Test & Tools
Test & Tools
Blog Programmable Electronic Load - Write a LabVIEW Library part 2: Read Output Block
  • Date Created: 3 Mar 2018 8:49 PM Date Created
  • Views 2199 views
  • Comments 5 comments
  • msp432
  • labview
  • scpi
  • electronic load
3 Mar 2018
Peter, Jon and I are building a Programmable Electronic Load. In this series of blogs I'm building a LabVIEW library of reusable components
In this second article: Reading the the instrument's measurements
LabVIEW has a set of blocks to build flows with serial communication devices. Those blocks work well with our instrument.
However, inspired by the example for (in this case) the BK Precision 91xx family, I'm going to create more abstract blocks.
Read Output Block
This blog reads the values sampled by the instrument. I've used the same options as the BK Precision lib:
0: VOLT
1: CURR
2: POW
3: DVM
4: RES
The bold ones are implemented by the firmware. The others are for future use (and to stay as true as possible to the lib that inspired this) will throw a SCPI error.
For the Initialize block, the input parameters are
  • VISA resource name eload
  • delay before read (ms)
  • Measurement Function
  • error in (no error)
The output parameters are
  • VISA resource name out
  • Measurement
  • error out
After running this block, the following functionality is performed:
  • The measurement option that's passed to it is performed
0: VOLT
1: CURR
2: POW
3: DVM
4: RES
  • If an error is detected, the VISA resource is closed and error info is passed to the caller.
    Else the block passes the measured value to the calling flow via the Measurement parameter.
Reading the Output
The block is simple to use. It expects that you've initialised the instrument with the Initialize block.
Depending on the value you pass (in this example 1: current), it will return the last value sampled by the instrument.
LABView blocks
LabVIEW Library part 1: Initialise Block
LabVIEW Library part 3: Close Block
LabVIEW Library part 4: Function Set Block
LabVIEW Library part 5: Input Control Block
LabVIEW Library part 6: Raw DAC Block
LabVIEW Library part 7: Raw ADC Block
Real World Examples
Programmable Electronic Load - Automating a DC Switcher Efficiency Test with LabVIEW
    DAB over 8 years ago +1
    Looks simple, but how much time did it take you to build and how long have you worked with labview to get that proficient? DAB
    genebren over 8 years ago +1
    Jan, Great write up. The LabView seems to have a pretty clean interface. I have seen quite a few groups using this to construct test beds, but I have never got around to trying it. Is it worth the cost…
    Jan Cumps over 8 years ago in reply to DAB +1
    This one didn't take that much time, DAB , because I had the core building block for the Load made previously. The part that allows to choose between current, voltage, power, ... I learned from the BK…
    Jan,
    Great write up. The LabView seems to have a pretty clean interface.  I have seen quite a few groups using this to construct test beds, but I have never got around to trying it.  Is it worth the cost/effort to learn it?  I have used LabWindows/CVI before an I was not a fan.  Hopefully LabView is better.
    Keep up the good work!
    Gene
    Jan Cumps over 8 years ago in reply to genebren
    genebren  wrote:
    .... The LabView seems to have a pretty clean interface.  I have seen quite a few groups using this to construct test beds, but I have never got around to trying it.  Is it worth the cost/effort to learn it?  I have used LabWindows/CVI before an I was not a fan.  Hopefully LabView is better.
    I paid $ 43 for the home and student edition 2014 (from Digilent. I used a $7.5 coupon that Digilent published when they were on The Amphour).
    For me it's worth the effort because I want to know how to develop with it. It's a desired skill on the market.
    I don't know LabWindows/CVI so I can't compare.
    genebren over 8 years ago in reply to Jan Cumps
    Jan,
    It is good to have skills, especially marketable ones.
    Gene
