Test & Tools
Test & Tools
Forum New Rigol dho804 oscillocope
  • Replies 82 replies
  • Subscribers 379 subscribers
  • Views 13612 views
ahmedfotoh
ahmedfotoh over 1 year ago
imageI just bought a new Rigimage
ol Dho804 Oscilloscope, but there is a problem, I connect the attached power supply to the 220 v power source and turn it on but the display stays black and no boot to the operating system, What should I do?
    michaelkellett over 1 year ago in reply to geralds +3
    I'll try to get round to a mini road test of the DHO924 in a couple of weeks. MK
    dougw over 1 year ago +2
    Check the power supply - is it providing the right voltage to the main controller card?
  • cstanton
    cstanton over 1 year ago in reply to ahmedfotoh +2
    Was this the original power supply you received with the device? If not, have you looked at the manual/datasheet for the oscilloscope to see what voltage and amps it requires from the power supply?
  • PavelKCZ
    0 PavelKCZ over 1 year ago in reply to Andrew J
    The main question is, what is the power input on his scope. Is it USB-C or a circular bayonet connector ?
    Can the OP post a photo of the power input on his scope ?
  • Andrew J
    0 Andrew J over 1 year ago in reply to PavelKCZ
    It’s USB-C
  • ahmedfotoh
    0 ahmedfotoh over 1 year ago in reply to PavelKCZ
  • PavelKCZ
    0 PavelKCZ over 1 year ago in reply to ahmedfotoh
    OK, than you need an USB-C power supply.
    In this case, I do not understand the photo, which Jan Cumps posted couple of hours ago - https://www.eevblog.com/forum/testgear/rigols-new-dho800-oscilloscope-unbox-teardown/msg4965181/#msg4965181
    where at the adapter is clearly indicated as a the circular bayonet connector with + inside and - outside.
    But, I am almost sure, that the power source is not a problem. If the scope is able to display a Rigol logo for five minutes and do a restart after that a go to loop, it really looks like a firmware problem.
  • ahmedfotoh
    PavelKCZ  Can I do something to reset firmware before start up operation? To make sure it's not a charger problem.
  • Andrew J
    Yeh, that’s confusing: the referenced PSU has a circular connector according to the datasheet, but the text with that message implies it has USB-C and same poster’s picture of the back of his scope shows a USB-C socket.
  • PavelKCZ
    I would not recommend any reset or any similar operation.
    If the instrument is under the warranty, the only proper way is to contact the vendor and ask for exchange for working instrument or money back.
  • ahmedfotoh
    PavelKCZ You are right , the cost of purchase, shipping and taxes was exorbitant, about $500.
  • ahmedfotoh
    0 ahmedfotoh over 1 year ago in reply to Andrew J
    I ask for why this pin is exist although that the USb type C is the same for two directions
  • PavelKCZ
    Definitely.
    You can try to repair an used instrument which you bought on E-Bay for example.
    I did this myself, last time it was an Agilent 53132A frequency counter which I bought from China. The instrument comes, but after power up, the panel was dead. I opened it and I found that the flat cable between panel and main board was unconnected. I reconnect the cable and the instrument started without any problem. But it was a used instrument, without the warranty.
    In your case, you have a new instrument under warranty, so go and require the exchange or money back. 500 USD is not a small sum.
