Test & Tools
Test & Tools
Forum goal for 2023: use a conical solder tip and enjoy it
  • Replies 63 replies
  • Subscribers 382 subscribers
  • Views 28853 views
Jan Cumps
Jan Cumps over 3 years ago
You have to challenge your habits. I have always soldered with chisel and sloped/bevel round tips.
Many irons come with a conical tip. A lot of people solder happily with it.
I have several, to use with an iron that I like. But I don't like soldering with the conical tips. I am not good at it.
That's going to change this year. I'm going to try and always use these tips when appropriate, and learn to love them.
The real goal is to become better at soldering with the conical versions than I am now with chisel and sloped types. And to enjoy the adaption path.
I'll keep you posted.
    shabaz over 3 years ago in reply to ntewinkel +5
    Hehe at least you got a choice : ) I didn't know of any other styles growing up, other than bevel. All the instructions taught everyone to use this style of tip: This is from the children's Ladybird…
    shabaz over 3 years ago +4
    Maybe they are good on QFN. They look like they could be usable to drag the tip right into the corner when manually soldering QFN. I'm the same, no good with conical. Although the very finest/pointiest…
  • Gough Lui
    Gough Lui over 3 years ago +4
    I've used my conical so much that it's "turned" into a chisel :). My technique hasn't changed much really ... but I do prefer conical for the potential for fine-pitch touch-ups. Not as nice for transferring…
    Jan Cumps over 3 years ago in reply to shabaz
    I have an opinion®:
    the cut end of a lead is exactly the same material as all the rest of the lead. And that's exposed too.
  • beacon_dave
    beacon_dave over 3 years ago in reply to shabaz
    Yes, I was referring to the base metal sealing there.
    Strange that they let that one through though given some of the other stuff.
    I think this is the one you are after about cutting stress
    shabaz over 3 years ago in reply to beacon_dave
    I've not read the NASA standards, but it would be surprising if they allow component leads to be snipped on a PCB after the component is soldered. (merely from what I observed in mil-product hand assembly).  I know nothing about metallurgy/chemistry, so I'm speculating it is shock and corrosion related. But the conformal coating comment does seem to align with the corrosion theory (at the junction of the exposed copper/plating/solder perhaps, but I have no idea).
  • hlipka
    hlipka over 3 years ago in reply to shabaz
    Here is what is done in avionics: https://www.youtube.com/watch?v=Vynb_HdEIDU . Whatever you do currently, it will not be good enough for these standards. (and yes, the cut before soldering)
    shabaz over 3 years ago in reply to Jan Cumps
    You could be right, but instinctively if I see exposed copper on the end of a component, I tend to solder over it. Just habit.
  • beacon_dave
    'Properly' kind of depends on which standards you are working to though.
    Also it doesn't help that some of those standards are expensive to get hold of and certification even more expensive...
    Jan Cumps over 3 years ago in reply to hlipka
    I saw this video series today too :). When Chris asked me to point to the Nasa videos I saw, I tried to find them back, but couldn't (maybe copyright issues?). But I found these and enjoyed watching them. There's one that takes 6 minutes to solder 1 wire into 1 connector pin <3.
    Edit:
    this one: https://youtu.be/yzkuWORme2w
    and you have to watch this one first :) : https://youtu.be/BiVkI4IooH4
    shabaz over 3 years ago in reply to hlipka
    That's a nice trick, not seen that before:
  • hlipka
    hlipka over 3 years ago in reply to Jan Cumps
    The video I had linked to takes about 12 minutes for one resistor. The amount of cleaning they do is kind of excessive, but the I think in avionics (or anything else where lives depend on it) you just do not take chances. This also explains why such devices are quite expensive - they just live up to a different standard that what I do at home...
  • beacon_dave
    beacon_dave over 3 years ago in reply to Jan Cumps
    It might be out of date now though...
    "NASA has adopted IPC J-STD-001FS for all Programs and Projects, effective on October 17, 2011.  The NASA standards for soldering, NASA-STD-8739.2 and NASA-STD-8739.3, are cancelled as of October 17, 2011."
    https://nepp.nasa.gov/index.cfm/22093
