Test & Tools
Test & Tools
Blog Programmable Electronic Load - Write a LabVIEW Library part 4: Function Set Block
  • Date Created: 11 Mar 2018 3:49 PM Date Created
  • Views 1756 views
  • msp432
  • labview
  • scpi
  • electronic load
11 Mar 2018
Peter, Jon and I are building a Programmable Electronic Load. In this series of blogs I'm building a LabVIEW library of reusable components
In this fourth article: Set the constant mode function to Current, Voltage, Power or Resistance
LabVIEW has a set of blocks to build flows with serial communication devices. Those blocks work well with our instrument.
However, inspired by what many instruments do, I'm creating more abstract blocks.
Function Set Block
This blog is also easy. It configures the instrument to constant current, voltage, resistance or power mode..
For the Function block, the input parameters are
  • VISA resource name eload
  • Instrument Function
  • error in (no error)
The output parameters are
  • VISA resource name out
  • error out
After running this block, the following functionality is performed:
  • The Instrument is set to one of the following constant regulation modes
    0: CURR
    1: VOLT
    2: POW
    3:RES
  • If an error is detected, the VISA resource is closed and error info is passed to the caller.
    Else the block passes the measured value to the calling flow via the Measurement parameter.
Setting the Function
Depending on the value you pass (in this example 0: current), it will set the instrument to the desired regulation mode.
The instrument doesn't support these functions yet. It'll always switch to constant current when you use a function it doesn't understand.
If you like this to be different, check out the source of the firmware in github and improve it.
https://github.com/jancumps/msp432/blob/master/MSP432_SCPI_ElectronicLoad/scpi_impl/scpi-def.c Look for static scpi_result_t ELOAD_SetInputState(scpi_t * context)
LABView blocks
LabVIEW Library part 1: Initialise Block
LabVIEW Library part 2: Read Output Block
LabVIEW Library part 3: Close Block
LabVIEW Library part 5: Input Control Block
LabVIEW Library part 6: Raw DAC Block
LabVIEW Library part 7: Raw ADC Block
Real World Examples
Programmable Electronic Load - Automating a DC Switcher Efficiency Test with LabVIEW
    genebren over 8 years ago +2
    Another great addition to your programmable load series of articles! Thanks for sharing your project. Gene
    Gene
    Gene
