Test & Tools
Test & Tools
Blog DIY Source Meter Unit - initial thoughts
  • Date Created: 6 Jun 2020 11:36 AM Date Created
  • Views 6186 views
  • Likes 10 likes
  • Comments 16 comments
  • opamp
  • smu
  • analog
6 Jun 2020
I'm thinking about building a low power SMU.
We're playing with OpAmps and discrete semiconductors regularly over here, and there's a Keithley 2450 SMU with I-V Tracer Software  road test going on.
Learnings from those activities can be applied here.
image: over simplified concept
Goals:
Only two;
  • Make a Source Measure Unit.
  • Make it programmable or scriptable
Possible capabilities:
This would be a low power instrument, µA up to maybe a few mA. Low voltage. A utility that can be used with analog low power devices.
Source and sink voltage and current. positive and negative.
Constant current, constant voltage.
(undefined) precision and speed
It should be possible to make this modular:
  • the driver part
  • the measure part
  • controller and converters
  • human and digital interfaces
I'm going to read up on the subject now. Ideas and support are welcome.
    shabaz over 6 years ago +7
    Hi Jan, There's a couple of open source SMU-like devices that might be worth exploring, in case it gives some ideas for your project. One is ADALM1000 ADALM1000 see here for more info Getting Started with…
  • michaelkellett
    michaelkellett over 6 years ago +6
    If you like to use it my power amplifier as blogged about in: Frequency Response Analyser Progress would be a possibility for your driver section. I'll have some boards soon (Fedex say Monday) and some…
  • jc2048
    jc2048 over 6 years ago +6
    This is interesting. Several times when I was doing the transistor blogs I wondered about about doing some kind of modular test setup [though it was fun designing the ad-hoc circuits and wiring the prototype…
  • fmilburn
    fmilburn over 6 years ago
    I would like to contribute.  If I can keep up with you guys.
    • Vote Up +5 Vote Down
  • fmilburn
