Test & Tools
Test & Tools
Forum goal for 2023: use a conical solder tip and enjoy it
  • Replies 63 replies
  • Subscribers 382 subscribers
  • Views 28866 views
Jan Cumps
Jan Cumps over 3 years ago
You have to challenge your habits. I have always soldered with chisel and sloped/bevel round tips.
Many irons come with a conical tip. A lot of people solder happily with it.
I have several, to use with an iron that I like. But I don't like soldering with the conical tips. I am not good at it.
That's going to change this year. I'm going to try and always use these tips when appropriate, and learn to love them.
The real goal is to become better at soldering with the conical versions than I am now with chisel and sloped types. And to enjoy the adaption path.
I'll keep you posted.
    shabaz over 3 years ago in reply to ntewinkel +5
    Hehe at least you got a choice : ) I didn't know of any other styles growing up, other than bevel. All the instructions taught everyone to use this style of tip: This is from the children's Ladybird…
    shabaz over 3 years ago +4
    Maybe they are good on QFN. They look like they could be usable to drag the tip right into the corner when manually soldering QFN. I'm the same, no good with conical. Although the very finest/pointiest…
  • Gough Lui
    Gough Lui over 3 years ago +4
    I've used my conical so much that it's "turned" into a chisel :). My technique hasn't changed much really ... but I do prefer conical for the potential for fine-pitch touch-ups. Not as nice for transferring…
    shabaz over 3 years ago in reply to beacon_dave
    We could rephase to "more properly " I guess : ) There are some things that seem to be common to all the standards, but some people take shortcuts like combing all the leads down like hair first, for all the components, and then soldering and then cropping. I think I saw it in an Adafruit or Sparkfun video. It might save half an hour on a project at most I guess.
    Jan Cumps over 3 years ago in reply to beacon_dave
    See you in an hour (of powerpoint. no soldering action)
    shabaz over 3 years ago in reply to Jan Cumps
    Slight smile
    Jan Cumps over 3 years ago in reply to hlipka
    Well, I claim that he bent the lead more than 30°:
  • beacon_dave
    beacon_dave over 3 years ago in reply to Jan Cumps
    Enjoy... but haven't you skipped over NASA-STD-8739.x to IPC J-STD-001E ?
    no cheating now...  Slight smile
  • ntewinkel
    ntewinkel over 3 years ago in reply to Jan Cumps
    Jan Cumps said:
    the cut end of a lead is exactly the same material as all the rest of the lead. And that's exposed too.
     hlipka ’s video starts by saying the leads have to be tinned too. I’m curious why exposed solder is ok, but exposed leads are not ok Shrug
    I won’t be soldering avionics boards anytime soon  Grin !!
    dougw over 3 years ago in reply to beacon_dave
    That is true. I run across NASA standards periodically and they provide some interesting insights, but are often different form other standards on the same topic. That said, I violate virtually every standard when I solder, and I'll even cut my own corners when some other requirement has higher priority. Like trimming the lead way too close to the card because there isn't enough room for a good solder joint. I do at least try to make the joint work for its intended application, and so far it is working out.
  • ntewinkel
    ntewinkel over 3 years ago in reply to beacon_dave
    beacon_dave said:
    'Properly' kind of depends on which standards you are working to though.
    That’s how I feel about it too. I imagine NASA would be the highest standard given the conditions the electronics for avionics and space flight would be used in: extreme vibration, temperature, and pressures. Maybe exposure to chemicals and gases too.
    Adafruit is geared towards hobby projects, so I imagine they’d rather not scare off the newbies with that level of precision! Similar for any beginner type classes.
    My standards will be slightly below that hobby level Rolling eyes
    I do want to start making them more visually appealing though, which includes cleaning of the flux and having more consistent solder joints.
    dougw over 3 years ago in reply to ntewinkel
    Leaving flux uncleaned - guilty as charged. Disappointed
    Maybe we should start a discussion  topic - How not to solder...Smiling imp
