Test & Tools
Test & Tools
  • Views 2992 views
  • Comments 21 comments
  • signal
  • am
  • 33622a
  • fm
  • transmitter
  • radio
  • blog
  • road_test
Robert Peter Oakes
Robert Peter Oakes
21 May 2014
90.5Mhz
1.414 VRMS output
Frequency Modulation
240Khz frequency deviation
External Modulation
1 Volt Modulation input
740Khz frequency,
Amplitude Modulation ,
100% depth of modulation,
External Modulation
1V modulation input...
Easy
so here is the show
  • Robert Peter Oakes
    Robert Peter Oakes over 12 years ago in reply to Problemchild +1
  • Problemchild
    Problemchild over 12 years ago
    Ok OK I'm Dancin'
  • Problemchild
    Problemchild over 12 years ago in reply to Problemchild
    I assume the radio there is where the noise is coming from ? no real demo of the reception... we'll believe anything though
  • Problemchild
    scope it or it didnt happen Peter
    I did switch between AM and FM on video but it is not easy to "Prove" it all in this case   (Trust me, I'm Batman)
    and Yes the radio is where the noise is coming from, picked up by my head set microphone
    any tips on how to Prove without actually being there ?
    Peter
  • Problemchild
    Problemchild over 12 years ago in reply to Robert Peter Oakes
    Yeah I caught the repeated sound slightly lagged from the Radio. I wrote that before getting to the end of the video.... I belive you ...This time image
    for sure it was a fun demo of how powerful the 33622A is I have yet to fail from an idea to doing it with that device... awesome
  • Problemchild
    /Yeah what other modulation schemes does it support natively ?
    AM, FM with a few variations like DDS
    DSSC on AM,
    you can also modulate with FM, PM, FSK, BPSK and SUM (Channel 1 + other channel or external input or arbitrary waveform)
    of course if you modulate with channel 2, it also can be further modulated by an inbuilt modulation or an external source, it blows your mind once you start looking at all the permutations you could create,
  • Problemchild
    Sorry to sound Noob but this have an Ethernet or USB data port that you can pump live data in to and if so how fast can you go with it before it goes flaky ?
    It has Ethernet and USB but this is not for modulation in real time
    There is a separate COAX input that can take a 1V or 5V peak signal to modulate up to the value you have set either in depth (AM) or width (FM). I have not tried to see what the upper data rate is but I can set up an experiment and see. It certainly handles the complete audio spectrum
    The fun will be in measuring when it starts to fail, my Oscilloscope is not too good at that so I will have to figure out how to test this
