Challenge Blog Blog #6: A Current-Sensing PSU Upgrade – PSU Logging, CSA & FastLog Comparison, a Sound Check & an Overall Summary
  • Author Author: Gough Lui
  • Date Created: 31 May 2022 7:21 PM Date Created
  • Views 19068 views
  • Comments 5 comments
  • Current 6 Click
  • winners
  • MAX40080
Gough Lui
Gough Lui
31 May 2022
While I had hoped to do more, unfortunately, because of time constraints arising from work commitments and the fact that the challenge is due to end, this will be the final blog in the series. It wouldn’t be a complete challenge if I didn’t get around the applying the current-sense amplifier to an actual problem. In this post, I will challenge it in two different ways – one is to profile the current of a blood pressure measurement and another would be to capture and reconstruct audio from the measured current. Before I close-off the series, I will also summarise the key learnings and take-aways from my experience.
Table of Contents
  • Challenge – Profiling a Blood Pressure Measurement
  • Head-to-Head – PSU vs. CSA
  • Head-to-Head – CSA vs. FastLog
  • Challenge – Can You Hear the Current?
  • Experimenting with Current Sense Amplifiers – Key Learnings
  • Conclusion
In a fortuitous turn of circumstances, I have been given a small, low-cost, cuff-based blood pressure monitor. Such a device is an interesting mix of an embedded microcontroller, a Bluetooth Low-Energy radio, an LCD with LED backlight, a pump motor and a solenoid valve.
As usual, the device came with a catch – the battery inside has aged and become so high in internal resistance that even at a full charge, it fails to complete a single reading, instead claiming “battery low”.
Thankfully, it was not too difficult to take apart – the offending battery can be seen with a date of 2015. It’s lived long enough, and on the plus side, it hasn’t swollen to oblivion.
To bring it back to life, rather than buy a battery that would cost more than half the cost of a new unit, I decided to drill some holes and lead in some silicone wire to allow the unit to be powered externally. The first hole, unfortunately, landed too close to an electrolytic capacitor, so the wire couldn’t actually be led out of the unit!
Now that I have a blood-pressure monitor that is powered by flying leads, it is now much easier to use for current profiling!
The challengers in this test include the Keysight EDU36311A which I received from the Keysight Smart Bench Essentials RoadTest which is considered a very basic power supply without any onboard logging capabilities. A short script (below) was used to “hammer” the unit for current readings which it provides at a rate of about 6Hz. A Rohde & Schwarz NGM202 was also used, whereby the standard logging mode of up to 10Hz is used to simulate what some mid-range power supplies are capable of when using onboard USB logging (e.g. the Rohde & Schwarz HMC804x). Finally, the FastLog mode of the NGM202 was also used to show what “professional” high-sample-rate logging is capable of, operating at the maximum 500kHz. We will be comparing what the current read-outs from these units look like when performing a single blood pressure reading on myself – unfortunately, as my arm is “tied” by the test, there are no photos!
import visa
import time
resource_manager = visa.ResourceManager()
ins_psu = resource_manager.open_resource("TCPIP0::192.168.xxx.xxx::5025::SOCKET")
ins_psu.read_termination = "\n"
print("Available:" + "\n" + ins_psu.query("*IDN?"))
print("Setting Up")
ins_psu.write("APPL N30V,4.2,1")
ins_psu.write("OUTP 1")
ins_psu.query("*OPC?")
print("Opening a logfile ...")
f = open("bppsu-basic.csv","a")
while True:
  pscurr = ins_psu.query_ascii_values("MEAS:CURR? CH3",separator="\r")[0]
  f.write(str(time.time())+","+str(pscurr)+"\n")
  f.flush()
# Never be called
ins_psu.write("OUTP 0")
f.close()
print("Script Completed!")
First, it is good to get an idea of what is achievable using a basic power supply.
From the whole-sequence view, we can see the unit starting up the microcontroller, turning on the LCD backlight, running an initial inflation then stopping for a leak-check, followed by a controlled inflation, then the cuff deflates naturally while the results are displayed and a Bluetooth upload is attempted, then I manually turn off the unit.
Zooming in, we can see the 6/10Hz sampling rate doesn’t give all that much detail – for example, here is the initial inflation and leak-check section.
Adding the data from the CSA into the mix, without the markers to improve clarity, we can see just how much more information is added. For one, the Bluetooth upload section near the end is now very obvious – small, short spikes.
Looking zoomed into the leak-check section, we can see the initial motor inrush current too – something that is entirely missed by standard logging, as well as some of the noise that you might expect due to the use of a brushed DC motor.
During controlled inflation, in-between two samples of the power supply, we can see this much more detail. The current bobs up and down, likely as each winding is energised in sequence, with a sort of repeating pattern which may suggest the motor has uneven loading due to mechanical reasons, uneven coils or it could be an aliasing with the sampling measurement.
Looking closer into the Bluetooth upload towards the end, the power supplies are powerless to resolve this, even though the slight wobble in their measurements suggest the presence of some activity. The CSA resolves this very clearly.
Having a CSA can, hence, be a sizable upgrade in terms of ability to resolve what is happening in the time-domain with respect to current. High-rate current digitisation is usually the realm of sophisticated high-end power supplies or source-measurement units, so being able to retrofit this to an ordinary power supply at an inexpensive cost would be quite useful. However, there is some key limitations as we will see when comparing to a proper digitising power supply.
Rohde & Schwarz’s FastLog is a feature on their NGM/NGU-series power supplies that digitises voltage and current at a rate of up to 500kSa/s. This is what I would consider a proper, professional, gold-standard way to perform current profiling based on the equipment I have to hand as it offers a good mix between accuracy and speed. Others may opt for oscilloscope-based measurements for speed, but rarely will they have the accuracy. So how does the CSA stack-up with the “big guns”?
The result from FastLog is in blue with the CSA in orange (or yellow in later graphs). The results show vaguely a similar profile, but the FastLog result seems to have a lot more “noise” around it. However, if we zoom in, it is clear that this is not “noise” but actually “data” as the unit modulates current so quickly that it likely exceeds the CSA’s usable (continuously communicable) sample rate.
For example, even before anything happens and the LCD display is turned on, FastLog can reveal the microcontroller is consuming about 22.5mA with spikes of activity on a regular basis. The CSA, on the other hand, has noticeably high levels of measurement noise by comparison but fails to clearly resolve these short spikes.
At the initial inflation, if we look from afar, both measurements have a similar shape and profile, but the FastLog result gives much more resolution.
Zooming far into the “noise”, we can see that it is not noise but seems to be spikes of sorts, likely a mixture of motor PWM driving (short spikes) and motor brushes changing coils (wider “wavy” pattern). You can really tell a lot from the FastLog, while the CSA is truly just giving an average “wave” with not much resolution. On the other hand, FastLog data is massive, so I had to resort to MATLAB just to be able to plot and analyse it!
Looking into the Bluetooth low-energy transmission blips, both CSA and FastLog could resolve the three bursts (one on each of the three channels, as mandated by BLE standards). However, the FastLog graph seems a lot nicer in terms of the smoothness, and the noise level is noticeably less than that of the CSA.
In all, this shows that the capability of digitising power supplies and source-measurement units surpass the capability of the CSA which is no surprise. The CSA really only operates at about 7.8kSa/s in my set-up and offers 12-bits of resolution on a single range at a time. This pales in comparison to the 500kSa/s of FastLog with 5-digits+ of resolution. Whether this is meaningful to you or not depends on the scenario – I would contend that the CSA really adds a lot of value over the integrated metering/logging capability of standard power supplies which will give you some idea of what your device is up to, but isn’t quite fast or quiet enough to resolve low-power standby modes (at least, with the shunt used in the Current 6 Click) or fast transient events. It is also more difficult to use, requiring a whole Raspberry Pi to drive it at this stage, but is also a whole lot cheaper than buying a new power supply. I can only declare my project to “upgrade” a power supply a partial victory based on these trade-offs.
One thing I proposed testing was whether it would be possible to use the CSA to measure a current waveform that contained audio. This would be a test of both noise performance (as that would present as background hiss) as well as sample rate capability (as you’d need about 8kHz to achieve telephone-grade audio). As we previously established the noise level of the CSA itself, I decided to eschew testing of a practical device as the audio-related current could be smaller than the noise and instead sought to push a clean signal with a moderate current instead.
For this, I used the Keysight EDU33212A Waveform Generator from my Keysight Smart Bench Essentials RoadTest. For this test, I used the famous Apollo 12 “set SCE to AUX” recording which I had transformed into an .arb file compatible with the waveform generator and previously used in a modulation demonstration. A listing of the .arb file is provided below in case you want to try this for yourself on your own compatible waveform generator –
File Format:1.10
Checksum:7983018
Channel Count:1
Sample Rate:11025.000000
High Level:1.000000
Low Level:-1.000000
Marker Point:1
Data Type:"short"
Filter:"step"
Data Points:39740
-1219
-2134
-927
545
1515
1263
400
-613
-1048
-893
-473
-560
-1081
-1284
-389
1032
1778
1332
672
817
1552
1632
534
-971
-1725
-1421
-477
705
1973
2907
2793
1345
-681
-1929
-1590
-128
1117
1133
52
-1128
-1673
-1726
-1771
-1704
-1032
132
798
337
-548
-669
-72
-3
-1022
-1908
-1235
523
1388
418
-1094
-1362
-353
481
300
-193
-76
415
394
-222
-501
228
1440
2032
1617
873
652
1080
1583
1648
1325
980
754
476
109
-13
369
865
640
-601
-2055
-2482
-1412
425
1829
2064
1209
-55
-845
-538
747
2157
2812
2564
1914
1208
284
-988
-2106
-2263
-1241
343
1680
2354
2222
1161
-620
-2157
-2231
-638
1277
1824
707
-744
-1182
-750
-668
-1512
-2452
-2399
-1462
-745
-832
-1085
-725
-80
-154
-1091
-1733
-1062
373
1048
305
-886
-1168
-358
546
645
-47
-946
-1567
-1654
-1031
220
1470
1888
1272
317
-188
-293
-691
-1571
-2048
-1089
1058
2809
2806
1384
155
184
954
1282
939
884
1859
3205
3450
1977
-195
-1390
-842
711
1842
1686
548
-471
-455
589
1807
2281
1758
675
-354
-971
-1031
-477
490
1253
1165
328
-302
85
1060
1236
-63
-1701
-1768
195
2477
2891
999
-1515
-2569
-1625
30
794
326
-341
-20
1360
2669
2795
1863
931
646
650
296
-476
-1056
-907
-305
-70
-599
-1434
-1814
-1383
-489
96
-39
-468
-489
49
731
1100
1021
777
723
801
655
239
-66
57
494
695
198
-607
-691
249
1147
772
-777
-2038
-1538
590
2488
2473
832
-765
-1191
-730
-424
-775
-1176
-788
247
1130
1480
1330
607
-571
-1520
-1470
-344
1007
1488
977
487
678
980
631
-217
-848
-766
-101
479
509
310
363
522
482
395
585
1057
1391
1033
34
-689
-479
190
558
472
69
-420
-451
278
1090
812
-911
-2872
-3106
-1086
1257
1790
756
-71
62
404
56
-954
-1597
-954
457
1086
183
-1355
-1864
-561
1312
1564
-85
-1413
-800
639
932
-160
-1184
-832
623
1711
1517
481
-521
-877
-267
749
869
-78
-526
548
1988
1895
-30
-2009
-1997
-86
1560
1451
243
-727
-886
-328
403
652
407
119
-169
-598
-919
-935
-799
-628
-467
-353
-14
770
1604
2021
2019
1495
375
-552
-381
487
890
422
-273
-271
617
1363
948
-125
-653
-380
193
702
859
602
399
564
790
831
682
160
-736
-1463
-1539
-929
44
532
-212
-1543
-1994
-1176
27
665
246
-965
-1826
-1410
-27
1417
2233
2058
1228
720
948
1333
1271
620
-283
-531
363
1295
857
-530
-1292
-757
501
1545
1834
1516
959
307
57
845
1831
1156
-1139
-2736
-2076
-57
1434
1435
486
-196
-125
311
726
728
-159
-1359
-1357
-55
743
-96
-1709
-2671
-2434
-1460
-593
-201
-124
-312
-566
-175
840
1199
339
-579
-513
240
957
1202
790
-145
-1306
-2286
-2282
-816
1108
1889
1138
-306
-1255
-583
1584
3198
2476
274
-1073
-446
1237
2252
1988
1566
1948
2363
1892
1107
835
861
667
84
-769
-1280
-827
83
312
-430
-1447
-1780
-951
298
634
101
-34
387
295
-515
-1020
-367
1307
2839
2791
986
-1286
-2741
-2754
-1261
650
1177
-106
-1787
-2417
-1690
-327
439
130
-253
224
1096
1486
1214
526
-78
-34
552
1051
1165
836
139
-134
760
2016
2118
904
-489
-976
-284
808
1105
383
-525
-918
-491
699
1721
1375
-251
-2054
-3208
-3213
-1812
253
1558
1418
377
-447
-425
-189
-709
-1471
-1179
-101
336
-86
-355
-11
402
265
-273
-349
383
1063
1019
786
864
896
732
761
1055
1366
1603
1645
1427
1246
1347
1578
1666
1257
178
-821
-718
67
50
-1209
-2560
-2539
-639
1999
3208
1982
-309
-1509
-844
539
817
-408
-1411
-630
1047
1629
680
-577
-1016
-584
-67
-105
-440
-464
-193
-106
-488
-1211
-1640
-988
425
1016
-130
-1961
-2708
-1819
-261
711
808
593
340
-170
-711
-603
204
961
1140
954
875
1002
1014
712
391
359
445
382
285
351
408
186
-205
-280
159
578
350
-222
-222
502
995
471
-525
-700
308
1299
1011
-238
-1047
-737
43
266
-279
-767
-270
1054
2024
1675
201
-1186
-1216
237
1979
2799
2513
1501
30
-1489
-2239
-1516
450
2236
2218
392
-1363
-1388
-47
947
487
-879
-1529
-501
1427
2746
2797
1941
806
-2
-138
172
457
580
724
1006
1263
1061
239
-558
-551
1
182
-157
-302
97
431
-142
-1574
-2649
-2300
-1086
-553
-1170
-1868
-1564
-363
709
704
-362
-1528
-1921
-1511
-767
-174
-161
-771
-1442
-1649
-1495
-1292
-1093
-801
-243
736
1876
2571
2505
1715
376
-890
-1157
-237
1109
2105
2435
2153
1691
1464
1286
916
740
1198
2163
3156
3391
2051
-458
-2345
-2301
-764
795
1112
154
-629
64
1743
2972
3067
2102
544
-589
-485
527
1370
1085
-563
-2417
-2666
-1224
-52
-478
-1715
-2199
-1206
514
1220
78
-1618
-2069
-992
586
1232
-115
-2659
-3688
-1580
1975
3640
1656
-2373
-4513
-2485
1335
2746
967
-1045
-743
1398
2848
1829
-618
-1826
-804
940
1864
1876
1487
995
609
666
1548
3130
4118
3049
471
-1445
-1598
-564
928
2346
2727
1406
-819
-2028
-1012
1235
2461
1778
344
-497
-672
-1069
-2221
-3481
-3781
-2718
-862
627
946
448
-80
-667
-1301
-1284
-752
-697
-1276
-1838
-2110
-2229
-2303
-2519
-2774
-2271
-214
3168
6221
6914
4774
1546
-216
376
1674
1971
1608
1025
-419
-2002
-1930
-626
341
1364
3046
4167
3707
1854
-314
-683
1558
3924
3866
2249
816
-544
-1626
-968
1325
2846
2074
-215
-3174
-5791
-6097
-3680
-499
1492
1291
-1128
-3713
-4087
-2537
-60
2741
3743
1672
-1287
-2197
-421
2217
2981
962
-2031
-4273
-4712
-2381
635
1151
191
-667
-2400
-3569
-1877
208
610
1925
4142
3687
1344
-51
-1256
-2379
-1035
2632
5194
4636
2464
351
-1989
-4617
-5576
-3050
1600
5694
6652
1575
-7689
-12541
-6649
5022
10834
6912
396
-2209
-2153
-2655
-2656
-654
1774
3465
4334
3922
2289
386
-1053
-2446
-3537
-2956
-1486
-778
-90
1144
1190
-27
320
1865
1526
375
708
1572
1752
1083
614
2137
4328
3885
2091
2503
3363
2077
45
-2511
-4180
-1242
2880
2226
-1109
-3821
-5751
-3710
1927
2496
-2108
-2490
497
972
812
827
-429
527
4123
4674
2035
136
-1728
-2925
-1673
-2319
-5478
-5063
-2176
-1065
2048
7839
7514
-87
-5907
-7753
-8786
-7123
-1146
5935
10264
10151
6590
1772
-3346
-7344
-7398
-4264
-594
4365
8018
5765
3435
6191
6073
1089
-39
-169
-5640
-7864
-3885
-3089
-2152
4678
7682
5720
7755
6582
-1986
-2641
3876
1011
-5015
-2763
-1859
-4894
-2633
-1190
-5846
-5204
1148
2956
4442
9285
8965
5170
5494
3710
-4275
-10093
-11152
-10449
-6919
-3324
-2541
997
6864
6924
3787
3303
1559
-1246
-1090
-2942
-5552
732
8531
6020
1567
208
-5651
-8852
-1806
1043
-4312
-3858
-935
-3395
-1324
4175
1399
-716
5119
6638
5317
11217
13862
7427
3352
676
-4836
-4340
-1812
-7899
-11416
-5252
-1721
308
8463
11812
7084
6511
6664
94
-3992
-4673
-10988
-14750
-7087
873
2600
5374
9410
9944
8067
3202
-5865
-11955
-7436
5668
18726
22577
13658
-3295
-20777
-30906
-26029
-8595
9062
21379
28068
21274
-73
-18581
-23488
-21049
-11764
6346
20692
23960
23485
15322
-6402
-22846
-20964
-17423
-18787
-9718
8759
22180
29047
28551
15957
1820
-1418
-300
-1609
-106
3524
911
-8067
-16087
-19402
-19032
-13966
-378
17285
26648
27028
27364
23369
7473
-10207
-19298
-22440
-19397
-12196
-13673
-21694
-19727
-12702
-13398
-9732
7988
23788
28176
28484
25328
16201
5331
-6862
-19492
-24808
-23760
-24464
-24151
-17726
-8775
496
8953
12675
15223
21501
25540
25429
25120
16022
-6161
-22513
-24320
-25373
-25993
-14454
1238
10133
17171
22777
19387
11222
2752
-7625
-10990
3589
21413
21232
4493
-12408
-22470
-24690
-17329
-41
16650
23825
22681
16157
-2803
-25555
-32337
-24668
-11819
2298
18943
28255
28833
25168
6927
-22272
-32767
-26936
-21453
-16284
4545
26899
29477
22616
17056
8305
-514
-1014
185
-344
2437
2835
-9218
-23350
-27155
-25620
-22344
-7357
15144
25226
20636
19175
21805
13948
-3087
-14660
-18989
-21717
-23007
-22249
-18742
-8624
2531
4339
3894
14359
26562
26609
22853
25528
24601
11102
-5521
-14391
-17326
-20155
-23627
-24856
-20535
-8899
6780
18570
22821
24043
25382
24929
23891
23122
15115
-2650
-17633
-22464
-25620
-30004
-25558
-10453
3944
11339
16176
21695
23324
14747
-1964
-14136
-10188
5329
14082
5887
-9096
-17682
-19344
-14332
1196
18454
22889
17848
11755
-918
-19356
-28668
-26231
-19143
-4139
16525
27544
26907
21944
7534
-14169
-24513
-23259
-26855
-29513
-14823
9380
25293
29634
25929
17340
9339
4295
248
-2300
-2163
-2737
-8596
-18450
-25280
-26067
-24153
-16896
539
16995
20311
20351
23743
15961
-2785
-11372
-9956
-14684
-20703
-17058
-8838
679
11859
14802
8169
7269
15295
21207
24438
28563
27055
14997
-2952
-18616
-23806
-20056
-20489
-27337
-25988
-12202
2579
12733
19373
19760
16094
17853
25222
25920
13119
-5590
-17928
-20395
-19927
-23451
-27842
-22422
-3083
17822
24028
16606
7889
1698
-2072
2043
9498
5933
-8328
-19513
-23677
-19611
-3887
14856
22339
23497
22108
8679
-17191
-31209
-31170
-22721
-1992
19609
29972
28199
22810
10786
-5857
-17530
-23583
-27861
-22136
-4731
11224
18578
21175
19512
15665
14158
11091
4221
4270
11855
9519
-5978
-17418
-20164
-25019
-30297
-23968
-7130
7696
15716
22431
29274
25835
5949
-15673
-21592
-19387
-24642
-29759
-19451
-658
11224
15915
19393
21214
20762
20222
20726
21647
18662
6198
-10301
-17869
-16835
-19318
-25953
-25645
-15756
-4216
4500
12284
19792
24182
24780
25226
25337
17400
-179
-15056
-18257
-17360
-21265
-25138
-19569
-4521
10823
17079
13616
8693
8665
10546
8190
386
-9539
-17453
-19124
-11382
3324
16319
21788
20852
12898
-3782
-19971
-24896
-24101
-23277
-11458
12197
25970
22914
17951
10323
-9043
-23947
-20377
-15621
-17824
-7082
16014
25574
19339
14452
9659
-79
-5579
-4849
-4648
1070
13159
13159
-4192
-17761
-18208
-15124
-11118
-851
10999
21556
30046
31562
21850
3798
-10006
-21006
-29416
-31604
-28032
-20890
-8929
7969
20866
23350
21919
23535
24028
19716
16638
16819
10891
-4940
-20806
-27984
-27693
-24662
-22881
-21379
-12407
5349
18940
21012
20905
25099
27937
26406
21072
8455
-9283
-21119
-24204
-24734
-23478
-19194
-15633
-11753
-2134
10430
20385
28484
30986
18742
-3881
-20216
-23227
-18137
-8740
4835
19612
27618
21103
2892
-14387
-24349
-28995
-24325
-6299
13274
21692
23588
23357
13203
-5276
-17363
-20468
-23023
-21869
-8922
10102
23951
28733
23537
9430
-6191
-16543
-20922
-18342
-7955
3952
10008
10559
7585
-318
-10393
-14513
-9614
-155
9882
19579
26592
26096
15659
-480
-14698
-23687
-28379
-27220
-18044
-5171
5093
12625
18980
22237
22502
22760
21913
16855
8583
-1185
-11541
-18179
-19141
-20458
-23960
-21632
-12136
-4307
1053
10425
20097
22276
20691
21067
19575
13800
8756
5431
-1095
-11255
-20248
-25116
-26187
-23997
-16762
-2683
13043
20208
16531
9088
2083
-4523
-7535
-4444
929
4647
6141
3919
-2310
-8315
-11352
-12538
-10810
-4036
5405
13874
19584
18876
8921
-5192
-15505
-20517
-22276
-19756
-10749
3823
19253
28739
28067
19465
8026
-3746
-14453
-20780
-20397
-15217
-8576
-1393
6204
11754
12585
9595
5619
2131
164
716
2191
1662
-1073
-4814
-9846
-15717
-19863
-20348
-16391
-7770
2821
10992
16145
20420
23149
22433
19067
14160
7353
-610
-8492
-16462
-23379
-26321
-25249
-22645
-18483
-11427
-3004
4312
10284
15299
18888
20969
21972
21599
18896
13326
5456
-3294
-11470
-17715
-20594
-19608
-16044
-11803
-8071
-5332
-3268
-622
3693
9548
15846
20862
22470
19289
11795
2024
-7336
-13620
-15065
-11705
-5270
1775
6966
8364
5283
-1261
-9054
-15584
-18719
-17259
-11356
-2490
7000
14641
18597
18157
13760
6752
-1053
-7957
-12654
-14275
-12701
-8900
-4452
-614
2007
3237
3250
2590
1828
1157
382
-760
-2328
-4042
-5358
-5830
-5488
-4758
-3974
-3047
-1608
696
4069
8414
13008
16353
16826
13807
8077
1125
-5702
-11509
-15774
-18254
-18860
-17645
-14953
-11304
-6920
-1784
3583
7945
10438
11373
11631
11682
11460
10616
8682
5498
1622
-2058
-5010
-7048
-8213
-9090
-10558
-12616
-14090
-13844
-11662
-7791
-2537
3446
9146
13542
15779
15517
13492
10925
8129
4637
822
-1867
-2558
-1865
-1175
-1832
-4525
-8496
-11812
-13052
-11976
-8563
-3074
2763
6592
7796
7530
6717
5690
5086
5205
5250
4635
3863
3140
1821
-51
-1804
-3953
-7368
-10671
-11328
-9250
-6649
-4875
-3795
-3240
-2807
-1567
310
1436
1758
2803
4599
5314
4538
3929
4206
4422
4105
3490
2142
-275
-2730
-4229
-5213
-6184
-6811
-7362
-8738
-10330
-10186
-7798
-4510
-1187
2406
6088
9026
10714
11031
10108
8738
7702
6464
4033
1028
-874
-1432
-2122
-4102
-7073
-9701
-10423
-8573
-5233
-2176
-71
1290
1704
1017
262
683
2152
3695
4839
5474
5372
4622
3719
2841
1887
1004
44
-1899
-5051
-7733
-8058
-6324
-4442
-3524
-3152
-2503
-1353
-174
290
-110
-528
11
1434
2948
4234
5539
6590
6384
4394
1493
-864
-2075
-2563
-2773
-2680
-2288
-1914
-1807
-1881
-1904
-1602
-827
45
404
376
731
1498
1791
1487
1720
3031
4317
4392
3469
2498
2037
1967
1505
-351
-3472
-6161
-7001
-6417
-5491
-4334
-2699
-1072
60
1160
2783
4467
5174
4323
2153
-330
-1814
-1779
-1092
-922
-1398
-1939
-2393
-3010
-3566
-3361
-2131
-466
816
1419
1588
1531
1089
127
-984
-1542
-1185
-277
434
573
512
838
1482
1831
1776
1961
2655
3067
2298
456
-1551
-2932
-3438
-3270
-2794
-2149
-1207
-82
780
1326
2176
3695
5215
5673
4683
2695
443
-1455
-2616
-2884
-2327
-1294
-409
-177
-528
-978
-1211
-1210
-916
-183
878
1694
1486
-15
-1990
-2967
-2285
-817
178
537
993
1934
2906
3118
2100
198
-1472
-1992
-1569
-1124
-1107
-1329
-1552
-1581
-1061
81
1265
1870
1980
2072
2352
2702
2886
2562
1465
-255
-2144
-3763
-4626
-4175
-2404
-340
672
277
-651
-992
-434
479
1142
1581
2298
3487
4503
4280
2343
-578
-3028
-4000
-3581
-2494
-1298
-192
782
1606
2146
1993
775
-1178
-2852
-3418
-2913
-2002
-1324
-977
-418
895
2621
3681
3480
2504
1544
841
207
-465
-1036
-1184
-711
1
81
-915
-2421
-3437
-3427
-2477
-969
666
2069
3031
3417
3108
2154
879
-297
-1047
-1143
-640
-86
-200
-1089
-2070
-2415
-2051
-1365
-570
393
1423
2024
1685
493
-736
-1081
-378
623
1039
658
-14
-378
-269
-15
-25
-311
-518
-443
-285
-208
14
611
1288
1446
889
108
-211
110
628
862
804
616
163
-691
-1545
-1766
-1237
-389
319
650
549
209
40
393
1307
2374
2863
2300
977
-381
-1349
-1807
-1713
-1297
-1023
-924
-528
223
667
333
-380
-661
-57
1113
2039
2307
2364
2611
