Test & Tools
Test & Tools
Blog Keithley DMM6500 Scanner Card - wiring
  • Date Created: 9 Feb 2023 10:49 PM Date Created
  • Views 2064 views
  • Likes 11 likes
  • 88ad1490-a97d-11ed-afa1-0242ac120002
  • 2000-scan
  • dmm6500
  • scan-2000
9 Feb 2023
I road tested the  Keithley Bench Digital Multimeter DMM6500. I recently purchased a 2000-SCAN 10 channel scanner card. This 2nd post shows 2 ways I wired it: for easy use and for least resistance
Twisted pair
For my first tests I wired channel 1 and 6 with twisted pairs.
I used these channels to do my first tests, because they allow for a few scenarios:
  • 2 x 2 wire voltage, resistance, temperature
  • 4 wire resistance
  • these channels can also measure current if you solder a shunt resistor
I'll post my measurement of the first two scenarios later. I have no intention (yet) to place shunts on channel 1 and/or 6.
Flat flex
A convenient way to get all 10 channels out is with a flat flex. This cable gives access to all 10 in an orderly way. The copper is thinner though, and you can't twist the pairs.
I tinned the wires before inserting them, and tried to make the whole thing neat.
I reused a little gizmo I made years ago to break out a 2x10 connector to a breadboard:.
Resistance, including the connections from the meter to the card, the relays, the flat flex + connector, my gizmo, a breadboard and a patch wire: 1.9 Ohm.
With the pins bridged right at the flat flex connector, it's less than 1 Ohm:
Good enough for a lot of measurements.
link to all posts
    Jan Cumps over 3 years ago in reply to DAB
    Have you looked at stability of the measurements over time?
    No. It's the most precise instrument I have. And I don't have good standards either. I'm not able to measure deviations.
    Long time drift for this instrument is documented though, by Keithley.
    Also, the calibration for the instrument has expired. I checked what it 'd cost me to send it in to a calibration lab in Germany, but it's expensive.
    DAB over 3 years ago
    Nice update Jan.
    Given the quality of the meter, it is probably not a problem, but it could be interesting to look at.
    genebren over 3 years ago
    This looks to be a couple of good solutions to wiring up scanner card.  Well done!
