Test & Tools
Test & Tools
Forum Keithley DMM6500 Scanner Card - mystery component hidden in one of the channels
  • Replies 19 replies
  • Subscribers 382 subscribers
  • Views 5087 views
  • pt100
  • 88ad1490-a97d-11ed-afa1-0242ac120002
  • 2000-scan
  • keithley
  • scan-2000
Jan Cumps
Jan Cumps over 3 years ago
When I was wiring my Keithley 2000-SCAN card, I found a little component hidden inside the connector for channel 3. I hadn't spotted it before, just saw it during my work.
I initially thought it was a wire bridge used to measure the relay resistance. But it was a tiny component:
A little device on a ceramic chip.
I regret that I didn't take a photo first. Fortunately, I saw that it was visible on a photo I took for my first blog (and I hadn't deleted the original high resolution version yet):
I measured it, and it was around 100Ω. 108Ω actually. I thought that it could be a shunt for current measurement. But that's not very precise for a 100Ω resistor. When I touched it, I saw that the resistance increased fast. And that's when I realised it's a local temperature reference: Pt100 /RTD. The Pt100 is a common player in the measurement- and control (control theory) practice.
I found one on the e14 shop that looks very similar to the one embedded in my card: NB-PTCO-152  RTD SENSOR, THIN FILM PLATINUM, 100R. The photo on the Farnell page isn't the same, but the picture in TE's datasheet is very similar. The blackish look of the leads on my component seem to point that they are the silver version.
Mystery solved
link to all posts
    Jan Cumps over 3 years ago in reply to wolfgangfriedrich +3
    These are things you don't learn when you buy new things. Second hand comes with a story.
    Jan Cumps over 3 years ago in reply to scottiebabe +3
    Side story: I made an app for the meter. To calculate a microcontroller's power envelope, and using the EEVBog µCurrent as test probe. It works.
  • scottiebabe
    scottiebabe over 3 years ago in reply to Jan Cumps +3
    What a time to be alive, installing apps on our color touchscreen multimeters , that's great work!
    shabaz over 3 years ago in reply to Jan Cumps
    It's ridiculously easy to break the leads off them : ( I destroyed my only PT1000 that way too, barely flexed but its a weak point there. Does DMM6500 allow for thermistor params to be configured for cold junction compensation? Not as ideal but I've got at least a hundred of them here (mostly surface mount but easy to tack wires onto). I can easy shove a load of them into a envelope tomorrow.
  • scottiebabe
    scottiebabe over 3 years ago in reply to scottiebabe
    Yesh, prices are going up! The PT1000 elements I used here  MTT - Ambient Air Temperature Sensing
    Have gone up 120% since I bought them, though still affordable ($CAD)
    223-NB-PTCO-163-ND
    Jan Cumps over 3 years ago in reply to shabaz
    I ordered a little set of 5 "RTD PT100 Tiny thin film type Class A".
    That 'll be enough to at least try to get one of them inside the screw terminals of channel 1 and let it sit there forever.
    I'm going to put that on channel one, because that's the assumption on the DMM6500 / 2000-SCAN combo when using a cold junction reference.
    Yes. And one of those options is to enter that temperature by hand. The error you make (if you just guess it) will influene the measurement error.
    My order arrived:
    The leads are short. There will be some fiddling required.
    I placed a new Pt100 in channel 1:
    Here's a test, using the meter's front panel.
    Channel 2 shows the measurement of my lab room temp, with a K-type thermocouple.
    The thermocouple cold junction is compensated by the Pt100 mounted inside the connector.
    Channel 1 shows that temperature of the cold junction, as measured by the Pt100
    Need a tiny little micro-sized "Fragile" label sticker next to them : ) So easy to break off their wires! : )
  • BigG
    BigG over 3 years ago in reply to Jan Cumps
    Not sure if these would be suitable for your application. I've had these 3 samples sitting in a box for over 10 years and still to find a proper use for them.
    {gallery:autoplay=false}IST PT100
    Jan Cumps over 3 years ago in reply to BigG
    The ones I have work. I just placed one. It is finicky but doable.