2495
1282
-672
-2234
-2661
-1958
-605
715
1538
1896
2000
1933
1810
1638
1037
-173
-1316
-1627
-1268
-789
-238
386
589
96
-566
-701
-184
584
1176
1531
1832
1850
1011
-420
-1171
-770
-385
-960
-1733
-1624
-984
-915
-1533
-1758
-698
1093
2008
1261
-83
-590
-315
-323
-952
-1541
-1474
-753
171
786
909
652
-59
-1308
-2311
-1836
60
1703
1737
602
-384
-690
-803
-1173
-1482
-1152
-307
323
405
259
50
-378
-782
-521
416
1291
1597
1431
882
-63
-903
-764
416
1477
1308
260
-283
298
1149
1229
639
162
125
412
1064
1961
2317
1471
41
-627
-189
401
368
18
-153
-420
-1132
-1743
-1376
-187
742
914
919
1256
1507
1212
785
806
972
654
82
-20
230
22
-617
-556
722
2035
1833
91
-1765
-2497
-1964
-718
496
926
295
-634
-694
209
910
627
17
-19
178
-298
-1247
-1452
-490
613
848
496
399
568
332
-389
-788
-244
862
1658
1738
1418
1285
1674
2320
2446
1463
-119
-820
333
2420
3155
1157
-2407
-4731
-3991
-1005
1753
2604
1916
1108
877
775
290
-317
-486
-185
177
509
1159
2178
2812
2030
-375
-3179
-4164
-1746
3092
6551
4819
-1853
-8352
-9052
-3321
3837
6764
4167
-815
-4385
-4961
-3068
22
2974
4685
4849
4063
2858
904
-2207
-5480
-6684
-4565
-501
2646
3253
2129
1047
773
858
914
1286
2313
3422
3422
1674
-1127
-3344
-3598
-1842
548
1901
1647
621
-34
-27
225
455
619
196
-1681
-4790
-7048
-6268
-2789
458
1105
75
384
3298
6484
6439
2429
-2409
-3853
-331
5694
9573
7828
676
-8005
-13296
-12612
-7220
-711
3974
6185
6723
6101
4060
667
-2739
-4227
-3014
-303
1801
2211
1563
1081
1042
755
-106
-718
-98
1376
2092
1037
-905
-1921
-1280
13
619
453
571
1630
2872
2837
1018
-1398
-2659
-2194
-1041
-481
-581
-429
382
1043
509
-1027
-2108
-1612
-106
742
26
-1515
-2450
-2036
-539
1238
2275
1798
294
-296
1433
4085
4420
1266
-2638
-3732
-1766
411
687
-211
-452
508
1819
2590
2615
2050
935
-664
-2106
-2300
-951
764
1596
1758
2031
2097
1402
868
1506
1966
225
-2623
-3368
-1502
179
125
-216
125
-115
-1498
-2157
-704
1426
2107
1313
570
733
1236
991
-248
-1360
-1181
-366
-531
-1494
-1510
-644
-1103
-3151
-3780
-1294
1697
2104
605
-455
-1070
-2437
-3544
-2146
1409
4037
3645
1122
-1417
-2629
-1859
1324
6372
10924
11892
7941
771
-6298
-10827
-12124
-10311
-5809
-88
4324
5784
5062
3891
2263
-1329
-6514
-9540
-6691
1361
10006
15017
15112
10976
4173
-2597
-6558
-7368
-7173
-7336
-6626
-3657
435
3114
3418
2658
2592
3585
4356
3355
591
-2176
-3443
-3536
-3657
-4184
-4649
-4463
-2742
1340
6748
10211
9294
5214
1232
-1108
-2585
-3675
-3338
-953
1937
3006
1834
162
-642
-1212
-2599
-4104
-4123
-2730
-1697
-1780
-1570
394
3596
6236
7079
5999
3465
363
-1978
-2347
-781
1041
1334
507
940
3535
5533
3323
-3248
-10883
-16212
-17466
-14126
-7567
-1333
2249
5380
11655
19671
23085
18017
7562
-2372
-9270
-14229
-17883
-18767
-15661
-9588
-2687
3870
9808
14270
16024
15392
14458
14353
13271
8464
-152
-9507
-16347
-19681
-20001
-17273
-11028
-2252
6324
12498
16035
17289
16077
13084
10265
8152
4980
431
-2860
-4227
-7446
-14074
-18285
-14124
-4908
849
652
-974
-666
1018
3758
8352
13704
17121
17018
12758
4160
-6456
-14816
-19140
-20496
-18054
-9560
2518
11667
15198
14993
10470
-920
-15546
-24625
-24507
-18262
-7771
6527
19030
22743
19815
18128
17567
10338
-4544
-17820
-22722
-21890
-19569
-14816
-5122
8375
20853
26366
21764
10532
408
-4513
-5714
-3989
2143
10039
12582
7531
578
-3823
-7679
-12566
-14821
-11565
-5501
22
5599
12151
17352
18891
17662
14781
8489
-2546
-14504
-20793
-19882
-17516
-18564
-19295
-12486
967
12110
16347
18553
23153
26321
22677
14085
6698
2831
-319
-6191
-15176
-23721
-27124
-24675
-19965
-14534
-5818
6052
15650
19952
21482
20222
11377
-4099
-16321
-18921
-15255
-8369
3641
17874
24950
22633
18898
16671
8625
-7426
-21114
-24115
-21089
-19963
-20480
-17467
-8579
4181
15682
20551
19038
17106
16992
13750
5534
-993
-1400
-721
-3744
-7130
-7495
-8078
-11145
-12645
-10169
-7742
-7798
-6297
8
8621
16382
22737
26035
22891
13101
872
-9399
-16085
-20314
-24242
-26684
-21316
-4851
14341
24003
23748
23592
26927
26062
16490
4894
-1027
-2669
-6390
-14447
-23060
-27035
-25092
-20809
-17051
-11028
966
15695
25901
29338
28026
21246
7874
-6812
-15793
-19247
-20323
-16190
-3307
12487
21529
22480
19592
12524
-844
-15410
-22975
-23269
-22459
-22377
-18308
-7029
7531
17185
17141
11335
8505
11580
14734
13349
10658
10009
7448
-1401
-12970
-20782
-23665
-23345
-19148
-10639
-1126
5717
9353
10814
11598
14255
19640
24208
23883
18521
9566
-2237
-13689
-20148
-22906
-27446
-31237
-23937
-4447
13771
20568
21058
23233
24907
20893
13693
8794
5873
1075
-6540
-14806
-21224
-24301
-24710
-24230
-21468
-12157
3555
18871
28013
30569
26509
14651
-1321
-13539
-19164
-21126
-18854
-8147
8237
20398
23968
23272
20090
10027
-6606
-20348
-24208
-22479
-22552
-23115
-16514
-1030
14709
21271
18983
15424
14375
13004
9893
8350
9173
7322
-167
-9171
-15204
-19095
-22398
-23094
-19285
-12240
-3901
4254
10123
13614
18311
25226
28709
24366
15709
6955
-3408
-15265
-22293
-22558
-23408
-27226
-23862
-7264
11893
21102
22631
24548
25807
21451
13783
8036
3779
-1564
-7002
-11304
-15869
-20451
-22133
-20373
-17036
-11286
-1013
11404
20768
24588
22142
12309
-2334
-14293
-19239
-19813
-17534
-8623
6915
20389
24907
23332
19840
11629
-3620
-19020
-25428
-22909
-18414
-14779
-8365
2767
13819
18827
17912
15272
12460
8779
6391
8319
11661
9462
142
-10637
-18161
-22918
-25623
-24102
-17647
-9181
-834
7498
14095
16368
16288
17639
18883
16222
10510
3701
-5549
-15431
-19022
-15996
-15283
-18899
-15807
-45
17440
24134
22289
20586
19318
14452
8260
4943
2386
-1999
-4869
-4802
-7325
-14902
-22062
-24846
-23989
-17950
-5170
8513
16525
20903
24575
22091
9051
-7045
-15803
-17139
-16300
-12232
-1405
11564
18546
19654
18855
12768
-2555
-19352
-26849
-25831
-22121
-14804
-2560
8625
13843
15859
17046
14190
6167
-800
-438
4954
7625
4744
165
-4149
-10561
-18125
-21516
-19149
-14002
-7035
2172
10810
15804
18300
20722
22664
22024
17997
11773
4443
-4161
-12412
-16462
-17284
-20813
-25077
-18680
604
19354
26998
26580
23472
17967
11244
6246
1951
-4615
-11715
-14624
-13009
-11548
-13082
-16000
-19010
-21260
-17085
-2215
14247
19556
17504
19818
22541
13682
-2763
-13510
-17857
-22131
-22561
-12122
4206
15324
18648
18391
14501
3795
-9982
-18181
-19260
-17467
-11647
164
9583
8807
5373
8220
10676
4936
-1040
2449
10342
13253
11556
9446
5109
-4946
-16985
-22983
-21633
-18431
-13889
-2965
11596
19875
20863
22418
25730
25346
20941
15135
5866
-8042
-20716
-26321
-26640
-26888
-26621
-18787
-426
19252
28350
25902
18375
9969
4072
3795
5274
1964
-3809
-5759
-5551
-8162
-12863
-17593
-22825
-25539
-19066
-3110
13125
21360
23607
25856
24679
11184
-10587
-24890
-26452
-23319
-17694
-5092
10033
18706
22012
23997
19446
3674
-14933
-23570
-19844
-11260
-3940
2287
7571
8170
4020
1642
2897
2011
-674
3076
13276
19473
15947
5860
-6649
-18022
-24369
-24824
-20806
-12577
-1620
7880
13537
16503
18765
21553
23676
21597
14714
6359
-2664
-13490
-22730
-26583
-27085
-25168
-16259
-459
13801
20931
22975
22784
20945
18062
14862
11270
6258
-929
-7654
-10013
-10760
-16374
-24160
-24407
-15592
-4387
6315
17057
24737
25099
17419
4085
-9898
-19461
-24176
-25127
-19308
-5170
11099
22185
26283
23592
13991
-121
-13802
-22006
-21984
-16289
-10403
-5509
269
4717
4480
1703
-27
-374
1714
8337
16708
20086
14622
2227
-10903
-19354
-23932
-27266
-25713
-15418
-2041
6900
12495
18016
21777
22448
21673
19667
15738
10338
2757
-7273
-16249
-21637
-25013
-25432
-18124
-3387
11575
20915
24574
25849
26892
25380
18095
7905
539
-4180
-9660
-15020
-18124
-20118
-20991
-17499
-8930
1007
9193
15743
20729
20308
10050
-6123
-17612
-21172
-22156
-19470
-6286
12704
24360
26456
25179
19147
4156
-13965
-25684
-28875
-25744
-17752
-7588
911
6193
9141
10914
11586
10481
8659
9149
12217
13608
9741
1149
-9291
-18210
-23520
-25797
-24969
-18021
-4824
8287
15788
18746
20459
21675
21636
19992
16707
10527
-913
-15703
-25562
-26478
-25307
-26335
-21645
-6087
10977
19751
22731
25541
27457
25825
20497
12413
3041
-6024
-14255
-20779
-24017
-24612
-24185
-21007
-12566
-779
10784
21141
28167
25935
12310
-4705
-14841
-17032
-16200
-11912
-441
14078
22800
24478
22491
14770
-74
-14165
-20435
-22026
-22518
-18761
-9902
-1314
4031
8036
11605
13770
14338
13665
12837
13311
13030
7031
-4670
-15295
-19908
-20337
-19836
-17611
-10964
-895
7262
10068
10350
12421
15956
18683
21009
22278
16740
992
-17185
-26069
-25397
-24932
-27094
-22979
-8732
7078
17038
23121
27619
28226
24605
18972
10639
-1123
-12187
-18508
-21161
-22590
-23127
-21876
-16620
-5765
7011
15972
21192
24832
22550
9960
-6293
-15843
-18129
-17624
-12609
-332
13623
21815
23985
21667
12624
-1900
-13957
-19296
-21774
-23549
-21136
-14116
-7767
-4752
-1932
3664
11202
17936
21545
21665
19647
15362
6635
-5600
-15552
-19326
-19410
-19284
-17733
-11945
-3312
3384
6042
7793
12077
17513
21355
24986
29006
26145
10114
-10828
-22245
-23496
-25055
-28560
-25517
-13857
-395
10999
20551
26036
26410
26120
26697
21823
8243
-7162
-17012
-21503
-23408
-23174
-20646
-15347
-6056
5552
14625
19307
21402
19918
11706
-1141
-12224
-18098
-18209
-11346
1304
13969
21827
23735
18259
4969
-9882
-18039
-19489
-19996
-20548
-17662
-11560
-6081
-2322
1898
7840
14299
18889
19999
18467
16010
11749
3654
-6567
-14703
-19918
-24241
-26808
-23950
-15000
-3905
5072
10976
15380
19151
21347
22267
24385
26402
20804
4280
-14105
-23604
-25213
-25476
-24064
-17855
-9744
-3203
4203
13612
20210
22291
24334
26066
20308
5965
-8415
-16960
-21696
-24552
-23940
-19270
-11384
-447
11480
19757
22478
21396
16391
5700
-8010
-18450
-22246
-19596
-10941
2112
15214
24119
26703
21677
9559
-5015
-16207
-22015
-23690
-21966
-16726
-9009
-1351
3678
5636
7068
10442
14592
17016
18098
18748
16129
7394
-4274
-12954
-17379
-19986
-20921
-18012
-11345
-3942
1839
6423
11298
16076
18753
19645
21822
24630
21101
7449
-9180
-19240
-22682
-25095
-26796
-23822
-15710
-5399
4942
13296
17613
19413
22296
25148
22458
12159
-1802
-14220
-22028
-25081
-26070
-26441
-22113
-8913
8377
19955
23046
22023
18136
8375
-5858
-17453
-21673
-19483
-12824
-2064
10917
21187
24439
20757
13254
4004
-6578
-16782
-23178
-24149
-21140
-15618
-7819
679
6646
8831
9167
9549
10099
10943
12736
14466
13031
6358
-3950
-13768
-19899
-21857
-20301
-15096
-6700
1712
6804
9468
12935
16767
17486
15266
14234
15005
12641
3980
-7765
-17389
-22825
-24713
-24183
-22304
-19502
-14710
-6463
4560
14858
20973
23207
24876
26532
23438
12111
-2939
-13678
-18218
-20874
-23458
-22260
-14358
-2251
9231
17284
20789
18395
9587
-2998
-14247
-19755
-17747
-8949
3479
14513
20372
21463
20204
16272
7110
-6387
-18345
-24020
-24656
-23659
-20306
-11124
3084
15680
20891
19338
15390
11536
7637
3829
1151
-493
-2736
-6660
-11479
-15278
-16135
-13013
-6917
-999
2108
3163
4978
7987
9233
6756
2933
1437
2227
1953
-1306
-6169
-10639
-14028
-15613
-14020
-9638
-5753
-5042
-5826
-3972
1767
8378
12853
15773
19383
23251
23555
16942
4413
-8946
-18051
-21745
-22801
-23902
-23900
-18823
-6875
8305
20131
24450
21782
14910
6093
-2683
-8433
-8452
-3156
3854
9308
12800
14965
14399
8602
-1870
-12315
-18349
-20350
-21724
-23324
-21805
-14096
-1843
9975
17915
22092
23776
22640
17250
7668
-3118
-10725
-12574
-9870
-6147
-3717
-2122
-403
366
-1556
-5173
-6925
-5175
-2760
-3533
-7205
-9424
-6893
-1038
3745
4577
2462
845
2142
5352
7061
5046
478
-3906
-6944
-8971
-9233
-5661
2062
11096
18149
22031
22279
17281
6420
-6818
-16869
-21544
-23149
-23671
-21428
-14057
-2986
7093
12432
12503
9039
4554
1376
391
618
1011
2348
5993
11129
14898
15323
12479
6755
-1871
-11929
-19962
-23640
-24073
-23249
-20301
-12604
-414
11810
19415
21533
20403
17899
13879
7599
-25
-6139
-8278
-6945
-5021
-4152
-2941
69
3018
2769
-193
-2005
-1180
-836
-3402
-6140
-5133
-1726
-887
-3618
-5109
-1463
5040
9140
8523
4656
-177
-4278
-6231
-5583
-3346
-314
4188
10198
15006
15613
12590
8816
4690
-2165
-11852
-20037
-22554
-19828
-14880
-9151
-2789
2568
4469
2913
468
-1014
-1687
-1509
915
6385
13435
19516
22789
22308
17740
9774
-18
-10188
-19400
-25592
-26908
-24021
-19556
-14274
-6053
5673
16694
21920
21084
17723
13620
7896
1294
-2860
-3265
-2705
-3498
-3831
-1246
2681
4390
3411
1963
330
-3500
-9333
-13435
-13059
-9756
-6783
-5224
-4138
-2765
-887
1650
4125
4580
1980
-1896
-4179
-3932
-2216
181
3325
6867
9894
12115
13679
13711
10457
3389
-5698
-14050
-19723
-21969
-20838
-17048
-11856
-6484
-1812
1319
2280
1823
2194
4581
7071
7268
6635
9297
16109
23057
26419
25829
21043
10403
-4493
-16924
-22086
-23048
-25508
-28933
-27362
-17686
-3277
10058
18657
21886
21171
18555
14862
9402
2294
-3755
-5552
-3266
-776
-1339
-3776
-4238
-1331
2278
3448
1610
-2266
-7143
-11167
-12125
-10338
-8789
-8795
-8032
-4428
576
4325
6013
5880
3804
287
-3123
-5455
-6492
-5128
-28
7556
14132
17711
18938
17915
12664
2455
-9143
-17003
-19963
-21247
-22611
-20723
-11980
753
9943
11591
8303
4479
2320
2677
5726
9815
12832
15270
19216
24263
26978
24218
15243
1959
-11126
-19370
-22506
-24479
-27101
-26668
-18852
-4615
10235
19602
21156
18046
15848
15877
13686
6557
-1267
-4625
-4794
-6065
-8392
-8511
-5836
-2636
-189
1820
3609
4979
5178
2716
-2241
-6052
-5562
-2943
-2763
-5357
-7097
-6102
-3693
-1181
844
661
-3425
-9333
-11028
-4052
8779
19109
22285
22666
25655
26903
17148
-2318
-18350
-22686
-21176
-22349
-24954
-21960
-10792
4828
18549
24117
18994
7342
-3659
-10077
-10994
-5346
5788
16756
22840
25506
27116
24356
13262
-2222
-13450
-17651
-19853
-24312
-28128
-24521
-10878
7329
20711
23792
18398
10288
4381
2705
4278
6405
7459
7602
5982
462
-7636
-12514
-11136
-7554
-6222
-5280
-787
6163
11101
12100
10435
7634
4504
1303
-2431
-6885
-11078
-14182
-15941
-14811
-9320
-2856
-1809
-6034
-6624
2798
17131
26207
26654
23487
21629
19005
9351
-7776
-22615
-25646
-20649
-19217
-22513
-19035
-3001
15964
25856
25245
18707
8499
-3932
-14807
-20474
-19249
-10816
1926
12905
19374
24044
26372
19466
2295
-13737
-18852
-17495
-18366
-20048
-15824
-5782
4594
12209
15715
12936
5057
-1578
-2278
1745
7819
14546
18559
15169
4781
-6408
-13665
-17384
-18984
-17566
-11865
-2654
7662
16126
19885
17691
11536
5776
3277
2312
-1207
-8260
-15768
-21044
-23573
-22239
-15812
-7277
-1948
276
4657
12552
19336
22183
23224
23436
19428
8758
-5874
-18929
-25581
-24625
-20315
-17929
-15965
-7551
8347
22807
27895
25269
19166
9041
-5330
-18549
-23995
-19765
-8299
6039
17757
23730
25657
23612
12889
-5564
-20483
-23730
-20337
-18081
-15356
-8192
162
6137
11343
14691
11275
2642
-2451
149
6195
12182
17647
18232
9612
-3558
-13487
-18980
-22071
-21092
-14093
-5093
1339
7409
15497
21137
19487
12635
6779
4380
1672
-4801
-13116
-19406
-22596
-24067
-23185
-17171
-7859
-1006
2758
7387
13449
18135
20634
21787
19850
13172
4866
-2926
-12697
-22711
-25848
-21578
-17139
-13983
-4776
11470
23912
25942
22748
18311
9360
-4709
-16712
-19731
-14014
-3295
9284
19855
25387
26002
21435
9783
-6662
-19333
-22319
-20000
-19125
-17862
-10960
-359
7124
8965
7984
6619
5560
5668
6476
6685
7804
11463
13838
8760
-3740
-16933
-25225
-26819
-21077
-10361
-120
7394
13952
19164
19545
15053
10678
8529
5570
811
-4026
-8947
-14281
-18794
-21024
-19907
-14637
-6081
1199
3605
5140
10702
17436
21155
22508
22260
17970
7764
-5658
-17434
-24115
-23551
-18551
-16356
-15967
-7963
8254
21484
24524
21657
17474
8939
-4290
-14905
-18602
-16030
-7598
3965
13873
20688
25029
23505
10884
-8046
-20134
-22673
-24157
-26428
-23037
-11821
923
7812
8062
5343
3156
4017
6645
8010
9641
13286
15187
11106
2021
-7163
-14069
-20438
-24948
-23002
-14374
-3297
6344
13648
19502
22099
18993
12769
7935
5616
3537
-847
-6562
-10904
-13816
-16398
-18402
-17679
-11581
-2183
4478
6688
8269
12173
16871
19304
19647
19183
15685
6308
-7565
-19719
-23304
-19353
-16849
-19280
-18261
-5852
12796
25764
28858
25072
15527
1426
-11778
-19407
-20474
-14656
-3324
8032
15148
19975
23318
18866
4327
-10402
-16660
-18335
-21446
-23186
-18421
-8392
1879
8507
9274
5375
2087
2678
5329
9105
15211
20256
17859
7978
-3099
-11177
-15973
-17295
-15495
-13081
-10562
-5783
401
4660
7527
10830
12532
10584
8101
7624
5830
-318
-7098
-11233
-15037
-20008
-22282
-18875
-11293
-2763
5294
11429
14018
13746
14032
16543
19649
19439
13553
3368
-7109
-14450
-17234
-17946
-20590
-24282
-21480
-6908
13658
28790
31601
31003
22925
7583
-6858
-16106
-19634
-19474
-13204
-587
13757
23407
25731
19048
4620
-11579
-21536
-23498
-21129
-17388
-11376
-3338
3762
6623
5389
2837
1660
2427
5245
9983
15100
17413
15134
9035
710
-8195
-14977
-18163
-19005
-18169
-13914
-6239
1155
5744
8852
11203
11426
10155
9104
7155
3069
-748
-2122
-3054
-6182
-11336
-17950
-23980
-22589
-9741
6714
15900
17526
17591
16773
13364
11147
13079
13663
7795
-573
-5845
-8622
-11669
-15416
-19848
-23820
-21418
-7980
9860
20130
20573
18059
15116
7439
-4711
-13091
-13225
-10211
-8419
-4260
6059
18094
23341
18032
4298
-12512
-24709
-26833
-21563
-15273
-9028
-1104
4714
3547
-51
2221
8345
10166
8400
10514
16683
19610
15805
7541
-2843
-12688
-18148
-19288
-19564
-17865
-10042
805
6281
5549
5343
7713
9074
9766
13133
16922
15460
8613
893
-5714
-11537
-15693
-18196
-20765
-21549
-14919
-606
12593
16750
13358
8130
3599
1370
4662
12781
18247
14933
5142
-5412
-14288
-20302
-21768
-20198
-19038
-16626
-7622
6849
18168
21213
18645
13378
5234
-4185
-10730
-12540
-10719
-5673
2722
11897
17520
16923
9547
-2993
-15321
-20549
-16739
-9023
-3761
-2594
-3390
-4269
-4587
-3807
-1206
3418
8922
13109
14776
15040
15092
13143
6245
-4645
-14432
-19384
-19972
-17582
-11803
-2846
5725
9222
6414
758
-2694
-1296
3747
9306
13353
15451
14576
8846
-975
-10057
-14609
-16825
-20888
-25146
-23130
-12790
-121
8031
11095
12654
14222
14230
12163
10508
11390
12860
10629
3414
-5397
-12098
-16791
-21684
-26258
-26242
-18204
-4409
8366
15596
18997
21893
22513
16064
3046
-9541
-16262
-17587
-14944
-7218
4570
14044
15194
8643
-510
-8130
-12184
-11973
-8917
-5758
-3510
-1582
-843
-2711
-5181
-4289
130
4652
8098
12164
16243
16985
13557
8297
1960
-6450
-14754
-17913
-14544
-8761
-4644
-2578
-1699
-2184
-3848
-4916
-3232
2197
10328
17751
20549
17793
12004
5544
-1409
-8485
-13528
-15361
-16046
-18126
-20507
-18907
-10491
2603
14577
20962
21986
20442
17249
11381
3761
-2106
-4364
-4873
-6066
-8420
-11900
-16765
-21465
-22319
-16963
-6578
5689
16462
22429
21840
16258
8801
815
-7528
-14185
-15925
-12098
-5253
1634
6351
6945
3088
-2472
-6435
-8312
-9010
-7399
-1864
5184
8128
4425
-2483
-7428
-8444
-6470
-2276
4194
11927
17925
18990
14372
6642
-296
-4356
-6398
-8093
-9294
-8615
-6343
-4946
-5842
-7248
-6727
-4437
-1856
1571
7621
15313
20633
20949
17506
12794
7423
643
-7467
-15177
-19860
-19883
-16762
-14577
-15390
-15903
-10815
784
14200
23698
26202
21299
10682
-1589
-10396
-12525
-8380
-1336
3984
3988
-1572
-9582
-16490
-20577
-20890
-15721
-4181
10998
23884
29169
25454
15218
2492
-9058
-16336
-16841
-10351
-679
6058
6207
1047
-5692
-11286
-14141
-12428
-4994
6170
15755
18380
12516
1630
-8549
-14180
-14656
-10509
-2088
8528
16349
16955
10918
3059
-2283
-3744
-1811
2136
5452
5044
-244
-8527
-16148
-19722
-17671
-11027
-2807
4049
8236
9858
9690
9010
9185
10547
12084
12529
11131
7139
-258
-10411
-20087
-24990
-22984
-15870
-8012
-3003
-1142
308
4461
11950
20030
24157
21090
11606
574
-6242
-6332
-1876
2597
3683
542
-5920
-14008
-21046
-23358
-18087
-5922
8442
19390
24114
23188
18142
9783
-682
-10105
-14527
-12454
-6554
-1684
-1134
-4627
-9341
-12186
-11223
-6007
2189
10312
14609
12793
5524
-4224
-13023
-18127
-17559
-10616
762
11679
16889
14777
8686
3814
2784
4372
6121
7052
7290
6020
1425
-6665
-15005
-18985
-16742
-10717
-4989
-1550
579
3237
7042
11359
15300
17967
18170
14977
9021
2642
-1950
-4610
-6857
-9513
-11295
-10220
-6142
-1382
1326
1221
-170
-637
1082
4835
9321
12527
12541
8865
3251
-1266
-2781
-2108
-1869
-3890
-7562
-10648
-11410
-9797
-6870
-3573
-297
2675
4782
5456
4698
3247
2143
2101
3147
4664
5731
5537
3718
537
-3130
-6056
-7237
-6572
-5054
-4045
-4073
-4359
-3720
-1964
-103
947
1636
3264
6195
8962
9633
7979
5869
5337
6469
7447
6487
3429
-515
-4057
-6533
-7721
-7617
-6602
-5440
-4670
-4098
-3192
-1911
-725
281
1829
4454
7290
8525
7371
5172
4045
4595
5521
5495
4740
4170
3456
996
-3849
-9150
-11875
-10939
-8163
-6027
-5061
-3964
-1907
218
1152
1153
1823
4091
7011
8792
8561
6800
4392
1929
-49
-862
-302
793
1184
533
-355
-805
-1282
-2615
-4391
-4894
-3057
-85
1492
463
-1792
-2863
-1837
26
946
479
-373
-459
452
1742
2616
2633
1862
822
140
-28
-281
-1438
-3572
-5724
-6721
-6246
-4956
-3629
-2401
-890
1136
3422
5357
6253
5562
3263
271
-1802
-1798
-106
1582
1812
644
-700
-1244
-1060
-735
-459
43
806
1317
1088
327
-256
-227
200
632
1046
1720
2707
3643
4107
4006
3533
2855
2037
1196
546
195
-17
-404
-1152
-2173
-3134
-3548
-2923
-1144
1150
2749
2763
1466
85
-385
-94
38
-499
-1201
-1159
-184
879
960
-188
-1754
-2652
-2448
-1562
-717
-322
-326
-435
-392
-122
302
780
1247
1637
1865
1954
2063
2199
1993
1095
-121
-581
423
2241
3194
2127
-386
-2419
-2443
-793
707
727
-197
-449
721
2430
3222
2510
938
-318
-469
412
1553
2123
1900
1396
1295
1707
2044
1705
760
-149
-483
-236
119
-3
-795
-1770
-2161
-1720
-881
-185
154
211
311
936
2093
2881
2290
472
-1280
-1861
-1242
-206
368
-4
-1141
-2232
-2335
-964
1556
4083
5261
4591
2853
1214
131
-614
-1185
-1424
-1195
-642
-214
-434
-1344
-2234
-2297
-1433
-56
1474
2722
2934
1766
-27
-1265
-1570
-1460
-1464
-1555
-1302
-372
912
1607
1122
26
-524
-8
1222
2459
2907
1951
-147
-2098
-2651
-1673
-48
1156
1355
797
327
388
475
43
-470
-265
528
1008
716
-11
-784
-1558
-2302
-2708
-2282
-737
1490
3202
3381
2199
757
-142
-538
-713
-639
-233
243
314
-204
-962
-1310
-794
528
2062
2928
2532
1198
104
240
1338
2014
1098
-1121
-3037
-3291
-2224
-1408
-1631
-2072
-1812
-1277
-1377
-1920
-1883
-841
679
1989
2748
2973
2900
2617
1877
702
-187
-365
-558
-1498
-2437
-2092
-673
380
419
117
155
388
362
64
29
735
1723
1802
742
28
931
2540
2971
1939
820
606
1019
1330
1108
403
-332
-716
-861
-873
-324
867
1589
819
-654
-1081
-14
1351
1850
1392
594
30
-227
-500
-822
-741
-216
-6
-548
-1284
-1707
-2006
-2092
-1339
76
1016
1138
1289
1784
1916
1468
1004
595
-106
-690
-576
-374
-876
-1356
-726
314
301
-469
-374
970
2314
2726
2421
1783
841
-172
-724
-681
-558
-741
-902
-643
-291
-347
-387
334
1330
1342
427
-52
356
769
752
683
423
-321
-675
260
1480
1544
1129
1724
2698
2293
749
-75
438
1235
1344
498
-1174
-2815
-3140
-1983
-563
174
335
153
-295
-581
-359
43
423
1165
2158
2487
1811
784
-139
-906
-1070
-343
526
812
926
1309
1341
471
-702
-1337
-1399
-1206
-674
458
1836
2323
1139
-877
-2085
-2091
-1756
-1387
-598
240
385
210
534
1029
937
506
314
213
22
50
226
28
-409
-353
263
762
739
376
115
385
1106
1502
1115
486
91
-403
-1028
-1050
-421
-14
137
876
1885
1861
821
46
-78
-112
-13
551
1060
787
-156
-1344
-2524
-3309
-3300
-2402
-507
2169
4258
4396
3198
2211
1542
632
143
690
1266
1063
837
859
30
-1574
-2159
-1207
-237
-61
-33
57
-102
-30
697
1088
255
-794
-613
595
1621
1856
1283
42
-1262
-1785
-1381
-560
371
1174
1143
79
-741
-122
1038
1012
-41
-641
-588
-697
-682
149
943
661
334
1217
2086
1271
-216
-488
18
-104
-559
-556
-759
-1716
-2192
-1071
795
2067
2628
2793
2358
1287
224
-303
-513
-860
-1393
-1903
-2446
-3022
-2597
195
4263
5625
2056
-3083
-4322
-625
3996
5685
4090
894
-2511
-5119
-5553
-2889
1506
4384
3856
1178
-1277
-2005
-291
2770
3633
820
-1314
1193
4865
4852
3547
4628
4513
-323
-4687
-3468
-775
-818
46
3526
3825
-511
-2530
-439
-749
-4302
-4527
-1166
-118
-465
2867
6647
4508
-343
-1114
492
-214
-1562
-1233
-2086
-4910
-5035
-1270
1480
1104
484
496
-477
-1256
281
2372
2167
135
-1946
-3291
-2690
376
3030
2190
-548
-1567
-541
709
1724
2589
2570
1675
950
598
232
283
728
166
-1568
-2134
-195
2240
2790
1778
924
853
1081
1261
1626
2499
3531
3674
2513
1128
707
813
217
-963
-1309
-323
622
63
-1615
-2735
-2352
-1036
47
208
-218
-74
1128
1973
891
-1033
-1302
127
1012
568
-16
-407
-1181
-1759
-1314
-623
-405
236
1445
1400
-246
-909
729
