Test & Tools
Test & Tools
Forum How to take Good Pictures of Electronics
  • Replies 26 replies
  • Subscribers 387 subscribers
  • Views 7980 views
  • photo_techniques
  • photos
  • picture
jw0752
jw0752 over 10 years ago
Recently I posted a couple of pictures that fell short of being the quality that I was looking for. mcb1 was kind enough to send me some excellent tips on camera settings. I thought it might be helpful to everyone if we all share some of the tips and techniques that we use to get good quality pictures of our projects and builds. This will hopefully get the conversation going and we can add to it as ideas and techniques begin to flow back and forth.
Here is my first Tip:
When I try to take a picture of a circuit board that is layed out flat on my bench I have difficulty with shadows frm my body and camera. I also experience difficulty eliminating flare on the circuit board from the over head lights. By propping the circuit board at an angle to the lighting it is much easier to avoid the shadows and the flare. In these pictures I am using a hockey puck to prop the board up.
These pictures were shot at f3.5  1/30th of a second exposure.
    balearicdynamics over 10 years ago +3
    Hi John! Good idea to open this discussion. Really. To avoid shades and get the best field depth also a lens ring light (neon or cold LED ring) is a good choice to reach a good illumination, reduce the…
  • D_Hersey
    D_Hersey over 10 years ago +2
    Sometimes there is a lot of high-albedo stuff on a circuit board You might experiment with a polarizing filter, linear or circular
  • D_Hersey
    I use a copy-stand. I illuminate with white LEDs and UV LEDs, but I could use tungsten.
  • D_Hersey
    D_Hersey over 10 years ago in reply to jw0752
    Alternatively, close-up rings:
    mcb1 over 10 years ago
    John and others.
    There is no magic bullet for bright spots due to lighting.
    A polarising filter might help only if the light is single direction to start with.
    When I worked at the Photography studio the copy setup used two light sources at 45 deg with polarising filters and a filter on the lens to eliminate the reflections, which is a little bit OTT for home use.
    Subject placement
    For most of my images I use natural light coming in from a window behind and mostly above the subject.
    The window is on the south side (light is from the north in our end of the world) and it is often later in the day, so it is much less intense and is not direct.
    I place a white card or white surface to bounce light back onto the subject.
    One of my reflectors is a A4 paper that has been laminated and it works well since it can be bent.
    This lighting works better than the studio lights as there are no bright spots and you can easily see the results.
    You can easily check the light by clenching your fist and pointing your knuckles at the light source. The shadow on your palm will give an indication of where the light is coming from and how bad the shadow will be.
    Colour
    The light colour (Flash, Tungsten, LED, Florescent v natural) can be corrected in the camera and often the colour needs tweaking slightly to enhance the image, so you can use whatever you have as long as you understand the correction required.
    My Metz flashes tend to be blue, and both the internal flash and studio flash are white, so know your equipment and the effects is more important than using xyz.
    Depth of Field
    I shoot at the lowest aperture (highest F stop) the lens has which usually dictates a shutter speed of 1-2secs.
    Rather than the close-up rings I use an extension tube between the lens and body, which gives the magnification while keeping the lens away from the subject.
    There is software that will allow stacking of images to improve the dof, but you need to take multiple images at different focus points.
    At these speeds and dof it is important to use a cable/remote shutter release. If you can't then use the self timer and cover the eyepiece to prevent stray light from entering and fogging the photo.
    RAW v JPG
    All my photography is done in raw format which means a 24mB raw image.
    Raw format allows some manipulation before it gets converted to a jpg, but the most important part of the manipulation is to sharpen the image which brings the three individual sensors into line.
    Many of the cameras do a reasonable job of taking what they see and converting it, but it is a compromise and once it is a jpg anything you do is subtracting from the image.
    Because of the small size of 35mm format, images need to fill the frame (something you don't need to worry about with a 6x6 camera) so get as close as you can.
    Post manipulation
    There are lots of things that can be done after the image is taken.
    I've removed scratches or annoying bits, however if the detail is not there, you can't easily recreate it using software.
    From experience it is quicker to do it in-camera rather than post image, so download the image and check it on your computer while the subject is still setup and go back and reshoot if you're not happy.
    Hopefully these insights help someone.
    jw0752 over 10 years ago in reply to mcb1
    Thanks Mark,
    Thank you for all the good information. It will be helpful to me as I try to improve my pictures.
  • D_Hersey
    Not too hard to experiment with polarizing the light source:
    https://www.sciplus.com/p/COLOR-PADDLE_40277
    http://www.amazon.com/Polarizing-Film-Sheet-Gadget-Electronics/dp/B004X3XFHU
    Another thing to try is frosted acetate over the light source
    mcb1 over 10 years ago in reply to D_Hersey
    You're right that it helps diffuse the light, but bouncing the light off the roof (assume it is light colour) will increase the distance and reduce the contrast between the light and shadow areas.
    Anything more than 2 stops tends to be like black and white, so if possible aim for 1 stop (1/2 the light).
    jw0752 over 10 years ago in reply to D_Hersey
    Hi Don,
    When I used to try to teach the grandkids a little about physics I had some of the polarizing sheets for experiments. I will have to dig for them is storage now but it might be fun to run a few experiments.
  • D_Hersey
    Decades ago we had a little setup comprised of two sheets of polarizing film in a bunk-bed like arrangement
    We would stretch Saran Wrap between the sheets which would color in accordance with the stress, fun
    My friend Dave would not stop playing with it unless someone interrupted him
    He had a diagnosis of autism, but it was really slight
    Read later that that was a standard test for autism
  • D_Hersey
    Post processing with a program like GIMP can really help with things like contrast
    Modern cameras have lotsa dynamic range making effects possible and good-looking
  • D_Hersey
    D_Hersey over 10 years ago in reply to D_Hersey
    These are interesting:
    https://www.lytro.com/
    Lytro’s Magical DSLR-Like Camera Lets You Refocus Photos After You Take Them | WIRED
    No you need some of these.
    Infinity Photo-Optical Company
    Very interesting history started by this Australian.
    Jim Frazier – An icon in Photography | Manning-Great Lakes Focus
    https://en.wikipedia.org/wiki/Frazier_lens
    Sadly the patent office screwed him over a technicality ...
