Test & Tools
Test & Tools
Blog Keithley DMM6500 Scanner Card - first impressions
  • Date Created: 7 Feb 2023 9:45 PM Date Created
  • Views 5897 views
  • Likes 11 likes
  • Comments 16 comments
  • 88ad1490-a97d-11ed-afa1-0242ac120002
  • 2000-scan
  • dmm6500
  • keithley
  • scan-2000
7 Feb 2023
I road tested the  Keithley Bench Digital Multimeter DMM6500. I recently purchased a 2000-SCAN 10 channel scanner card. This is my fist little test after receiving it.
I bought a 2nd hand card. 250€ on eBay. It's the relay version (there's also a solid-state version).
It can switch 10 2-wire inputs. For low resistance measurements, you can make 5 4-wire measurements.
Photos
At the top of the post, you see the front side with the lid closed. Here is the same view with that lid open.
This is the unspectacular underside:
Wiring it up
I've wired channel 1 and 6 up. So that I can do 2 2-wire measurements or one 4-wire one.
Then plugged the card into the DMM dock:
I connected the 2 channels to a power supply. Channel 1 to a 1V dc output. Channel 2 to 1.5V dc.
Specs
Setting up a simple scan
I defined a DC Volt scan for both, taking 1 sample on each channel
Then I used the Channel App, and ran the scan:
Simple start, but it worked as expected.
link to all posts
    Jan Cumps over 3 years ago in reply to Gough Lui +1
    I'm surprised you didn't actually build one Look here: DC switching board . neuromodulator made one. I've been thinking (and procrastinating) about it too. Then this one popped up in my eBay search…
    One hesitation I would have buying second hand is simply the amount of wear on the relays. It was a gamble. That's why I never bought 2nd hand ones that were going for a higher price. 250 € is still…
  • Gough Lui
    Gough Lui over 3 years ago
    I'm surprised you didn't actually build one - I'm aware of Cozscan2020 which seems like a pretty decent choice if you were to DIY:
    https://github.com/cozdas/CozScan2020
    It's nice that Keithley has compatibility with such a wide variety of (and some old) scanner cards. One hesitation I would have buying second hand is simply the amount of wear on the relays. Then again, I suppose you could just replace them yourself when the time comes ...
    - Gough
  • Gough Lui
    - Gough
    Look here:  DC switching board . neuromodulator made one. I've been thinking (and procrastinating) about it too. Then this one popped up in my eBay search at a decent price.
    I can still build one.
    It was a gamble. That's why I never bought 2nd hand ones that were going for a higher price. 250 € is still a lot of money to loose, but no drama.
    The relays can switch 10^8 operations, I hope they still have some life in them. And as you say, I can always replace the relays.
    I actually think that my card has never been used in anger. Devices that have been around in a test lab have a certain patina. This one looks virtually unused.
  • Gough Lui
    Gough Lui over 3 years ago in reply to Jan Cumps
    Well, I did build my own ... more than one actually ...
    https://goughlui.com/2022/09/24/project-usb-lan-40-input-1w-2w-4w-solid-state-relay-multiplexer-w-rp2040/
    Not that it was anything special or particularly user friendly. Just something quick for "the guy that still doesn't have a DMM6500" ... i.e. me.
    - Gough