2293
1516
-442
-1220
-450
535
593
-315
-1248
-1228
-325
555
807
542
252
331
597
565
594
1504
2561
2008
293
-92
1319
2307
1751
647
-568
-1985
-2149
206
3177
3745
1652
-1171
-3179
-3438
-1562
1134
2516
2122
1073
114
-471
-254
480
646
69
-324
-164
224
761
1135
629
-409
-691
-153
210
530
1343
1581
290
-933
-287
1254
1886
1801
1857
1724
1016
156
-551
-883
-122
1646
2775
2199
844
-108
-533
-460
151
741
751
341
-384
-1536
-2384
-1901
-298
1540
3180
3776
2175
-647
-1790
-321
1689
2451
1962
504
-1417
-2353
-1607
-447
79
484
872
353
-780
-1058
-319
330
649
996
852
-318
-1795
-2698
-2978
-2539
-1070
683
1200
109
-1310
-1533
-80
2002
2790
1502
-288
-554
719
2010
2252
1333
-290
-1667
-2025
-1629
-1045
-202
742
913
343
375
1257
1398
81
-1220
-1111
114
1475
2307
2320
1872
1611
1313
262
-952
-720
1215
3218
3617
2083
-406
-2199
-2267
-1221
-245
547
1601
2497
2465
1552
314
-797
-1133
-121
1673
2866
2787
1760
194
-1553
-2775
-2905
-2183
-1151
76
1546
2746
2722
1023
-1580
-3473
-3442
-1622
797
2558
2974
2057
399
-1182
-2093
-2042
-998
624
2022
2659
2676
2357
1613
475
-467
-732
-647
-718
-744
-199
766
1333
947
-56
-756
-476
495
1124
727
-353
-1326
-1742
-1568
-868
229
1319
1826
1497
714
118
-16
58
148
511
1303
1953
1591
148
-1305
-1606
-787
-67
-474
-1692
-2398
-1766
-336
865
1425
1456
1074
240
-823
-1282
-410
1213
2135
1626
339
-272
425
1356
1193
-101
-1406
-1601
-674
425
909
652
-67
-759
-965
-524
314
832
660
275
279
727
798
-209
-1668
-2198
-1080
697
1440
723
-233
-137
698
991
107
-1172
-1370
-422
282
21
-522
-207
1248
2740
2728
1316
162
314
1397
1843
659
-1237
-2283
-1448
835
2936
3703
3046
1730
679
353
531
605
440
199
0
-124
0
650
1421
1851
1743
968
139
-132
73
262
99
-136
-108
325
706
423
-199
-650
-783
-1000
-1695
-2261
-1996
-860
566
1583
1934
1714
1175
126
-1511
-2980
-3393
-2314
-563
546
525
-338
-1197
-1684
-1762
-1127
83
1359
1960
1616
946
698
1145
1577
1128
-266
-1748
-1948
-631
1296
2745
3099
2777
2211
1550
779
-261
-1215
-1455
-476
1357
2741
2594
849
-1251
-2626
-3180
-3107
-2705
-1644
411
2791
4282
3747
1482
-1146
-3091
-3983
-4104
-3169
-340
4266
8810
10779
9125
4578
-804
-5031
-7613
-8695
-8493
-6723
-3042
1377
4628
5288
3335
223
-2249
-2952
-2222
-620
1379
2775
3395
3416
2866
2387
2585
3112
2677
869
-1021
-1421
60
1990
2349
219
-2979
-4843
-4758
-3396
-2038
-1347
-394
1156
3000
4591
5480
6663
8266
8434
5991
1766
-2321
-4201
-3034
-1014
-910
-3088
-6265
-8425
-8488
-6943
-4581
-1595
2290
6171
8366
7733
4295
9
-3042
-3705
-2115
280
2890
5703
8345
9776
8341
3927
-2193
-8389
-12632
-13894
-12605
-9356
-4884
-548
3070
5529
5949
5333
4315
2528
1060
268
303
2062
4842
7013
7434
5568
1737
-2198
-3888
-3176
-1579
-444
-202
-541
-900
-717
-587
-1448
-3107
-4783
-5627
-5160
-2692
1968
7408
11680
12761
10164
5780
2427
1627
1174
-984
-3935
-6787
-7710
-5295
-2559
-2722
-4978
-7667
-9859
-10209
-8455
-4918
760
8018
14845
17733
14711
8088
1109
-3753
-5190
-3609
182
5101
9942
12698
11074
5343
-2603
-10901
-17369
-20615
-20980
-18229
-10780
24
9857
15723
16757
14011
9986
6289
2800
363
565
2397
4346
5429
4516
2814
1067
-2018
-6117
-9715
-11589
-10976
-7605
-2012
3380
5888
5332
3494
1582
-523
-3019
-4386
-2328
2214
6439
9019
9725
9565
8146
3865
-1537
-5601
-7699
-7382
-5613
-4798
-5242
-4795
-2990
-1160
-215
-1206
-3830
-5852
-5799
-3702
-106
4324
8827
12828
15236
14830
11791
7210
2722
-678
-2631
-1969
1030
4575
6646
4914
-889
-8984
-16266
-19541
-19740
-19064
-15790
-8246
1987
12284
19160
21233
21516
20506
15935
9424
4027
770
-628
-1274
-2154
-3956
-6964
-10740
-14213
-16287
-16745
-15825
-13289
-7884
234
7287
10313
10156
8481
5525
1081
-2918
-3179
775
6363
10989
12870
11860
9167
4029
-3333
-8947
-11088
-10450
-7835
-6355
-7251
-7691
-5760
-1536
2886
3952
1420
-1719
-3677
-3557
-1081
2655
7374
12797
16865
17557
14284
8674
3234
-1294
-4548
-5477
-4633
-3501
-1856
68
-490
-5480
-13213
-19383
-21491
-20649
-16660
-7953
3701
14148
19216
18579
18230
20893
20955
15733
8672
1725
-3787
-6111
-6528
-7369
-9712
-13292
-16430
-18097
-18084
-15985
-11844
-5373
3330
11450
15588
15095
11653
7707
4228
527
-1907
-567
3406
7044
8830
9204
9587
8919
4409
-2764
-8499
-11031
-10753
-9152
-8448
-9183
-9705
-6880
489
7181
8362
6443
3731
-723
-5091
-5811
-1765
5959
13884
17989
17422
13240
6529
-681
-6146
-9089
-10495
-10858
-8560
-3613
-145
-1854
-7868
-14235
-17973
-18994
-17696
-13219
-5437
4516
13909
18867
20429
23002
23932
17799
7512
-832
-5412
-6567
-6287
-7421
-9924
-12300
-14196
-15456
-16147
-16650
-16303
-12601
-2961
10361
20542
23992
21803
15128
6259
-732
-3934
-3826
-1595
1140
3735
6257
8033
8179
5673
147
-5901
-9015
-8771
-7500
-7278
-8129
-8616
-6670
-576
7287
11037
9080
4533
-958
-5721
-6929
-4730
31
7786
15412
18454
17234
13630
7251
-1730
-10403
-14641
-12688
-7087
-1405
2480
2541
-2681
-10425
-15787
-17168
-15979
-12910
-7163
2087
12539
18241
17887
17992
20494
18965
11778
4002
-2321
-7143
-8826
-8518
-10197
-14755
-19131
-20830
-20001
-17143
-12607
-7297
0
10133
18140
20226
19477
16885
10008
1222
-5271
-8246
-7014
-2748
1268
3923
5344
5230
3545
-861
-7215
-9771
-6011
-1403
-682
-2556
-4050
-3472
177
5890
9605
8552
4045
-2706
-10572
-15103
-13707
-8142
829
10977
17518
21063
22980
17954
5783
-4798
-10725
-14162
-12331
-3987
4204
6123
1838
-5839
-13979
-20069
-22671
-20697
-12696
409
12856
18865
19250
18799
19241
18258
13350
5662
-624
-4384
-8377
-12176
-12996
-12669
-14362
-17406
-20253
-20656
-15599
-7004
1173
9841
18992
24575
25498
22186
13529
2381
-6470
-12131
-13501
-9074
-2304
2386
4138
3250
1582
1877
2391
-604
-4591
-3713
927
2987
1195
-1541
-4074
-3670
2295
8095
6640
-784
-10556
-19663
-23000
-18700
-8310
7017
20819
25704
25857
26302
20170
4265
-10770
-17063
-18347
-17619
-11663
-1350
5017
2185
-7068
-16839
-21981
-21553
-18118
-9741
6065
20445
23543
20203
19145
19024
14412
4669
-4827
-8038
-6611
-6801
-9452
-11959
-13693
-14429
-14849
-16530
-17670
-14509
-5774
6239
15803
19732
22513
26360
24545
13815
843
-8277
-13076
-13640
-9523
-2958
2090
3891
2676
-578
-2104
361
1802
-978
-2715
-573
2764
6027
5609
-1825
-7209
-599
9806
9622
-1820
-14778
-21716
-22058
-17727
-7255
9548
24700
30062
28253
25825
20095
5060
-12566
-20520
-20983
-22319
-20209
-8949
3267
6220
-177
-10026
-17341
-20054
-19098
-12098
2854
18277
24123
20935
17491
17158
13765
3587
-7169
-12068
-11341
-7735
-5639
-8942
-14439
-16621
-16093
-15747
-16105
-15290
-8772
4062
14971
17775
16826
18075
20130
17525
8319
-3598
-12645
-15628
-13357
-9901
-6820
-2081
1612
-376
-3254
-392
4260
4889
3472
4204
7928
11287
8603
-725
-8870
-7500
1976
7622
665
-11985
-18050
-16674
-13915
-9997
-721
12836
22674
24832
25181
25978
19068
2634
-12138
-18244
-19975
-20454
-15675
-3984
6571
6811
-1898
-11773
-18686
-21531
-17962
-5800
11521
23150
22715
18940
20545
20398
10147
-4087
-11947
-11244
-6390
-3182
-5065
-11470
-18264
-19987
-16361
-14077
-15426
-12403
237
14391
19084
16249
16663
21585
21076
10698
-3648
-15402
-21320
-21042
-17327
-12690
-7854
-3936
-1564
-97
1316
4226
8594
11194
11548
13409
16775
15817
6329
-7288
-13717
-8116
-650
-2683
-11402
-17697
-19798
-19762
-14482
-576
15260
22522
22481
24392
27726
22184
4796
-13706
-22166
-22231
-20840
-15675
-2594
9904
10890
2867
-5635
-12722
-19255
-20291
-8973
10826
24176
23395
17508
16312
15796
7560
-5625
-12805
-9789
-2358
3368
4553
-626
-10015
-17482
-20523
-21049
-18602
-10336
2795
14698
20157
20603
21146
22936
21694
12587
-4145
-20817
-28201
-25022
-17804
-12138
-7914
-2692
2676
5083
5652
8236
11455
10946
8200
9061
14542
17957
12190
-739
-10613
-11422
-8172
-8295
-11806
-14827
-17211
-18514
-12205
4350
20115
23718
19770
19215
20614
13575
-3267
-18821
-24285
-22040
-16960
-8220
4682
15238
15787
6705
-4699
-13239
-19289
-22029
-15640
1933
21066
29361
26540
21947
18036
8067
-7773
-17604
-14230
-4397
2465
4245
1985
-4430
-12978
-19022
-20446
-18025
-11200
313
12281
19676
22924
25012
24937
19314
8314
-4460
-15580
-21902
-21079
-15279
-10170
-7984
-6281
-3960
-2353
-534
3465
7278
7419
6949
11919
20849
25137
19605
7182
-5355
-12107
-11441
-8405
-10376
-17800
-23387
-21374
-12275
852
13951
21280
21063
19510
21173
19542
7055
-10503
-20934
-22162
-20052
-14800
-2818
11252
17267
12898
4256
-4482
-13010
-18658
-16817
-7229
5275
15650
21611
23293
21308
14476
1503
-13312
-20411
-15026
-3071
6271
8934
4639
-5420
-15960
-20002
-17353
-13758
-10220
-2037
10479
20528
25470
28491
28392
19030
1241
-14923
-22356
-22857
-20103
-15246
-10422
-8651
-8845
-6746
-1333
4250
7619
9295
10964
14295
19965
25553
25878
17424
2290
-12474
-19924
-19368
-17254
-19364
-23142
-21732
-13851
-3799
6354
17019
25177
26927
24785
23589
20604
9478
-7115
-19040
-22398
-21835
-19590
-12289
203
11370
15459
12450
4997
-4251
-11519
-12577
-6562
2604
9849
13852
17222
20616
18847
7377
-8256
-16170
-12103
-3069
3364
5486
2781
-5422
-14915
-19205
-18335
-16567
-12274
-743
14125
22704
23647
23348
22314
14344
-742
-14903
-22606
-24589
-22014
-15552
-8880
-5751
-5165
-4330
-2729
304
6619
14484
18932
19444
20559
23105
21925
13775
1118
-12047
-22303
-26467
-24819
-21999
-20308
-16606
-9192
-814
7836
18589
27835
29449
26812
28119
28947
16531
-6780
-23082
-25085
-23466
-24332
-19511
-5109
8912
14359
14266
11926
5151
-4404
-9219
-6396
-38
7132
15314
22216
24239
20771
12259
-498
-11411
-12020
-3546
3259
3004
73
-2943
-8962
-17308
-22793
-23933
-21565
-12635
3186
16566
20398
20778
23726
21713
7653
-9515
-18228
-21113
-24061
-22134
-11324
-838
696
-1458
-256
1594
1905
5780
13669
17956
17699
20476
25191
20648
5109
-9945
-18150
-23763
-27921
-25790
-18176
-11643
-7272
-809
8301
17106
24120
28026
27966
27715
29677
25358
6342
-17246
-27531
-25460
-25563
-27598
-17944
2467
16941
19400
18310
15762
5984
-6910
-11473
-6974
-832
6493
17433
25934
25300
18905
11542
1180
-10912
-15174
-8658
-1881
-2453
-5338
-6476
-11085
-20566
-25777
-21000
-11514
-2462
6600
14218
17509
19229
21820
19296
7240
-7012
-15338
-19777
-23101
-20923
-12084
-4520
-3227
-3551
-1155
2564
7567
15648
22278
20856
15793
16820
20414
13997
-1556
-12684
-15809
-18923
-22217
-18392
-10130
-6905
-7151
-1429
10443
19983
23461
24196
25559
27679
27185
18868
2492
-13522
-21094
-22456
-24236
-24897
-17148
-1249
13844
22257
24457
19984
8016
-5656
-13020
-13611
-11094
-4902
6068
17411
23993
24575
18416
5564
-7992
-14218
-12658
-9200
-6937
-5119
-4964
-9399
-17166
-22293
-20511
-13126
-3668
6214
15925
23729
27415
25602
17942
5871
-7107
-17566
-23836
-25183
-21409
-13843
-5234
1267
3309
1825
1815
7105
14994
19585
19206
17078
15855
14341
9239
-682
-11917
-18696
-18965
-15831
-12262
-7854
-2586
880
1923
4412
10420
16125
18348
19748
22591
22957
16544
5357
-5544
-13584
-18323
-19711
-18168
-13747
-5726
4929
14654
20445
21394
16393
4376
-11050
-21432
-21481
-14127
-4455
6529
17578
23155
20363
13680
7265
150
-6918
-9355
-6801
-4311
-4446
-6308
-10465
-16873
-20801
-17391
-7868
2684
11385
18743
24829
26776
21830
11235
-1333
-12772
-20167
-22006
-20883
-19307
-14886
-6616
-327
324
456
4825
11322
17488
23026
24830
19399
9632
1717
-2670
-6707
-13078
-20463
-24877
-23950
-17673
-6353
6688
13416
10653
6324
8142
14056
19719
23950
24257
19075
12506
6712
-2340
-14090
-21406
-23386
-25001
-23808
-13110
3975
17040
22536
24506
23889
15513
-1085
-15927
-20274
-18462
-15729
-6264
13469
29567
29936
19305
7263
-2379
-8487
-9836
-9674
-8375
-2793
2492
-1396
-10197
-12870
-10651
-11057
-10547
-1449
12703
21900
23725
23166
21218
11826
-5761
-20137
-22903
-20896
-21360
-19144
-10821
-3782
-2025
-926
1590
4928
10555
15673
15565
15632
21706
24059
12942
-2341
-10138
-14771
-22642
-28452
-25984
-17872
-9402
-1216
9234
20620
25423
20625
15159
16754
19955
17097
9324
724
-6028
-8510
-9095
-13351
-19664
-22961
-24386
-22565
-9103
13088
27051
26516
20837
14566
4764
-6858
-16446
-23133
-24024
-16167
-2903
11163
23157
26329
15846
-279
-9626
-9716
-5329
-241
3850
6584
6529
92
-11240
-19265
-21189
-20810
-16050
-3339
10147
17238
21771
25127
20888
9900
-1251
-13424
-26052
-28692
-18654
-8052
-4375
-4442
-6591
-9193
-5240
6639
17111
20032
19937
22841
27222
25001
11426
-6938
-19787
-24974
-24686
-20249
-17103
-19028
-16153
33
18256
25381
26334
26979
22553
14178
10223
7917
415
-7224
-8823
-9741
-13897
-18107
-21973
-27698
-29964
-22126
-5422
11919
24256
30307
31738
27112
11309
-6732
-17415
-21687
-22485
-14887
3
11473
17238
22302
21396
8387
-6159
-9822
-5124
1552
7909
8092
-1310
-12124
-16755
-18675
-20598
-17821
-7614
6183
18403
25942
28878
27485
18632
1955
-13650
-20481
-20750
-17666
-11048
-5412
-5913
-9310
-11762
-14707
-14577
-4556
10792
20606
23229
22417
19213
15342
11104
1011
-15034
-25864
-25259
-20538
-19581
-22423
-24357
-18487
-2446
14746
22969
24157
24719
23568
16020
1333
-15826
-26085
-22663
-10388
117
3913
551
-9065
-19394
-24008
-21667
-11644
6162
22439
26877
24165
22845
17653
1994
-16304
-26399
-25929
-15757
97
11722
14679
15736
18169
14458
504
-14476
-17156
-4364
13040
20282
12106
-5398
-21833
-28225
-23751
-17488
-13876
-4138
14771
28717
28820
24130
20384
11333
-2451
-11411
-13480
-12327
-7742
-2830
-6020
-16044
-21269
-17771
-12267
-7349
1824
15895
26669
26825
18843
10194
4325
1943
3748
4760
-2511
-13246
-15365
-11507
-14167
-21495
-22025
-15621
-7540
4530
19762
28375
27603
24170
18041
3861
-13713
-24017
-24849
-20186
-10996
1073
7418
106
-15892
-26133
-22971
-10859
3786
16781
22025
17509
11734
10112
4683
-8778
-19339
-19367
-15227
-11295
-4783
910
-565
-4465
-2844
1288
2568
4553
11023
17639
19568
17267
10849
-1943
-18381
-28613
-26145
-15466
-3792
8257
20161
25071
19973
12127
7490
5344
7264
14542
17883
8394
-6397
-14695
-18367
-23799
-28061
-26006
-18299
-6346
8463
19471
20309
14640
11362
12575
13572
12214
10941
9565
3709
-6989
-16424
-20631
-20806
-16880
-8312
-196
2585
3476
6718
9877
12121
18032
26286
27577
18164
3915
-9422
-19555
-23780
-20656
-12861
-3803
4722
9566
6523
-3419
-11929
-11178
-2370
7031
13031
17143
20162
20010
14964
4691
-8932
-19245
-19014
-9670
79
5166
6763
5797
1455
-5236
-11388
-14074
-10694
-1188
9370
14012
10171
1068
-7935
-12827
-12080
-6350
2114
10100
14735
15136
12531
8930
6088
4850
4605
3871
1622
-2352
-7618
-12792
-15865
-15593
-12372
-8007
-4654
-3042
-1698
992
4581
7706
10257
12778
14916
15862
15050
11804
6073
-416
-5942
-11147
-16723
-19886
-17035
-9307
-1964
1188
290
-1984
-2210
1013
4619
4444
1735
2316
8476
15637
17922
13629
4825
-5026
-12360
-15143
-14024
-10384
-4364
2846
6897
4482
-1873
-6968
-8723
-7447
-2894
4071
10279
13631
14373
12208
6607
-114
-4546
-6161
-5932
-3318
1621
5574
5153
1119
-3097
-5533
-6239
-5442
-3479
-1287
946
3793
5916
4654
978
-256
3202
8407
11792
11938
8371
2243
-2814
-4210
-3185
-2147
-2027
-3321
-6373
-9754
-11011
-9528
-6795
-3886
-397
3780
7129
8058
6777
4763
3630
4669
7344
8483
5805
1276
-1783
-2841
-3045
-3012
-3483
-4967
-6228
-6041
-5347
-5201
-4804
-3448
-2023
-1637
-2396
-3308
-2520
1174
6595
10726
11134
8143
5189
5798
9438
11887
9553
1994
-8156
-16129
-18233
-15169
-10153
-5051
-896
554
-1436
-5421
-9119
-9801
-5043
4055
12422
15725
13705
8979
4802
3056
2773
1644
-1026
-4129
-6441
-7459
-7681
-7956
-7754
-5708
-2329
210
915
363
-548
-594
1107
3487
4642
4366
3717
3151
2473
1497
143
-1257
-2018
-1879
-1160
-262
491
1011
1447
1397
90
-1962
-3043
-2501
-1327
-587
-739
-1653
-2102
-513
2899
6031
7258
6848
6031
5512
5024
4003
2349
360
-1633
-3380
-4913
-6513
-7804
-7682
-5888
-3647
-2034
-812
721
2752
4810
5959
5524
4064
3062
3211
3554
2753
938
-377
-381
-37
-658
-2325
-4032
-4535
-3254
-1331
-1014
-2819
-4314
-2798
1509
5569
6242
3021
-1392
-3408
-1708
1855
4231
3971
2247
1085
1020
1265
1419
1636
1709
1151
-410
-3164
-6357
-8008
-6922
-4417
-2789
-2679
-2770
-1438
1534
4514
5490
4171
2258
1650
2570
3281
1974
-913
-3152
-3543
-2958
-2659
-3042
-3744
-3840
-2656
-931
-146
-549
-933
-219
1624
3726
4815
4081
1820
-890
-2961
-3824
-3503
-2117
386
3468
5613
5644
3898
1629
69
-34
908
1332
133
-2070
-3872
-4472
-3863
-2494
-1066
-161
137
181
352
753
1356
2307
3562
4301
3566
1535
-597
-1920
-2377
-2367
-2308
-2255
-1840
-868
179
634
354
-223
-463
90
1294
2258
1919
135
-1896
-2719
-2106
-997
-86
733
1605
2236
2228
1396
-61
-1406
-1747
-901
313
841
398
-319
-514
-222
-78
-323
-433
298
1960
3718
4442
3771
2308
843
-138
-448
-384
-683
-1672
-2713
-2903
-1997
-491
841
1424
1215
741
699
1261
1703
1160
-80
-710
-148
654
569
-270
-888
-790
-432
-431
-637
-307
842
2241
3159
3310
2724
1675
749
463
684
815
604
453
687
857
312
-668
-1045
-448
307
473
450
1062
2155
2570
1568
-253
-1688
-2149
-1884
-1319
-627
98
592
484
-256
-984
-742
668
2085
1959
199
-1441
-1360
-127
198
-1289
-3224
-3671
-2315
-485
514
424
-285
-961
-919
207
1902
2917
2335
465
-1435
-2203
-1594
-380
264
-168
-913
-716
528
1390
617
-1164
-2127
-1487
-249
405
554
839
1102
662
-248
-379
912
2593
3065
2036
727
268
449
272
-576
-1247
-818
459
1300
791
-625
-1783
-2138
-2116
-2158
-1973
-1107
95
688
331
-200
-55
518
519
-316
-966
-396
968
1612
776
-643
-1277
-855
-115
459
1022
1543
1572
1177
1291
2360
3248
2518
581
-590
-34
1032
1096
327
-213
-479
-1210
-2110
-1750
322
2569
3263
2521
1743
1554
1289
317
-1011
-1906
-2020
-1584
-1060
-827
-923
-952
-510
328
1172
1851
2358
2366
1539
384
-42
308
57
-1698
-3682
-3775
-1812
130
424
-262
-316
617
1603
1956
1775
1196
186
-795
-907
-80
592
219
-657
-740
351
1736
2559
2870
3028
2801
1711
80
-923
-593
341
486
-558
-1722
-1788
-774
300
802
1105
1798
2749
3235
2805
1742
693
47
-267
-472
-553
-364
-101
-300
-1000
-1225
-29
1934
2810
1876
632
734
1658
1615
290
-858
-1043
-1179
-1963
-2522
-2062
-1413
-1446
-1144
738
2846
2520
-38
-1492
-89
1766
1245
-717
-1268
-206
190
-694
-850
738
2320
2348
1824
2080
2257
1129
-138
342
1673
1199
-1080
-2065
-244
1890
1584
-244
-878
18
543
31
-216
375
649
-26
-564
-239
-182
-1462
-2954
-2838
-1366
-425
-705
-1011
-462
223
175
-218
-121
474
1059
1470
1637
1060
-420
-1758
-1656
-332
677
590
234
517
1051
1043
803
1237
2129
2118
692
-831
-953
-1
429
-253
-968
-693
151
695
1180
2348
3589
3182
888
-924
43
2856
4245
2702
273
-331
807
1359
128
-1475
-1451
367
2418
3268
2766
1674
737
159
-292
-795
-1120
-907
-261
303
534
664
765
440
-380
-822
-52
1333
1842
1078
282
471
989
660
-245
-366
703
1819
1962
1486
1147
767
-204
-1280
-1196
277
1690
1606
376
-387
102
974
1009
218
-271
310
1577
2605
2982
2907
2552
1797
692
-229
-419
-1
286
-67
-786
-1174
-937
-451
-186
-104
163
601
626
-125
-1097
-1348
-728
-22
276
703
1767
2671
2063
81
-1410
-1098
70
269
-618
-921
307
1848
1958
640
-491
-273
849
1673
1654
1242
1139
1521
1850
1457
456
-121
475
1531
1525
146
-1091
-725
669
1245
430
-364
105
1030
678
-1105
-2619
-2538
-1424
-602
-322
96
711
626
-559
-1927
-2382
-2022
-1684
-1515
-824
543
1555
1170
-245
-1321
-1272
-507
215
654
971
1183
1005
231
-889
-1667
-1404
-65
1390
1727
767
-328
-402
425
1111
1000
430
98
349
1172
2239
2706
1717
-370
-1755
-1015
984
1810
357
-1695
-1877
95
2046
2006
486
-331
702
2412
2704
971
-1199
-1761
-397
1362
1994
1417
557
-24
-495
-847
-514
518
1068
54
-1822
-2527
-1145
724
908
-300
-486
1224
2290
-137
-4598
-5668
-396
6788
8167
1881
-5271
-5545
509
4811
2024
-3774
-4756
553
5938
5756
1640
-444
1780
4602
3853
-107
-3651
-3913
-924
2930
4833
3426
-85
-2410
-1106
2254
3612
1570
-865
-189
3340
5911
4537
593
-2030
-1373
1356
3667
3725
1628
-724
-1659
-1122
-134
239
-132
-452
-604
-1405
-2464
-2087
-62
1649
1300
-595
-1672
-656
678
389
-329
478
1897
1653
-222
-998
1441
5059
5295
1374
-2134
-1546
1353
2089
-943
-4048
-2112
4090
7154
1848
-7545
-10699
-2361
9917
12006
-71
-13560
-13455
-464
9980
6225
-5491
-8936
986
11762
10351
-392
-7026
-2890
4824
5452
-1304
-6187
-3760
1355
2322
-1350
-4726
-3988
-657
900
-743
-3030
-3446
-1754
913
3069
3911
3904
3620
3274
3734
5555
7054
5581
920
-3397
-2867
2432
6186
3070
-3698
-6253
-2427
1794
479
-4238
-4985
176
4425
2091
-3038
-3426
1781
6130
4500
-610
-2963
-1052
1022
637
-132
1067
3188
3501
1324
-912
-872
277
-276
-2381
-2748
454
4163
2746
-4683
-10378
-5705
6592
12888
4457
-10213
-13725
-1155
12285
9908
-4367
-10846
-219
14083
13714
-576
-10445
-4365
8157
10729
1469
-6987
-5501
1561
4999
2912
126
-744
-1792
-3878
-4032
-843
1869
116
-3840
-3845
1652
6761
5494
-206
-2655
1789
8061
8678
2906
-2396
-1232
4041
5485
-344
-7624
-8216
-1851
3351
863
-6268
-9463
-5294
973
2792
15
-2583
-2028
337
2081
2518
1880
147
-1691
-1141
2622
6214
5492
1326
-978
1207
4023
2586
-1734
-3147
-312
1055
-3310
-8658
-6672
2379
8100
2825
-7665
-10648
-2453
7065
7334
61
-4204
-136
6712
8673
5677
3245
3780
4396
2846
1084
1163
1036
-2146
-6269
-5980
-653
3224
48
-6986
-9472
-4680
859
76
-5329
-7287
-1955
5557
7960
4600
1320
2670
6934
9230
7433
3571
509
-902
-1386
-1576
-1715
-2212
-3349
-4500
-4506
-3146
-1675
-1415
-2108
-2267
-1142
255
478
-379
-697
559
2344
2723
1475
745
2592
6262
8586
7325
3653
958
1379
3846
5360
3759
-578
-4982
-6244
-3132
1807
3456
-1286
-9492
-13959
-10304
-1986
3161
1530
-2548
-2443
2826
8049
8616
5520
2888
2639
3540
4364
5230
5563
3430
-1391
-5390
-4880
-1219
87
-3739
-8857
-9397
-4717
61
497
-2359
-4261
-3074
-234
2222
4056
5967
7798
8658
8262
7227
6067
4625
2651
528
-963
-1494
-1568
-1983
-2913
-3639
-3383
-2445
-2142
-3277
-4878
-5030
-3104
-640
345
-372
-1086
-117
2515
5268
6479
5592
3584
2439
3642
6515
8261
6413
1585
-2570
-2684
892
3968
2096
-5226
-13483
-16579
-12221
-4350
251
-1508
-5977
-6666
-1138
6597
10539
8811
4918
3546
5977
9498
10524
7882
3520
478
119
1097
932
-1501
-5116
-7946
-8802
-7618
-5056
-2404
-1217
-1966
-3019
-2016
1331
4613
5470
4286
3361
3973
5357
6343
6625
6099
4313
1545
-577
-877
-532
-1714
-4423
-6239
-5741
-4552
-4816
-5890
-5390
-3009
-1196
-1536
-2372
-1310
1266
2962
3052
3383
5314
7612
8374
7690
6886
5959
3745
795
-5
2908
6524
5500
-1897
-11228
-15920
-13495
-7340
-2811
-2392
-4515
-5957
-4563
-248
5282
9292
9575
6587
3860
4973
9527
13008
11548
6208
1430
-295
-669
-2290
-5098
-7339
-8622
-9850
-10565
-8931
-5104
-2358
-3008
-4704
-3158
1879
5997
5979
3916
3978
6839
9473
9578
7741
5277
2427
-283
-1074
808
2951
2017
-2086
-6024
-7161
-6225
-5429
-5592
-6122
-6514
-6410
-5020
-2075
968
2328
2547
4148
8123
12195
13407
11294
7634
4341
2920
4550
8298
9731
4378
-6344
-14948
-15520
-10151
-5861
-6346
-9195
-10530
-9095
-5241
704
6786
8777
4728
-715
-231
7357
15153
16344
11663
6728
4393
3004
1036
-592
-1524
-3776
-8325
-12151
-11533
-7368
-4503
-5703
-8526
-8810
-5346
-226
3903
5643
5134
4179
5283
8997
12520
12415
8752
4994
3684
3975
3840
2807
1178
-1686
-6122
-10010
-10443
-7808
-5754
-6401
-7668
-6627
-3826
-1873
-969
1141
5117
8599
9706
9513
9246
7708
4246
2241
5633
11875
12675
3978
-8015
-13815
-11483
-7145
-6030
-7358
-8492
-9373
-10126
-8225
-1919
5140
6790
2569
-1112
1066
7556
12909
14459
13140
9795
5102
1485
1731
4590
4448
-1719
-9834
-13297
-10716
-6786
-5629
-6476
-6476
-5067
-3518
-1960
382
2974
3853
2803
2627
5490
10064
12714
11335
7321
3404
1753
3106
6031
7307
4015
-3029
-9327
-11217
-9355
-7210
-6626
-6959
-7405
-7791
-7304
-4367
618
4683
6024
6198
7227
8093
7228
6862
10535
16216
16052
6300
-6337
-12065
-8965
-3850
-2721
-5066
-8451
-12222
-15070
-13456
-6027
1945
3567
-584
-3152
540
7741
13192
15213
14840
11939
6782
3045
4192
8078
8233
1683
-6670
-10119
-7708
-3685
-2208
-4102
-7754
-10929
-11028
-6567
53
3801
2064
-2381
-3822
463
7603
12719
13253
10165
6323
3824
3159
3965
5002
4455
1233
-4102
-8961
-10568
-8968
-6661
-6277
-8431
-10784
-10425
-6501
-708
4029
6625
8518
10341
10159
6699
3277
5703
14186
20023
14802
734
-11512
-14022
-8892
-3066
-262
-1188
-5819
-12256
-15375
-10712
-1246
4710
3175
-1507
-2708
1167
7522
13771
17764
16762
10109
2762
990
4584
6861
2776
-5268
-11759
-14251
-13219
-9508
-4640
-2476
-5209
-8950
-7828
-1498
3539
2912
352
1148
5464
9449
11532
13585
14624
11022
3310
-1969
419
6499
7440
565
-7978
-11699
-10901
-9509
-9227
-8656
-7719
-8421
