Test & Tools
Test & Tools
Forum New Rigol dho804 oscillocope
  • Replies 82 replies
  • Subscribers 379 subscribers
  • Views 13611 views
ahmedfotoh
ahmedfotoh over 1 year ago
imageI just bought a new Rigimage
ol Dho804 Oscilloscope, but there is a problem, I connect the attached power supply to the 220 v power source and turn it on but the display stays black and no boot to the operating system, What should I do?
    michaelkellett over 1 year ago in reply to geralds +3
    I'll try to get round to a mini road test of the DHO924 in a couple of weeks. MK
    dougw over 1 year ago +2
    Check the power supply - is it providing the right voltage to the main controller card?
  • cstanton
    cstanton over 1 year ago in reply to ahmedfotoh +2
    Was this the original power supply you received with the device? If not, have you looked at the manual/datasheet for the oscilloscope to see what voltage and amps it requires from the power supply?
  • ahmedfotoh
    0 ahmedfotoh over 1 year ago in reply to Jan Cumps
    Yes, so do you think it's largely a charger voltage issue?
    0 Jan Cumps over 1 year ago in reply to ahmedfotoh
    I don't know. But if the power supply can deliver 75% of the required power, it's hard to validate if it is anything else...
  • Andrew J
    0 Andrew J over 1 year ago in reply to Jan Cumps
    It could be that Rigol re-designed the power requirements.  Certainly the newer version of the manual calls for 15V 3A.  I wouldn't plug anything in without checking with Rigol first what the specific instance based on serial number requires.
  • ahmedfotoh
    0 ahmedfotoh over 1 year ago in reply to Andrew J
    Ok, Thank you very much, I should contact Rigol service  to know if the power adapter came with scope is a correct or not.
    (Yes), and give them a photo of the error, and how long it takes from powering on to the error
    I mean: no, contact the vendor. Rigol will most likely ask you to do that anyway
  • anniel747
    0 anniel747 over 1 year ago in reply to Andrew J
    [deleted]
  • Andrew J
    0 Andrew J over 1 year ago in reply to anniel747
    Yes, I understand the difference here.  My point is that there seems to be a (perhaps older) version requiring a 12V 4a PD3 power supply and a newer version requiring a 15v 3A PD3 power supply.  The OP seems to have the latter supply but possibly a former instrument but it isn’t wholly clear: perhaps there is an unrelated fault (maybe using a 15v supply for a 12v instrument caused a problem), perhaps the PSU is wrong.  Is he reading the wrong version of the manual??  I wouldn’t be plugging any old supply into an instrument that is new and under warranty.
  • ahmedfotoh
    0 ahmedfotoh over 1 year ago in reply to anniel747
    anniel747  I have original  power adapter for Toshiba laptop 15V 5 A , Can I try to connect it to scope.
  • PavelKCZ
    0 PavelKCZ over 1 year ago in reply to ahmedfotoh
    Well, maybe you should take a multimeter and check the polarity of both power adapters at the output connector.
    Of course, the decent instrument should have a polarity protection at the input, but at modern times, nobody can be sure, because the cutting of costs. Slight smile
  • Andrew J
    0 Andrew J over 1 year ago in reply to ahmedfotoh
    No.  You already have a 15v 3A supply but something isn’t working properly.  You may need a 12v 4a supply but it must be a USB-C PD3 supply as the scope will tell the power supply what it needs.  Don’t just plug any old supply into it: go back to your seller and tell them it doesn’t work
