Test & Tools
Test & Tools
Blog PST.. Release 4 for the Pico SCPI labTool firmware (experimental functionality release): what's new?
  • Date Created: 30 Sep 2023 10:00 AM Date Created
  • Views 2024 views
  • Likes 11 likes
  • Comments 7 comments
  • pico_usbtmc_scpi
  • pico
  • USBTMC
  • Pico SCPI labTool
  • labview
  • scpi
30 Sep 2023
The Pico SCPI labTool (PST) allows you to connect your PC to equipment to control and monitor all sorts of things. It runs on a Raspberry Pico.
In this post: new functionality available in the Release 4.
What's new?
This release adds experimental functionality.
Release 4 adds these new SCPI functions:
digital input in: registers instrument specific registers for digital input pins
STATus:OPERation:DIGItal:INPut:CONDition?
STATus:OPERation:DIGItal:INPut:PTRansition
STATus:OPERation:DIGItal:INPut:PTRansition?
STATus:OPERation:DIGItal:INPut:NTRansition
STATus:OPERation:DIGItal:INPut:NTRansition?
STATus:OPERation:DIGItal:INPut:EVENt?
STATus:OPERation:DIGItal:INPut:ENABle
STATus:OPERation:DIGItal:INPut:ENABle?
Other functionality added:
refactoring closer integration of usbtmc and scpi parser library
More info on the experimental functionality:
 PST.. Experimental event / trigger support for Pico SCPI labTool - 1: investigate
PST.. Experimental event / trigger support for Pico SCPI labTool - 2: design the registers
PST.. Experimental event / trigger support for Pico SCPI labTool - 3: Instrument Specific Registers Test
PST.. Experimental event / trigger support for Pico SCPI labTool - 4: let TinyUSB USBTMC code use SCPI-LIB's Status Byte register
PST.. Experimental event / trigger support for Pico SCPI labTool - 5: Propagation to IEEE488.2 SCPI Registers Test
How to get the software (binary included)
check this post for a "how to install firmware and run the first LabVIEW process" video.
download link info
Pico firmware backwards compatible with previous versions. includes the .uf2 file to program your Pico right away
LabVIEW driver backwards compatible with previous versions. driver blocks for new functionality and extra examples
Command reference
This section describes the added commands. It lists
  • the SCPI syntax,
  • LabVIEW Virtual Instrument driver block
  • the pins that are used,
  • parameters, return values.
digital input registers query the registers of a digital input, set filter and fan-out to IEEE488.2 Operation Status register
bits:
0: GP20
1: GP21
2: GP27
registers:
CONDition
PTRansition
NTRansition
EVENt
ENABle
fan-out to IEEE488.2:
Operation Status[0]
SCPI STATus:OPERation:DIGItal:INPut:CONDition?
VI Use LabVIEW VISA write and read
For the compete reference:  PST.. Program the Pico SCPI labTool?
LabVIEW
This version doesn't include LabVIEW changes. I cut a driver release, to keep the versions in sync.
link to all posts
    Jan Cumps over 3 years ago in reply to ggabe +1
    > Is raising SRQ expected, or yet to be coming? To do. I could not get it to work. The code knows when to fire the SRQ, but I don't know (yet?) what to do in usbtmc to send correct data back > Also…
    dougw over 3 years ago
    Nice.
    Do you run it like your work? Sprints and release schedules? Do you have scrums with shabaz  Relaxed
    Jan Cumps over 3 years ago in reply to dougw
    hehe. We use a backlog
    We don't scrum,
    We have milestones that represent release trains / schedules
    and we do peer code reviews. Here's an example of shabaz reviewing my code:
    (all actions below Shabaz review are performed by github automation)
    We don't scrum,
