Test & Tools
Test & Tools
Forum radar mechanism to monitor diy radar reflectors made on aluminum foils or tape or cd, any alternative to radar?
  • Replies 36 replies
  • Subscribers 382 subscribers
  • Views 5982 views
silentknight14th
silentknight14th over 8 years ago
We have a study on implementing a ship's radar design and mechanism in the forest where on a bunch of trees there's a radar reflector and that radar reflector can be seen in the radar but a radar will cost much so we're trying to find a cheap way
can a software design radio be used? or not?
thank you.
    shabaz over 8 years ago +6
    Hi Raymond, Any reason you've raised four near-identical posts? Three with silly titles..
    shabaz over 8 years ago in reply to silentknight14th +5
    Yes, I have a suggestion, If you keep it to a single thread, people won't waste time repeating what someone else may have already discussed in one of your other threads. Basically, if you try to show some…
  • ntewinkel
    ntewinkel over 8 years ago in reply to shabaz +5
    > if you give it a better title, people won't waste their time clicking to open to see what it's about I very much agree. In general I don't even look at posts with titles like "asap" or similar. Having…
  • ntewinkel
    ntewinkel over 8 years ago in reply to silentknight14th
    >To find a way to monitor trees in the forest.
    That's really cool!
    And I see you've chosen to use radar for your school project, so I assume it would be best for us to stick to that, as the idea is part of your project. Someone providing an alternative brilliant way would then be kind of like cheating.
    I see you've figured out the idea of radar reflectors.
    So the question that is left is: how do we build our own inexpensive radar?
  • silentknight14th
    silentknight14th over 8 years ago in reply to ntewinkel
    Yes, that's what I was thinking too.
    And I've done also some researching that's why I was asking for some opinions and suggestions on an inexpensive one but I was not able to deliver it much clearer.
  • colporteur
    colporteur over 8 years ago
    Design goal, build a (better) radar reflector.
    I suggest you limit your project to just the radar reflector design. Avoid any work that involves designing a radar. The scope of work to achieve just one of these goals is high, to accomplish both for a school project is setting yourself up for failure.
    Before designing the reflector you do need to determine some method of testing your design. That means you need a source radar to use for testing and someone willing to assist in providing meaningful test results.
    Using a ships radar might be effective. Ships radar can be portable and are easily available (at a cost). Do you have any means to access a ships radar? Do not limit your thought to purchasing one.
    Sean
    dougw over 8 years ago in reply to silentknight14th
    Those cheap modules are just used for close range detection of objects.
    If you want to recognize boats at a distance it will take a pretty fancy radar, emitting fairly high levels of radiation and extensive signal processing of the return signal. Investigate commercial boat radars to get some idea of what is involved in a unit that can see a kayak.
    It might be possible to use sonar instead.
  • ntewinkel
    ntewinkel over 8 years ago in reply to dougw
    Looks like a longer-distance radar would be rather complicated to build...
    https://hackaday.com/2012/04/28/build-your-own-radar-system/
  • silentknight14th
    Nico teWinkel.
    Good day Sir, I have reviewed the link you send.
    It would be a cool idea to implement the design used on the video but I fear it would cost expensive for us, especially in our country here in the philippines where $1 is equals to 50php. so a $359 dollar design would cost around 16000php on our country and it would be very expensive for us but I appreciate the idea you gave on me.
    anyway, im still searching for the past 2 weeks on what to do and what to use but I fear many questions are still coming in my mind when I search something but thank youuuu
