Test & Tools
Test & Tools
Documents Cool Tools Bench Awards 2018
  • Author Author: e14mindi
  • Date Created: 4 Jun 2018 6:27 PM Date Created
  • Last Updated Last Updated: 6 Oct 2021 9:38 PM
  • Views 16010 views
  • Likes 20 likes
  • Comments 267 comments
Hello Community Members and happy June.
It is officially summertime here at the element14 offices, which is enough of a reason to celebrate but as we batted around some ideas we thought - why don't we involve the Community in some fun?  We have already been asking you about your favorite tools for our RoadTest reviews and now we'd like to present to you the Cool Tools Bench Awards!
Starting today and going through the entire month of June, we want you to submit photos and/or videos of your own bench or workspace for other Community members to see.  Then in the month of July we'll pick out some winners every week and send them some of our favorite Cool Tools chosen by us and other Community members like the ones below:
Duratool PL 501 Cutter
Klein Tools 4-1 Screwdriver
Duratool PC Maintenance Tool KitDuratool Soldering Station
Milwaukee Bit SetDuratool Wire Stripper
We will have ten (10)  winners total for the following categories:
•      Where’s my Cat? (messiest bench)
•       Tony Stark’s Dream Bench (state of the art bench)
•      Fire Hazard Award (Worst cable management)
•       Pepped to the Post Award (Best coffee mug)
•      Totally Screwed Award (Worst organisation of screws, nuts and bolts)
•      Bat Cave Award (Award for wide range of tools)
•       Mom Would Be Proud (Neatest bench)
•       Man Cave Bench (Best use of personal space for a bench)
•      Jury Rigged Award (Most improvised or makeshift repair or bench)
•       Time Machine Award (Best piece of Retro Tech on display)
Along with the above, we'll also have a special “In Their Element" award (best representation and love of element14)
Let's have some fun with this and show us the benches and workspaces where all of your amazing projects come to life!
Comment with your photo/videos on this post through June 30th.
imageCool_Tools_Bench_Awards_2018_Contest.pdf
  • giveaways
  • members
  • cool tools
  • hand tools
  • contest
  • bench awards
    jw0752 over 8 years ago +20
    I have been accused of not really doing any electronics on my bench, but I actually do projects quite often. Perhaps it is Mom's fault as she always insisted that I pickup my toys at the end of each day…
  • gordonmx
    gordonmx over 8 years ago +13
    This is a fun contest, but most of my lab bench is still packed until a have a more permanent facility. I currently only have unpacked those pieces I really need in my work. But with that said, here a…
    dougw over 8 years ago +13
    Okay - this series of workspace images should be good for a chuckle... First up is my computing office - note all the project boxes on either side of the desk - these are some of my current projects in…
  • spyderjacks
    spyderjacks over 8 years ago
    Here's my entry, where I've set aside a wall of the ManCave for electronics and use both standing and sitting bench tops.  I do all of the fabrication and testing at the standing bench, which has additional drawers and storage on the reverse side.  The foundation for the bench is actually a Craftsman Workbench (but the 1980's edition)  which I elevated and added retractable wheels along with the work surface - and then fit in the equipment risers.  So I have to move out the bench to access some of the infrequently used tools and equipment.  Alternatively, I can just turn the bench 90 degrees or put it in the center of the ManCave.
    Most of my work is with computers and micro-controllers and the occasional kit or repair project.  This needs a consistent set of tools and prototyping boards, which I keep at hand.  The benches all roll out of the way to get into the wall cabinets which extend up to the 10' ceiling.  Each of the lower cabinet doors has parts cabinets on the reverse.  The wall cabinets are 47"W x 60"H x 18" deep.
    While I have computer screens on both benches, I do most of my software development, research and email, at the sitting bench.  This also houses my older analog equipment.  I prefer portrait screens for viewing PDFs in full page size.  The small monitor is for booting up raspberry pi's - thereafter I use putty or VNC.
    I keep the right side of the ManCave dark to support YouTube and movies on the big projection screen.  To the left starts the woodworking bench and tools.  I also have a small machine shop to handle all of my metalwork for cases and chassis restoration, and for custom camera fittings.  I built all of the benches, shelves and cabinets.  Long ago, my 6th grade shop class was woodworking, metalworking and electronics - which makes a variety of projects possible - if you keep up with it!