-9854
-8689
-3405
3334
7788
10680
13463
13886
9668
4183
5926
16583
25479
21361
5195
-10850
-17619
-16506
-12250
-6766
-2058
-3374
-12394
-20860
-18010
-4378
7280
8203
2339
-1756
-702
3076
9316
18161
23162
18104
6080
-1349
2514
9683
9263
324
-10256
-16888
-19185
-17119
-10416
-3483
-3290
-9599
-13266
-7800
2820
9012
7832
5285
5253
6946
9199
12303
16472
17502
12134
4014
-706
540
3457
2497
-2910
-9874
-14678
-15325
-11929
-7121
-4999
-6792
-10078
-10164
-4665
3173
8245
8513
7665
10224
14983
16370
11488
5783
6204
11852
14967
9180
-2411
-13034
-19734
-21570
-18994
-12723
-6516
-6586
-11572
-13683
-8192
2037
9625
11052
8672
6019
5078
7432
13365
19672
21251
15279
6301
658
-1573
-1598
-1190
-3142
-7664
-14191
-19471
-19241
-14204
-8423
-5838
-5822
-4673
-1974
1323
5859
11313
15330
16508
14830
11721
10677
11564
10695
7212
3237
784
-1618
-5252
-8097
-9918
-11918
-14648
-16902
-15245
-9405
-3879
-2530
-3055
-1120
2573
6307
9638
11700
12049
10930
10653
13118
16387
15566
7017
-4841
-10525
-7080
-1673
-2142
-8269
-15317
-19647
-20910
-18325
-8425
4828
10679
5128
-4341
-6244
1011
10551
18283
21378
17239
8073
1343
3711
12503
17408
12527
1790
-8713
-15815
-17513
-13512
-6881
-4713
-10690
-18198
-19177
-11793
-1029
5234
6018
6304
8510
11108
12900
15666
19208
18916
12421
3929
-270
740
2028
-837
-6523
-11283
-14848
-16405
-13481
-8925
-8654
-12616
-14351
-10247
-2882
4316
8624
9012
7338
6325
8212
13095
17647
16962
10944
5519
3473
3669
5673
6375
1094
-9407
-18671
-21189
-15769
-4973
3997
4018
-4152
-13488
-17601
-12768
838
15472
21683
17346
6663
-1916
-647
9324
19319
21642
14783
1528
-12014
-16892
-10078
1031
6519
1880
-10005
-20599
-22097
-14444
-3664
3601
3028
-3940
-10252
-9023
433
12239
19473
18729
12358
6518
5364
8975
13902
14726
8967
-6
-6714
-9050
-8795
-8745
-10151
-11918
-12762
-12453
-10210
-5657
-1432
-449
-1312
-586
2728
7497
11718
13199
11848
9621
7465
5699
5475
5754
3091
-2426
-6431
-6318
-3534
-1201
-1955
-5868
-10182
-12468
-11790
-7191
-22
4193
2136
-2253
-3264
417
6831
13019
15445
12279
5479
-437
-1167
4059
10562
11961
6604
-1690
-8235
-10327
-7535
-2251
1039
-840
-6923
-12701
-13539
-8534
-1471
2850
3048
1071
-690
-342
3392
9165
12845
11773
7642
4051
3063
4431
6308
6669
4722
810
-3918
-7202
-7425
-6142
-6253
-8179
-10208
-11017
-10176
-7930
-5102
-2269
268
2046
3568
6145
9094
10070
8892
7581
7063
6738
5975
4402
2037
-789
-3912
-6450
-6873
-5768
-5675
-7107
-8157
-7531
-4900
-581
3270
4361
3073
1242
466
2429
6943
10425
9906
6261
1997
-569
268
3493
5688
4795
821
-5097
-9378
-8186
-2951
1131
1540
-980
-4765
-6845
-4704
206
4295
5825
4961
3032
2267
3283
4266
4105
3198
1462
-759
-1629
-610
307
-414
-2314
-4152
-4656
-3403
-1828
-1607
-2230
-1958
-392
1414
2443
2212
757
-1037
-1774
-808
1332
3578
4538
3093
109
-1861
-1466
486
2559
3329
2053
207
-116
598
609
-98
-804
-1331
-1072
176
1154
1268
1139
292
-1658
-2677
-1254
976
2184
2047
408
-1763
-2151
-581
812
1379
1727
1503
812
767
1293
1632
1818
1274
-672
-2242
-1309
1099
2700
2550
373
-2894
-4409
-2592
739
3015
3043
837
-1951
-2731
-729
2482
5012
5537
3651
750
-980
-801
486
1700
1698
214
-1306
-1194
365
1789
1915
777
-510
-607
627
1891
2004
1069
-17
-489
-113
715
1326
1231
341
-800
-1066
67
1526
1716
364
-1372
-2149
-1420
174
1261
932
-588
-2287
-2768
-1036
2079
4115
3539
1224
-889
-1515
-641
485
581
-167
-833
-1263
-1498
-1104
-129
828
1564
1790
1037
129
453
1586
2136
1930
1301
282
-474
-443
-353
-524
-118
830
1548
2254
2994
2866
2254
2492
2983
2328
996
-6
-504
-96
1032
1327
595
471
902
556
97
619
1185
1071
852
353
-634
-1091
-976
-1192
-729
1401
3054
2313
496
-862
-1363
-180
2109
2755
1132
-535
-1392
-1798
-999
715
1320
535
-347
-1093
-1190
442
2298
1838
0
-718
-192
867
2278
2776
1463
-105
-717
-983
-435
1694
3110
1449
-1498
-2822
-2015
306
2580
2253
-314
-1583
-595
574
1401
1934
854
-1046
-1159
-55
290
764
1990
2259
1643
1701
1715
979
893
1256
424
-473
439
1945
2218
1210
-650
-2110
-1267
1134
2351
1822
684
-563
-1040
146
1870
2810
3155
2574
670
-819
-578
183
754
1478
1434
447
378
1146
764
-70
281
510
-411
-866
-558
-807
-668
998
2062
967
-256
-270
-304
-369
632
1487
695
-322
-320
-491
-893
30
1496
1570
816
254
-373
-76
1941
3129
1731
63
-431
-917
-1000
104
831
759
1288
1521
400
-42
825
1009
864
1443
1068
-51
561
1488
546
118
896
-104
-1479
-226
543
-988
-495
1816
926
-1331
-534
756
447
1441
2778
1297
-40
1198
1390
31
774
2039
478
-1362
-1095
-688
-262
1369
1723
-407
-1396
122
1161
848
618
145
-725
-397
994
1555
1265
1309
1564
1626
1711
1736
1706
2036
2269
1756
1210
1045
254
-862
-580
632
911
697
1108
1295
802
481
-73
-1285
-1515
-364
127
-266
-134
29
-266
180
805
-72
-1211
-923
-80
966
2361
1912
-991
-2788
-1970
-932
-345
631
1038
624
558
311
-556
-518
412
962
1825
2724
1422
-785
-602
886
1342
1521
1447
106
-786
-333
-735
-1558
-321
1341
1042
373
376
105
536
1975
2073
1275
2101
3047
2214
1853
2632
1989
602
918
1565
918
484
641
-28
-877
-604
-2
99
106
150
102
194
326
118
-311
-483
-262
-285
-963
-1159
-22
837
101
-801
-668
32
1369
2765
1934
-707
-1702
-566
551
1745
3121
2402
-211
-1380
-581
96
411
854
739
36
-627
-1184
-1058
213
1272
1113
646
278
-264
-125
988
1774
1863
1746
1004
-58
-159
51
-787
-1428
-366
1098
1325
550
-414
-717
443
2221
2658
1652
895
1021
1390
2078
3262
3461
1586
-472
-740
-243
-127
309
512
-954
-2607
-2408
-1588
-1427
-919
-28
304
727
1487
1327
507
227
65
-207
167
573
239
87
410
654
1374
2142
1153
-707
-1209
-1064
-1172
-246
1308
1570
777
-457
-2153
-2123
821
3075
2215
612
-391
-1501
-1287
976
2482
1767
423
-749
-1544
-1016
262
823
1020
1371
1123
539
690
1287
1710
1901
1424
503
475
1234
1408
1287
1744
1886
1019
300
526
1030
1187
981
695
797
1175
1093
633
658
1072
997
384
-72
-12
512
1279
1879
1996
1703
1316
1103
941
356
-649
-1169
-455
947
1727
1067
-700
-2272
-2434
-1392
-418
-84
-120
-621
-1413
-1070
942
2576
2039
339
-755
-747
327
2048
3117
2674
1185
-489
-1456
-927
514
1248
892
399
126
-267
-702
-954
-1097
-947
-193
782
1270
1243
999
593
498
1299
2145
1743
852
1015
1820
2111
2070
2037
1572
404
-1374
-3042
-2916
-690
1174
944
-229
-1099
-1536
-1000
579
1797
1789
1023
-110
-1057
-724
761
1857
1753
974
306
171
287
-114
-1105
-1864
-1876
-1301
-567
-264
-667
-1190
-1107
-520
65
493
741
435
-703
-1918
-1773
-89
1470
1498
558
119
654
1340
1397
1227
1535
1784
1048
-131
-535
-100
367
229
-527
-867
343
2192
2450
776
-1041
-1721
-1454
-934
-687
-870
-1242
-1384
-879
171
837
424
-565
-1399
-1889
-1866
-1339
-980
-1208
-1476
-1065
80
1053
604
-891
-1285
90
1381
1496
1325
1287
768
-258
-1210
-1503
-586
989
1255
-513
-2234
-1866
-147
891
658
126
103
330
235
-13
245
1003
1486
1525
1841
2455
2348
1343
558
531
748
991
1307
1249
588
-167
-623
-690
-137
907
1700
1740
1102
78
-718
-708
-316
-472
-1076
-1152
-249
1218
2458
2704
1902
1000
767
725
231
-242
-16
552
786
649
234
-601
-1636
-2304
-2195
-1168
194
537
-487
-1284
-609
835
2139
3132
3196
1841
343
254
1065
1276
550
-409
-914
-742
-428
-727
-1387
-1375
-455
561
1008
892
607
670
1271
1925
2043
1667
1034
78
-905
-971
150
1333
1541
1014
269
-663
-1338
-1002
-178
-217
-1027
-1343
-984
-673
-376
190
558
442
310
474
902
1561
1933
1424
618
495
788
760
558
507
461
463
690
942
1114
1281
1055
298
71
1094
2022
1176
-776
-1667
-715
905
1787
1380
27
-1166
-1137
-51
1083
1718
1665
627
-968
-1748
-1141
-218
-40
-372
-539
-567
-805
-992
-488
609
1329
1133
581
349
375
270
-23
-380
-835
-1349
-1453
-787
211
864
1060
805
-34
-831
-607
192
351
102
388
792
588
404
857
1357
1503
1648
1672
1087
181
-269
38
649
668
-42
-232
848
1961
1944
1371
735
-433
-1779
-2065
-977
836
2481
2720
1173
-532
-951
-955
-1842
-3038
-3024
-1278
1040
1999
1118
-47
-463
-765
-1080
-628
241
579
550
578
586
1007
2002
2314
1332
473
757
1484
1911
1831
1037
-99
-727
-618
96
1253
1976
1497
520
-80
-515
-750
-238
655
1301
1959
2448
1704
-116
-1392
-1185
-53
832
691
-100
-611
-692
-483
291
1094
847
179
379
740
294
0
261
-352
-2074
-3207
-2769
-1115
835
1599
686
-149
382
1116
794
-242
-994
-80
3093
5937
5029
1145
-2187
-3666
-3660
-1663
1926
4638
4878
3355
1213
-795
-1830
-1416
41
1597
2419
2687
3434
4573
4343
1810
-1524
-3467
-3320
-2044
-1039
-851
-995
-929
-604
-207
88
454
1167
1507
340
-1476
-1925
-1469
-2165
-3417
-2948
-987
711
2093
3471
3634
1899
-421
-1648
-1055
508
559
-2049
-4666
-4296
-1605
1134
2813
2818
1382
351
699
1405
2140
3337
3968
3181
2033
1011
-528
-1754
-1527
-977
-1201
-967
791
3080
4272
3573
1787
937
1653
2227
1739
1501
2352
3134
2283
-330
-2631
-2102
627
2111
665
-2268
-4523
-4208
-793
2878
3069
-154
-3994
-6421
-5919
-1778
3435
5646
3986
1135
-25
809
927
-1988
-6239
-8800
-9249
-7577
-2811
3075
5933
5413
4071
2286
-269
-1983
-2338
-3055
-4326
-4068
-1124
3036
5099
3085
-359
-806
1785
3812
3254
381
-3427
-5322
-3637
-711
669
698
128
-743
-239
2422
4686
4483
2974
1517
182
-688
-882
-875
-545
364
1169
1511
1690
1364
562
268
-49
-1827
-3673
-3064
-905
256
161
-348
-967
-938
109
898
490
-600
-1965
-2909
-1679
1904
5225
6123
4884
2914
1792
2494
4014
4270
2425
-749
-3328
-2856
594
2997
1241
-2709
-5136
-4823
-2362
1016
2983
1740
-1312
-2502
210
4650
5847
1201
-5574
-7937
-4067
2001
5853
5396
341
-6650
-10384
-7507
485
8001
9105
3581
-2187
-3220
-966
1296
2525
2535
1022
-1532
-3275
-1803
2756
6482
6242
3397
793
-805
-1640
-1151
782
2017
273
-2714
-2891
-116
1614
389
-992
630
3885
4582
2242
480
270
-879
-2752
-2173
1149
3383
1394
-2875
-4430
-2136
507
2025
3554
3729
639
-3161
-3181
1141
4848
2427
-4287
-7612
-5051
-1183
723
875
494
2056
6369
9373
6277
-3176
-12890
-12708
400
14939
17724
8448
-4688
-14245
-15511
-7704
5343
16252
16191
3536
-10095
-12479
-4841
4234
9301
8348
2228
-5012
-8131
-2611
9784
18221
15041
5292
-2849
-6166
-3564
3061
7686
5550
-3232
-12699
-14234
-7232
-64
3035
3929
2031
-2346
-2999
4007
14428
19789
13413
-1123
-10280
-8376
-3435
-420
2004
1170
-4384
-9405
-9309
-3012
5149
5449
-2049
-5582
-2433
673
2319
2511
-651
-4491
-5389
-2498
3785
8471
7214
4633
4753
5535
7645
11564
12204
7130
-1092
-8662
-9789
-3788
330
-2657
-8782
-15197
-19788
-16938
-5621
7570
14859
10157
-4414
-13475
-5543
11196
23985
28713
21219
1419
-16001
-17380
-4200
14562
25096
15929
-4737
-19925
-24194
-16351
212
8556
-324
-14859
-24037
-22470
-5695
16567
26166
19334
4818
-6417
-4399
9912
23939
27075
15963
-4136
-18844
-17413
-3858
8814
10004
-1128
-16664
-26795
-24229
-10032
3744
6631
-646
-11817
-18274
-11902
4937
20042
23941
17299
8856
5845
8000
13199
19143
19691
10859
-3130
-13237
-12975
-6941
-5611
-9240
-12670
-16302
-17310
-11014
-2402
3012
4995
2218
-979
3242
11906
18976
22963
19595
9245
932
-1070
1919
5272
421
-10973
-18362
-19853
-16051
-6780
-370
-1181
-6346
-15669
-17712
-478
18846
22696
17249
5167
-8149
-5075
9746
19983
25995
19869
-4934
-24131
-22782
-11115
7448
19901
6508
-16297
-25396
-24331
-11265
13230
26043
18905
2772
-15199
-18810
125
19543
25779
22640
6080
-14675
-17488
-4712
9619
18087
10244
-9837
-22648
-24023
-15519
4039
17075
9359
-4944
-12605
-11675
1575
19249
25058
16490
-490
-16521
-17615
-3806
9529
14091
10242
44
-9252
-9584
-265
10990
13243
4168
-7961
-15604
-15261
-8120
-2040
-1217
-2453
-4557
-4975
1565
10987
15354
15034
11861
6831
5126
8556
12284
12355
6928
-3107
-11944
-15309
-15235
-14934
-14620
-14161
-15713
-18548
-16008
-5952
5485
14531
19579
17561
12757
13278
18201
22610
23319
16463
3456
-9761
-20352
-22339
-10434
3239
2235
-10610
-22006
-24813
-18231
-4770
11219
22493
20197
6565
-2782
1593
14057
24433
25291
14566
-2569
-16744
-19121
-8182
5874
11289
6233
-5090
-17398
-22888
-16737
-4679
2439
201
-7296
-13309
-12249
-2346
11973
24116
29620
25560
14847
6793
4448
3249
2181
327
-6219
-14071
-16590
-14337
-8964
-2290
-575
-3530
-3424
50
3320
7417
9693
5045
-3103
-7961
-7437
-2382
2755
2053
-3376
-6797
-4212
4457
15484
20476
13956
1242
-7392
-6865
1426
11308
13303
2663
-13741
-23670
-20560
-7804
4303
7234
777
-8723
-12223
-3524
12442
22865
21410
12684
4695
1844
2718
3784
2824
-2698
-12082
-16965
-11895
-3890
-2510
-8111
-12875
-8294
5649
18937
22470
14839
-918
-16833
-20297
-6026
15535
27376
20868
2009
-14085
-16295
-5821
8269
16422
11649
-4864
-20238
-21356
-8875
6065
13495
9737
-1569
-11747
-13554
-5520
6764
12663
6385
-5622
-12112
-7729
5405
20324
28309
23732
8656
-6943
-12168
-4547
8034
13959
6995
-8883
-23619
-28509
-19980
-2535
11991
14521
6786
-2464
-5060
1171
10497
14608
9851
-1205
-11417
-13555
-7640
-1021
303
-3412
-7750
-7495
-569
9265
14884
11740
2248
-5819
-6630
-1375
4171
5047
104
-7691
-12874
-11158
-3771
2843
3648
130
-2266
-230
4743
8983
10211
7867
2951
-1017
-707
2227
2134
-3792
-11244
-13198
-7796
948
8241
10391
5276
-4242
-9443
-2515
14046
27304
26144
10927
-9884
-26152
-28769
-14528
8538
24302
21067
2822
-14395
-17697
-5842
13468
27803
25612
5717
-18847
-30387
-21705
-1649
14190
16247
4901
-12101
-22861
-17939
411
17990
21212
8973
-8133
-17527
-13331
1243
16917
23585
16942
2812
-7979
-9882
-5275
404
2607
-317
-6299
-10972
-10302
-3720
4743
10364
11364
7878
1426
-4301
-5874
-3155
1093
3708
3182
-331
-5622
-9513
-8180
-1792
4741
7100
5965
5326
7062
9010
8348
4113
-2651
-8610
-9953
-6295
-1419
-34
-3177
-6735
-6496
-2633
2555
6823
7525
3868
-1111
-2720
1508
8212
10092
4304
-4728
-11146
-11679
-6580
40
3293
1151
-4285
-6866
-1600
8398
14386
10671
-693
-10946
-11397
-1507
10925
16234
9445
-5544
-18398
-20521
-10399
6355
20117
23039
13883
-1017
-10733
-7653
5032
15461
13241
-1541
-18064
-24502
-17571
-2562
11809
18140
14143
3504
-6173
-7332
1100
11376
14035
6017
-7616
-17094
-15147
-2783
12229
20626
17150
5039
-6568
-10837
-7197
-71
4218
2109
-4710
-11257
-12538
-7250
805
6979
9752
9246
5524
-55
-3976
-2828
2662
7082
5738
-609
-7364
-10515
-8996
-4259
1278
5307
6442
4746
1267
-2332
-3909
-2266
1312
3858
3181
-193
-3757
-5751
-6079
-5005
-2974
-1228
-919
-1940
-2928
-2148
1046
5498
9082
9856
7213
2885
-297
-1081
-238
983
1451
-31
-3846
-7935
-8019
-1447
8641
14489
10221
-2472
-14518
-15736
-3402
13972
22633
15208
-3067
-19389
-23789
-14928
1663
17831
25611
20447
5224
-9915
-14417
-5621
8784
16700
11212
-4228
-18924
-23081
-14449
1222
14940
19610
13144
-257
-11633
-12701
-2579
10357
15018
7341
-6197
-14619
-11880
-1006
9827
14160
10721
2518
-5693
-9601
-7254
-574
5246
5311
-1020
-9506
-14279
-12088
-4095
5530
12261
13202
8252
494
-5033
-4549
1313
7642
9161
4507
-3054
-8699
-9597
-6042
-359
4521
6092
3500
-1380
-4662
-3366
1798
6800
7716
4039
-1169
-4188
-3795
-1737
-513
-1072
-2633
-4001
-4398
-3378
-832
2559
5285
5908
4242
1607
-191
-153
1489
3633
4786
3771
687
-2820
-4701
-3846
-489
3823
6293
4254
-2027
-8200
-8755
-2080
7264
11728
7063
-3775
-12847
-13514
-5237
6677
15171
15937
9597
613
-5845
-6702
-2222
4073
7105
3709
-4364
-11384
-12186
-6023
3430
10952
12811
8475
700
-5924
-7542
-3557
2679
6279
4745
-178
-4432
-4986
-1523
4025
8816
10475
8063
2350
-4304
-8582
-8149
-3949
143
791
-1983
-5470
-6733
-4341
938
6401
9115
8037
4379
284
-2312
-2150
626
3857
4371
663
-5180
-8777
-7317
-2051
3210
5435
3990
326
-2861
-3223
-792
2144
3819
4342
3867
1510
-2488
-5297
-4232
-243
2860
2349
-1098
-4605
-5708
-3842
-117
3616
5596
4951
2301
-663
-2489
-2637
-1232
989
2657
2819
2013
1404
1264
1322
1844
2845
2877
383
-3832
-6742
-5917
-1861
2226
3031
201
-3158
-3644
-908
2616
4598
4419
2601
-59
-2477
-3172
-1137
2639
5084
3663
-797
-4864
-5918
-3929
-448
2620
3601
2101
-379
-1888
-1810
-709
724
1778
1659
334
-1117
-1596
-1092
-412
-100
73
467
632
-206
-1496
-1445
385
1955
1450
-242
-1190
-1147
-984
-627
634
2451
3515
3108
1736
410
-183
62
917
1981
2614
2206
864
-572
-1467
-1618
-745
953
1801
78
-3215
-4926
-3438
-210
2436
3320
2279
3
-1813
-1589
497
2672
3248
1874
-377
-1773
-1310
357
1578
1268
-315
-1959
-2416
-1290
769
2682
3497
2673
738
-604
-226
820
862
133
-87
-110
-1194
-2808
-3009
-1390
495
1529
1994
2317
2411
2199
1728
904
-78
-305
1013
3160
4119
2834
742
24
569
379
-972
-1567
-458
650
297
-373
346
2045
2977
2314
644
-927
-1594
-1460
-1381
-1697
-1563
-201
1733
2734
2113
696
-54
400
1084
804
-169
-582
-183
-81
-1100
-2744
-3836
-3468
-1630
539
1653
1580
1409
1824
2432
2676
2303
1137
-521
-1526
-990
453
1323
900
-336
-1481
-1984
-1935
-1728
-1431
-857
-142
449
1131
2118
2873
2868
2632
2842
2972
2139
694
-373
-955
-1567
-2057
-1798
-880
-155
-79
-129
378
1246
1622
1267
832
663
372
15
363
1265
1236
-275
-1745
-1706
-590
419
772
14
-2313
-5143
-5909
-3438
200
1925
1060
-367
-424
735
1834
2381
2697
2656
1801
559
43
509
1144
1206
385
-1444
-3680
-4751
-3705
-1573
-170
-43
-384
-302
509
1773
2737
2707
1783
763
347
649
1318
1841
1934
1764
1564
1137
145
-1167
-2005
-1881
-1253
-1146
-1981
-2839
-2449
-1014
-121
-454
-765
172
1791
2808
3021
2951
2570
1495
-78
-1448
-2142
-2147
-1680
-1002
-370
-53
-263
-941
-1675
-1982
-1538
-231
1579
2910
2974
2171
1628
1794
2154
2212
1941
1385
522
-383
-776
-294
768
1469
929
-597
-1665
-1105
622
1980
2059
1250
459
174
413
1094
2056
2730
2285
569
-1239
-1561
-138
1610
2074
924
-849
-1961
-1851
-1103
-782
-1066
-877
542
2148
2126
461
-620
649
3177
4228
2837
811
91
347
87
-891
-1530
-1447
-1334
-1449
-1019
461
2183
2742
1570
-497
-1891
-1560
93
1495
1385
129
-710
-197
989
1642
1596
1519
1494
842
-471
-1319
-916
-175
-653
-2407
-3784
-3509
-2173
-1186
-867
-321
976
2315
2640
1789
519
-364
-660
-697
-900
-1427
-2092
-2601
-2800
-2655
-2086
-1067
126
1047
1594
2187
3111
3836
3414
1655
-404
-1406
-877
513
1729
2175
1892
1233
388
-702
-1917
-2592
-2022
-452
859
933
105
-589
-737
-608
-238
696
1940
2502
1919
1062
1039
1650
1594
132
-2017
-3487
-3554
-2584
-1559
-1297
-1852
-2437
-2171
-1037
72
421
219
58
-52
-445
-760
-133
1292
2049
1217
-130
-422
51
-393
-2134
-3483
-3031
-1467
-304
142
535
1038
1244
1217
1506
2097
2236
1493
375
-338
-319
361
1470
2469
2639
1838
920
858
1496
1684
833
-236
-428
125
381
-81
-685
-938
-988
-887
-287
689
1225
1097
1299
2494
3614
3150
1303
-309
-829
-817
-823
-552
202
863
862
513
523
1005
1420
1342
892
440
158
-50
-236
-207
184
678
776
256
-641
-1447
-1656
-935
438
1549
1768
1491
1412
1366
750
-131
-247
528
1086
722
137
262
969
1556
1774
1763
1486
912
385
252
337
162
-508
-1535
-2541
-3001
-2519
-1280
-21
636
699
604
678
799
519
-327
-1110
-873
442
1685
1765
816
-259
-907
-1038
-634
38
241
-408
-1184
-1064
-101
755
955
751
469
211
199
653
1244
1332
907
700
1152
1773
1761
957
-55
-643
-691
-504
-321
-106
160
256
30
-289
-435
-499
-569
-212
966
2361
2776
1912
766
307
449
589
468
140
-335
-724
-623
-89
149
-432
-1419
-1958
-1755
-1131
-393
342
846
832
452
311
763
1397
1525
1086
737
971
1429
1341
503
-506
-986
-688
177
1116
1507
1073
371
346
1174
1902
1595
503
-304
-227
400
983
1256
1172
650
-204
-868
-739
169
1104
1291
750
261
458
1070
1167
263
-958
-1210
-28
1538
2009
1195
418
804
1856
2185
1332
181
-329
-247
-155
-239
-240
-68
-43
-488
-1242
-1756
-1665
-1203
-855
-684
-313
388
1059
1447
1809
2302
2437
1672
364
-434
-148
752
1368
1313
946
792
868
692
51
-491
-246
631
1304
1346
1069
758
307
-151
-11
964
2028
2185
1291
156
-250
353
1282
1420
463
-561
-526
275
547
-177
-1030
-1186
-885
-738
-786
-665
-205
525
1385
2092
2305
1970
1356
732
237
0
128
577
1148
1553
1459
768
-3
-90
506
844
311
-426
-337
589
1517
1914
1861
1539
1061
686
657
888
1128
1325
1474
1369
891
285
-286
-1041
-1885
-1993
-836
724
1237
421
-545
-554
215
739
347
-728
-1686
-1887
-1376
-690
-257
-179
-440
-832
-768
161
1345
1512
275
-1209
-1600
-874
5
447
604
778
1061
1291
1085
310
-404
-140
1148
2430
2817
2486
2014
1401
456
-304
-75
1040
2035
2115
1305
153
-687
-836
-484
-146
-32
40
172
262
353
630
930
764
108
-383
-313
-67
35
339
993
1354
1037
729
1104
1607
1307
396
-200
-344
-636
-1055
-819
293
1387
1411
343
-712
-767
-314
-747
-2169
-2891
-1787
-122
108
-877
-883
823
2081
1150
-403
-243
1022
1177
178
106
1857
3762
3764
2080
740
588
273
-1046
-1860
-633
1501
1957
38
-2000
-1600
843
2464
1756
178
-433
50
958
1628
1160
-795
-3006
-3595
-1923
786
2446
2013
513
-441
-666
-941
-1352
-1313
-649
117
290
-113
-113
887
1984
2184
2033
2391
2746
2159
832
-368
-1211
-1943
-2009
-80
3306
4258
-135
-6123
-6160
1319
8800
8272
389
-6848
-7181
-2094
2327
2827
1404
1137
2319
3174
2370
285
-1310
-884
1100
2615
2438
1348
710
407
-968
-3402
-4343
-2139
798
979
-1086
-1788
382
3239
4067
2420
10
-1155
-653
125
-107
-844
-716
137
-167
-2380
-3954
-1601
4080
8409
7441
1639
-5169
-8981
-7923
-2882
3361
7566
7246
2401
-3218
-4705
-1473
1777
1291
-711
225
3822
5452
3097
240
729
3572
4464
1030
-4529
-7493
-5375
-795
1618
1128
1065
2747
3207
815
-1082
673
3749
3875
1049
-1531
-2547
-2797
-2105
-11
1570
439
-1738
-1312
1600
3271
2177
588
-66
-1341
-3906
-4899
-1686
3402
4983
1455
-2748
-3061
-706
-250
-2297
-2137
2864
7438
4389
-4098
-7190
0
8526
7403
-1374
-6535
-3635
547
34
-1799
676
5363
5078
-1649
-7001
-2549
9343
15327
5985
-9871
-12877
1968
16212
11202
-6218
-12862
-1417
10417
6017
-7941
-13104
-4349
6505
8159
2575
-875
593
65
-6842
-12233
-5809
7883
12278
1226
-10857
-7820
5982
12058
3513
-7270
-7952
-1764
1002
-1988
-4702
-2764
877
435
-3738
-4174
2492
7934
2695
-8873
-12497
-2628
9878
11532
2803
-4481
-3845
-363
-6
-1406
-590
2586
4934
3766
229
-1155
1102
2058
-1865
-5530
-1807
7351
12129
6313
-5169
-10987
-5602
5093
11263
8870
867
-6742
-8921
-5261
250
3965
4453
1242
-3361
-4055
619
4865
3073
-3073
-6951
-3953
3497
7664
4715
-203
-1090
361
-604
-3248
-2262
4360
10540
7451
-4290
-12267
-7131
5243
11676
6765
-3330
-8392
-4501
2109
3825
1488
-18
-541
-1635
-1151
2150
4436
2014
-3210
-5556
-1688
4930
7455
4312
-40
-2704
-4105
-3538
269
5705
8813
5537
-4158
-11779
-7654
4103
9057
3018
-3505
-2763
477
-1142
-6059
-6016
1499
7438
2857
-7149
-9379
-39
10993
11981
2024
-7425
-5877
1948
3543
-1292
-1572
4673
7171
1017
-6022
-5532
839
4927
2943
-176
1286
5063
4543
-1542
-7280
-6097
1643
7337
4137
-2821
-4172
-1227
-1608
-4264
-2159
4003
6543
2097
-5352
-9555
-6449
2635
10284
8555
-2394
-12356
-10921
220
9149
8276
1016
-5473
-6894
-2982
1615
1687
-362
1399
4360
1201
-5635
-6370
551
6278
4001
-3310
-7280
-3524
4019
8366
6758
998
-5243
-7522
-3771
2723
6611
4939
-1834
-8200
-5766
5623
14187
10774
159
-7116
-6343
-136
5194
5436
2612
-88
-3524
-6455
-2755
7568
14326
9675
-3457
-15452
-16343
-3843
10942
14078
5256
-4845
-9150
-7604
-2129
4968
10763
11859
5480
-5594
-12212
-9048
-722
5725
6801
1811
-4661
-4557
2154
6687
4803
-691
-7763
-13051
-9796
1823
12420
15989
13648
6712
-2497
-8112
-7401
-4348
-3556
-5811
-8201
-5782
2844
11872
14397
9279
39
-8242
-11225
-8135
-785
8286
12657
5332
-8290
-12372
-1574
11979
14941
5281
-8843
-14755
-6086
7907
11949
3362
-7078
-9401
-2422
7929
12909
7176
-5491
-13885
-9825
2350
10490
9418
4176
-1007
-5875
-7196
-1470
6975
10491
6442
-3484
-13951
-15795
-5540
7671
12687
8035
-970
-8338
-8718
-431
11141
16249
8480
-7478
-17317
-11883
2483
12994
12929
3036
-9277
-12769
-4295
6363
9472
4407
-4858
-11746
-8952
1433
8346
7245
3132
-790
-4278
-4972
-2116
1584
4818
6336
2992
-3424
-5674
-1614
3615
5282
2216
-3231
-5256
-748
5878
9074
7397
1019
-7267
-11490
-9601
-4504
2526
9671
10539
3726
-1534
622
4000
2238
-2567
-5059
-2169
3801
5245
-1518
-8454
-5459
5047
11719
8336
-1301
-8395
-7808
-2051
3479
4890
1093
-4815
-6611
36
10686
14792
8212
-3426
-10576
-7083
2628
8308
5445
-2152
-7677
-8526
-6395
-2456
2469
6854
7977
3616
-4031
-9921
-8241
2743
14452
16427
6998
-6576
-13628
-9984
272
9484
10434
4380
-2417
-6900
-5964
31
4590
3832
-10
-1314
1347
2742
-26
-4949
-6167
892
8969
8573
2289
-2207
-2161
-935
-1850
-3063
-1112
4640
8586
4349
-4032
-8206
-6054
-288
5148
7703
5769
83
-4553
-5284
-974
8079
14016
10658
1741
-7183
-11350
-7417
1662
8133
6546
91
-3891
-3449
-526
3049
5197
5298
4097
569
-5554
-8748
-3744
5171
9422
6065
-1410
-7155
-7291
-1950
5388
9977
8932
2650
-4839
-7551
-3540
3140
8025
9887
8215
2109
-5894
-9904
-5856
4795
14529
14869
4213
