Test & Tools
Test & Tools
Blog Voltage References - The Modular Bench Power Supply ++
  • Author Author: Robert Peter Oakes
  • Date Created: 29 Sep 2014 1:55 AM Date Created
  • Views 5386 views
  • Comments 14 comments
  • bench
  • vref
  • ref02
  • reference
  • voltage
  • zener_diode;
  • supply
  • power
Robert Peter Oakes
Robert Peter Oakes
29 Sep 2014
To Main Blog: The Modular Bench Power Supply ++, The Essential DIY Build for Every EE Student and Old Timer alike...
Every good power supply depends on a good voltage reference, it provides the anchor to keep everything stable and performing well and accurately
Without a good voltage reference, your supply will drift over time, with temperature changes and if the supply voltage changes even a little, not to mention noise that can be introduced by outside sources
What I will show you over the following two videos is a bit of theory and a practical demonstration of how the above things can interfere with the workings of the reference and therefor the rest of the power supply
I will exaggerate the problems by using a hot air soldering gun, an Arbitrary Waveform Generator and significantly changing the source voltage for the reference circuit
I will only show 3 variations which should represent the most popular techniques
A Zener Diode 3V _+ 5%
A Zener Diode with a JFET constant current source and an offset silicon diode to assist with temperature stabilization
A Silicon Chip reference device (REF02 in this case from TI but this is one of dozens of choices available) that outputs a stable 5.000 Volts
First up the theory:
Now time to turn up the heat... Literally image
These are the circuits I used in the above videos, the video used a bread board, the circuits are assuming a plug in module but the circuit is the same either way
Conclusion
USE A REF02 OR SIMILAR DEVICE, ITS NOT WORTH THE HASTLE OF THE ALTERNATIVES
If you disagree, lets hear it, this is just my opinion and I would love to hear yours
BOM
REF02 http://canada.newark.com/analog-devices/ref02hsz/ic-series-v-ref-5v-25mv-8-soic/dp/59K9016  $3.53
Zener BZX79-C3V0 NXP Diodes - Zener Single | 96K7357 | Newark element14 Canada  +  $0.177
Resistor  $0.10
Diode      $0.216
So yes the REF02 is significantly more expensive but were still talking under 4$ for the part and watch the video to see the rest
In the next video we will look at OP AMPS and how we can use them to help control our circuits
    jw0752 over 12 years ago in reply to mcb1 +2
    If there are communication problems on the site they usually aren't because of the spellings. The main concern is: Does one understand what is being said? Peter does and excellent job of conveying his…
  • Robert Peter Oakes
    Robert Peter Oakes over 12 years ago +1
    Thanks for all the support so far, next up, OP Amps and I welcome the "Negative Feedback"... "Did you see what I did there... negative Feedback.. Op Amps . No , ah well, you will
    Thanks Guys - It seems that I looked at the Data sheet before I went searching for a source and price and inadvertently added the "Z" to the part number. These links look much better.
    Robert Peter Oakes over 12 years ago in reply to jw0752
    http://www.newark.com/webapp/wcs/stores/servlet/Search?catalogId=15003&langId=-1&storeId=10194&categoryId=800000004703&st=Voltage%20Reference&mf=100066&pageSize=25&showResults=true&pf=810033312,810100841
    These are about $3.24USD from Newark USA and 8ppm temp co which is more than enough but only 33V max supply
    if you include linear tech and filter voltage references to 40V supply there is a nice one for 7$ with a 3ppm http://www.newark.com/linear-technology/lt1021ccn8-5-pbf/ic-series-shunt-v-ref-5v-2-5mv/dp/57M0980
    Regards
    Peter
  • michaelkellett
    michaelkellett over 12 years ago in reply to jw0752
    When you search for REF02Z on Digikey they offer you one part in a ceramic package - that's why it's a silly price.
    I'm guessing that you don't need thast package or even that spec for drift.
    Look on Digikey (or elsewhere) for REF02 and then pick one in a package you like and perhaps with 65ppm/C drift and it can be less than $3 for one.
    (65ppm/C drift over 25C is only 0.16% so I think that'll be good enough for a start.)
    MK
    Hi Peter,  I was looking into getting one of the REF02Z voltage reference chips you mentioned but, at least here in the States, they are not common or cheap. DigiKey has some for $22.50 each and Newark lists them for $20.50 but doesn't have any in stock. Why would there be such a difference between Canada and the US on price? As you mentioned I am sure there are many substitutes.
    Thanks for all the support so far, next up, OP Amps and I welcome the "Negative Feedback"... "Did you see what I did there... negative Feedback.. Op Amps image. No , ah well, you will