    • Vote Up +6 Vote Down
    jw0752 over 8 years ago in reply to spyderjacks
    Hi Michael,
    I really like your shop. It has a functional look and a flexibility that is somewhat rare. I can see that you are a true maker by your inclination to modify things to make them fit your needs rather than just accept them as is and adapt yourself instead. I also believe that the functional compartmentalization works very well to get things done provided that there is enough room to do it.
  • spyderjacks
    spyderjacks over 8 years ago in reply to jw0752
    Thanks John!  Let me share a couple more pictures of the bench re-purpose.
    Here is some of the reinforcing of the sheet metal to all for mounting of the work surface.  This bench had the capacity I wanted but was just too low and too small a work surface to be use comfortably.  While it is a standing height, I do sit at a stool while soldering and bread boarding.  So I really needed to be able to sit under the bench - and the original top just could not support that use.  With this frame in place, I could easily use pocket screws to fasten the new bench top on the old bench.
    Of course, Having a large overhang would make it more difficult to access the drawers.  So the top is positioned asymmetrically with leg room at the back and minimal overhang at the drawers side.  Thus tools that are bulky and would otherwise take up bench top space, can be easily stored away until needed.
    A lot of the tools that I use frequently then moved from the drawers to a "tool caddy" which I now use on the bench top.
    The chunk of granite is a sample from a kitchen project.  I'm not sure it is really useful - but it seemed like a good idea at the time!
    Now I could have just slapped on (2) slabs of MDF but I was doing everything in the ManCave in Oak.  I was thinking of the Edison Labs and how they they build everything to purpose.  So here I am trimming out the slabs in Oak.  The tape is used to mark the biscuit locations to help guide the clamping during the glue up.
    If you look at the lower left corner of the bench you can see that the original bench just sits on a cleat.  This allows you to tune the height.  The leg is then bolted to the lift .  I settled on the final height by using a lift cart, raising the whole assembly, and trying it out.
    Finally, here is the detail of the lift mechanism.  A scissor jack with a custom hand wheel adapter, one at each end.  I could have used the jack handle but it is a little fussy to get it attached through the opening.  The slot is critical because the center-line of the jacks moves quite a bit, over its range.This is maybe a little overkill but the final bench is pretty heavy and keeping it mobile is the most important criteria.  The bench is up against additional shelving and the wall cabinets so it needs to move easily to access that storage.
    mcb1 over 8 years ago in reply to spyderjacks
    Great setup.
    I like the tool caddy. My bench in the garage has them in a small bucket and it really doesn't work.
    Every time I use them I think I should resolve it, and many years later, it's still the same.
    Your solution seems to be just what I need.image
    Thanks
  • spyderjacks
    spyderjacks over 8 years ago in reply to mcb1
    Mark:
    Here is a little more detail on the Tool Caddy.
    It is approximately7"W x 5-1/2"D x 5-1/4"H.  Not counting the granite sample.  A chunk of anything will give it some mass and keep it from moving around on its own.
    I made it by combining (3) tool holders - screwdrivers, thin bits (scales and gauges) and roundish items.  This forms the center divider.  The pliers holder is pretty simple - just needs a dowel or some other 'beam'.
    You just need to decide which tools should make up the 'everyday' carry, for the bench top.  Lay them out to get the overall dimension and spacing.  I use a cheap plastic hole gauge Then start drilling and mounting.
    For the spacers, I used thin MDF or fiberboard.  Easy enough to cut if you have a cross-cut jig.  Otherwise - use a small saw (for safety).
    Be sure to use a drill press and a clamp to hold the work.  Otherwise, you are going to have a miserable time.
    The most important use, for the various rulers, is to remind me of the pitch for some SMD - and curtail my ambitions!  But also helpful to select through holes for various devices in the salvage box.
    The holes for the other tools are not uniform so I lay these out by eye.
    The scales are sandwiched between the misc. tools and screwdrivers.
    From left to right:
         - non conductive probe
         - x-acto knife
         - spluger (to separate phone cases and similar)
         - small utility knife (not shown here)
         - standard and Phillips screwdriver (I've had it forever)
         - small metal file
    If everything has a place... you can, at least, set aside a Friday afternoon to clean everything up! ;-)
  • spyderjacks
    Mark:
    From left to right:
         - x-acto knife
         - small metal file