-9865
-17531
-15679
-5615
9679
19993
15565
-227
-14362
-14643
-827
14783
19996
10642
-5289
-14132
-12959
-6452
2473
9350
10254
5938
-438
-5675
-7920
-6300
-1936
1988
3315
1473
-1999
-4885
-6314
-5321
-2810
83
3673
4143
-344
-4623
-5265
-1584
3807
4519
253
-3561
-3407
-212
786
-1584
-2529
-1020
186
-414
-2437
-3407
-1332
2231
3269
271
-3185
-3614
-1707
760
3459
5134
3395
-987
-4730
-5460
-1654
5234
10182
8711
215
-9772
-13197
-7196
4032
11762
9343
-414
-9075
-12531
-11491
-6558
955
8460
12463
8411
-903
-6661
-7042
-3844
666
2746
4002
3478
-2819
-8561
-7564
-1245
5650
5024
-1738
-4713
-1898
3020
5232
2848
-34
-1119
-606
1392
4952
8529
6470
-439
-5819
-7543
-3751
1384
2179
2317
1227
-1801
-2868
-4238
-4106
-1258
23
3418
7704
7422
4386
-1274
-4036
725
5750
8083
6544
656
-4755
-9850
-11086
-4510
2851
6322
3672
-3016
-5403
-3844
-1481
1189
4480
9713
9438
1780
-4399
-6936
-3566
1438
-193
-1609
-1340
-1310
2343
2649
1915
5680
3425
-1045
242
2436
6696
9542
5674
669
-3333
-5780
-4850
-1866
2649
7772
10248
4445
-7535
-16928
-21795
-13923
7903
22411
23863
15827
-3590
-18443
-20850
-15358
2545
20747
25297
18695
-963
-20963
-21955
-12070
-2358
5620
5609
-1239
-3973
-602
2007
1859
-862
-3088
3073
11860
13262
8170
-5600
-19005
-17533
-10832
-3314
8975
13581
10155
7155
1269
-2199
1139
3968
5150
4125
-285
-2565
-3238
-5841
-6349
-5559
-7131
-3215
7599
12108
8876
4878
440
208
6086
10903
13281
13294
8821
1087
-9309
-15752
-10947
-5552
-9172
-13130
-11453
-4978
8153
20679
20275
9481
-2339
-10867
-11427
-564
16820
26371
17474
-615
-13668
-20415
-20234
-10462
2372
11118
16413
15438
2553
-13413
-18215
-12834
-3585
8282
20402
28984
30648
24579
11200
-8108
-20714
-15052
-926
7405
6715
-1942
-13574
-20535
-21228
-19447
-12890
3417
21126
29125
29590
27023
20514
8983
-3085
-7759
-5009
710
5382
1255
-9636
-16464
-20651
-24680
-18221
2641
22895
26421
15571
2352
-6816
-8358
-2229
4889
8437
9388
6276
-3703
-12268
-8670
-864
-156
259
7400
14113
13696
9652
6155
1698
-2447
-1728
3730
12194
19881
16994
-447
-21029
-30431
-26976
-15669
2308
20167
22917
7003
-13687
-23003
-14998
2933
17220
23595
27485
27604
16041
-5120
-22973
-27631
-22473
-15918
-8579
-88
4824
3804
-5259
-18879
-23132
-12670
2818
15758
22420
19831
9484
-2827
-12074
-14532
-8197
5605
19458
23874
17428
8049
-1400
-11875
-19844
-25231
-27300
-16903
2312
11794
5674
-6253
-13790
-14319
-7478
7596
26269
31859
30884
22576
8254
-1906
-4846
-3300
-4907
-7783
-11190
-16962
-23771
-25669
-21170
-11585
-1773
5595
12127
19773
24359
20664
10483
2721
1948
7786
17296
22033
13380
-3582
-15219
-17734
-17541
-12772
2624
18265
17781
2342
-16102
-26545
-20318
-1499
13780
18714
20023
20267
12840
-3364
-17077
-21569
-23482
-24725
-17386
-1308
14777
21378
10721
-11008
-22928
-16075
-1421
10794
18192
17655
7672
-5342
-13567
-16784
-16829
-9893
4521
17531
24011
25061
17099
-185
-15218
-20117
-18647
-13040
-1900
8055
7377
-1188
-8671
-11447
-8235
1154
13146
23083
27173
23931
16251
7699
-1039
-9349
-15018
-16680
-15341
-14453
-15303
-14746
-14181
-16390
-13632
-3074
5097
10279
18943
25066
21175
11467
3785
1614
4670
10293
11175
-45
-16542
-22666
-18209
-14320
-8292
5793
14887
6860
-8423
-14370
-6140
8339
20143
27239
28378
23309
13440
-2822
-21858
-31424
-29622
-23501
-16335
-5276
9252
18347
16537
7494
-542
-1950
1227
4949
9214
10175
3032
-8169
-14668
-11949
-4781
-1646
558
9924
20593
22014
15207
3836
-10102
-19088
-19576
-16891
-12637
-6959
-3942
-4496
-6665
-6911
-2204
2571
5412
13513
24374
27019
21072
12548
2873
-8408
-18914
-23695
-20519
-14353
-12775
-15630
-15263
-9992
-4811
875
8505
13978
17362
20331
18271
11291
7310
8665
9078
2244
-9346
-17218
-21216
-23980
-15740
6164
21856
18932
6379
-6713
-13911
-8202
7127
21800
28521
25403
16162
2905
-12596
-21972
-23117
-23091
-21301
-11857
4395
18258
17971
5078
-4506
-3325
2420
7362
10219
10964
10290
7360
1373
-6716
-14733
-16139
-7021
4533
12871
20878
22420
9545
-8304
-17694
-18711
-17475
-14332
-7859
-3452
-5372
-8857
-9379
-6793
-1246
6808
16435
23586
23428
18044
10249
555
-5248
-5897
-8613
-12758
-14857
-17731
-18595
-15021
-13015
-10564
-2762
4149
8361
14597
20239
22524
22715
21449
19740
13036
-3263
-19056
-24949
-25776
-22181
-8653
7700
13224
7189
-561
-4137
-3176
2154
9056
14212
19308
24259
22239
8436
-11566
-23521
-21198
-16017
-14200
-6516
6660
14039
13774
10009
5713
2902
-142
-1987
1711
7074
9717
9167
372
-14579
-21681
-15939
-4380
7123
16430
21898
18982
7491
-2250
-7197
-14550
-20395
-17294
-10410
-6021
-6186
-11088
-13953
-8260
4078
16760
22819
22781
23008
19672
7973
-2993
-7630
-10811
-12927
-13403
-15847
-17774
-14219
-10213
-12432
-14230
-5745
7788
15816
18892
20810
21246
20886
20029
15329
3205
-12635
-21033
-21170
-22069
-17591
-879
11319
9158
4282
469
-3773
-1903
6463
15676
22510
23839
20524
12805
-2767
-18082
-22986
-23498
-23166
-15636
-2970
8411
16520
18429
13776
7238
2196
440
3055
8416
11883
8532
-205
-8046
-12693
-13866
-9817
-1204
9379
18523
22488
20225
10630
-5376
-18543
-22196
-19734
-14199
-7808
-5610
-8237
-10987
-8871
-1057
6852
12786
20761
27145
24741
15803
5717
-3286
-10197
-14332
-14258
-12267
-12405
-10904
-7373
-9669
-12716
-6008
3925
9472
14365
19367
21269
20064
17967
14981
4383
-14127
-24979
-22647
-18408
-11917
2048
11621
7857
209
-3597
-6570
-8206
-1096
14508
26949
29347
24864
14709
-1897
-18114
-24524
-22182
-19248
-15476
-5362
6938
14412
16828
13430
5226
-1104
-3597
-2540
4316
10923
8584
-914
-12546
-21288
-20821
-12076
-720
9947
16946
20635
21957
15081
-407
-13706
-18549
-16762
-11954
-9708
-12643
-16318
-15372
-9480
-2891
3054
12134
22432
26666
24233
18206
9184
-376
-7641
-13830
-20494
-24676
-21044
-12027
-8450
-11263
-8578
2714
13179
18061
20122
19333
13296
6154
4108
2365
-7035
-18390
-21115
-15786
-7901
2518
15323
22558
18053
9047
2717
-6118
-16701
-15716
-599
16074
24552
22724
11654
-4870
-19363
-23970
-19896
-14925
-8651
2915
14163
18571
17069
11160
2275
-5045
-7334
-5048
-1010
2203
2908
-1778
-12070
-20049
-17856
-7602
4246
15297
24635
28267
23018
11172
-3512
-18466
-27793
-25440
-15460
-9347
-11676
-15889
-16110
-14377
-11025
-689
14786
24722
24942
20222
13250
3681
-5364
-9864
-12345
-17558
-21766
-18390
-11858
-10864
-12493
-7972
1883
9958
14899
18882
19764
15364
9354
4803
-1646
-12879
-24455
-29455
-25673
-14682
970
15885
23162
21417
14747
5678
-5039
-13585
-14001
-3429
13695
26006
23776
8425
-9303
-19774
-21520
-19071
-14960
-6915
5515
17017
21977
19143
10439
173
-5435
-3550
1091
2591
2351
3275
417
-10113
-19859
-19607
-12026
-2091
10178
21758
27137
25864
18742
5125
-10914
-22512
-27036
-24661
-17255
-10575
-9221
-11332
-12559
-10011
-1936
10350
21274
25993
24591
18359
6505
-8432
-18909
-22255
-22075
-18214
-10949
-8859
-13989
-14162
-4414
6121
13141
18974
21583
19124
13059
2881
-8894
-15240
-16183
-17352
-18824
-18593
-17092
-11467
1385
16080
23825
22105
13398
474
-12204
-17258
-10830
2288
14549
20855
17000
4339
-7837
-15301
-21664
-23923
-16061
-3100
7923
16933
21214
17515
11281
6396
-691
-8397
-9673
-4079
2371
4083
-463
-7614
-13535
-16867
-13763
-1758
12494
21656
26145
26307
18378
2325
-14514
-23316
-22788
-19598
-16906
-12225
-8309
-9569
-10351
-3220
9058
19266
24120
25264
25221
20570
7462
-6954
-14616
-19043
-23614
-25724
-26505
-26011
-18742
-5969
6393
18615
28355
29784
26930
23321
10865
-9094
-20219
-18293
-15108
-15838
-17359
-19655
-21655
-15868
-262
14759
21237
23807
24178
15521
-68
-11537
-16092
-13770
-2020
12203
18249
16602
7246
-10674
-23780
-22661
-19564
-18195
-5566
14252
23401
21744
16831
6875
-5845
-11473
-8056
-1009
4715
3707
-5296
-14365
-16553
-16699
-16537
-5574
18775
31945
29458
23789
18608
1994
-21169
-28507
-22801
-17156
-12826
-9012
-9641
-10906
-10271
-6715
4457
19085
22913
19535
22356
25477
15417
-1998
-14244
-19632
-22163
-22996
-22823
-23009
-22160
-15002
-898
13182
21732
24228
22375
21931
23748
16099
-3602
-18070
-19323
-17118
-14257
-9330
-9921
-15477
-12724
301
12050
15718
14370
14930
17930
13802
-403
-13626
-18360
-14684
-354
20040
30588
23446
6660
-8932
-18886
-25351
-28995
-22510
-3498
15389
22943
20981
13915
3836
-4947
-6935
-46
8982
8470
-1028
-8106
-12305
-19800
-23554
-13750
4667
19662
24683
22945
21361
14953
-4909
-25204
-28136
-22164
-20289
-16019
-7206
-5462
-10818
-10608
-1120
9506
13739
14034
18803
26617
25224
10225
-8457
-19571
-22197
-23617
-25497
-21975
-16099
-15686
-12903
1310
15319
18104
17927
22880
28576
26323
10589
-11088
-21961
-20226
-17395
-14585
-9078
-7908
-11768
-9793
67
9230
14527
19424
24530
24563
14207
-4021
-20780
-26815
-17293
2571
18511
22592
18016
7217
-7554
-18468
-21698
-18968
-8081
9360
21658
22456
15470
3505
-9243
-14126
-8202
3531
13865
15322
6421
-6408
-18850
-27985
-25673
-10096
7265
17447
22069
23371
18850
5865
-11165
-21354
-20807
-16590
-12722
-8132
-6317
-9947
-13983
-12808
-4459
8670
18594
21721
23845
25349
18157
2297
-12323
-19243
-20309
-21106
-22677
-20048
-13540
-9400
-5716
3415
13500
17976
19711
22319
22705
15741
535
-15576
-23023
-21926
-17987
-11347
-1573
6241
7789
3383
-2503
-2385
5865
15925
23126
25596
17855
-772
-19096
-26254
-20958
-7144
9335
21828
25202
17370
2391
-11223
-19684
-23076
-17804
-3136
12089
19097
16106
5867
-4924
-9508
-6344
3297
14574
17360
7683
-6974
-19606
-27185
-25891
-15751
-1849
11976
22318
26149
24733
18534
5401
-9778
-16825
-13906
-8720
-7538
-9176
-10462
-13181
-17605
-15278
-1615
14252
22938
24623
22334
17616
10357
50
-8797
-10990
-11071
-15355
-19744
-18614
-14801
-12130
-7705
3270
18048
26003
22054
15127
15160
17737
10800
-6393
-20321
-21681
-16658
-13104
-8345
887
9233
10390
5850
2936
6691
14908
21884
24076
19899
8956
-6046
-19167
-24550
-21003
-11582
1904
16927
24633
17816
927
-15720
-24509
-21824
-9244
6622
17032
15009
3299
-5595
-5022
-457
2764
5398
8608
10006
4302
-9580
-22869
-26333
-19992
-8343
4385
14777
22890
28659
27222
16177
1401
-8476
-9290
-5704
-6617
-12470
-16424
-17180
-17303
-14760
-6336
6418
17082
19750
17136
16070
14936
8883
1696
-481
1016
-359
-9063
-20698
-25577
-21839
-14776
-5924
4573
13028
17132
18028
18773
22035
24000
18227
7307
-1944
-9111
-16094
-21828
-22866
-14944
-307
11222
14760
13169
9599
7957
11114
15775
18003
16430
8273
-6432
-21811
-30852
-26603
-7832
13681
24753
23142
12404
-1395
-10421
-12588
-10219
-4547
1023
2901
1409
-3546
-9518
-8544
568
10251
16143
16423
8735
-4648
-18620
-27211
-23811
-10140
4469
15853
22267
20625
14468
9727
5838
2933
2843
3834
2665
-4029
-17936
-29714
-31229
-25690
-15494
-544
13882
21867
24987
24966
22535
17433
8825
1764
290
-4115
-16069
-25599
-26669
-23388
-18651
-12528
-3072
9873
18580
18869
17769
19187
21255
23145
19063
4513
-11369
-19519
-22570
-24655
-25287
-19003
-1360
17322
22238
16235
9626
6319
10513
21317
26546
18818
3277
-10597
-16843
-20064
-24533
-18161
5413
26297
26342
11302
-4151
-10629
-8284
-2867
5036
13033
10191
-4069
-17311
-23237
-19531
-3924
15090
25659
24755
13663
-2427
-16123
-24587
-22674
-6583
9963
12015
4943
-1045
-3640
-2313
1451
6663
13783
15566
6032
-7600
-18534
-24705
-20993
-10427
-3973
-1564
3499
11687
19846
22595
19119
18243
20335
14071
-403
-13438
-21216
-22310
-18988
-18588
-20242
-17675
-10389
973
13164
18912
19794
20544
16858
8933
4301
2666
160
-3885
-11327
-19771
-24099
-24482
-18185
-780
18718
28428
26079
13272
-1606
-4157
5272
13699
12458
1273
-12742
-20403
-24006
-23826
-11256
12461
29346
31292
20175
649
-11477
-10269
-596
8686
8059
-4431
-15899
-19448
-19537
-14010
943
16963
23798
18055
3952
-7826
-11966
-10254
-1251
10675
11477
-131
-11188
-14072
-7582
6513
20529
26825
20549
2238
-15458
-21362
-20208
-16431
-7665
396
-519
-7146
-10720
-5637
6437
17634
24992
28700
21689
3439
-11777
-16458
-15934
-14536
-14203
-15854
-18337
-20798
-17877
-3604
14939
26337
29814
26252
14891
3694
3023
10822
15839
8807
-8075
-23058
-30097
-31397
-22248
449
22128
29056
19542
862
-12140
-9485
4114
19630
25111
13141
-5919
-19152
-26474
-25351
-11497
11397
29432
29232
8695
-15452
-23988
-15996
801
14614
15225
1962
-14954
-25257
-23588
-10649
7663
23267
27998
16780
-2398
-14073
-12822
-3583
6597
10136
4542
-5769
-14480
-14908
-4369
10940
20897
18976
6435
-8391
-16448
-13853
-4481
3198
3065
-4477
-12415
-13821
-8519
1524
13511
21054
20586
13312
2639
-4013
-3355
-795
-639
-5049
-14950
-24233
-25502
-17566
-4679
5897
11268
14026
14004
10725
7504
6491
8215
11805
12426
6309
-4475
-15486
-23195
-25425
-22274
-15905
-7119
6018
21279
27794
18583
3427
-2932
1801
11687
20442
19762
5828
-12702
-23755
-23800
-15828
-2076
13624
20686
12063
-3782
-12270
-6979
7822
19156
15045
-1603
-17083
-22961
-19010
-7901
4817
12883
14181
9772
1799
-5819
-7318
301
9463
8871
-59
-8802
-14280
-14229
-6718
4734
14136
15461
7239
-4085
-11005
-9177
17
7665
6357
-3855
-16397
-20870
-14215
-2425
9065
15257
13726
8438
4207
4601
8016
7378
2531
-2683
-8206
-11567
-12606
-14737
-14478
-9188
-2852
2542
6521
9389
12230
12783
10677
9206
9400
11120
11789
5231
-8442
-19293
-20193
-15922
-14046
-14684
-12899
-3424
11359
19445
15177
4937
-1336
3791
14674
18689
13720
1637
-13582
-22322
-22719
-15420
647
13876
13695
2793
-11167
-13286
1756
17150
19946
8518
-11099
-22178
-18412
-7098
6858
14654
10871
2416
-5632
-8063
311
12310
17160
9793
-6848
-19907
-20208
-10015
3495
13099
16226
12477
3340
-3408
-3406
1369
7194
6088
-3240
-12879
-17949
-13746
-3360
552
15
2740
6016
11025
16934
16868
12300
4867
-4608
-9363
-9049
-6594
-3846
-8348
-17898
-19578
-12658
-3824
4495
8439
6067
3982
7915
13742
15954
15211
12469
6610
-2148
-8559
-6308
-3115
-10248
-21387
-28133
-25327
-5087
19567
25619
13555
-3860
-11178
1241
19471
28552
24698
5009
-17539
-28153
-28915
-16405
6211
17700
11809
-2628
-13490
-6141
13496
25541
21674
2077
-19798
-25138
-15438
-1691
8288
7591
66
-5805
-6799
1024
14605
20890
12644
-4989
-18776
-18793
-7918
4324
9241
3970
-3947
-5440
-368
6504
11915
12910
6493
-4648
-13004
-14591
-10379
-4706
-3616
-8397
-12483
-6879
7835
19587
21973
17792
8731
177
-1320
1309
2801
626
-5044
-10037
-13500
-14870
-10740
-5984
-5281
-4489
-2824
351
8022
15933
20000
19874
14637
8160
4006
1009
-1151
-6132
-16588
-25273
-25852
-18125
-4197
8342
11974
7031
-435
-1327
8449
21360
26647
18730
-24
-18700
-26569
-21088
-7108
5064
6923
-401
-9609
-12165
-2780
13239
23303
18248
-755
-19471
-22501
-9745
6742
13986
7194
-4629
-9719
-4612
7889
18232
16849
5522
-8223
-16590
-13034
-1114
8688
9674
1994
-5204
-2819
6107
13186
12195
1595
-10557
-15043
-11734
-4711
1165
705
-6291
-13467
-12616
-1395
12727
20106
17778
9366
2452
3604
10042
11987
5545
-4399
-11986
-14401
-12366
-9287
-8039
-8991
-9704
-7296
-1912
4673
10192
11566
9368
7895
8966
11080
11633
8579
2430
-4654
-10305
-13410
-15632
-17422
-15846
-9227
823
9832
12348
7720
1132
-1050
4660
14725
19972
14427
44
-15402
-23071
-19190
-7728
2273
2210
-7964
-17431
-15164
-651
16248
22449
13147
-2017
-9420
-5037
4465
9284
5302
-3332
-9696
-8769
-155
10136
14274
8484
-4725
-15490
-13316
495
13086
13368
2244
-8494
-7966
2729
13099
13979
4321
-9116
-18005
-18131
-9988
1197
6974
2991
-6045
-10235
-3064
11213
20544
18090
8552
1717
2495
6790
7870
4132
-1953
-7589
-11053
-11604
-8571
-3656
-1775
-5098
-9490
-8452
-433
7820
9025
4463
1597
5220
11834
13873
9430
3224
-267
-957
-1589
-3140
-4550
-6473
-10204
-13686
-11784
-2217
8853
11571
3782
-5631
-5728
4365
14359
14274
3775
-9279
-17007
-17189
-11683
-4020
830
-938
-7864
-11965
-5162
10151
21285
17935
3217
-8472
-6711
3921
10533
5661
-6238
-14327
-12598
-3109
8219
14980
13290
3999
-6733
-9833
-1829
9778
13261
4168
-9557
-15230
-9055
1146
5477
1342
-5596
-8806
-6882
-2040
2956
5576
4049
-1065
-5307
-2970
6198
14846
14720
5293
-5082
-7343
-711
7637
10606
6852
-177
-6794
-11667
-14153
-13405
-10139
-6754
-5378
-5444
-3647
1715
8526
13466
14907
14213
13345
11920
8938
4652
392
-2445
-4368
-6583
-8876
-10804
-12287
-13453
-13673
-10191
-1410
9584
16615
14895
6500
-375
580
8371
15131
12734
687
-14255
-23752
-23569
-16590
-8962
-5040
-5240
-5537
-1466
7555
17691
22349
17821
7311
-2067
-4523
-426
4077
3895
-1078
-6696
-8266
-5309
-805
2096
1686
-823
-2828
-2586
210
3204
3382
662
-2017
-682
5107
10224
9309
1902
-6607
-9342
-5305
466
2454
-882
-5562
-6703
-3175
3159
8814
11278
10576
7471
3584
745
-711
-853
-432
-773
-2195
-5010
-8809
-11491
-11336
-7779
-2481
849
555
-1681
-2402
1161
7635
12854
13919
10806
6473
3991
3634
3904
2967
20
-3952
-7643
-10041
-10638
-10305
-10723
-12996
-15971
-15525
-7767
6315
19918
24955
19302
9468
4863
9052
16430
17401
7249
-9634
-23701
-27775
-21853
-12352
-6574
-6979
-9546
-7169
3349
17061
24624
20656
9274
493
-6
4052
4468
-2283
-10835
-13163
-7201
1898
6888
5002
-704
-5594
-6292
-2308
3236
5662
1539
-7287
-12987
-9173
2511
13153
14253
6960
103
39
5257
8294
4238
-4013
-10700
-12144
-8690
-3933
-360
1092
736
1406
5024
10420
13999
11723
5037
-67
-372
2085
1402
-5150
-12515
-14940
-11673
-6868
-5365
-5744
-3436
2397
9125
12686
12454
11970
12485
12798
11401
7397
2689
-1493
-5683
-8846
-10414
-10626
-10107
-10561
-10763
-8391
-4809
-2530
-2922
-3109
2797
13777
21676
19587
8534
-156
2927
13791
20550
13487
-4933
-21345
-26693
-21588
-13407
-10244
-11717
-12624
-9036
789
12191
18738
18067
11231
5068
5187
8886
10353
4291
-7224
-14267
-11866
-2776
5113
4478
-1776
-6556
-6144
-871
3150
1898
-2903
-8340
-9494
-4397
3613
10567
11708
6641
1165
-256
3431
8026
7112
790
-6283
-9448
-7237
-3829
-2655
-2919
-2562
43
3452
4815
4271
3585
3928
4878
4296
1461
-1592
-2858
-1982
-445
-848
-3559
-6503
-7824
-5984
-1626
2813
6544
8851
9839
10718
10413
8766
6456
3248
917
-817
-3610
-6656
-10157
-12479
-11818
-10232
-7681
-4202
-457
4517
7229
5372
1674
-672
3364
12465
18140
16030
6201
-4105
-6123
-1786
2710
1215
-7803
-16168
-18354
-14490
-7659
-4277
-3982
-2281
2700
11905
19965
20911
15191
5561
-1215
-1257
1208
1720
-3032
-10714
-13806
-10595
-4233
-195
-2131
-5314
-4423
1046
7376
7837
1615
-5907
-9513
-6474
-173
4060
4611
2450
1020
2416
5051
6816
5965
3164
963
95
-416
-2477
-6326
-8975
-7813
-3183
1057
952
-2676
-5319
-2863
3945
9566
9915
5781
1921
2189
4815
5466
1909
-3804
-6965
-6282
-4502
-4505
-6340
-6154
-1340
5841
11152
11887
9979
9403
10541
10637
6849
-239
-6372
-8975
-9103
-9356
-11084
-12348
-10916
-6958
-2015
2277
5400
7138
6662
4661
4178
8181
15694
20547
16629
4749
-6835
-9607
-3156
4149
3381
-6129
-16563
-19587
-14158
-6784
-3947
-5492
-5605
807
11996
20650
21077
14102
6351
3625
5278
6120
1795
-6582
-13334
-14380
-10250
-4971
-2269
-2097
-2547
-2295
-1267
-466
151
1085
1944
2300
1659
523
214
1024
2905
5198
6705
6877
5225
2430
322
-232
411
66
-3373
-8670
-12231
-10656
-4516
1034
2088
-289
-1273
2450
8008
10213
7504
2993
995
1571
1406
-1174
-4669
-5914
-4131
-1970
-1830
-3715
-5161
-3898
-809
1682
2284
2141
3602
6626
8917
8722
6431
4050
2320
262
-2655
-5877
-8263
-9326
-9322
-8158
-6110
-4257
-3396
-2817
-355
4738
9877
11353
8331
4771
5870
11892
16422
11769
-2272
-16052
-18626
-9010
2042
3193
-5548
-13900
-13244
-5504
845
1217
-1394
-1446
2797
8544
12245
12157
9105
5874
4931
5988
5516
639
-6444
-10249
-7952
-2860
-798
-3288
-6608
-6534
-2845
692
971
-1316
-2582
255
5950
9749
8270
3223
261
2549
6985
8089
4050
-1224
-2785
-248
2609
1761
-3360
-9283
-11757
-8921
-3042
1130
1203
-795
-769
2991
7803
10092
8984
6341
4590
4204
3912
2312
-924
-4158
-5376
-4627
-3962
-4956
-6069
-4419
-196
3138
2929
606
-262
1454
4170
6420
7848
7865
5239
624
-2706
-2746
-1627
-2996
-6948
-9741
-8987
-6319
-4323
-3090
-1284
746
1738
2557
5527
10330
12788
9746
3758
627
2711
6044
4834
-2056
-9963
-12890
-9183
-3039
-367
-3224
-7892
-8908
-5038
-64
1788
444
-382
2268
7868
13236
15081
12541
7697
3974
2961
2343
-1150
-7097
-11264
-10652
-7816
-7681
-10838
-12667
-8887
-834
5954
7669
5151
2456
3301
7787
12157
11850
6349
750
212
3744
5356
1592
-3925
-5531
-2843
-433
-1597
-4814
-6824
-6657
-5038
-2472
417
2222
2271
2414
4796
8017
8358
5057
2056
2936
5799
5789
1692
-2668
-3674
-2362
-2346
-4762
-7147
-6803
-3893
-989
-148
-841
-670
1863
5216
6132
3507
97
-485
1940
4009
2990
-295
-3152
-4280
-4503
-4953
-5722
-6100
-5270
-3001
-321
954
307
-203
1857
5830
8332
7544
5350
4193
3621
2081
698
1973
4587
3128
-4834
-13781
-15572
-9063
-1419
618
-1970
-3235
-100
4886
7755
7672
6914
7845
10621
13055
12398
8055
2764
102
380
109
-3657
-9466
-13169
-12811
-10158
-7664
-5801
-3956
-2142
-473
1853
5317
8366
8845
7165
6220
7427
8524
6696
2741
193
503
1029
-1396
-6248
-9887
-9879
-7567
-6188
-7197
-8870
-8404
-5127
-1358
174
-324
239
4007
9101
11526
9925
7115
6475
7999
8813
6747
2250
-2685
-6107
-6808
-5118
-3434
-4430
-7671
-9252
-6293
-1004
1690
466
-628
2436
8284
11855
10582
6844
4355
3982
3925
2631
246
-2250
-4125
-5091
-5320
-5378
-5616
-5526
-4328
-2288
-832
-864
-1379
-385
2786
6523
8502
8043
6597
5764
5215
3335
85
-1937
-688
1509
-444
-7878
-15054
-14767
-6895
976
2168
-1831
-4080
-666
5560
9167
8009
4591
3049
5305
9192
10150
5940
-98
-2262
388
2226
-1812
-9170
-12728
-10070
-5947
-4901
-5354
-3441
368
2404
2089
2782
6027
8966
9025
7715
7300
6504
3101
-949
-1348
1655
2549
-1724
-6977
-7504
-3972
-1985
-3993
-6574
-6098
-3487
-1781
-1584
-1235
81
1735
3405
5289
6784
6936
6280
6350
6951
5880
2340
-1134
-1768
-406
-400
-3080
-6255
-7433
-6778
-6042
-5835
-5200
-3341
-674
1872
3913
5804
8057
10508
11961
11104
8050
4513
1980
159
-2131
-4996
-7395
-8784
-9571
-9760
-8461
-5500
-2467
-1024
-694
534
3616
7407
10050
10508
8887
6338
4596
4316
3712
515
-4147
-5823
-2463
1458
-570
-8597
-15045
-13240
-5035
1861
2772
115
-851
1961
6225
8411
7389
5381
5675
8758
10964
8338
2021
-2167
-698
2771
1680
-5028
-11373
-11677
-7144
-3633
-4349
-6686
-5971
-794
5642
8661
6525
2333
1242
4930
9230
8527
2459
-3429
-4241
-1246
437
-1628
-4922
-5791
-3604
-757
38
-2063
-5387
-6671
-3881
1194
4246
3361
1460
2415
5755
7385
5368
2539
2451
4683
5777
3770
75
-2685
-3231
-2181
-1383
-2586
-5527
-7371
-5529
-1204
1590
1173
416
2446
5833
6561
4003
2013
3490
6430
6941
4416
1626
585
513
-182
-1841
-3980
-6220
-7934
-8032
-6118
-3289
-1015
268
924
1210
1590
3158
6226
8672
7514
2838
-1244
-955
2496
4063
819
-4445
-6416
-3511
-16
-1412
-7845
-13100
-10860
-1820
6568
7940
3611
262
1865
5820
7330
5533
3758
4794
7750
9600
8364
4438
-188
-3546
-5200
-6502
-8719
-10860
-10507
-7274
-3982
-3175
-3545
-1648
3243
7980
9585
8588
7445
7230
7246
6771
5508
3011
-542
-3323
-3562
-2422
-3020
-5841
-7349
-4842
-837
-38
-2777
-4520
-2288
1302
2016
-172
-1644
-405
1826
2820
2730
2918
3677
4390
4849
5032
4360
2535
704
235
456
-772
-3812
-6161
-5702
-3803
-3535
-5312
-6165
-3754
502
3350
3789
3798
5268
7649
9142
9098
8243
7054
5111
2258
-530
-2184
-3019
-4430
-7096
-9973
-11332
-10436
-8019
-5374
-3248
-1454
695
3495
6238
7774
7876
7660
8099
8534
7531
5061
2575
635
-1940
-5391
-7030
-4474
-476
-1286
-8600
-15623
-14116
-4512
4238
5335
1620
734
5200
10296
10996
7866
5260
5814
8154
8906
5786
-468
-6182
-7620
-5071
-3300
-6251
-11766
-13670
-9421
-3331
-901
-1871
-1255
3592
9620
12235
10705
8202
7736
9298
10347
8149
2283
-4227
-7041
-5140
-2708
-4506
-9493
-11491
-7149
-916
265
-4121
-7600
-5165
662
3809
2425
215
876
3929
6458
6819
5525
3946
3397
4496
6018
5258
1183
-3302
-4241
-1870
-742
-3664
-7717
-8287
-5482
-3607
-4518
-4824
-1102
4644
7288
5312
2531
2989
6363
9263
9362
6973
3747
1266
347
294
-885
-4266
-8068
-9323
-7611
-5670
-5624
-6078
-4264
-87
3716
5199
5236
5571
6417
6951
7017
6989
6516
4792
2025
-582
-2507
-4373
-6399
-7583
-7301
-6661
-6977
-7508
-6359
-3480
-915
521
2779
7144
10755
9354
3574
-338
2256
8323
10684
6897
1841
847
2820
2237
-3273
-9855
-12137
-9149
-4625
-2599
-3772
-5635
-5134
-1409
3337
5781
4861
3051
3499
6177
8003
6907
4375
3122
3351
2794
115
-3277
-5146
-5018
-4274
-4372
-5599
-6995
-6927
-4335
-194
2811
3056
2150
3096
6218
8333
6713
2658
-128
-106
714
-65
-2170
-3493
-3066
-2065
-2043
-3023
-3570
-2387
305
2814
3435
2141
