Test & Tools
Test & Tools
  • Views 3001 views
  • Comments 21 comments
  • signal
  • am
  • 33622a
  • fm
  • transmitter
  • radio
  • blog
  • road_test
Robert Peter Oakes
Robert Peter Oakes
21 May 2014
90.5Mhz
1.414 VRMS output
Frequency Modulation
240Khz frequency deviation
External Modulation
1 Volt Modulation input
740Khz frequency,
Amplitude Modulation ,
100% depth of modulation,
External Modulation
1V modulation input...
Easy
so here is the show
  • Robert Peter Oakes
    Robert Peter Oakes over 12 years ago in reply to Problemchild +1
  • Problemchild
    Problemchild over 12 years ago
    Ok OK I'm Dancin'
  • Problemchild
    Problemchild over 12 years ago in reply to Problemchild
    I assume the radio there is where the noise is coming from ? no real demo of the reception... we'll believe anything though
    I did switch between AM and FM on video but it is not easy to "Prove" it all in this case   (Trust me, I'm Batman)
    and Yes the radio is where the noise is coming from, picked up by my head set microphone
    any tips on how to Prove without actually being there ?
    Peter
  • Problemchild
    Problemchild over 12 years ago in reply to Robert Peter Oakes
    Yeah I caught the repeated sound slightly lagged from the Radio. I wrote that before getting to the end of the video.... I belive you ...This time image
    for sure it was a fun demo of how powerful the 33622A is I have yet to fail from an idea to doing it with that device... awesome
  • Problemchild
    /Yeah what other modulation schemes does it support natively ?
    AM, FM with a few variations like DDS
