Test & Tools
Test & Tools
Blog MP710086 / MP710087: Lab Bench Power Supply Quick Review!
  • Author Author: shabaz
  • Date Created: 18 May 2026 8:35 PM Date Created
  • Views 798 views
  • Likes 10 likes
  • Comments 9 comments
  • power supply
  • mp710086
  • bench psu
  • MP710087
  • psu
  • bench supply
shabaz
shabaz
18 May 2026
I've desired a decent linear low-noise power supply for ages, and I think I've finally found one at a reasonable price.
image (Image source: Farnell website)
It's actually been around for ages. fmilburn reviewed the 30V 5A 150W model several years ago! I had forgotten about that review, and recently rediscovered it. I went for the 60V 3A 180W model, since that will suit my needs I think.
It's well worth reading Frank's review, and special thanks to both Frank and (+) Gough Lui - element14 Community for figuring out how to interface the instrument to a PC; I'm looking forward to using that feature as well.
I created a brief video review with a mobile phone so the video quality is a bit shaky. First, here's a quick bullet-point review:
Things I Loved
* The compact size (although it's very heavy of course, due to the internal transformer)
* A really simple, easy-to-use user interface!
* Surprisingly low-noise
* Good behavior when the PSU output is enabled/disabled, and under changing loads
* Very large, easy-to-read display
* Dual interfaces for programming; RS-232 and USB
Things I Liked
* Construction seems solid
* Proper front-panel rocker switch for power
Things that could be Improved
* The charting capability could do with some more work
* Ethernet interface option would be useful
* The font could be cleaned up, seems weird to have 7-segment-style characters on a dot-matrix TFT.
* Price is admittedly quite fair, but it would be nice to see a discount, and perhaps a saving for a bundle of two PSUs
Video
Thanks for reading / watching!
    shabaz 5 months ago in reply to kk99 +1
    Zero or low audible noise is definitely a good thing : ) Interestingly I'd seen some reports that the Owon badge version of this MP71008x PSU made a lot of noise, but the fan noise seemed reasonable…
    shabaz 5 months ago in reply to DAB
    Hi DAB,
    Thanks!
    DAB 5 months ago
    Very good review.
    Nice testing.
  • kk99
    kk99 5 months ago in reply to shabaz
    Nice power supply. Yes, the DIY kit has a good educational aspect. With manually selected components and, let's say, your own project of a PCB, it probably can end with a really nice device. Similarly, with enclosure, where these days we have the possibility to use 3D printers, etc.
    Interestingly I'd seen some reports that the Owon badge version of this MP71008x PSU made a lot of noise, but the fan noise seemed reasonable to me (i,e. as expected, for a linear PSU, and it adjusts depending on the load).
    I also have this crude thing built ages ago, assembled from ready-made modules and Velleman project kits:
    It's quite low-noise, just a couple of tens of mV p-p perhaps. At that ballpark level and at the frequencies involved, the noise rarely becomes a limiting factor, especially since most projects will have some element of filtering and regulation too. I've used it a lot with op-amp experiments, and the dual outputs are useful.
    There is no current limit adjustment (doesn't really need it, since it cannot provide more than a few hundred mA). Anyway, particularly for (say) sub-500mA uses, personally I'd definitely consider a DIY build (hopefully constructed better than this, and maybe with a better regulator, say LT3081 or LT1963? - don't know though!) since then it can be completely silent, and considerably lower-noise than most cheap ready-made power supplies, and to keep it simple, as mentioned, personally I wouldn't miss a current limit in that case; I know that wouldn't suit everyone. I sometimes look to see if there are nice PSU DIY projects online, but most of them overcomplicate things. There are LT1963 boards with large heatsinks pre-assembled on AliExpress, for low-cost, and that seemed appealing to me.
    Photo of the insides:
    The voltage regulators, P1823 kits, are LM317 based:
    Really ugly hole drilling, I didn't have many tools at that time:
    The power entry uses an IEC inlet block. Could have added a filter there:
  • kk99
    I saw used 1305X model around 176euro, but yes, the drawback is that it does not have 60V. Additionally, I am not sure if it behaves well in the case of power on/off on different loads. I also saw HP E3610A for around 100 euro, but is limited only to 0-8V 0-3A or 0-15V 0-2A and lacks programming etc. The only benefit is that it does not have a fan.