711
901
2541
3746
3029
840
-1070
-1475
-660
117
-22
-704
-715
490
1841
1766
397
-126
1774
4747
5731
3526
97
-1962
-2244
-2107
-2296
-2208
-1388
-577
-770
-1887
-2866
-2722
-1234
979
2711
2882
1646
560
1032
2610
3413
2387
558
-311
109
461
-507
-2373
-3501
-2908
-1401
-686
-1370
-2116
-1186
1313
3319
3251
2010
1846
3476
5202
5116
3428
1933
1633
1701
896
-718
-1952
-2116
-1921
-2515
-3877
-4660
-3833
-2155
-1380
-1940
-2138
-212
3295
5968
6262
4968
3823
3488
3335
2557
855
-1471
-3443
-3862
-2743
-1868
-2871
-4877
-5401
-3792
-2222
-2423
-2983
-1511
1460
2913
1629
-96
230
2053
3107
2705
2040
1931
2027
2047
2174
2071
1082
-221
-254
1024
1316
-916
-3747
-3900
-968
2316
3789
3837
3467
2533
1014
260
1232
2567
2277
732
-19
310
-241
-2507
-4392
-3798
-1684
-488
-543
-71
1662
3193
3201
2276
1584
1174
583
170
527
1151
926
-264
-1457
-2017
-2147
-1924
-1026
190
502
-513
-1434
-631
1470
2895
2649
1712
1354
1527
1436
747
-356
-1657
-2721
-2736
-1515
-273
-359
-1375
-1554
-195
1383
1875
1778
2307
3360
3697
2889
1771
877
-194
-1568
-2362
-1959
-1286
-1641
-2761
-3236
-2662
-2215
-2721
-3182
-2157
92
1777
1753
824
577
1435
2362
2229
1213
655
1443
2781
2928
1209
-955
-1504
-49
1729
1777
-510
-3838
-5924
-4982
-1326
2189
2628
429
-581
2362
7005
8450
5343
1463
722
2212
2045
-773
-3157
-2472
-79
619
-1227
-3179
-2852
-355
2272
3315
2677
1353
582
865
1511
1664
1273
1096
1615
2098
1576
63
-1472
-1880
-932
415
719
-818
-3119
-4027
-2917
-1577
-1997
-3369
-2781
474
3380
2816
-347
-2153
-632
2005
2710
1275
-75
-28
358
-265
-1637
-2432
-1920
-692
262
599
552
459
383
187
112
685
1947
3080
3008
1729
468
68
85
-322
-943
-530
1229
2897
2964
1572
395
561
1320
1370
467
-447
-496
-153
-423
-1468
-2562
-2849
-2334
-1544
-578
537
1451
1709
1403
1523
2590
3767
3981
3133
2212
1820
1236
-158
-1729
-2220
-1453
-1199
-3042
-5778
-5897
-1247
5272
7462
2703
-4141
-5337
658
6842
6270
718
-1898
2095
7547
7645
2575
-1757
-1533
1370
3066
2096
-667
-3772
-5427
-4309
-1562
-422
-2263
-4084
-2360
1622
3433
1804
346
2240
5678
6861
5136
2642
834
-570
-1821
-2713
-4159
-6858
-8560
-6083
-370
2977
616
-3376
-2846
2297
6566
6513
4589
4035
4066
2522
-66
-1315
-767
-241
-522
-922
-1352
-2068
-1917
969
5417
6974
3716
-563
-960
2077
3427
606
-3066
-3291
-181
2214
1099
-2189
-4102
-2472
1401
4261
4270
2762
2464
3656
4074
2695
1223
1434
2144
1024
-1260
-2256
-1834
-2373
-4680
-5936
-4079
-1287
-824
-2541
-2954
-243
3364
4805
2778
-852
-1407
4315
13339
16291
6888
-7433
-11913
-2485
7888
5102
-7035
-12703
-5921
2663
1222
-6936
-9796
-4002
3931
8021
8412
7936
7183
7124
9725
12308
9233
504
-5832
-3566
1713
141
-7589
-10828
-4635
2691
2452
-2960
-5560
-2059
2876
4228
2790
-357
-4809
-6232
-889
7840
11179
4933
-3197
-2999
4181
7920
3160
-4075
-6328
-3692
-1444
-2723
-5369
-6469
-5894
-3767
-387
2056
1948
924
1809
4570
6853
6972
5251
4250
4758
3900
993
-1931
-4067
-4220
-2059
-944
-3003
-5492
-4548
537
5771
5810
1446
-605
2872
8098
9997
7407
2774
-1373
-3362
-2292
-812
-3190
-8280
-9175
-1780
7325
6202
-5746
-13828
-6705
8252
15016
9388
2041
2505
7609
8654
3860
-1549
-3833
-3818
-2778
-995
-968
-5353
-10740
-10131
-3108
1766
-1783
-8289
-7718
1289
9872
10053
4959
3730
8519
13732
14283
9185
1642
-3138
-3257
-1880
-3539
-9102
-13269
-10345
-2558
2263
6
-4633
-3388
3877
9814
11245
9746
6854
4495
2789
494
-923
-1055
-1751
-1340
1455
2209
-1404
-5022
-3600
3614
11033
11098
4354
-1397
-1684
658
346
-4131
-9691
-12040
-9099
-3690
-552
-888
-2553
-1547
4121
9865
10787
8308
6047
6249
8052
6632
155
-6938
-10571
-8618
-1210
4202
-237
-11216
-18196
-12953
2027
11489
5633
-5595
-6660
5339
18466
18589
6360
-4512
-4882
2384
8250
6621
-394
-6589
-8077
-4903
-1515
-3526
-10064
-13877
-10115
-1400
4651
3551
-50
1041
6846
11897
12237
8470
4272
2186
1562
689
-1351
-4540
-7114
-6323
-2709
-685
-2612
-5640
-4780
1505
7702
6711
-858
-7964
-9154
-4543
873
2309
10
-2587
-2456
979
5010
7346
8945
11072
13242
12970
7509
-423
-4209
-2740
-1261
-4653
-12860
-19906
-19655
-12943
-5605
-1677
-94
1967
4433
7079
10872
14247
16624
18625
15915
7105
-1467
-6610
-6500
689
4856
-3508
-15478
-19654
-14188
-2749
3000
-3101
-7728
-800
9609
14483
11807
4541
568
3116
7730
11263
11070
3588
-7602
-12503
-6453
2686
2062
-9186
-17699
-13516
-944
8288
7870
3342
3133
6403
7795
6897
5428
3878
3614
4990
5158
1528
-4924
-9041
-5351
3193
6244
280
-7033
-8202
-3474
1738
2947
277
-3989
-7543
-6974
-1588
3618
4212
1799
2193
8598
15334
14294
7093
1885
2140
4251
2643
-2876
-7376
-9791
-12293
-13185
-10950
-8890
-10092
-12414
-9502
581
9402
9497
5630
6597
13916
21280
20465
10000
-1955
-5064
3310
13315
10513
-6839
-23717
-24656
-10740
1265
-1670
-13280
-17346
-7416
8347
17842
17271
11915
6867
4075
6147
12789
15511
6118
-9371
-15073
-6764
1167
-4472
-18134
-23794
-15559
-3096
3245
3294
974
-1313
-658
4774
11844
14006
8021
-421
-1945
4227
8750
3694
-7047
-11219
-4313
3822
3017
-5116
-11790
-11093
-4698
1747
4198
492
-7496
-11336
-5475
4117
8237
5891
3609
5907
9360
9277
7400
7061
7350
6057
3084
316
-915
-2685
-7639
-13717
-15679
-11467
-5640
-4903
-8974
-9971
-2707
9086
17356
17313
10772
3400
200
3624
11911
18050
14470
178
-17093
-25077
-16850
184
9693
3791
-9036
-14509
-7530
4439
11079
9033
1800
-4595
-4059
5168
16022
16794
3267
-14067
-19480
-9900
2025
3135
-7015
-17347
-17193
-6620
6103
12891
9299
-1639
-7972
-920
13327
20382
13059
-2056
-12179
-12021
-6212
228
4846
4202
-2520
-8819
-6669
3414
11283
8502
-563
-4561
-1192
628
-4239
-8887
-6142
-1061
-2530
-7470
-5102
4970
11257
8534
5739
10430
16158
13652
5503
135
-1807
-5663
-11722
-14603
-12805
-11537
-14202
-16489
-12014
-938
9441
12039
6858
266
-1386
4028
14282
22650
19687
2457
-16872
-20050
-4470
11755
11337
-3293
-17747
-23087
-17904
-3267
13182
16775
3037
-10777
-4966
15962
28699
20461
1284
-11533
-10879
-2199
3403
-1797
-14967
-24789
-22430
-8600
8880
19596
15485
-262
-11151
-3852
14194
23040
14358
-2099
-13631
-15446
-8582
1994
7773
4422
-1765
-1993
3596
9260
13013
14677
10297
-1630
-12763
-13731
-7804
-6374
-12497
-17598
-14323
-4818
4693
11163
14535
15100
13774
12589
12740
12828
9979
2793
-6453
-13177
-15275
-15806
-18000
-19225
-14437
-5252
1158
2055
1594
2797
5690
11815
20628
21918
7025
-13069
-16735
-2179
10199
7521
-1938
-9955
-18751
-25067
-15742
7258
20669
9821
-8822
-10820
7163
26759
31816
21188
1310
-12706
-13765
-6692
-1377
-2400
-9031
-17314
-19025
-7846
9268
16767
10334
960
-2006
275
5500
12651
14224
1821
-16575
-21339
-6919
10416
15224
9599
3680
1283
1750
5730
12003
13637
4839
-10402
-20801
-19517
-10580
-3614
-3981
-9111
-12052
-7371
4571
16896
21701
17882
11865
9563
10644
11298
8784
1942
-8479
-18434
-22824
-20382
-14141
-7794
-3780
-3149
-4192
-2471
5509
18501
29409
27933
9728
-13805
-22397
-9889
7100
10111
-841
-14692
-24532
-25880
-13717
6235
15888
7243
-4713
-2785
10533
21990
25678
21912
10194
-5925
-16220
-14726
-6999
-2239
-4307
-11318
-17098
-13757
111
15076
20177
14002
2997
-5959
-7876
-1411
7299
8427
-175
-9820
-10922
-2176
10106
17604
15506
6233
-2193
-2986
4103
12450
12099
-1791
-20473
-27280
-16793
-1858
3524
103
-3796
-5447
-5382
-557
10470
20847
21750
12677
1520
-3241
387
5724
3421
-7461
-17483
-18672
-13522
-8999
-7047
-4328
3074
15962
28218
28318
11801
-9311
-17342
-8157
6808
14917
11793
-431
-16042
-26817
-25853
-13112
2854
10007
3598
-7025
-7384
4934
18545
24023
21675
13010
-2082
-16474
-18288
-7485
2267
2317
-2288
-4956
-5234
-2056
7215
17466
17312
3964
-11877
-18448
-13871
-4149
3871
6420
3553
-2037
-6534
-5701
2363
12900
17091
12293
5359
2858
3287
1929
-2263
-7466
-11522
-11933
-7881
-2575
148
103
-1002
-1388
2616
13012
22519
20085
7097
-2613
-2147
775
-1211
-5125
-7090
-9855
-15450
-19550
-17381
-8562
5092
19605
26620
18812
-252
-16105
-15646
653
18482
22594
11023
-5415
-17055
-22420
-21043
-10096
6512
15833
10642
-487
-4266
2344
12866
20172
19942
10948
-3411
-16267
-21697
-17557
-6508
3925
6269
676
-5406
-5586
1014
11211
17997
13170
-2570
-16195
-16971
-9360
-3296
645
5848
7754
1016
-6972
-3691
9784
19514
17212
8149
639
-3616
-6686
-8642
-8807
-9127
-11275
-11681
-5538
3768
6893
2948
2572
11280
19720
18436
12137
9080
6165
-2948
-13192
-14872
-9530
-6802
-9605
-12774
-12891
-10197
-3587
7939
19568
22516
12966
-2641
-11840
-6655
8757
21521
21457
8198
-10991
-26064
-28382
-16541
632
11114
10315
2626
-4683
-5525
2829
15917
23145
17707
3713
-9274
-15319
-13348
-4452
7306
14253
10297
-2364
-13383
-12816
-936
11270
13229
4966
-6060
-14436
-17990
-13983
-2608
8017
9209
3005
-1470
-698
2429
7359
15236
20869
16014
1919
-10130
-12845
-10355
-9421
-9853
-7718
-3516
-1675
-3167
-3439
1149
8422
13778
15466
13972
9083
1127
-6678
-10435
-9251
-5250
-2108
-4119
-12237
-19369
-15038
2010
20170
26712
19290
4634
-8295
-11633
-2022
14365
24165
18483
811
-17598
-27099
-23975
-10647
4982
13244
9814
-405
-7553
-5029
6016
18564
24865
20970
8548
-6323
-16417
-16794
-7204
6842
15650
11538
-3285
-16518
-17021
-5916
6230
11475
9271
1545
-9322
-17040
-14158
-1826
9263
11069
5971
-75
-5111
-7625
-3014
8921
18068
14152
442
-10211
-11262
-6876
-2094
2312
4573
930
-6715
-9795
-3995
4865
9712
10749
10689
7848
315
-7616
-9944
-6952
-3084
-45
1824
-1046
-10320
-17611
-10963
8834
26193
27826
15761
1064
-8313
-9541
-2110
9843
16447
10492
-4145
-17111
-22557
-20933
-12921
884
14413
18024
9419
-1839
-4107
4589
16458
22533
18931
7498
-5931
-14491
-14451
-7549
935
6021
5341
-227
-7013
-10785
-9727
-5024
1028
5971
6813
1825
-6062
-10178
-6401
2724
11136
14544
11740
3910
-4554
-7133
-1206
7595
10456
4724
-4441
-11036
-13157
-11099
-5240
1990
5555
2688
-3060
-5239
-1284
5875
11750
13624
10905
4946
-1112
-4264
-4060
-2234
-210
1470
1450
-2314
-9382
-15054
-13580
-3548
10089
19242
18384
8500
-3492
-9514
-5868
4453
13946
15434
6640
-8149
-20732
-24440
-18104
-5658
6955
14481
14224
7747
539
-1984
1104
6493
10674
12167
10165
3897
-5157
-12290
-13101
-7782
-674
3910
4329
952
-4819
-10280
-11840
-7537
645
7656
9279
5546
557
-1144
1707
6619
10057
10294
7916
4458
1200
-1126
-2274
-2499
-2591
-3635
-6248
-9437
-10478
-7173
-834
4004
4028
786
-1226
290
3601
5940
6478
5726
3817
863
-1901
-2830
-1650
245
1111
9
-2716
-5365
-5847
-3606
-309
1960
2788
3078
3355
3376
2979
2307
1417
487
-34
-248
-1190
-3370
-5516
-6009
-5074
-4065
-3009
-749
2414
4222
3455
1867
1958
3803
5268
4784
2806
745
-629
-1625
-2864
-4236
-4654
-3293
-1092
-223
-1542
-3306
-3187
-1068
1108
1937
1823
1666
1467
856
223
514
2098
4192
5360
4597
2372
489
230
627
-497
-3574
-6412
-6771
-4799
-2269
-443
435
484
229
706
2358
4233
5208
5439
5622
5438
4149
2290
1245
1111
497
-1260
-3035
-3564
-3048
-2440
-1984
-1340
-602
-250
-205
241
1355
2361
2335
1402
712
1184
2555
3740
3930
3101
1706
310
-612
-1023
-1388
-1964
-2152
-1175
599
1651
914
-879
-1892
-1078
949
2869
3795
3442
1922
-66
-1359
-1216
-98
747
517
-492
-1454
-1868
-1566
-352
1635
3350
3522
2176
835
866
1980
2824
2760
2290
1761
801
-529
-1286
-968
-275
-18
-316
-1082
-2251
-3333
-3571
-2710
-1298
-358
-551
-1323
-1333
-112
1370
1932
1219
-212
-1092
-421
1152
1939
1518
1046
1188
1360
946
-42
-1281
-2199
-2283
-1719
-1112
-664
-244
64
130
109
414
1417
2810
3369
2313
721
261
839
1024
412
-15
267
546
133
-528
-566
26
545
741
913
1019
737
220
-140
-327
-350
-38
446
743
997
1594
2384
2776
2251
842
-455
-514
246
411
-127
-401
-593
-1591
-2837
-2985
-2038
-1102
-963
-1638
-2225
-1452
461
1639
1145
50
-495
-319
389
990
605
-340
-486
122
245
-90
172
930
1137
619
119
158
546
620
71
-402
-162
92
-592
-1734
-2219
-1862
-1048
59
1088
1351
800
328
677
1437
1476
401
-955
-1719
-1792
-1283
-401
-52
-833
-1681
-1373
-626
-729
-1211
-727
790
2216
2683
2446
2371
2306
877
-1879
-3436
-2229
99
1567
2083
1776
563
-341
153
764
-34
-1274
-1447
-989
-907
-1025
-609
568
1813
1875
763
384
1727
3137
3147
2571
2298
1900
1349
1212
1076
337
-145
592
1726
1781
633
-581
-838
-177
483
484
82
-208
-187
212
706
582
-260
-857
-528
194
405
-175
-1144
-1763
-1548
-565
880
2149
2085
453
-993
-689
482
898
517
-53
-688
-944
-377
313
445
515
724
356
-441
-697
-427
-129
418
1016
730
-162
-354
285
1083
1947
2475
1758
309
-314
-2
329
567
684
110
-773
-815
-89
554
1149
1857
2047
1456
699
209
7
110
322
399
472
513
169
-427
-864
-1326
-1965
-2219
-1781
-1035
-273
342
550
513
498
137
-598
-741
24
804
1097
847
-335
-1789
-1686
-56
994
826
600
608
540
776
1080
517
-365
-294
347
567
442
14
-900
-1416
-868
-330
-433
-87
1031
1769
1746
1338
316
-1083
-1654
-1265
-1033
-1093
-674
129
629
620
301
109
431
763
245
-767
-1255
-1169
-1098
-1222
-1516
-1780
-1378
-200
838
1115
896
444
-55
-134
288
754
1040
918
-43
-1158
-884
629
1566
1178
100
-1105
-1482
217
3143
4600
3631
1788
587
554
1521
2247
1519
196
-33
786
1603
1994
1723
759
42
23
-378
-1319
-1107
541
1632
1288
685
510
436
406
399
201
150
577
917
777
509
83
-722
-1290
-1171
-979
-949
-586
-162
-159
170
1367
2256
1658
28
-1374
-1556
-516
430
330
74
447
549
-40
-261
74
81
-125
-27
65
303
1271
2066
1551
667
669
1241
2000
2802
2584
1132
166
216
-102
-703
-341
272
-99
-771
-1023
-1172
-821
184
329
-761
-1168
-369
138
139
321
208
-286
-238
-23
-615
-1240
-1112
-1046
-1219
-865
-406
-345
121
879
695
139
574
1204
887
296
-29
-347
-109
877
1395
1221
1360
1447
775
343
555
192
-531
-252
445
474
627
1350
1671
1596
1655
1197
408
869
2262
2771
2518
2387
1791
774
513
509
-339
-946
-306
386
383
363
294
-13
129
391
-247
-776
141
1211
1021
514
582
846
1272
1610
786
-799
-1285
-468
416
1001
1106
237
-719
-422
490
815
808
688
-37
-854
-760
-79
474
883
926
430
239
805
1136
659
65
-276
-570
-484
264
1006
1009
336
-522
-973
-597
231
779
1028
1287
1244
708
416
858
1347
1259
998
995
1024
859
498
-113
-644
-397
562
1326
1449
1236
1002
1013
1313
1279
513
-156
-34
222
34
-83
239
586
580
131
-438
-151
1328
2612
2438
1354
385
-81
282
1253
1570
784
100
250
700
1192
1868
2335
2200
1665
994
505
541
718
467
292
763
1085
463
-496
-899
-567
351
1333
1539
885
108
-441
-821
-807
-339
75
129
66
153
440
748
627
-131
-968
-1055
-221
935
1591
1310
398
-347
-413
-61
106
29
208
730
991
752
621
1023
1470
1148
-34
-1056
-807
337
941
604
141
-85
-200
91
842
1472
1841
2191
2153
1442
533
-205
-668
-453
283
612
385
62
-649
-1642
-1498
78
1366
1207
77
-1056
-1050
426
1629
918
-690
-1444
-1104
-124
582
-233
-1758
-1547
172
883
329
120
381
433
318
31
-181
392
1107
741
121
381
627
337
313
80
-901
-863
1043
2693
2905
2584
1778
431
-187
14
-76
-4
643
346
-1064
-1645
-1153
-698
-114
405
-119
-767
-398
-362
-1235
-1268
-458
-345
-349
270
323
-71
416
786
20
-168
698
725
167
696
1429
1089
432
-171
-878
-718
201
381
349
1128
1067
-485
-1031
5
568
735
1434
1224
-252
-727
171
746
972
1384
1312
928
938
620
-92
206
1152
1145
661
654
581
656
1567
1878
548
-515
-183
82
-256
-306
-125
128
894
1328
395
-808
-1108
-1101
-946
37
1249
1530
900
-147
-1027
-887
-25
296
214
521
514
-305
-619
147
695
438
185
256
288
236
189
7
-372
-698
-559
49
467
329
286
917
1701
1803
1118
257
-35
436
1144
1422
1054
474
600
1638
2317
1764
1106
1383
1749
1459
1103
907
471
52
-67
-190
-166
184
46
-788
-1102
-606
-380
-564
-549
-516
-644
-688
-1070
-1988
-2392
-1841
-1195
-614
276
841
683
566
528
-117
-686
-188
615
735
463
37
-629
-859
-236
443
689
854
878
607
522
700
638
430
299
-46
-204
535
1240
668
-219
-66
483
429
34
-287
-399
-31
500
558
415
349
-266
-1210
-1151
11
1238
2100
2126
688
-1119
-1504
-635
484
1704
2451
1903
648
-631
-2163
-3175
-2617
-1588
-1196
-521
518
654
366
667
554
-322
-453
146
206
2
-190
-1023
-1522
-490
602
708
1048
1244
-150
-1469
-767
297
309
309
330
-232
-276
347
132
-379
132
407
-273
-80
1114
1389
837
428
-500
-1767
-1748
-563
460
1172
1463
854
50
-317
-947
-1542
-664
1220
2333
2428
2014
909
-412
-640
318
1077
706
-231
-666
-482
-263
75
882
1557
1554
1423
1445
1063
232
-479
-627
61
1050
1052
211
63
672
886
650
205
-638
-956
78
1140
1157
944
602
-374
-834
-181
-26
-707
-661
27
303
683
1366
1181
41
-992
-1447
-1093
-198
36
-357
-93
315
-308
-800
-114
480
419
517
435
-212
-393
113
401
385
115
-511
-538
259
391
-90
109
119
-705
-350
1395
2071
1513
846
-581
-1792
-338
1981
1798
331
-343
-974
-1172
133
1014
251
-308
-434
-1018
-566
932
792
-294
114
298
-1045
-1201
-125
-629
-1249
421
1932
1577
1575
2183
1699
819
243
-737
-1000
249
765
30
305
1234
1118
914
899
-416
-1766
-1195
-376
-559
-115
750
334
-334
-3
267
343
1001
1143
88
-642
-301
549
1552
1739
694
342
1156
614
-1205
-1412
-378
-212
11
1007
907
-352
-989
-1206
-1468
-809
199
175
-84
63
-330
-923
-996
-1660
-2619
-1921
-695
-1059
-1233
253
1066
457
469
727
-88
-395
516
532
-434
-313
708
1355
1695
1311
-340
-1621
-1153
-199
114
125
-110
-290
405
1093
358
-681
-591
-252
-94
876
1803
946
-540
-560
384
1128
1978
2781
2298
518
-940
-763
929
2687
2811
1221
-223
52
1545
2325
1144
-1039
-2030
-1216
-205
-117
-298
-308
-649
-1086
-828
-275
-314
-616
-490
-145
216
935
1737
1629
531
-281
116
970
1068
648
669
786
198
-392
-171
-54
-676
-894
-167
560
1102
1798
1674
62
-1429
-998
1008
2629
2062
-178
-1140
393
1710
785
-623
-646
290
1441
2187
1825
1127
1211
1104
66
-299
610
1270
1425
1759
1412
113
-431
279
996
1309
1265
629
227
638
527
-448
-641
-259
-1012
-2044
-1516
-157
619
760
350
-180
157
847
569
35
376
733
508
573
964
910
627
467
290
482
1113
1161
469
102
114
-118
-102
624
1154
773
71
-242
-253
-357
-462
-18
869
1272
934
575
554
890
1730
2388
1802
544
20
182
245
203
323
628
883
508
-280
-209
666
895
559
586
260
-679
-701
57
-202
-944
-576
126
250
605
1045
508
-406
-763
-932
-902
-323
48
-169
-293
-405
-515
467
1722
782
-1282
-1014
1129
2076
1555
872
106
-272
436
920
-23
-1021
-882
-412
-25
646
991
566
420
991
1210
816
810
1242
1151
466
-8
96
629
1018
318
-1154
-1297
447
1587
764
-169
-15
377
1007
2166
2457
1338
359
-171
-898
-469
1577
2300
481
-1067
-865
-204
520
1135
239
-1635
-1860
-33
1940
2772
1934
40
-651
284
353
-833
-816
378
515
-117
74
644
764
865
1153
1537
2331
3098
2685
1049
-775
-1787
-1170
923
2726
2699
1244
-244
-796
-224
797
1370
1201
295
-1140
-1889
-705
1476
2339
1268
9
200
1404
1997
1480
794
437
0
-307
287
1412
1728
841
-171
-236
389
743
802
1122
1234
635
570
1983
3134
2106
-132
-1366
-972
-35
78
-840
-1532
-992
181
958
1041
622
199
201
392
672
1356
1723
898
278
1310
2223
1256
138
497
813
-239
-1470
-1404
-55
1353
1529
837
688
900
592
457
725
72
-904
-277
652
-443
-2148
-2313
-1537
-303
1498
1963
310
-523
557
840
106
967
2611
2302
992
803
954
596
681
1121
716
-313
-915
-638
438
1199
411
-581
164
886
-623
-1862
-210
1639
1049
262
972
1155
181
-214
-290
-1031
-1007
263
570
-316
-252
538
563
676
1369
868
-628
-615
727
1071
285
-439
-844
-472
805
1221
53
-514
379
649
-311
-900
-1081
-1675
-1643
-465
-11
-903
-1158
-43
1027
1436
1493
976
246
478
1369
1490
862
450
365
606
1421
2075
1855
1527
1319
46
-1662
-1445
216
676
185
623
1028
8
-645
447
1417
1145
974
894
-446
-1898
-1242
524
782
-441
-1185
-772
31
728
1332
1561
986
-3
-334
66
31
-679
-736
227
686
-40
-627
-324
-163
-605
-592
77
20
-1050
-1526
-648
434
885
878
296
-630
-620
318
303
-810
-891
326
985
866
929
675
-144
-74
1195
2119
2290
2442
2331
1602
743
-116
-811
-410
739
1035
837
1439
1575
-121
-1732
-1488
-624
-16
1152
2422
2411
1381
233
-786
-1044
-170
712
639
-52
-930
-1399
-617
581
654
453
1239
1455
83
-664
231
681
116
280
1097
920
-194
-1007
-1030
-532
-156
-154
207
840
246
-1260
-1388
-227
119
-120
501
1378
1721
2122
2383
1996
1812
1629
-98
-2004
-1128
1277
1788
739
415
785
872
451
-639
-1550
-651
1271
1884
1394
1267
957
-7
-261
496
824
310
-393
-1053
-1386
-1348
-1679
-2038
-1051
460
406
-519
-330
391
206
-459
-968
-1456
-1387
-301
893
1337
985
-366
-2176
-2455
-588
1073
480
-1300
-1824
-506
888
889
295
184
-220
-1242
-1088
604
1329
63
-1241
-1532
-1391
-535
1167
2101
1423
511
268
43
-376
-372
180
723
840
804
1162
1481
786
-270
-106
878
1214
1187
1466
1078
-292
-1101
-800
-486
-412
-45
369
486
474
266
-50
200
972
1313
949
417
124
223
302
-365
-1158
-700
400
614
507
1028
1018
-152
-791
21
1106
1499
972
-440
-1538
-1031
267
937
885
80
-1361
-1733
-396
165
-1155
-1579
290
1796
1033
-545
-1298
-1492
-1913
-2185
-1001
1372
2282
868
119
1398
1780
151
-537
453
350
-1254
-1957
-1271
-353
858
2449
3079
1891
49
-428
947
2176
1571
685
1345
1919
733
-353
129
539
180
545
1471
1399
688
457
463
582
1369
2455
2924
2400
925
-344
476
2722
3223
1263
-509
-503
533
1759
2583
2336
1005
-973
-2615
-1886
1327
2972
333
-3004
-2719
-96
1432
1351
715
-69
-857
-1465
-1411
-41
1547
1004
-1142
-1747
-332
663
548
616
1086
1206
723
-51
-310
324
625
-239
-826
-305
-61
-295
309
906
-110
-1223
-461
912
1242
1060
798
85
-391
219
1120
954
-416
-1656
-1115
797
1576
569
-162
-167
-862
-1326
228
2050
1720
551
376
131
-1013
-1439
93
2418
3156
1030
-2164
-3090
-1348
374
848
874
202
-1599
-2895
-2164
-344
838
626
-650
-1492
-706
638
973
770
877
702
22
-334
-255
-34
679
1470
1075
-80
-312
352
549
-12
-602
-467
740
2076
1835
79
-1330
-1466
-805
167
894
813
349
144
47
294
1421
2302
1465
33
-43
854
1526
2057
2358
1576
168
-338
65
-65
-1123
-1742
-841
612
820
-165
-630
-114
277
403
1014
1493
762
-282
-83
819
643
-893
-2197
-1778
11
1402
1455
1023
972
939
603
459
713
945
1004
1023
1035
1319
2189
3082
2973
1775
497
75
584
1404
1826
1496
524
-525
-905
-454
135
248
22
-116
116
765
1270
776
-375
-533
954
2495
2382
1029
14
-35
411
835
790
-12
-906
-628
668
1264
548
15
542
767
-328
-1297
-559
879
1173
620
647
989
426
-602
-693
25
486
847
1585
1568
-160
-1578
137
3865
5094
1809
-2816
-4569
-2744
645
3808
5317
3436
-1663
-6016
-5222
97
4576
4293
677
-2329
-2722
-797
2495
5279
4731
325
-4042
-4030
-265
2837
2769
731
-1372
-2583
-2037
332
2299
1435
-1224
-2246
-524
1572
1750
260
-1282
-1606
-315
1747
2780
1816
14
-800
-287
637
1390
1897
1764
535
-1282
-2334
-1783
-238
827
543
-511
-1063
-554
674
2225
3660
3652
708
-4123
-6377
-2226
6059
10732
6515
-3065
-9410
-8008
-1447
5369
8992
7054
-408
-7964
-8299
-1235
4982
3901
-1756
-5296
-4172
-25
4928
7898
5907
112
-3429
-975
3632
4067
-508
-5517
-6981
-4749
-1183
1006
241
-2735
-4988
-3642
1295
6339
7333
3615
-939
-1860
1265
4951
5923
3835
498
-1886
-1924
52
2121
2620
1496
-343
-1879
-2047
-731
176
-1174
-3419
-3365
-614
2019
2750
2515
2370
2280
2684
4207
5452
4105
768
-1110
102
1940
862
-3999
-9941
-12073
-6969
2435
7075
877
-10799
-15954
-9449
2164
9646
10274
6880
2922
1609
5405
11902
13522
6325
-3230
-5563
-230
4513
3064
-2437
-7578
-10167
-9180
-5066
-1777
-3214
-7044
-7082
-2130
2882
4797
5498
6658
7351
7981
10409
12681
9992
3008
-1193
694
3248
958
-4066
-7084
-8013
-8873
-8652
-5968
-3104
-2313
-1494
1519
3836
2091
-922
-28
4297
7276
7161
5760
3634
628
-523
2526
5857
3256
-3903
-7413
-4009
-53
-1880
-6952
-8304
-3999
1551
3429
426
-4548
-5982
-152
9286
12688
5142
-6005
-8715
-511
9219
11160
5556
-1019
-3570
-1233
3665
6087
1622
-7184
-11275
-5824
2543
3967
-1890
-6630
-4914
283
3563
2787
-1057
-4762
-3819
2686
8445
6544
-441
-2997
2189
8158
8168
3808
118
-1406
-1563
-516
148
-2963
-9477
-13298
-10398
-5072
-4136
-7516
-9074
-5084
2007
7314
7925
4513
1100
2108
7310
11025
8774
3365
1276
3839
5718
2686
-2559
-4496
-2430
-842
-2606
-5316
-5630
-4239
-3810
-3949
-1882
2336
4958
3502
-32
-1608
1091
6976
11438
9270
944
-5425
-2863
4785
7391
2191
-3478
-3636
-794
306
-718
-2589
-5505
-8078
-6711
-1785
804
-1883
-4833
-2605
2798
5870
5138
2764
579
207
3036
6610
5675
439
-1473
4085
10203
8099
-227
-5024
-1935
3849
5289
545
-6781
-10970
-8777
-3196
-807
-3536
-5948
-2989
3141
6800
6281
4185
3153
4314
7448
9989
8543
3795
953
2759
5088
2520
-4212
-9270
-8519
-3252
1422
856
-4614
-9080
-7420
-2049
356
-1490
-2051
1919
6122
5080
-215
-3718
-1034
6597
12800
10815
996
-7297
-5662
2441
6238
2287
-2250
-1359
2296
3558
1584
-2137
-6309
-7898
-4058
1549
1271
-4729
-6749
152
7776
6689
-255
-3459
-380
3754
5272
4749
2982
905
1452
5427
7621
3317
-3239
-3703
1951
4900
-61
-7850
-10702
-7460
-2887
-1395
