Test & Tools
Test & Tools
Blog Keithley DMM6500 Scanner Card - temperature and 4-wire resistance continuous measurements
  • Date Created: 6 Mar 2023 9:20 PM Date Created
  • Views 2481 views
  • Likes 9 likes
  • Comments 5 comments
  • 88ad1490-a97d-11ed-afa1-0242ac120002
  • 2000-scan
  • dmm6500
  • keithley
  • scan-2000
6 Mar 2023
I road tested the  Keithley Bench Digital Multimeter DMM6500. I recently purchased a 2000-SCAN 10 channel scanner card. This 4th post shows a continuously running script that logs temperature and 4-wire resistance with the scanner card.
Test Setup
I'm trying to measure the shortcut-resistance of a connector on a PCB, related to the temperature of the PCB. The board is heated from room temperature to 65°C. A thermocouple is connected to channel 2 of the switch card. The 4-wire to channel 5 and 10.
The scan config:
  • chan 2: Temp, thermocouple, K, simulated cold junction temp 21°C, label temp
  • chan 5: 4 Wire Res, 1 Ohm, label res
  • scan: infinite, interval 5 s
I start the scan, and llet the temperature ramp up to 65°, then ramp down again
Results
I stored the data on a memory stick and used a spreadsheet to draw a graph:
image image
I also used the DMM6500 graph options to show individual channels, and both together in various setups.
All graphs, from spreadsheet and DMM6500, are based on the same data.
data: defbuffer1_0306_212839.zip
link to all posts
    Jan Cumps over 3 years ago
    Rant after the facts:
    Halfway my exercise I had to take the scan card out and switch the 2 wires of the thermocouple. The temperature was dropping below 0° when I heated the PCB.
    K-type wiring has yellow +, red -. Rage
  • javagoza
    javagoza over 3 years ago in reply to Jan Cumps
    Scream
  • javagoza
    Scream
