Test & Tools
Test & Tools
Documents Cool Tools Bench Awards 2018
  • Author Author: e14mindi
  • Date Created: 4 Jun 2018 6:27 PM Date Created
  • Last Updated Last Updated: 6 Oct 2021 9:38 PM
  • Views 15997 views
  • Likes 20 likes
  • Comments 267 comments
Hello Community Members and happy June.
It is officially summertime here at the element14 offices, which is enough of a reason to celebrate but as we batted around some ideas we thought - why don't we involve the Community in some fun?  We have already been asking you about your favorite tools for our RoadTest reviews and now we'd like to present to you the Cool Tools Bench Awards!
Starting today and going through the entire month of June, we want you to submit photos and/or videos of your own bench or workspace for other Community members to see.  Then in the month of July we'll pick out some winners every week and send them some of our favorite Cool Tools chosen by us and other Community members like the ones below:
Duratool PL 501 Cutter
Klein Tools 4-1 Screwdriver
Duratool PC Maintenance Tool KitDuratool Soldering Station
Milwaukee Bit SetDuratool Wire Stripper
We will have ten (10)  winners total for the following categories:
•      Where’s my Cat? (messiest bench)
•       Tony Stark’s Dream Bench (state of the art bench)
•      Fire Hazard Award (Worst cable management)
•       Pepped to the Post Award (Best coffee mug)
•      Totally Screwed Award (Worst organisation of screws, nuts and bolts)
•      Bat Cave Award (Award for wide range of tools)
•       Mom Would Be Proud (Neatest bench)
•       Man Cave Bench (Best use of personal space for a bench)
•      Jury Rigged Award (Most improvised or makeshift repair or bench)
•       Time Machine Award (Best piece of Retro Tech on display)
Along with the above, we'll also have a special “In Their Element" award (best representation and love of element14)
Let's have some fun with this and show us the benches and workspaces where all of your amazing projects come to life!
Comment with your photo/videos on this post through June 30th.
imageCool_Tools_Bench_Awards_2018_Contest.pdf
  • giveaways
  • members
  • cool tools
  • hand tools
  • contest
  • bench awards
    jw0752 over 8 years ago +20
    I have been accused of not really doing any electronics on my bench, but I actually do projects quite often. Perhaps it is Mom's fault as she always insisted that I pickup my toys at the end of each day…
  • gordonmx
    gordonmx over 8 years ago +13
    This is a fun contest, but most of my lab bench is still packed until a have a more permanent facility. I currently only have unpacked those pieces I really need in my work. But with that said, here a…
    dougw over 8 years ago +13
    Okay - this series of workspace images should be good for a chuckle... First up is my computing office - note all the project boxes on either side of the desk - these are some of my current projects in…
  • vishwasn
    vishwasn over 8 years ago
    This is my desk.image
    • Vote Up +7 Vote Down
  • clarkkent57
    clarkkent57 over 8 years ago
    Of course, sometimes you just need to take a refreshing break from all that hard bench work and look around the rolling man cave! Maybe enjoy a refreshing Nuka Cola and friendly affirmation!
    (Don't ask me why I posted this. Tension breaker...had to be done...) image
    • Vote Up +6 Vote Down
  • spyderjacks
    spyderjacks over 8 years ago in reply to mcb1
    Mark:
    Here is a little more detail on the Tool Caddy.
    It is approximately7"W x 5-1/2"D x 5-1/4"H.  Not counting the granite sample.  A chunk of anything will give it some mass and keep it from moving around on its own.
    I made it by combining (3) tool holders - screwdrivers, thin bits (scales and gauges) and roundish items.  This forms the center divider.  The pliers holder is pretty simple - just needs a dowel or some other 'beam'.
    You just need to decide which tools should make up the 'everyday' carry, for the bench top.  Lay them out to get the overall dimension and spacing.  I use a cheap plastic hole gauge Then start drilling and mounting.
    For the spacers, I used thin MDF or fiberboard.  Easy enough to cut if you have a cross-cut jig.  Otherwise - use a small saw (for safety).
    Be sure to use a drill press and a clamp to hold the work.  Otherwise, you are going to have a miserable time.
    The most important use, for the various rulers, is to remind me of the pitch for some SMD - and curtail my ambitions!  But also helpful to select through holes for various devices in the salvage box.
    The holes for the other tools are not uniform so I lay these out by eye.
    The scales are sandwiched between the misc. tools and screwdrivers.
    From left to right:
         - non conductive probe
         - x-acto knife
         - spluger (to separate phone cases and similar)
         - small utility knife (not shown here)
         - standard and Phillips screwdriver (I've had it forever)
         - small metal file
    If everything has a place... you can, at least, set aside a Friday afternoon to clean everything up! ;-)
    jw0752 over 8 years ago in reply to three-phase
    Hi Donald,
    I am very glad I asked as I would never have guessed. For my sake it isn't necessary to go into any more detail as I don't have any application but is nice to know that such instrumentation exists. Thanks again for bringing a window on your specialty to the forum. There have been several times recently where your expertise has helped answer a question that I was just guessing at.
  • three-phase
    three-phase over 8 years ago in reply to jw0752
    Hello John,
    The large piece of test apparatus is an Omicron CMC356 Secondary Current Injection Test Set (SCITS).
    This particular model has 4 voltage output channels at 0V to 300V, DC to 1kHz AC in the top left corner. Three of the channels can be configured to give a 3 phase + neutral output, or can be combined to give a 0V to 600V output. These are used to test synchronisers, power and impedance protection relays.
    Below the voltage outputs are two sets of 3 phase + neutral current outputs. Each current channel can output 0 to 32A, DC to 1kHz AC. These can be reconfigured to give a maximum 128A single phase output. These are for testing standard over current relays along the more specialised differential relays and generator protection relays.
    The larger round connector to the right of the current outputs is a standard speaker connector that has 3 x 300V and 3 x 25A output channels.
    Next to the voltage outputs is a specific DC output channel, 0V to 240V, to provide power for electronic relays being bench tested.
    The remaining sockets are a variety of digital input and output channels used for catching signals from the relays for recording trip times to simulating inputs into the relays for breaker operation schemes.
    I could create a more detailed blog on it if there is some interest.
    Kind regards
    mcb1 over 8 years ago in reply to shabaz
    Wow - that's a really nice work table and surface!!
    I was thinking exactly the same thing.
    I might need to replicate that ...
    mcb1 over 8 years ago in reply to spyderjacks
    Great setup.
    I like the tool caddy. My bench in the garage has them in a small bucket and it really doesn't work.
    Every time I use them I think I should resolve it, and many years later, it's still the same.
    Your solution seems to be just what I need.image
    Thanks
    genebren over 8 years ago in reply to shabaz
    Thanks Shabaz,
    That unfortunately is my old workshop.  Two years ago we move to Texas to be with our grandkids.  Here I do not yet have a workshop (my wife really wanted to park the car inside here).  I am planning on building a new shop, but I have not yet come up with the right plan.  I really need to push a bit harder to get that moving.
    Thanks!
    Gene
    shabaz over 8 years ago in reply to genebren
    Hi Gene,
    Wow - that's a really nice work table and surface!! Your whole workshop looks great, a pleasure to work in I imagine.
  • clarkkent57
    clarkkent57 over 8 years ago in reply to spyderjacks
    I can really appreciate your organization, Michael, and it contrasts really well with the space you have. I think most people would allow their project space and equipment to overwhelm the area allocated to it because of the freedom, but you appear to have taken the time and trouble to blend your space in organization and atmosphere. Very nice.