-3591
-6691
-6813
-2721
2119
3272
1273
1040
4730
8318
7146
2390
-649
534
3163
3498
1202
-1499
-3245
-4327
-4843
-4159
-2688
-2399
-4247
-6222
-5697
-3224
-2039
-3370
-4120
-878
4586
6334
1987
-2514
743
10457
15521
8628
-3044
-6055
1855
9123
6321
-1848
-4475
647
5586
3470
-4049
-10107
-9858
-4584
-530
-2518
-7484
-7294
-96
5729
3185
-2453
-1245
6176
9667
5155
-28
776
4683
6147
5478
5481
5321
3221
1037
840
365
-2961
-6543
-6437
-4204
-4390
-6909
-7520
-5116
-3111
-3436
-3906
-2361
442
3020
5107
6570
6959
6730
6797
6685
5272
3265
2554
2929
1941
-1265
-4114
-3883
-1612
-1255
-4774
-9016
-8760
-3334
1501
349
-4484
-5648
-571
5113
5047
-48
-3643
-522
8043
14593
11860
1602
-4956
-251
8276
7354
-2707
-7782
-1071
6506
2950
-7395
-11632
-6847
-1364
-1310
-4644
-6705
-4914
558
5794
5335
-117
-2206
3678
10407
9123
2549
191
3783
6458
4570
1698
1182
2065
2709
2584
745
-2519
-3927
-1926
-709
-3962
-7838
-6784
-3143
-3175
-6110
-5700
-1034
2829
4142
5884
8257
8167
6282
6577
8594
7974
4829
3538
4018
1667
-3233
-4732
-1409
878
-1494
-5287
-7162
-7801
-7410
-4460
-736
-441
-2569
-1432
3676
6848
5109
2019
529
217
2302
8101
11834
6031
-4168
-4920
4648
8847
-11
-8257
-2641
7823
6135
-6095
-12521
-7399
-1194
-2129
-6109
-6460
-2688
2493
6458
5945
568
-3068
1349
8962
8981
1001
-3865
-37
4590
2029
-3596
-3801
978
3301
256
-3704
-4076
-1521
-26
-2545
-7874
-10808
-7429
-926
1341
-2246
-5091
-2097
3042
4303
2586
3094
6408
8131
6218
3297
1941
1971
2435
2578
1123
-2011
-4009
-2736
-996
-2930
-6940
-7318
-3075
318
-640
-2561
-1225
1870
2635
1041
779
3524
6639
6520
2806
-655
719
6497
9856
5232
-3095
-5046
1442
6625
2704
-4522
-4392
2290
4577
-1795
-8251
-6758
-1303
-635
-5155
-7666
-4517
330
1984
575
-290
1845
5755
7405
4279
-371
-307
4857
7443
2150
-5118
-4810
2239
5631
386
-6257
-5596
782
4147
284
-6179
-8304
-4912
-1294
-2293
-5885
-5801
-681
3407
1994
-627
1887
7572
9106
5377
2725
4520
6669
5248
2208
759
279
-950
-2075
-1876
-1491
-2117
-2683
-2181
-1825
-2752
-3911
-4116
-3928
-3709
-2251
669
2736
2378
1420
1900
2344
604
-1075
1746
8112
10729
5285
-2542
-3672
2143
5925
2326
-2768
-1551
3254
2193
-6109
-11885
-8115
-532
965
-3944
-6905
-3270
2521
4204
1650
-115
2519
7678
9976
6634
1398
464
4096
5834
2042
-2091
-429
4052
3628
-1639
-3733
206
2815
-1745
-8014
-7329
-1071
1667
-2245
-6116
-4030
1074
2856
695
-473
2455
6883
8011
4629
758
1163
5161
6808
2860
-1985
-1543
2233
1875
-3763
-7374
-4877
-1875
-4013
-7371
-5153
618
2068
-2097
-5175
-3266
-36
629
129
862
2042
2601
3530
4521
3032
-66
773
6837
10192
4382
-4190
-4414
2344
3861
-3379
-8057
-2377
4578
1085
-8035
-8875
-629
3545
-2164
-7699
-3974
3460
4755
991
288
4182
6741
4823
1638
675
1764
3165
3546
2143
-100
-613
1105
1752
-944
-3959
-3207
-128
225
-3182
-5890
-4411
-811
525
-1334
-2981
-1245
2434
3627
1125
-757
1725
5645
5327
1130
-816
2037
4987
3583
-12
-1303
-352
-648
-3125
-4924
-3687
-697
627
-1398
-4540
-4794
-1281
2173
1828
-931
-1656
964
3736
3586
1092
-828
11
3225
5770
4519
345
-1785
1143
5510
5187
-455
-5699
-5832
-2753
-1904
-4868
-7007
-3587
2882
4661
-695
-5944
-4040
1447
2129
-1712
-2002
3080
5714
1809
-1617
2182
8562
8817
3315
-166
1694
4407
3183
-1310
-4814
-4176
-428
1760
-709
-4583
-3946
981
3486
201
-3964
-3477
194
2267
1911
1684
2501
3073
2878
2817
3734
5631
7384
7046
4150
1226
714
1333
512
-997
-732
524
-100
-2369
-3498
-3129
-3155
-3371
-2165
-663
-1331
-3156
-3015
-943
593
1406
2781
3604
2325
997
2196
3881
2768
620
1313
3618
3102
-238
-2102
-653
1781
2603
795
-2957
-5172
-2368
2391
1654
-4503
-6693
-1232
2711
-1528
-5873
-1214
6063
4573
-2387
-2770
3421
5124
53
-2029
3206
7980
6086
1612
285
1392
1806
784
-1619
-4939
-6275
-3597
-559
-1733
-4396
-2495
2457
2919
-2293
-5871
-3556
195
438
-1349
-1540
-16
1495
2655
3576
3699
3169
2955
2941
2183
1054
661
535
-509
-1841
-1984
-1491
-2108
-3561
-3788
-2163
-209
759
892
919
1349
2256
2984
2677
1612
1059
1477
2100
2430
2697
2746
2131
1325
1128
985
-232
-1954
-2488
-1808
-1670
-2709
-3348
-2100
291
1525
181
-2464
-3369
-1398
779
441
-705
682
3223
2350
-1577
-2887
83
1974
-355
-2385
-207
2296
440
-2737
-1812
1622
2184
25
-503
832
408
-1907
-2457
-454
990
483
-121
153
273
81
338
236
-1427
-3115
-2273
439
2098
1985
1755
1900
1458
664
710
1390
1712
1979
2658
2412
229
-1833
-1237
832
1219
-244
-1078
-743
-1206
-2974
-4101
-3509
-2321
-1457
-584
138
-116
-786
-105
2008
3446
3019
2014
1896
2434
2906
3292
3321
2115
-82
-1352
-577
717
378
-1365
-2283
-1113
829
1144
-825
-2692
-1271
3089
5729
3282
-1082
-1469
2123
3632
410
-2458
-432
3070
2480
-689
-813
2161
3105
873
-148
1712
2644
690
-592
1259
3035
1538
-829
-303
2132
2964
1685
317
-521
-1591
-2609
-2670
-1930
-924
304
1099
281
-1412
-1478
451
1704
937
183
860
1252
173
-376
1070
2422
1684
615
1437
2666
1792
-177
-531
521
621
-593
-1431
-1421
-1617
-2115
-1945
-1222
-1173
-1972
-2298
-1157
914
2503
2578
1421
558
1112
2290
2495
1746
1396
1583
946
-742
-1733
-946
291
273
-729
-1272
-936
-636
-1192
-2238
-2490
-1081
1076
1724
-147
-2536
-2335
951
4356
4719
2175
-205
-226
907
732
-489
-114
2199
3121
790
-1620
-695
1503
808
-1883
-2098
411
1247
-929
-2183
-277
1683
931
-548
-170
868
464
-553
-484
75
-110
-387
361
1698
2723
3351
3359
2254
832
601
1214
924
-235
-621
-308
-928
-2122
-1765
-69
386
-827
-1308
-293
140
-771
-1043
207
1169
795
407
651
225
-1097
-1424
-49
1162
1007
714
1336
2019
2042
2082
2368
1934
655
-165
-37
66
-148
171
858
431
-1306
-2613
-2472
-1814
-1495
-1082
-367
-141
-665
-935
-148
1290
2563
3175
2900
2029
1487
1720
1963
1570
1258
1772
2199
1228
-521
-1126
-77
1082
881
-359
-1196
-849
-60
-124
-1097
-1706
-1357
-1091
-1534
-1423
150
1541
969
-201
514
2485
2997
1835
1309
1899
1559
-371
-1908
-1716
-763
-99
466
987
989
657
477
-27
-1210
-1741
-469
1110
832
-652
-1088
-306
157
180
804
1663
1588
1063
1337
1857
1263
78
-194
205
11
-596
-605
-323
-581
-816
-120
825
893
468
469
674
664
946
1614
1571
572
165
1105
1858
1231
333
293
254
-540
-895
107
1024
263
-1270
-1735
-1136
-748
-877
-867
-510
-158
98
525
1338
2394
2927
2017
84
-886
207
1841
2002
1027
503
369
-582
-1978
-2040
-442
1135
1379
632
-225
-739
-699
-191
260
375
566
1014
991
34
-966
-884
52
725
704
521
698
1113
1260
896
480
711
1357
1252
90
-719
-123
672
-38
-1576
-1744
-248
853
230
-1062
-1495
-1044
-552
-264
175
831
1265
1151
752
658
1014
1302
1193
1179
1738
2284
1867
645
-311
-460
-89
476
965
851
44
-592
-441
-191
-595
-1016
-588
108
101
-185
134
602
317
-244
-178
73
-180
-122
1065
1964
745
-1515
-2016
-340
1136
906
-36
-396
-236
-56
80
44
-443
-1067
-1112
-444
485
1297
1649
1174
274
165
1120
1667
729
-459
-136
1193
1557
574
-204
-7
93
-723
-1427
-673
1008
1710
686
-600
-335
1304
2433
1941
748
210
279
159
-47
291
773
395
-526
-566
374
695
-200
-722
198
1089
379
-691
32
1912
2376
972
-206
-178
-317
-1418
-2131
-1356
-86
304
-173
-938
-1717
-1867
-606
1240
1484
-457
-2458
-2460
-860
655
1213
799
-303
-1231
-920
473
1529
1480
1077
1126
1387
1382
1144
754
124
-378
-82
928
1769
1959
1853
1772
1531
911
-51
-1221
-2186
-2196
-1024
387
878
444
-24
-97
-82
-32
660
2239
3549
2870
267
-1529
-105
2892
3185
-96
-2618
-1211
961
-632
-4209
-4231
-538
1275
-849
-2313
-146
1807
-224
-3173
-2223
1280
2517
1113
835
2669
3542
1834
-224
-424
437
372
-1059
-2502
-2331
-409
1316
912
-701
-799
976
2079
1358
815
1746
2439
1585
828
1591
2306
1301
-125
-122
542
249
-503
-313
536
797
253
-502
-1049
-925
156
1317
1307
426
-67
-190
-674
-882
107
1038
173
-1314
-1028
348
215
-1104
-888
874
1253
-434
-1510
-719
-134
-1191
-2340
-2021
-1019
-592
-609
-536
-285
412
1570
1834
97
-1811
-918
2100
3152
956
-496
1811
4446
2414
-2440
-3344
1071
4292
1934
-1517
-338
2968
2178
-1919
-2886
381
1959
-939
-3496
-1501
2223
3084
1495
704
1387
1894
1515
831
314
88
-96
-858
-1759
-891
1939
3327
768
-2775
-2871
-450
145
-1396
-1346
1075
2375
1047
-20
1218
2748
2338
1127
1301
2588
3004
1832
388
205
1091
1267
-332
-2433
-3102
-2474
-2057
-1925
-1016
153
-1
-897
-249
1775
2276
416
-879
453
2359
2039
158
-648
202
1014
692
-171
-771
-1073
-1127
-561
605
1146
-441
-3595
-4988
-1841
3707
5627
1175
-4688
-5157
-914
788
-2802
-5199
-642
5980
5696
-702
-3559
791
4848
2474
-1721
-1037
2316
2117
-814
-592
3294
5313
2874
-535
-1399
-162
1147
1475
793
92
643
1828
1617
225
171
1706
2055
377
-847
-455
-124
-513
-506
-497
-1682
-2469
-631
1886
1576
-545
-676
1515
3344
3820
3499
2033
-156
-780
509
892
-587
-1416
-940
-1611
-3146
-2139
632
11
-4185
-5426
-947
3548
3053
101
-930
-135
669
1504
2131
1117
-818
-925
739
1200
142
475
2353
2192
-836
-2813
-1325
1276
2442
2332
1144
-1211
-2284
196
2798
596
-3471
-2111
3472
4462
-760
-3853
-965
1542
-602
-2700
-986
831
-312
-1243
513
2138
1385
178
45
92
308
1211
918
-1806
-3685
-1769
905
384
-1312
-399
1641
1299
-486
-833
-326
-903
-1657
-927
362
736
712
1039
1068
579
809
2395
4131
4449
3041
1044
142
772
1364
638
-139
580
1343
-111
-2401
-2027
995
2967
2016
238
-103
655
1301
1604
1679
1460
1397
2053
2694
1961
148
-1031
-1070
-1011
-952
69
1095
-578
-4599
-6226
-2405
3319
4865
1105
-3173
-3300
-18
1846
-39
-1952
189
3352
1545
-3244
-3082
1843
2201
-4099
-6980
-1238
4310
2229
-1517
488
4677
4742
2217
1113
1009
1124
2603
3561
919
-2016
131
4018
2378
-2599
-2865
1145
2224
-342
-1236
-60
-816
-3093
-3099
-851
780
1056
602
-390
-446
1980
4560
3717
809
-4
1477
2363
1766
298
-1966
-3338
-1340
1707
492
-4106
-5450
-2188
-70
-1488
-2337
-584
753
220
-140
225
-28
-226
1179
3020
3450
3213
3351
2808
1194
219
67
-1528
-4355
-4207
752
5572
4226
-1733
-4498
-970
2217
-1125
-5823
-2741
5383
6758
-507
-5264
-1898
1531
-1312
-4743
-2695
973
775
-1463
-1767
-244
1605
3034
2259
-1109
-3014
-694
1740
160
-2024
-424
2017
858
-1523
-742
1860
2632
1660
639
-471
-1332
-599
891
950
96
144
251
-782
-800
2012
4774
4220
2114
1863
3146
3748
3353
2509
1236
526
1589
2786
1450
-1068
-1030
1134
1221
-1424
-2571
-153
2392
1668
-854
-1736
-501
483
-365
-1872
-1483
1631
4894
4705
916
-2731
-3346
-1918
-642
-2
41
-789
-1229
380
1842
-556
-4156
-2012
4777
6441
338
-3707
57
3531
-324
-4946
-2687
1501
98
-3392
-2085
1835
2639
1194
879
761
-262
90
1855
1366
-1350
-1942
-146
-43
-1440
-237
2780
2806
7
-1082
100
348
-643
-839
-752
-1860
-2940
-2618
-2193
-2428
-1518
1085
2958
2769
2125
2277
2574
2516
2318
1810
1102
1117
1739
1378
-354
-1734
-1428
98
1622
1787
-195
-2831
-3241
-1111
902
1369
1086
5
-2043
-2185
1701
4856
1112
-5731
-5342
2985
7681
2280
-4276
-1633
5550
5178
-2449
-4596
3208
9076
3459
-5176
-4037
3306
3748
-3232
-6067
-1698
371
-4243
-7852
-4645
755
2378
864
-500
-364
1369
3378
2986
466
-148
2069
2855
701
-317
1162
1150
-1127
-1290
939
519
-2705
-3018
-1
102
-3836
-5394
-2090
539
-1203
-3588
-2017
2806
6735
6659
3360
1296
3277
5800
4320
1394
2324
4895
2949
-1751
-2183
1055
1279
-1372
-964
1634
0
-4835
-5351
-1174
500
-1934
-2409
1254
3740
1356
-2746
-3303
1317
7087
6808
-1237
-7900
-4267
3671
3396
-2904
-1913
6083
6249
-3676
-7371
1637
7648
-375
-10169
-7786
-74
-610
-7292
-8884
-3853
421
578
-524
-115
2169
4879
5365
3250
2252
4198
4902
1706
-355
2910
6507
4600
718
873
2996
2067
-493
-1025
-1080
-2889
-3592
-1234
-167
-3466
-6073
-2452
4220
6975
4866
2404
2358
3579
3856
2257
-33
-574
1124
2321
1106
-422
17
669
-1035
-3643
-4038
-2507
-1925
-3430
-5509
-6045
-4028
-870
-62
-3225
-6888
-5951
-92
5566
5887
836
-4119
-3382
1528
3007
-1189
-2969
3255
9494
6174
-1059
-69
6961
7196
-684
-4602
176
4283
861
-4875
-6369
-4668
-3072
-1747
-545
-377
-422
739
1698
791
212
2477
5214
4740
2417
2181
3846
4092
2508
1628
1844
947
-1375
-2772
-2472
-2707
-4734
-6563
-6272
-4867
-3908
-2736
-423
1679
1986
1463
1848
2700
2711
2350
2827
3785
3943
2887
1124
-259
234
2688
4449
3154
367
-780
-429
-938
-2143
-1693
475
1651
108
-3167
-5801
-5362
-1270
2973
2360
-2612
-5091
-1256
3371
2054
-2192
-1014
5249
7113
1493
-2092
3265
9510
5913
-3222
-5321
248
2247
-3517
-8839
-7759
-4324
-3312
-3541
-3050
-2630
-2396
-1348
-427
-733
-466
1618
3182
3012
3825
6340
6720
3816
1952
2922
2818
143
-1022
911
1720
-895
-3498
-3407
-2565
-2948
-3373
-2352
-381
1151
1289
379
211
1460
1859
-6
-1175
1052
3733
3012
1120
2439
5512
5550
2523
581
1112
1598
421
-994
-615
1286
1697
-1778
-6500
-6634
-1342
2713
203
-5382
-7019
-3817
-1065
-2044
-3576
-910
4602
6104
1517
-1366
3900
10555
7894
-830
-2867
2849
4123
-3373
-8869
-4810
1535
902
-4518
-6777
-3666
472
1149
-1683
-3601
-936
3584
4298
1733
1796
5470
7280
5110
3104
3454
3401
1631
344
202
-373
-1228
-1257
-1710
-3748
-4965
-2979
11
401
-1493
-2632
-1802
-542
-715
-2276
-3109
-1640
517
822
239
1560
3712
3018
220
196
3811
6070
3872
321
-515
1001
1600
-623
-4311
-5946
-3318
1084
1835
-2688
-7242
-6099
-1316
-439
-4925
-6194
1774
10855
9202
629
247
9959
14311
5787
-2691
331
6636
4050
-3538
-5269
-1378
445
-1744
-4774
-6977
-7178
-4094
-742
-1635
-4151
-1908
3456
4476
1092
397
3837
5822
4562
3872
4611
3550
531
-1042
-481
-435
-1810
-2882
-2946
-3094
-3577
-3101
-1266
-98
-1622
-4248
-4095
-890
998
-406
-1226
1177
3019
1037
-919
1603
5628
5770
2947
1811
3102
3986
3088
1211
-403
-468
843
479
-3486
-7007
-4610
1444
2746
-3193
-8412
-5464
1406
2027
-4059
-5685
2779
10959
7847
272
2400
11620
12245
2161
-3523
1766
6159
1080
-5132
-3554
825
-136
-4940
-8111
-8731
-7677
-4876
-2614
-3635
-4953
-1797
2892
2302
-1925
-1454
4743
8488
5798
2590
4114
6881
5421
1083
-1013
-52
513
-877
-2438
-2958
-3072
-2837
-1841
-1398
-2778
-3906
-2111
704
695
-1160
-523
2754
4434
2996
1470
2236
4495
6428
6500
4030
958
456
2052
2049
106
-10
2038
1316
-3759
-7150
-3794
1972
1536
-6059
-11866
-8573
-1287
-1003
-7397
-7694
2623
9979
4045
-3509
2250
13033
10470
-2019
-4661
5049
9341
1310
-5123
-695
5249
2851
-3670
-6483
-5616
-4272
-3123
-2891
-4297
-4391
-480
3589
2938
721
3000
7547
7328
2735
632
2744
4257
3136
2167
2022
315
-2390
-2809
-1279
-1250
-2586
-1947
315
306
-2159
-2973
-1042
-53
-1759
-3042
-1224
1990
3382
2222
554
856
3117
4128
1768
-805
566
3517
2234
-2174
-2534
1971
3243
-2707
-8547
-6272
1224
4374
-713
-7991
-8854
-2553
2268
-792
-5330
-937
8901
10246
1701
-1730
6447
12473
5601
-3343
-695
7057
5625
-2685
-4589
1262
3969
-656
-5536
-5414
-2864
-1497
-1682
-2678
-3336
-2102
135
438
-586
1241
5783
7225
3612
559
1909
3999
3110
1311
786
-564
-3625
-4956
-3165
-2013
-3498
-4141
-1648
788
265
-1174
-833
299
192
-906
-1526
-750
1466
3676
3814
2581
3180
5636
5738
2444
656
2772
3866
426
-2671
-362
3370
1773
-3725
-6082
-3124
583
487
-3361
-6809
-5381
-72
2027
-2271
-5089
1208
9535
7560
-941
-542
9677
13139
3400
-4600
247
7059
2676
-6071
-5283
2535
4415
-1382
-5389
-4058
-2749
-3816
-3872
-2222
-2063
-3407
-2771
242
2491
2943
3350
4086
4036
3700
4301
4927
4006
2214
933
-345
-2265
-3346
-2382
-1072
-1441
-2527
-2300
-1055
-277
134
908
1192
-46
-1482
-861
1546
3090
2356
874
773
1891
2225
1028
148
1307
2991
2199
-872
-2531
-824
1502
817
-2704
-5791
-5889
-3271
-858
-1925
-5792
-6904
-2113
2865
809
-4352
-1802
8044
11673
3725
-2712
3527
12907
10294
-310
-2959
3692
5455
-2523
-8275
-3947
2108
851
-3456
-3090
-58
-470
-3402
-3823
-1372
729
1599
2220
2509
2610
3583
4417
2770
244
1356
5477
6286
1742
-2239
-1284
910
-431
-3695
-4808
-3613
-2148
-818
150
-596
-2535
-2776
-847
218
-645
-657
1309
2281
627
-819
261
1925
1867
1263
2000
3169
2853
1124
-528
-1114
-566
294
64
-1658
-3490
-4140
-3827
-3014
-1887
-1624
-3013
-3590
-718
2395
349
-4160
-2576
4879
7577
2010
-1233
4542
9640
4386
-3560
-2276
3646
1704
-6050
-6901
-154
2152
-3412
-6880
-3265
69
-1926
-3938
-1565
1286
1079
463
1376
1539
968
2918
6019
4904
633
362
4534
5270
273
-3026
-920
486
-2687
-5078
-2766
-490
-2015
-3086
-363
1862
373
-514
2266
3992
1156
-1331
995
4045
3042
1095
2588
4731
3160
230
623
3364
4385
3075
1285
-388
-1357
-91
2362
2024
-1990
-5210
-3940
35
2537
1586
-1606
-3563
-1515
1959
881
-4186
-4416
3205
8292
2946
-3468
1168
10167
8177
-2230
-4220
4501
8106
460
-5177
-703
3239
-1957
-7173
-3031
2903
264
-5953
-5612
-1011
-214
-1716
472
3744
2061
-1512
147
5182
6091
2385
-287
-398
-695
-1196
-361
-228
-2968
-5595
-4743
-2774
-2844
-2694
123
2117
56
-2137
-75
2905
2048
162
1911
4411
2630
-594
493
3677
2746
-882
-669
3125
3990
584
-1748
-718
261
-540
-685
625
695
-1645
-3899
-3452
-302
3037
2757
-2158
-6065
-2520
4572
4348
-3413
-5527
3450
10425
4718
-3295
435
9006
6373
-4161
-5245
4234
7146
-2238
-8951
-3446
3235
-297
-7429
-6885
-1197
401
-2139
-2603
-524
38
-861
-272
1310
1689
1993
4182
6430
5884
3432
1701
1017
671
1158
2003
643
-3205
-5370
-3041
232
-423
-3612
-3901
-465
1740
56
-1739
93
2763
1419
-2371
-2470
1848
4236
1362
-1844
-700
1633
477
-1852
-714
1978
1287
-1433
-1000
1885
1815
-1406
-2383
224
1490
-1208
-4060
-3065
440
2118
-363
-4896
-6351
-2393
2035
833
-2760
-99
7353
8143
395
-2850
4479
9499
2074
-6407
-1956
7376
5129
-5245
-7051
935
4380
-765
-3555
626
3459
587
-1905
-644
257
-208
1859
5020
3549
-419
978
6574
7040
1366
-1259
2368
4868
2213
-497
-46
-61
-2091
-2532
-1072
-1881
-4300
-2666
2586
4130
315
-1910
611
2293
-170
-1757
1214
4112
2228
-1102
-477
2836
3704
1104
-1535
-1905
-879
60
761
1539
1667
-281
-3835
-5294
-1604
4240
5180
-871
-7227
-6414
347
4731
1584
-4877
-6047
354
6547
4411
-2478
-2946
4681
8672
2303
-4124
388
8391
5508
-5136
-7481
766
4741
-2166
-7951
-3246
3631
2149
-3477
-3704
282
1106
-1523
-2446
-898
125
608
2187
3286
1899
355
1828
4715
5237
3232
1240
105
-856
-1300
-671
-80
-941
-2935
-4650
-4949
-3368
-911
-56
-1618
-2476
310
4080
3463
-1452
-4405
-1345
4370
6674
3841
-650
-2477
-561
2292
2617
287
-1757
-1918
-1629
-1961
-1741
-775
-1428
-4409
-6131
-3400
1641
4068
1728
-3497
-7589
-6669
-878
3588
1274
-3460
-1455
6055
7366
-568
-4902
2837
11137
6198
-4442
-3338
7508
8969
-3600
-12022
-4486
6061
3725
-5781
-6892
439
3416
-1499
-5006
-1834
2546
3088
1857
1538
1215
807
2161
4049
3013
400
1482
6179
8080
4689
1273
1637
2282
-259
-2848
-1524
1269
655
-3045
-5539
-4952
-2821
-593
1387
2709
3227
3417
3069
1455
-407
-205
2017
3519
3062
2429
2846
3151
2532
1929
1749
1148
137
-545
-1468
-3170
-3704
-1537
382
-1542
-4930
-4439
-415
1841
615
-1003
-1423
-1154
1246
6023
7408
1416
-4386
-664
6772
4598
-4621
-4678
6473
11253
1578
-6871
-1058
7513
3091
-7662
-8148
235
2680
-3315
-6292
-1871
2148
1356
257
1337
1386
-140
76
1481
446
-1473
330
3903
3189
-444
322
5539
6922
1652
-3054
-2186
-379
-2854
-6634
-6176
-2344
-527
-2838
-6251
-7008
-4419
-921
661
318
682
2951
4870
4569
4030
5811
8255
7530
3452
-104
-379
1354
2100
615
-1572
-1917
49
1670
550
-1707
-1696
345
821
-1270
-2720
-1541
-11
-259
-493
1490
3650
2052
-2845
-5370
-1361
5638
7481
1804
-3652
-1056
5532
5276
-2485
-5939
990
8363
5607
-1887
-2333
2971
2752
-4819
-9392
-5491
-83
-348
-3902
-5021
-2845
277
2732
3242
1488
422
2996
6370
5176
407
-1626
536
1818
88
-491
2208
3984
1592
-1895
-2453
-733
519
250
-1694
-4717
-5807
-2648
1204
244
-3634
-3087
2446
5002
1242
-1743
1582
5859
3973
-1173
-1785
2354
4364
1218
-2663
-2727
-119
1000
-836
-2804
-1506
2228
3680
511
-3418
-3359
-657
-175
-2220
-2431
537
2826
1699
-757
-1627
-769
652
1811
1731
252
-656
511
2042
2220
3010
5963
7262
3201
-1911
-1121
3523
3671
-1346
-3167
1377
4824
1542
-3520
-3794
-1034
-287
-1170
-508
1141
1565
1759
3377
4674
3794
2862
4118
5184
3126
249
500
2436
1380
-2757
-5280
-3996
-1745
-1221
-1545
-1174
-790
-1671
-3295
-4069
-3352
-1902
-883
-669
-368
1126
3345
4400
3476
2090
1929
2545
2422
1416
725
935
1459
1694
1590
1149
327
-476
-646
-220
7
-556
-1638
-2552
-2979
-3048
-2828
-2195
-1231
-335
370
1262
2384
2900
2219
1277
1516
2712
3177
2271
1196
816
296
-1120
-2405
-2223
-1171
-1018
-2160
-3221
-3091
-2173
-1408
-1005
-503
322
1037
1064
531
285
802
1470
1539
1404
1943
2769
2421
591
-1033
-841
687
1729
1297
50
-624
135
1919
3197
2640
604
-1135
-1338
-509
59
-123
-596
-920
-1182
-1526
-1634
-1069
-124
202
-479
-1088
-399
994
1366
538
315
1606
2868
2511
1268
689
621
11
-877
-1023
-679
-891
-1447
-1186
-98
587
252
-665
-1720
-2534
-2281
-706
806
787
-151
-335
359
762
697
934
1212
585
-324
135
1686
2018
271
-1594
-1744
-774
-19
591
1578
2236
1556
6
-1042
-1163
-993
-861
-389
572
1577
2234
2543
2489
1939
1173
907
1381
1812
1318
170
-552
-459
-318
-769
-1399
-1575
-1474
-1516
-1402
-660
200
206
-530
-842
-214
537
599
322
554
1345
1863
1474
573
189
772
1556
1474
581
-30
143
264
-506
-1542
-1445
70
1732
2135
1202
178
293
1379
1970
1072
-474
-984
-57
1125
1553
1408
1087
427
-428
-461
841
2207
1943
189
-1334
-1563
-1034
-646
-566
-634
-1007
-1778
-2288
-1599
250
1952
2149
856
-478
-518
447
976
417
-348
-305
322
550
13
-654
-746
-331
-1
-109
-518
-839
-770
-374
27
317
613
810
652
300
321
985
1902
2465
2412
1848
1021
399
543
1279
1429
222
-1417
-1813
-556
1117
1870
1607
1127
874
605
110
-331
-321
166
769
1105
1106
908
513
-28
-274
174
880
840
-262
-1574
-2051
-1606
-983
-769
-943
-1155
-997
-227
791
1175
529
-466
-888
-654
-322
-192
-172
-349
-956
-1729
-1945
-1337
-474
6
140
401
1061
1925
2484
2309
1440
430
-175
-326
-290
-170
86
341
397
389
586
781
385
-722
-1789
-1888
-857
619
1608
1501
411
-787
-1158
-609
111
387
302
202
52
-468
-1335
-2048
-2208
-1873
-1325
-759
-240
228
487
135
-951
-2094
-2261
-1139
527
1731
2088
1834
1223
449
-33
110
431
203
-473
-766
-238
697
1379
1532
1193
412
-562
-1054
-640
118
386
232
363
1025
1714
1880
1593
1433
1674
1902
1672
1129
738
752
1077
1431
1684
1812
1439
192
-1287
-1668
-641
575
710
-188
-1075
-1353
-1505
-2014
-2368
-1880
-779
107
173
-610
-1522
-1527
-426
823
1102
176
-1107
-1587
-910
286
1237
1540
1163
585
400
543
621
769
1247
1691
1550
919
506
786
1225
855
-246
-916
-455
729
1818
2156
1629
855
415
164
-157
-277
181
1125
1926
1914
1125
268
-265
-575
-625
-467
-601
-1265
-2029
-2420
-2324
-1884
-1456
-1207
-802
10
901
1298
866
-49
-410
295
1145
1105
489
180
312
301
-394
-1546
-2161
-1597
-313
813
1212
763
79
103
922
1729
1915
1449
727
441
836
1238
1010
383
4
244
867
1164
903
677
755
717
523
576
731
447
-328
-1012
-851
174
886
224
-1293
-2317
-2170
-1129
-101
22
-732
-1638
-2244
-2301
-1493
-173
596
276
-614
-1001
-158
1375
2165
1631
487
-508
-1038
-988
-682
-659
-911
-1093
-1035
-673
-227
-240
-761
-1163
-1015
-320
726
1598
1851
1713
1521
1281
1115
1151
1114
887
746
809
1039
1368
1347
671
-68
-184
284
1015
1572
1404
621
-41
-279
-258
-151
-350
-1005
-1466
-1350
-1220
-1316
-1099
-416
262
591
606
606
726
544
-73
-273
454
1250
1277
899
656
373
-158
-571
-423
103
444
490
627
854
655
88
112
1274
2716
3257
2890
2385
1987
1388
537
-204
-379
171
927
1077
544
99
428
1384
1998
1411
81
-639
-303
384
916
1284
1342
1006
580
245
-102
-438
-676
-959
-1306
-1388
-1011
-467
-371
-1177
-2233
-1704
955
2979
1428
-2016
-2904
-480
1728
1733
1293
1967
2679
2004
425
-498
-322
-104
-124
1249
4210
5458
3024
41
-390
190
48
689
2339
2302
500
189
1712
1809
-158
-866
1467
4147
3477
-474
-3611
-2781
-6
510
-1336
-1875
171
2153
2115
675
-1305
-2932
-2504
-145
1421
1157
610
-151
-1738
-1969
263
1479
-112
-1150
-111
588
877
2085
1789
-1543
-3709
-1567
1972
3104
678
-4069
-6277
-1855
4536
4965
361
-2809
-2977
-1900
-280
215
-993
-158
3883
5855
3475
1036
539
-10
-437
157
-26
-1571
-2288
-1313
451
1995
1742
-127
-330
1778
2355
146
-2085
-3270
-3529
-1652
1176
1312
-1208
-3029
-2506
175
3206
2685
-1732
-4514
-3160
-1626
-1934
-2147
-1827
-915
1625
3099
-6
-4082
-3657
-262
2459
4277
4325
1566
-733
36
1242
1126
1299
1458
436
-52
602
369
-20
1789
4115
4198
2896
1641
489
378
1671
2381
1750
1421
1813
1938
1667
1014
5
-1
1702
3309
3224
1928
354
-652
-356
386
84
-835
-1183
-1054
-649
139
539
49
-445
-530
-647
-514
-7
-11
-384
-21
617
426
-85
-104
186
592
756
45
-769
-241
1070
1653
1470
968
190
-162
404
912
663
399
596
947
1341
1418
514
-874
-1431
-896
105
1227
2113
2336
2125
1725
619
-1167
-2350
-2221
-1464
-747
-275
-247
-252
403
1124
761
-332
-922
-494
704
1539
527
-1540
-1710
652
2555
1642
-991
-2441
-913
2111
3051
1038
-769
-173
1415
