Test & Tools
Test & Tools
Blog Sound and Vibration Measurement: First Demo of the test jig
  • Date Created: 26 Apr 2022 7:07 PM Date Created
  • Views 4620 views
  • Likes 8 likes
  • Comments 14 comments
  • RoadTest
  • raspberry
  • mcc172
  • labview
26 Apr 2022
For the Sound and Vibration Measurement Hat for Raspberry Pi road test, I'm reviewing Measurement Computing's IEPE Measurement DAQ HAT for Raspberry Pi.
Time to demonstrate the first setup of the Automated Vibration Test Jig.
In this video, the flow lets the vibration table shake from 20 to 40 Hz, with 2 Hz increment.
At each step, the MCC172 takes 32.768 samples, then calculates the RMS value of that result.
This gets written to a data file.
The video is real time. You will not hear the lowest frequency because my microphone (and your speaker) don't capture that. You can see the sample speed of the DAQ by looking at the LED blink time.
Excel output attached:
daqhatmcc172_0.xlsx
Link to all posts.
    Jan Cumps over 4 years ago in reply to Jan Cumps
    ... and with a few harmonics in view:
    With 512 samples / sec, 2048 samples taken
    Jan Cumps over 4 years ago in reply to michaelkellett
    FFT is working now:
    90 Hz sent to the vibration table. Top is a realtime waveform, bottom is a non-real-time FFT over 10k samples, 50k sample rate.
    going by using my hands to feel the resonance, I'd say the cabinet resonates around 50 Hz, 100 for the plate we mounted on top of it with the sensor attached to it.
  • michaelkellett
    michaelkellett over 4 years ago in reply to Jan Cumps
    That's showing the distortion at very roughly 3% (on the good curve).
    Not bad for an open loop system  - do you know the mechanical resonant frequency of the set up ?
    MK
