Test & Tools
Test & Tools
Blog Keithley DMM6500 Scanner Card - temperature and 4-wire resistance continuous measurements
  • Date Created: 6 Mar 2023 9:20 PM Date Created
  • Views 2431 views
  • Likes 9 likes
  • Comments 5 comments
  • 88ad1490-a97d-11ed-afa1-0242ac120002
  • 2000-scan
  • dmm6500
  • keithley
  • scan-2000
6 Mar 2023
I road tested the  Keithley Bench Digital Multimeter DMM6500. I recently purchased a 2000-SCAN 10 channel scanner card. This 4th post shows a continuously running script that logs temperature and 4-wire resistance with the scanner card.
Test Setup
I'm trying to measure the shortcut-resistance of a connector on a PCB, related to the temperature of the PCB. The board is heated from room temperature to 65°C. A thermocouple is connected to channel 2 of the switch card. The 4-wire to channel 5 and 10.
The scan config:
  • chan 2: Temp, thermocouple, K, simulated cold junction temp 21°C, label temp
  • chan 5: 4 Wire Res, 1 Ohm, label res
  • scan: infinite, interval 5 s
I start the scan, and llet the temperature ramp up to 65°, then ramp down again
Results
I stored the data on a memory stick and used a spreadsheet to draw a graph:
image image
I also used the DMM6500 graph options to show individual channels, and both together in various setups.
All graphs, from spreadsheet and DMM6500, are based on the same data.
data: defbuffer1_0306_212839.zip
link to all posts
  • javagoza
    javagoza over 3 years ago
    Thanks for sharing! It's interesting, the relationship between the change in temperature and the change in electrical resistance seems somewhat linear.
  • javagoza
    Jan Cumps over 3 years ago in reply to javagoza
    Yes, although I don't know what I'm measuring. I think it's an interesting exercise to show what the DMM6500 and scanner card can do.
    But I have no clue what I'm measuring. Could be the copper, the connector, the contacts. Or maybe it's the resistance change in the chunk of alu foil that I used to create the connector short. That's why I don't document this as a post related to the connector series that I'm writing.
    It doesn't matter - I just wanted to try out the scanner options. That works very well.
