should get you the distance you want.
    After that, you just need to setup a scanning fixture and let it look over the area.
    Emissive IR is very strong compared to reflected IR, so you might need to set up some filtering.
    dougw over 11 years ago
    You can probably use instruments like Omega OS523E-LR or a Raytek RAYR3ILRSCU, but they can get expensive.
    I did some fire sensing with a fairly inexpensive narrow band UV sensor to pick up a unique spectral line. I focused it with an aluminum reflector because lenses that will pass UV (or IR for that matter) can get very expensive. I did not try for distances beyond a few meters, but the sensor was pretty sensitive it would detect a candle about 10 meters away - perhaps a good aluminum parabolic dish would provide enough range.....
  • juanarysantana
    juanarysantana over 11 years ago in reply to dougw
    OK, thanks a lot for the information, sounds that this is a very good option, I will certainly try.
    Regards
    Juan
  • juanarysantana
    juanarysantana over 11 years ago in reply to DAB
    Excellent, many thanks for the idea!
    Regards
    Juan
  • juanarysantana
    Good, these are very interesting ideas, it sould work,
    Regards and thanks
    Juan
