Test & Tools
Test & Tools
Forum Keithley DMM6500 Scanner Card - mystery component hidden in one of the channels
  • Replies 19 replies
  • Subscribers 382 subscribers
  • Views 5186 views
  • pt100
  • 88ad1490-a97d-11ed-afa1-0242ac120002
  • 2000-scan
  • keithley
  • scan-2000
Jan Cumps
Jan Cumps over 3 years ago
When I was wiring my Keithley 2000-SCAN card, I found a little component hidden inside the connector for channel 3. I hadn't spotted it before, just saw it during my work.
I initially thought it was a wire bridge used to measure the relay resistance. But it was a tiny component:
A little device on a ceramic chip.
I regret that I didn't take a photo first. Fortunately, I saw that it was visible on a photo I took for my first blog (and I hadn't deleted the original high resolution version yet):
I measured it, and it was around 100Ω. 108Ω actually. I thought that it could be a shunt for current measurement. But that's not very precise for a 100Ω resistor. When I touched it, I saw that the resistance increased fast. And that's when I realised it's a local temperature reference: Pt100 /RTD. The Pt100 is a common player in the measurement- and control (control theory) practice.
I found one on the e14 shop that looks very similar to the one embedded in my card: NB-PTCO-152  RTD SENSOR, THIN FILM PLATINUM, 100R. The photo on the Farnell page isn't the same, but the picture in TE's datasheet is very similar. The blackish look of the leads on my component seem to point that they are the silver version.
Mystery solved
link to all posts
    Jan Cumps over 3 years ago in reply to wolfgangfriedrich +3
    These are things you don't learn when you buy new things. Second hand comes with a story.
    Jan Cumps over 3 years ago in reply to scottiebabe +3
    Side story: I made an app for the meter. To calculate a microcontroller's power envelope, and using the EEVBog µCurrent as test probe. It works.
  • scottiebabe
    scottiebabe over 3 years ago in reply to Jan Cumps +3
    What a time to be alive, installing apps on our color touchscreen multimeters , that's great work!
  • wolfgangfriedrich
    wolfgangfriedrich over 3 years ago
    The evidence tells the story. Nice.
  • Gough Lui
    Gough Lui over 3 years ago
    Looks like you got an extra $20 of goods ... I have always wanted to buy some nice Pt100s, but the class I wanted would have been a bit costly.
    - Gough
  • mp2100
    mp2100 over 3 years ago
    Jan
    We do use Pt 100 RTD all the time at my work in our industry. Good accuracy and  wide temperature range.
    Do you  know how this RTD used in the Keithley, wired into those terminals?
    Jan Cumps over 3 years ago in reply to mp2100
    I don't by know by who or how this card is used in the past. It comes off eBay Germany and its history is undocumented.
    My guess is that the channel 3, where the Pt was wired in, was sampled as part of a test setup's environmental attributes collection.
    Maybe a validation if the meter is in the temperature range where the needed precision is guaranteed?
    Or was it used in a similar way as the onboard reference junction in Keithley's 2001-TCSCAN card 10 channel temperature sample card?
    image image
    That one measures the cold junction temperature, at the spot where the other temp sensor wires are turned into copper wires. That should be measured as close to the connection point as possible. And inside the terminals, touching iron, is pretty close .
    Yesterday, I tried to put the device back inside the connectors. In channel 1, so that the default scripts for the DMM6500 would work.
    Unfortunately, even while I was careful, one of the leads of the Pt100 broke off. It was not a surprise - I was extra careful because I could feel that this was a weak point.
    Once I have saved some more equipment budget, I'll buy a new Pt100. Or if you have one that you can miss, send it to me.
    I'll post a comparison of temperature measurement, one with a simulated cold junction temp value, one with a Pt100 ...
  • scottiebabe
    Interesting. Go big! Measure your PT100 in 4W mode.
    Apparently there is a thermistor app for your DMM
    Fancy!
    yes :)
    It works.
  • scottiebabe
    What a time to be alive, installing apps on our color touchscreen multimeters Slight smile, that's great work!
