Test & Tools
Test & Tools
  • Views 2675 views
  • Comments 21 comments
  • signal
  • am
  • 33622a
  • fm
  • transmitter
  • radio
  • blog
  • road_test
Robert Peter Oakes
Robert Peter Oakes
21 May 2014
90.5Mhz
1.414 VRMS output
Frequency Modulation
240Khz frequency deviation
External Modulation
1 Volt Modulation input
740Khz frequency,
Amplitude Modulation ,
100% depth of modulation,
External Modulation
1V modulation input...
Easy
so here is the show
  • Robert Peter Oakes
    Robert Peter Oakes over 11 years ago in reply to Problemchild +1
    DSSC on AM,
    you can also modulate with FM, PM, FSK, BPSK and SUM (Channel 1 + other channel or external input or arbitrary waveform)
    of course if you modulate with channel 2, it also can be further modulated by an inbuilt modulation or an external source, it blows your mind once you start looking at all the permutations you could create,
    Robert Peter Oakes over 11 years ago in reply to DAB
    Nothing embedded except me and my madness, and IE is more than used t that I assure you image
    AM, FM with a few variations like DDS
    DAB over 11 years ago
    Your video crashed my IE browser.
    Now I wonder what you embedded in it to kill it. image
  • Problemchild
    Problemchild over 11 years ago in reply to Robert Peter Oakes
    /Yeah what other modulation schemes does it support natively ?
