Test & Tools
Test & Tools
Blog Do you want to create your own Pico SCPI device, based on PST.. Pico SCPI USBTMC labLib (and labTool)?
  • Date Created: 10 Nov 2023 1:07 PM Date Created
  • Views 1443 views
  • Likes 11 likes
  • pico_usbtmc_scpi
  • pico
  • USBTMC
  • Pico SCPI labTool
  • labview
  • scpi
10 Nov 2023
How to: start your own Pico SCPI project, based on Pico SCPI USBTMC labLib?
You can start from the example source:  PST.. Have you worked with the Pico SCPI labTool? and adapt it to your needs. Git and GitHub will help you to get a project set up in minutes.
1: use GitHub Web to start from my template (easiest)
I enabled the template option for this repository on GitHub. This allows you to directly start a fresh repository from the current code base with a few clicks.
Done.
2: If you prefer the command line approach:
image: a new repository, primed and ready to start a project for  Data Acquisition Board for Pi Pico
1. on GitHub, create a new (empty) repository (say: pico_scpi_usbtms_relayboard)
2. On your computer, get the latest version of PST:
git clone https://github.com/jancumps/pico_scpi_usbtmc_labtool.git --recurse-submodules
3. On your computer, push the PST code base to your new GitHub repo:
cd pico_scpi_usbtmc_labtool
git push https://github.com/<yourname>/pico_scpi_usbtms_relayboard.git +main:main
You can get the clone url of your new project from GitHub:
optionally, you can now delete the cloned repository on your computer. It was only needed to prime your new github repository.
4. On your computer, you can now clone that new repository:
git clone https://github.com/<yourname>/pico_scpi_usbtms_relayboard.git --recurse-submodules
5. On your computer, set an environment variable PICO_SDK_PATH=<path to where you installed the pico sdk>.
You can do this on OS level. And most IDEs allow you to define environment variables (CLion: in the Project wizard. VSCode: in the CMake extension config).
You will get a ready-to-go project, with the same code as the Pico SCPI labTool. Ready to build your own firmware.
Enjoy.
link to all posts
    Jan Cumps over 3 years ago
    I enabled the Template option for the repo on GitHub.
    This gives you  a one-click new repository with the latest version of the application and dependencies Heart
    You can directly clone that and start designing.
    shabaz over 3 years ago
    It's brilliant that this submodule method is available! An excellent way of adding the SCPI functionality to any project that needs it.
