Design For A Cause 2021
  • Design For A Cause 2021
Blog VACBAG (IoT Dashboard Live Parameters)---Blog#3
  • Author Author: sidastro
  • Date Created: 9 May 2021 9:03 AM Date Created
  • Views 1123 views
  • atmel_samd
  • https
  • refrigeration
  • system engineering
  • acclerometer
  • vaccine
  • iot system
  • ubidots
  • data logging
  • gyroscope
  • pid
sidastro
sidastro
9 May 2021
<--Blog#2
Blog#4-->
IoT Dashboard
Live Parameters
Heat sink Temperature(analog type)-t_ana
Inside container Temperature(digital type)-t_di
Reference values
(Inner)-15*C
(Outer)-32*C
Accelerometer- x,y,z
Gyro-gx,gy,gz
Temperature- https://stem.ubidots.com/app/dashboards/public/widget/xgp5XfhBtZXIcAdTjsxINB-UeFOWUiCEFZ5xeI047lQ
Table--https://stem.ubidots.com/app/dashboards/public/widget/Z8IStnEENTVZIXRGaR5D6SXMQ-dcQN_mOBkmrquTBFc
Gyro- https://stem.ubidots.com/app/dashboards/public/widget/ZCELVE0WoNlPihq27sbuF2oOoXhfSUUXbSSorbtfeTU
ACC-https://stem.ubidots.com/app/dashboards/public/widget/3TwY16kp-GoI5oT1wIHQUVTkOgRkKu40HprozAGZcio
02:05:26.176 -> Connected to wifi
02:05:26.176 -> SSID: ************
02:05:26.176 -> IP Address: **************
02:05:26.176 -> signal strength (RSSI):-60 dBm
02:05:29.401 -> connected to server
02:05:29.401 -> POST /api/v1.6/devices/arduino-nano-33/ HTTP/1.1
02:05:29.401 -> Host: things.ubidots.com
02:05:29.401 -> User-Agent: Arduino Nano 33 IoT
02:05:29.401 -> X-Auth-Token: ********************************
02:05:29.401 -> Connection: close
02:05:29.401 -> Content-Type: application/json
02:05:29.401 -> Content-Length: 116
02:05:29.401 ->
02:05:29.401 -> {"seti":15.00,"T_di":15.62,"seto":32.00,"T_ana":36.41,"x":-0.99,"y":0.09,"z":-0.01,"gx":-2.56,"gy":-4.15,"gz":-0.18}
02:05:30.199 ->
02:05:30.199 -> Ubidots' Server response:
02:05:30.199 ->
02:05:30.199 -> HTTP/1.1 200 OK
02:05:30.199 -> Server: nginx
02:05:30.199 -> Date: Sun, 02 May 2021 20:35:30 GMT
02:05:30.199 -> Content-Type: application/json
02:05:30.199 -> Transfer-Encoding: chunked
02:05:30.234 -> Connection: close
02:05:30.234 -> access-control-allow-origin: *
02:05:30.234 ->
02:05:30.234 -> 115
02:05:30.234 -> {"gx":[{"status_code":201}],"gy":[{"status_code":201}],"gz":[{"status_code":201}],"seti":[{"status_code":201}],"seto":[{"status_code":201}],"t_ana":[{"status_code":201}],"t_di":[{"status_code":201}],"x":[{"status_code":201}],"y":[{"status_code":201}],"z":[{"status_code":201}]}
02:05:30.234 -> 0
02:05:30.234 ->
02:05:30.747 ->    32.00    15.00  15.63   0.62  406   0.01   0  406  32.00     36.41   4.41  2646    0.00  0    1200 -0.99 0.09 -0.01 -2.56 -4.15 -0.18
02:05:34.009 -> connected to server
02:05:34.009 -> POST /api/v1.6/devices/arduino-nano-33/ HTTP/1.1
02:05:34.009 -> Host: things.ubidots.com
02:05:34.009 -> User-Agent: Arduino Nano 33 IoT
02:05:34.009 -> X-Auth-Token: ******************************************************
02:05:34.009 -> Connection: close
Topics
Blogs#
VACBAG   Portable Vaccine Box (Application Of Thermoelectric Cooling) ----Blog#1 "Overview n Progress"Blog#1
VACBAG "Overall Schematic"  Blog#2
VACBAG (IoT Dashboard Live Parameters) Blog#3
VACBAG-- SYSTEM CONTROL Blog#4
VACBAG 'CODE' Blog#5
VACBAG "Performance curves"Blog#6
VACBAG Machine Learning Model-Door_check || System ON || System OFF || System Anomaly Blog#7
VACBAG---"PRODUCT"Blog#8
    Jan Cumps over 5 years ago +1
    Do the ubidots widgets work with a fixed date range? I get "No data withing given date range" when following the hyperlinks.
  • sidastro
    sidastro over 5 years ago +1
    thanks for feedback I just change the span of data now links are working
  • sidastro
    Jan Cumps over 5 years ago in reply to sidastro
    Yes! Thank you.
    Yes! Thank you.
