Test & Tools
Test & Tools
Blog Voltage References - The Modular Bench Power Supply ++
  • Author Author: Robert Peter Oakes
  • Date Created: 29 Sep 2014 1:55 AM Date Created
  • Views 5387 views
  • Comments 14 comments
  • bench
  • vref
  • ref02
  • reference
  • voltage
  • zener_diode;
  • supply
  • power
Robert Peter Oakes
Robert Peter Oakes
29 Sep 2014
To Main Blog: The Modular Bench Power Supply ++, The Essential DIY Build for Every EE Student and Old Timer alike...
Every good power supply depends on a good voltage reference, it provides the anchor to keep everything stable and performing well and accurately
Without a good voltage reference, your supply will drift over time, with temperature changes and if the supply voltage changes even a little, not to mention noise that can be introduced by outside sources
What I will show you over the following two videos is a bit of theory and a practical demonstration of how the above things can interfere with the workings of the reference and therefor the rest of the power supply
I will exaggerate the problems by using a hot air soldering gun, an Arbitrary Waveform Generator and significantly changing the source voltage for the reference circuit
I will only show 3 variations which should represent the most popular techniques
A Zener Diode 3V _+ 5%
A Zener Diode with a JFET constant current source and an offset silicon diode to assist with temperature stabilization
A Silicon Chip reference device (REF02 in this case from TI but this is one of dozens of choices available) that outputs a stable 5.000 Volts
First up the theory:
Now time to turn up the heat... Literally image
These are the circuits I used in the above videos, the video used a bread board, the circuits are assuming a plug in module but the circuit is the same either way
Conclusion
USE A REF02 OR SIMILAR DEVICE, ITS NOT WORTH THE HASTLE OF THE ALTERNATIVES
If you disagree, lets hear it, this is just my opinion and I would love to hear yours
BOM
REF02 http://canada.newark.com/analog-devices/ref02hsz/ic-series-v-ref-5v-25mv-8-soic/dp/59K9016  $3.53
Zener BZX79-C3V0 NXP Diodes - Zener Single | 96K7357 | Newark element14 Canada  +  $0.177
Resistor  $0.10
Diode      $0.216
So yes the REF02 is significantly more expensive but were still talking under 4$ for the part and watch the video to see the rest
In the next video we will look at OP AMPS and how we can use them to help control our circuits
    jw0752 over 12 years ago in reply to mcb1 +2
    If there are communication problems on the site they usually aren't because of the spellings. The main concern is: Does one understand what is being said? Peter does and excellent job of conveying his…
  • Robert Peter Oakes
    Robert Peter Oakes over 12 years ago +1
    Thanks for all the support so far, next up, OP Amps and I welcome the "Negative Feedback"... "Did you see what I did there... negative Feedback.. Op Amps . No , ah well, you will
    DAB over 12 years ago
    Good Job Peter.
    You did a good job describing the circuits and the contributions of the components.
    I did not know that you had so many multimeters, but if I count my old analog ones, I can probably beat you. image
    shabaz over 12 years ago
    Hi Peter,
    Glad the project has started!
    As an idea, perhaps the vids could be chopped up into 6-minute versions with descriptions, so people can immediately jump to the relevant one, (or alternatively have a 6-minute "highlights" version too).
    Regarding the voltage references, I too agree with you, and would avoid zener diodes. You might also want to check out the TL431, cheap yet high performance - initial trimming is 0.5% (so that may rule it out depending on needs) but on most other points it should fare well. Still there is such a choice that everyone may select differently!
    By the way, forward to the next instalment - I have a main PSU, but my current home-built dual supply is pretty basic - based around dual LM317. So I'm keen to get building : )
  • michaelkellett
    michaelkellett over 12 years ago
    It's such a shame you've done this as video - I'm sure you've put a lot of effort into it but I can't possibly afford 90 minutes to look at it. I also suspect that it's much harder for those where English is not their native language.
    It also means that it's not cut and paste-able or searchable.
    BTW, a typo has crept in to the preamble and there are several references to silicone when you mean silicon.
    MK
    Thank you Peter, As usual an excellent easy to understand presentation.
