Test & Tools
Test & Tools
Forum Hot Air Station suggestions?
  • Replies 20 replies
  • Answers 12 answers
  • Subscribers 389 subscribers
  • Views 5160 views
  • hot_air_stations
ajens23
ajens23 over 10 years ago
Hi All,
I find myself wanting to do more surface mount work.
While a toaster oven works pretty good for the whole board, I would like to try a hot air station.
After looking at a Weller station at over $700 US, then looking at $50 stations on E-bay,
I would like to hear from some actual users and their experiences and recommendations.
So what is a reasonable brand of hot air station that will last for several years and not break the bank.
(I.e. under $200US would be nice.)
Al
    jw0752 over 10 years ago +3
    Hi Al, I have the same unit 21-10125 - TENMA - HOT AIR REWORK STATION, 280W, 100V | Newark element14 that michaelwylie has. When I got it I modified it to include a shut off in the cradle. I was pretty…
    mcb1 over 8 years ago +3 suggested
    I have the same unit as kas.lewis referred to Tenma 21-10130 21-10130 it has the cutoff feature when you place the handpiece down, and the picture doesn't show it, but includes a temperature controlled…
    dougw over 8 years ago +3
    I use an Aoyue because it was low cost, but it works fine for my needs. I use it for rework (chip removal) and small heat shrink tubing.
    0 jw0752 over 8 years ago in reply to jbundock
    Hi James,
    My unit runs on 120 volts just fine. Once I closed the case and stopped looking at the solder job it has continued to work well and properly. I have had it for about three years now and I have had no problems. Yours will probably have a better solder job than mined did as I can't believe things could have gotten worse.
  • jbundock
    0 jbundock over 8 years ago in reply to jw0752
    Thanks John,
    I was weirded out by the "100V" spec on the Newark site.  As long as it has a USA plug like yours I'm all set.  I'm hopeful the workmanship has improved, but I'll take a peek.  I tried looking everywhere to verify that the thing I ordered had a US plug, but to my chagrin, I discovered the manufacturer uses the same part number for the 220V unit so I thought wow, will this one be Japanese (100VAC)?  I wish they'd show a picture of the back or have a spec sheet that is actually a spec sheet, or put the manual online (the Temna website is useless).  Oh well, I feel a little better now that it I know it is almost certainly going to have a US power plug. Thanks again.
    0 dougw over 8 years ago
  • COMPACT
    0 COMPACT over 8 years ago
    One of the most time consuming parts about SMT is component placement.
    This is how to do it easily yourself.
    There. A thousand times easier!
    0 mcb1 over 8 years ago in reply to COMPACT
    Quite neat.
    This seem to use the same extrusion as the newer Shapeono.
    0 michaelkellett over 8 years ago in reply to jw0752
    I've always fancied these things:
    PCB Pre-heaters. Preheat for SMT, SMD, BGA. Lead-Free Solder Preheaters. Rework Pre-heat.
    Not very cheap (but competitive with Weller and the like) but they look as if they're pretty focused on what they do.
    0 Jan Cumps over 8 years ago in reply to mcb1
    I'm using that Tenma pre-heater too (thank you Shabaz) when using hot air. I put on paste and place components with the board on the switched-off heater. When all is placed I turn it to 120 degrees for a few minutes, then start reflowing with hot air.
    0 mcb1 over 8 years ago in reply to Jan Cumps
    The rework machine at work is Infrared based.
    It can even do pick and place, but the price tag is a little beyond any hobbyist.
    It surprises me that we aren't seeing more Infrared preheaters, like this has.
    It seems to me that this is a few rows of elements, that you turn on or off depending on the size and amount of heat required.
    Maybe someone need to build one of these types of preheater.
  • COMPACT
    0 COMPACT over 8 years ago in reply to mcb1
    It's nice to know that some of you have heeded my advice and use preheaters.
    Don't forget about the flux or flux paste!
    Merry Xmas!!
  • rachaelp
    0 rachaelp over 8 years ago in reply to Jan Cumps
    I have a 24V heated bed PCB I designed for a 3D printer attached to a spare metal shelf from my Rayburn oven. I use my meaty 420W power supply with a 4-wire connection to ensure the heater gets the full 24V. I paste up the board and place the components along with a thermocouple an put this on top of the plate then switch on and cover with an insulated cover to increase the heating speed. Once it’s been soaked at 110-120C for a few minutes, off comes the cover and out comes either the hot air pencil or my main iron. This technique helps a lot with regular soldering too if you have lots of planes in a board and components without thermal relief connecting to them. You do have to be careful not to frazzle yourself on anything though!
    Best Regards,
    Rachael