2114
1657
513
-353
-52
959
1681
1758
855
-715
-1147
112
765
-493
-1754
-1118
940
2581
2222
512
195
1837
2452
525
-1661
-1780
108
2199
1996
-923
-3291
-2356
364
1952
1428
-435
-1536
-184
1882
1617
-436
-1483
-763
576
1027
-535
-2829
-2848
-498
1209
758
-1024
-2859
-3104
-1076
1307
2307
2564
2403
1014
-971
-2093
-2005
-652
1558
2634
1399
-730
-2282
-2692
-1057
2049
3532
1729
-1356
-2952
-1966
440
1369
-330
-1869
-848
916
819
-683
-1427
-97
2533
3812
2395
498
484
1404
1205
-239
-1567
-1365
465
1918
1163
-731
-1524
-852
181
734
624
295
215
11
-707
-1267
-1029
-468
-163
11
290
614
828
877
918
1052
983
551
246
588
1324
1665
1101
-11
-759
-659
40
845
1158
641
-10
259
1310
2118
2201
1771
1249
935
581
11
4
854
1160
166
-599
83
1202
1149
-411
-2076
-1786
349
1598
610
-864
-1342
-1100
-353
683
1083
600
-89
-547
-340
563
759
-288
-444
1331
2597
1369
-1171
-2845
-2500
-823
-153
-1283
-1844
-465
890
656
-346
-956
-378
1423
2425
819
-1763
-2555
-1204
803
1462
-474
-2974
-2362
999
3020
1846
-544
-1458
126
2405
2338
200
-509
1284
3014
2817
1168
-564
-948
45
460
-811
-2544
-3413
-2816
-226
3215
4573
2850
322
-589
374
1481
685
-1506
-2043
60
1917
1261
-426
-529
1321
2892
1758
-1396
-2956
-996
2251
3501
1869
-1033
-2735
-2045
-332
196
-682
-1227
-51
2184
3156
1363
-1636
-2650
-591
2390
3510
2132
41
-569
789
2687
3215
1651
-723
-1606
-125
1958
2137
20
-2156
-2059
-65
1353
1099
653
1379
2386
1831
-651
-3146
-3114
-321
2484
2494
-392
-3887
-5275
-3464
-116
2017
2028
842
-685
-1930
-2080
-1033
330
1254
1738
2326
3002
2007
-1966
-5735
-3843
3463
8527
4871
-4700
-10480
-6494
2418
6440
2808
-2199
-2746
243
2610
2431
953
101
267
823
1717
2763
2723
1532
1427
3315
4457
2176
-2140
-4482
-2821
543
1702
60
-1352
-693
483
417
-442
-717
219
1835
2777
2105
315
-1216
-1292
237
1738
1030
-1700
-3758
-3244
-830
1697
3025
2636
819
-1324
-2214
-999
997
1223
-767
-2423
-1829
-417
-512
-1700
-1605
265
1466
225
-1541
-653
2792
5496
5234
2892
368
-1122
-452
2846
6011
3797
-4934
-12656
-9769
2924
12599
8638
-4154
-11042
-5185
4903
7062
251
-6102
-4988
962
5099
4808
1907
-1436
-3830
-3470
331
4476
4279
-420
-4029
-1948
3381
5550
2275
-2328
-3519
-1354
700
521
-1150
-2686
-3086
-1863
740
3218
3922
3129
2798
3679
4021
2179
-600
-1594
-255
1180
765
-1037
-2691
-3498
-3288
-1590
1339
3496
2981
790
-29
1650
3620
3593
2215
1316
661
-1219
-3465
-3037
672
3840
2777
-1023
-2824
-994
1302
1103
-378
-385
913
1094
-299
-1101
-362
-169
-2252
-4853
-5084
-3157
-1751
-1585
-526
2205
3864
2448
995
4000
9833
10789
2887
-7127
-8299
1348
11565
11237
596
-10040
-12228
-7165
-1745
-223
-1681
-3575
-4486
-3471
162
4756
6009
1536
-4722
-5442
1512
9422
9740
2060
-5208
-4544
2413
7615
6126
593
-3418
-3860
-2683
-1834
-1311
-985
-1807
-3923
-5070
-2793
1944
5080
3936
288
-1891
-988
1071
1812
1041
214
100
207
251
1018
3173
5766
6751
5168
2398
829
1247
1904
521
-2870
-5620
-5387
-3026
-1770
-3360
-5824
-5811
-2653
953
2419
2224
2655
4434
5993
6060
5549
6053
7360
7631
5867
3017
493
-1401
-2986
-4066
-4333
-4464
-5558
-7285
-7744
-5819
-2912
-1417
-1871
-2625
-2103
-258
2285
5114
7251
6902
3763
1048
2932
9009
13085
9356
-741
-9533
-11013
-6278
-983
676
-1654
-6186
-10390
-11194
-6766
456
4489
1791
-4103
-6015
-1223
5760
8956
7435
4749
3623
3686
3896
4302
4425
2250
-2896
-7570
-6969
-964
4662
4231
-1572
-6648
-6095
-741
4525
5563
1992
-3129
-5747
-3766
1206
5042
4710
1010
-2404
-2457
1093
6086
9495
8830
3664
-3224
-7215
-5877
-1652
514
-1538
-5194
-6514
-4621
-1915
-855
-1789
-3549
-4698
-3910
-545
4170
7350
7047
4505
2873
3713
5671
6605
5861
3933
1044
-2686
-6152
-7786
-7443
-6713
-6885
-7397
-6949
-5403
-3668
-2125
-330
1667
2927
3164
3816
6499
10635
13439
12468
7781
1801
-2311
-2389
1215
5071
4634
-1677
-10196
-14810
-12602
-6311
-1218
-378
-3113
-6743
-8458
-6257
-239
6282
8534
4823
-991
-2918
1096
7378
10769
9534
5657
1723
-1049
-2313
-2075
-1311
-1842
-4377
-7167
-7612
-5197
-2046
-486
-786
-1541
-1506
-453
1252
3065
4271
4365
3691
3251
3575
4041
3625
2137
484
-160
727
2582
3856
2959
-212
-3643
-4842
-3503
-1948
-2390
-4278
-5166
-3902
-1839
-661
-146
996
2839
4116
4328
4647
6096
7736
7632
5316
2339
468
88
477
717
-56
-2426
-5772
-8043
-7498
-4767
-2310
-1633
-1882
-1600
-878
-713
-809
384
3205
5643
5650
3862
2913
4232
6507
7347
5505
1373
-3555
-6896
-6265
-1627
3252
3356
-2597
-10304
-13753
-10643
-3574
3242
7153
7389
4386
74
-2231
-179
4956
8955
8635
4712
460
-1693
-1598
-149
1931
3805
4092
1843
-2157
-5684
-6820
-5343
-2538
-138
626
-356
-1858
-1899
773
5400
9437
10328
7440
2647
-864
-819
2417
6015
6831
3870
-1089
-5062
-5963
-3584
628
4272
5001
2006
-3053
-6994
-7540
-4939
-1249
1497
2237
805
-1887
-3608
-2058
2626
7157
7971
4934
1387
360
1630
2954
3152
2782
2191
598
-2251
-4709
-4793
-2838
-1429
-2481
-5230
-7402
-7580
-5890
-3141
-332
1324
1147
146
501
3151
6434
7898
7033
5321
3886
2462
1044
979
2904
4324
1395
-6124
-13120
-13819
-7907
-779
2175
224
-3855
-7618
-9939
-9229
-3507
6267
14501
15079
7782
-705
-3181
1265
7440
10149
8682
5285
1352
-3095
-6889
-7219
-2992
2482
4001
-100
-6189
-9406
-8468
-5639
-2911
-73
3264
5500
4607
1400
-458
1675
6433
9950
9836
6912
3526
1290
594
1210
2353
2577
752
-2552
-5291
-5933
-4880
-3691
-3362
-3768
-4349
-4662
-4270
-2841
-852
366
107
-291
1472
5783
10086
11461
9667
6921
5041
3832
2413
1046
653
844
-229
-3399
-6806
-7866
-6460
-4907
-4747
-4947
-3911
-2102
-1465
-2523
-3379
-2119
622
2565
2964
3588
6065
9362
10996
10103
7995
5902
3640
1012
-809
-662
136
-1764
-7925
-15338
-18704
-15627
-8706
-2404
904
1267
-796
-4557
-7580
-6075
1638
12288
19528
19364
13337
6108
807
-2343
-3709
-2697
727
4255
4517
385
-5648
-9772
-10209
-7999
-5001
-2185
-87
305
-1727
-5184
-7445
-6220
-1395
4976
10341
13318
13944
12770
10262
7088
4320
2882
2824
3182
2518
-117
-4357
-8661
-11460
-12022
-10311
-6703
-2229
1435
2906
2100
325
-581
460
2991
5561
7118
7609
7355
6513
5266
3916
2662
1669
1191
1135
798
-405
-2214
-3953
-5345
-6511
-7432
-7741
-7069
-5682
-4689
-4953
-5649
-4842
-1903
1549
3658
4359
4745
5242
5300
4663
4229
5248
7611
9415
8835
6191
3286
985
-1318
-3875
-5738
-6346
-6817
-8816
-12388
-15330
-14806
-9742
-1841
5713
10243
10434
6514
777
-2811
-1160
5348
13183
18384
18725
14136
6295
-1936
-7492
-8561
-5832
-2191
-410
-944
-2499
-4455
-7426
-11187
-13453
-11840
-6644
-854
2617
3315
2803
2420
2301
2661
4747
9371
15016
18605
18227
14415
8875
2756
-3521
-9197
-12776
-13275
-11697
-10391
-10661
-11654
-11763
-10269
-7228
-2722
2996
8882
13160
14412
12918
10747
9817
9972
9782
8869
8143
7749
6225
2239
-3579
-8850
-11343
-10858
-9231
-8175
-7601
-6766
-6160
-6793
-8177
-8590
-7056
-3915
113
4366
8065
10440
10894
9273
6571
4674
4426
4644
3995
2714
1474
-41
-2196
-4265
-5457
-6073
-6884
-8010
-8580
-7134
-3187
946
1448
-2705
-8040
-10010
-6763
657
9566
16339
17949
13979
6599
-981
-5443
-4378
1778
9595
15290
16620
12595
3895
-6271
-14009
-17523
-16829
-12281
-5323
989
4164
3846
830
-3518
-6823
-6940
-4009
201
4610
9160
13386
16017
15917
12924
8309
4643
3950
5392
6044
4238
461
-4989
-12403
-20288
-25419
-25942
-22597
-17147
-11068
-5055
1016
6720
10398
11585
12526
15082
18017
19260
18604
16627
13173
8062
1881
-4211
-8779
-11040
-11863
-12514
-12538
-10689
-7774
-6480
-7862
-9650
-8867
-5026
90
4705
7911
9290
9001
7750
6218
5093
5107
5912
6034
4961
3479
1435
-2146
-6242
-8092
-6574
-2957
1125
4360
5464
4017
1022
-1732
-2330
129
3773
4717
1020
-5207
-10287
-12008
-9749
-3690
4345
10372
10759
5698
-878
-4844
-4468
-132
6790
14458
20537
22075
16639
5148
-7391
-15945
-19422
-19159
-15391
-7840
1265
7418
7341
1554
-6091
-11015
-10841
-6612
-1034
4363
9682
14476
16685
14650
9223
3104
-1104
-1929
416
3736
4970
2323
-3744
-11147
-17308
-20418
-20451
-18662
-15545
-9925
-1142
8427
14800
16619
16250
16186
16251
15115
12881
10932
9716
7525
2311
-5084
-10994
-13291
-13918
-15430
-16617
-13748
-5853
2814
6603
4639
1527
1271
2954
3786
3426
3202
3552
4085
4660
5285
5467
4032
399
-3451
-4231
-1889
-441
-2679
-6437
-7660
-5468
-2605
-1322
-306
2721
6436
7407
5868
5593
7489
7192
175
-12470
-23720
-26366
-19573
-8330
2972
12376
16874
13782
6001
376
586
5196
11299
17243
22439
25053
20673
6847
-10890
-22755
-25398
-23890
-22510
-18511
-7346
8132
17462
13722
2115
-6606
-8319
-6183
-2656
3288
12587
22885
28495
24869
14434
4475
-1414
-4527
-4791
-907
3882
3281
-4543
-14828
-21379
-22554
-21975
-22371
-20482
-11733
2233
15026
22149
23389
21462
19236
16273
10452
3784
946
1657
1178
-2481
-7594
-12228
-14822
-15039
-15208
-16729
-16877
-12825
-5334
3365
11108
15698
16894
16063
12766
6272
-507
-3897
-4115
-3633
-4141
-5831
-6623
-4550
-2195
-3040
-4454
-2080
2108
3881
3832
4712
7460
11695
14628
12218
6169
3436
5466
5932
614
-7998
-15722
-20812
-23692
-24155
-19179
-7185
6140
13081
13596
12743
12466
12482
13762
16691
20548
24149
22752
10787
-7680
-20376
-22109
-19210
-18004
-17742
-14090
-3890
10649
20754
18879
7342
-5109
-12622
-14386
-10987
-2569
9657
21405
27139
25476
19883
13160
5782
-695
-4445
-6369
-7562
-7312
-7033
-10248
-16099
-19620
-19655
-19413
-18499
-11739
2096
16107
23165
24127
23950
22937
17469
7112
-4126
-11376
-11430
-6309
-4167
-9817
-16891
-17536
-14666
-15381
-18401
-16757
-7826
4885
15964
22012
23686
22978
18622
8447
-4432
-13138
-14840
-13523
-14170
-15683
-12913
-6816
-5428
-10208
-11384
-3450
6510
11930
15094
18249
19544
19140
18058
13893
6989
3742
5569
3885
-6493
-18393
-23720
-25131
-27989
-27488
-15009
5581
20773
26028
27950
28575
23264
13923
8654
9262
11724
14321
14775
7428
-7314
-19551
-22862
-21949
-22091
-19463
-8158
8627
21444
26152
24991
17745
2550
-14645
-23481
-22095
-15868
-6780
5127
15745
21411
22267
17242
5855
-5022
-7542
-3686
-726
-1350
-4384
-8485
-12040
-14851
-18665
-22366
-21183
-12705
777
14686
23850
26035
24370
21235
13866
1854
-8915
-14705
-16616
-14107
-7427
-3313
-6483
-11914
-14306
-14866
-13348
-6367
3941
11870
17091
21604
23041
18315
7845
-6016
-18567
-23986
-22476
-19373
-15061
-6582
1796
2881
-1345
-3509
-1303
4190
12302
19683
22263
21489
20701
18268
10978
-207
-11018
-16499
-14928
-12001
-14268
-18752
-19510
-18696
-17583
-8315
10117
23831
25541
24211
24228
18470
7059
-565
-2425
-2588
769
8804
13066
6120
-7908
-19731
-24309
-22638
-18073
-10334
3317
18602
26146
24980
20189
10189
-6024
-18027
-19023
-17074
-16132
-7391
9208
20246
21376
19664
15577
5945
-3213
-5337
-3390
-1339
385
-789
-6025
-10711
-13362
-17967
-22876
-21114
-11672
1038
13080
19932
20207
20055
21640
16088
267
-14793
-21356
-21938
-17086
-7247
-1250
-3748
-6866
-6947
-9189
-10066
-894
12167
17353
18379
23717
28413
23810
10829
-4872
-17662
-22781
-22199
-21595
-18994
-10405
-2164
-980
-1718
1271
5647
10978
18977
24561
24452
25002
26774
19288
1769
-12744
-18605
-21267
-22810
-22318
-22335
-23273
-22499
-20327
-14815
-384
17257
23487
19182
18097
19445
11527
-2484
-9826
-9424
-6526
-396
8152
12287
8875
284
-11136
-21203
-24212
-19383
-9192
4695
17403
23352
24796
23882
13488
-6579
-20079
-19005
-15516
-15344
-7765
8559
20108
22552
22905
21396
14316
6108
2449
2146
3079
4331
2602
-3825
-12194
-20203
-26061
-26189
-20801
-13923
-4417
9849
21499
23993
23728
25525
21321
7335
-6780
-14836
-19839
-21698
-18665
-15338
-14087
-10500
-5670
-5571
-6256
759
11994
18739
21815
25537
27416
22670
10426
-5731
-18096
-21516
-20807
-21855
-20814
-14204
-8452
-7459
-5325
548
5822
10588
17679
23881
26744
29462
29470
18349
-1328
-16637
-22623
-24352
-25074
-25020
-25145
-24657
-21658
-16347
-7910
4986
17198
22088
22627
23443
18324
2059
-15157
-20799
-16225
-8536
682
10443
15892
13606
4627
-7007
-15501
-16975
-12363
-3699
7823
18010
21928
20262
14993
3659
-12567
-23973
-24919
-20519
-14450
-3633
10985
22329
27614
29041
26041
17295
6849
128
-2533
-3809
-4943
-6232
-8881
-13997
-19933
-22324
-18880
-12433
-5761
3112
15169
24878
26947
23254
17433
8885
-2927
-14460
-21862
-23937
-20787
-14026
-7261
-2804
86
2117
2819
3618
7608
14797
21079
23357
22425
18883
9913
-5475
-20551
-26803
-24679
-21313
-18833
-13423
-5196
518
2344
4710
9718
14484
17434
20732
24859
26251
22140
13688
2719
-10134
-22007
-27503
-25118
-19866
-16451
-13982
-10427
-6798
-3689
1284
9108
16805
22160
25464
24070
12464
-8186
-26283
-31418
-24944
-13538
355
15928
26823
25539
13594
-473
-11192
-17994
-19285
-11896
2111
14720
20352
19763
14951
5305
-8381
-20512
-25805
-24367
-18555
-8600
5206
18522
25737
25479
20328
12854
4634
-2419
-6688
-7928
-6829
-4923
-4651
-7860
-13121
-16847
-17515
-15462
-10299
-1331
9741
18416
21860
20718
16274
8866
-1713
-13612
-22276
-24161
-19620
-12782
-7395
-3778
-1363
-142
669
3058
8371
14959
20110
23103
23669
19345
7259
-9987
-23375
-26626
-23358
-20610
-18928
-14426
-7393
-1923
1690
6481
11865
15199
17449
20879
23805
22413
16982
10467
2637
-7543
-17485
-22968
-22820
-19834
-16211
-11974
-7639
-3990
-759
3686
10540
18155
23761
25099
20004
8180
-6732
-18268
-22009
-18602
-10043
2676
16121
23735
21054
10184
-2570
-12748
-18248
-16815
-7784
5247
15747
19598
17965
12642
3057
-9941
-21377
-25530
-21676
-13211
-2261
9646
18707
21362
18300
13714
9997
6204
2445
929
2212
3364
544
-6485
-14322
-20140
-22769
-21754
-17192
-9402
679
11715
21450
26494
25937
21275
12838
858
-11756
-19881
-21302
-18719
-14332
-9064
-5396
-5089
-6255
-4750
729
7595
13517
17524
19674
20627
18954
11357
-1930
-14596
-20634
-20849
-19452
-17524
-14316
-11182
-8838
-5322
744
8205
14496
18637
20974
21443
20631
18189
12854
4565
-6083
-16452
-23129
-25116
-23385
-19407
-12517
-3336
2501
1829
-1778
-2891
358
6636
15371
24014
26746
20465
6834
-9639
-23021
-27484
-21431
-9596
2890
14610
23831
25582
17186
3143
-9839
-17686
-19293
-15273
-6363
5274
16192
21613
17299
5778
-6711
-16338
-21722
-22018
-14901
-1804
10580
17501
18016
14526
9516
3551
-872
-901
3910
10191
11707
6059
-4208
-14565
-21365
-24461
-24484
-20533
-11228
1883
13363
19719
22081
22320
18940
10001
-1201
-9113
-10877
-8222
-5243
-3880
-4946
-7941
-11323
-14024
-13198
-7232
2548
13140
20231
22904
21832
16157
5853
-7204
-16879
-18593
-15569
-12723
-11702
-10282
-7047
-4061
-1817
552
3990
9453
15743
20284
20975
18643
14855
8486
-322
-8190
-12103
-13606
-15920
-18265
-18448
-15255
-9740
-5626
-4977
-6178
-3928
4408
14796
23763
28886
27018
16769
571
-14075
-21760
-21469
-13296
-1043
10786
19252
21477
15451
1242
-14514
-23103
-22376
-14340
-2139
10995
21285
24511
18960
5681
-9972
-20563
-23132
-19286
-11152
379
11579
16695
14934
9176
2715
-1675
-1623
3527
9571
13068
13270
7926
-3110
-15819
-24158
-25932
-23896
-17693
-6699
5501
14842
19061
19304
16596
11236
5747
1722
153
1218
2526
1557
-3179
-10093
-15812
-18446
-17249
-13286
-7770
-1012
6151
12197
15234
15136
12420
7313
1868
-1667
-2745
-3754
-7049
-11031
-13739
-14145
-12318
-9281
-4820
309
5440
10445
13666
14313
12309
9383
8440
9050
9535
8276
4078
-2837
-11755
-19448
-22464
-20504
-14931
-8584
-4344
-3601
-4681
-2882
4105
14234
23372
27942
26160
17299
3541
-9926
-17469
-15955
-7489
2921
10037
10556
4944
-4562
-14435
-21312
-23151
-18275
-7773
5017
16206
22179
21770
15039
4091
-6232
-11626
-10003
-3405
3780
8442
8863
5490
248
-4523
-6800
-6384
-3495
1612
7497
11777
12052
7570
-877
-10859
-18160
-19620
-15229
-7807
-171
6450
10922
12534
11197
7596
3676
1228
1188
2436
2543
763
-2508
-6513
-10458
-13486
-13873
-11028
-6102
-877
3086
5872
8082
9607
10019
9007
7124
4881
2209
-635
-3052
-4627
-5774
-7085
-8139
-7842
-5836
-3319
-1619
-665
325
1480
2171
2657
4275
7536
11257
13149
11869
8350
4256
-55
-5578
-11876
-15898
-15767
-13328
-11810
-12127
-12156
-9492
-3587
4025
10863
15713
18649
19109
15930
9606
3136
-619
-1217
84
1598
1709
-598
-5412
-12112
-19122
-23409
-21865
-14204
-3704
5479
11089
13043
12234
9445
5324
1205
-737
864
4592
7221
7054
5161
3034
422
-3437
-7411
-8816
-6218
-1228
2725
3371
1317
-1248
-3272
-5324
-7412
-7921
-5657
-1623
2243
5051
6913
7942
8067
7182
5233
2733
832
237
497
723
179
-1803
-5200
-8472
-9761
-8892
-7133
-5385
-3691
-1896
149
2396
4182
4782
4503
4361
4828
5605
6090
5510
3324
15
-3201
-5523
-6730
-6704
-5744
-4873
-4834
-5166
-4846
-3418
-1215
1138
3379
5814
8488
10264
9626
6431
2065
-1876
-4219
-4077
-1412
2219
4194
2593
-2109
-6956
-8700
-6512
-2087
2681
6936
9812
9901
6485
700
-4814
-7255
-5194
472
7018
11263
10667
4379
-5634
-15001
-19519
-17471
-9805
675
10116
15001
13889
7941
-34
-6989
-10780
-10627
-6762
-162
7038
11873
12375
9014
3959
-566
-3088
-2994
-648
2606
4816
4241
543
-4676
-8977
-10740
-9615
-6048
-1151
3317
5688
5286
2749
-233
-1749
-867
1880
5195
7816
8656
7002
3071
-1915
-6270
-8442
-7709
-4774
-1371
982
1658
672
-1396
-3283
-3605
-1909
1002
3745
5375
5961
6038
5414
3124
-953
-5006
-6545
-4673
-825
2543
3818
3068
1423
-122
-1145
-1474
-1055
-157
738
1262
1106
-89
-2333
-4819
-6213
-5551
-2997
176
2532
3477
3319
2561
1647
1236
1919
3426
4568
4266
2456
74
-1768
-2654
-2980
-3156
-2954
-1994
-582
346
64
-1379
-3060
-3505
-1654
2054
5723
7350
6215
3140
-274
-2782
-4090
-4438
-3828
-2106
276
2139
2471
1277
-439
-1402
-924
591
2010
2469
2051
1472
1220
1102
512
-826
-2391
-3193
-2662
-1184
280
977
777
81
-456
-302
589
1684
2246
1911
928
-78
-631
-732
-714
-786
-800
-495
90
554
470
-155
-761
-631
453
1959
2978
2921
1939
741
-29
-310
-535
-1041
-1664
-1896
-1415
-460
302
349
-229
-818
-803
-2
1285
2472
2976
2602
1703
901
554
547
544
385
298
701
1633
2444
2278
927
-935
-2328
-2657
-2082
-1359
-1228
-1708
-2089
-1711
-631
453
811
340
-190
193
1491
2490
2049
467
-747
-384
1292
2701
2316
155
-2153
-2941
-1996
-425
573
564
-12
-231
521
1789
2343
1366
-794
-2937
-3801
-2837
-627
1549
2775
2966
2412
1446
580
281
373
218
-395
-969
-910
-123
895
1371
923
11
-623
-835
-904
-731
-17
947
1471
1314
795
207
-311
-518
-145
802
1905
2366
1544
-131
-1242
-948
16
514
461
403
336
-214
-1287
-2300
-2556
-1791
-456
606
1028
1113
1046
594
-147
-605
-702
-978
-1388
-959
844
3172
4532
4076
2195
231
-622
-401
-31
-32
-286
-859
-1890
-2756
-2517
-1301
-267
-149
-567
-655
87
1333
2016
1398
71
-703
-469
344
1358
2308
2599
1857
588
-392
-763
-517
323
1421
2176
2297
1814
801
-341
-816
-393
125
12
-507
-932
-1210
-1362
-1182
-566
459
1903
3362
3882
3082
1906
1480
1754
1827
1043
-513
-2041
-2483
-1694
-859
-1046
-1824
-2087
-1542
-613
336
917
621
-498
-1610
-1930
-1293
-102
821
739
-95
-631
-534
-563
-1048
-1131
-127
1401
2393
2343
1435
264
-580
-1110
-1776
-2481
-2503
-1673
-703
-103
305
659
834
978
1345
1793
2109
2476
2965
3095
2499
1508
749
645
1206
1727
1048
-1017
-3006
-3392
-2348
-1165
-564
-299
164
1111
2298
2997
2795
2121
1535
987
404
286
937
1731
1865
1312
630
307
472
709
316
-738
-1493
-1256
-586
-409
-741
-970
-809
-438
-163
-185
-345
-213
225
358
-107
-622
-679
-543
-535
-343
405
1428
2059
1806
637
-909
-1988
-2200
-1822
-1127
-108
911
1212
587
-279
-630
-273
574
1480
1895
1570
798
9
-565
-651
28
1203
2010
1746
443
-1185
-2026
-1265
625
1990
1643
104
-1158
-1334
-759
-270
-392
-936
-1236
-868
-30
754
961
153
-1512
-2712
-1720
1708
5697
7844
7158
4333
718
-2529
-4521
-4421
-1859
2111
4957
4515
1118
-2705
-4698
-4529
-3134
-1264
792
2535
2976
1462
-1233
-3030
-2288
588
3582
4993
4563
2932
662
-1879
-4006
-4587
-2773
942
4598
6114
4955
2317
-215
-1852
-2493
-2100
-704
1082
2036
1262
-742
-2371
-2471
-1401
-279
475
1242
1969
1704
-156
-2566
-3452
-1815
1115
3122
3146
1906
614
-264
-835
-980
-403
666
1419
1287
514
-336
-1201
-2363
-3553
-3718
-2063
828
3264
3857
2583
552
-991
-1420
-812
312
1273
1514
923
-72
-884
-1232
-1170
-804
-232
287
414
111
-214
-105
471
1111
1438
1519
1687
1975
1970
1379
525
-4
-58
-27
-324
-968
-1628
-1937
-1769
-1294
-771
-299
210
910
1857
2830
3309
2894
1839
944
748
1025
1080
446
-742
-1835
-2090
-1243
215
1344
1385
309
-1076
-1608
-657
1312
3135
3825
3064
1148
-1130
-2652
-2483
-573
2069
3896
3783
1801
-829
-2633
-2836
-1596
215
1356
760
-1554
-4067
-4684
-2500
1220
3894
3694
1039
-1943
-3356
-2800
-1031
997
2439
2565
1270
-385
-741
880
3224
4090
2441
-581
-2901
-3471
-2773
-1652
-417
703
944
-371
-2639
-4040
-3166
-462
2152
3026
2064
433
-540
-107
1713
4029
5298
4380
1758
-590
-944
567
2281
2748
1858
324
-1329
-2781
-3305
-2041
710
3077
3190
1188
-776
-754
1017
2545
2315
703
-885
-1658
-1831
-1739
-1214
-86
1052
1160
-55
-1659
-2401
-1824
-415
964
1564
1013
-399
-1583
-1324
426
2176
2260
565
-1433
-2263
-1702
-524
489
870
275
-1213
-2494
-1945
845
4078
5125
3155
96
-1272
33
2661
4591
4776
3267
503
-2773
-5108
-4838
-1835
1659
2731
510
-3061
-5151
-4513
-2073
461
1961
1989
685
-850
-898
1287
4362
5880
4478
1124
-1867
-2910
-2024
-95
1799
2512
1411
-861
-2761
-3022
-1530
671
2197
2283
1013
-877
-2030
-1200
1341
3694
4035
2159
-494
-1976
-1358
597
2412
3170
2726
1488
192
-607
-738
-82
1117
1737
649
-1817
-3980
-4238
-2440
-187
584
-381
-1652
-1849
-636
1448
3215
3559
2510
1062
156
134
568
557
-176
-930
-1162
-1094
-1014
-941
-829
-524
-38
132
-276
-742
-716
-254
363
838
887
603
278
-62
-263
207
1331
2204
2046
798
-992
-2231
-1943
-346
1362
2141
1704
720
399
1146
2153
2849
3492
3919
3185
939
-1640
-2554
-834
2072
3469
2161
-832
-3929
-5842
-5462
-2676
836
2647
1585
-1208
-3238
-2945
-854
1726
3931
4774
3194
-262
-3035
-2819
57
2814
2867
398
-2106
-2703
-1538
137
1234
1218
266
-877
-1458
-1035
386
2136
3099
2570
937
-422
-157
1645
3259
3052
1148
-944
-1940
-1639
-577
627
1485
1574
795
-357
-1134
-1140
-528
163
328
-251
-1098
-1356
-608
550
1095
861
659
927
1157
977
794
1015
1308
1042
325
42
449
397
-971
-2553
-2692
-1463
-300
-81
-532
-1036
-1424
-1670
-1103
901
3190
3498
1371
-1133
-1921
-762
1087
2186
1962
908
-48
-54
1321
3339
4198
2850
228
-1927
-2641
-1858
-294
700
328
-684
-1044
-321
887
1551
1274
904
1030
818
-43
-205
990
2360
2759
1969
198
-1799
-3118
-3169
-1381
1629
3056
1177
-1803
-3044
-2475
-1158
553
2273
3059
1821
-1283
-3289
-1107
3455
5427
3328
-59
-2359
-3313
-3222
-2039
211
2151
1331
-2192
-4614
-3292
-98
2139
3158
3723
3614
2380
598
-267
513
1623
1317
205
169
999
1011
377
719
2003
2677
2132
1202
1012
1845
2551
2055
1126
456
-1095
-3523
-4402
-2837
-625
845
1103
-75
-1682
-2651
-3072
-2116
947
3296
2131
-584
-1893
-1547
-106
1154
400
-1258
-1305
-440
-19
654
1114
481
490
1662
1635
292
-495
-748
-495
713
1057
-441
-1563
-1786
-2459
-2320
-261
1612
2134
1994
1013
-8
755
2387
3307
4101
3848
340
-4579
-6759
-4787
301
5541
6689
3100
-1430
-4020
-3714
148
5590
8387
6860
2490
-2189
-4051
-1826
1998
4553
4757
1841
-3372
-7143
-6445
-1779
3780
6053
2962
-2541
-5732
-4893
-1058
3260
4728
2169
-2183
-5338
-5091
-941
4262
6727
5916
3442
561
-1366
-1557
-764
445
1596
941
-1851
-4206
-4339
-2689
-98
2019
2367
1829
1435
485
-650
-278
1424
3064
3812
2578
-693
-3560
-4159
-2825
-41
2992
3685
1361
-1909
-4227
-4331
-1549
2425
4762
4380
1681
-1821
-3198
-1085
2121
3498
2547
192
-2532
-4765
-5812
-4536
-382
4178
5102
1576
-2992
-4950
-3584
-366
3271
6031
5616
550
-6197
-7970
-830
11081
18215
14760
3666
-7895
-14570
-13806
-5997
4395
10619
8135
-1242
-9086
-7734
1350
10251
13438
10072
2303
-5153
-7742
-4216
3579
10705
10941
3499
-5810
-11751
-12195
-6621
1394
5263
2293
-4950
-11475
-11493
-3657
6114
12106
13115
8544
50
-5765
-4475
1534
7101
7166
489
-6695
-8369
-6253
-3155
1184
4651
4308
1264
-2252
-4055
-1493
3224
4757
3739
3412
2288
-510
-2486
-3466
-3920
-2344
-374
-698
-988
502
1310
1621
3399
4709
4375
4401
4129
1703
-1263
-2991
-2949
-302
2438
701
-4455
-8743
-11019
-10146
-4258
3627
7693
4887
-4112
-12549
-10255
3759
19006
25715
20380
4851
-12174
-20306
-15813
-1361
14279
17669
4921
-11681
-19532
-16018
-4012
8200
10169
1461
-9704
-16429
-12519
3551
20155
24492
17275
5334
-4976
-6195
1922
10459
14133
11629
969
-11276
-13979
-9048
-4751
-1431
471
-2203
-5649
-5726
-4774
-2066
3911
6839
4002
2029
2933
3162
3095
3526
3478
4206
4845
2657
786
2361
3768
3465
3911
4402
4037
2795
-2721
-11461
-15557
-14253
-12533
-9266
-4662
-4455
-7106
-6362
-2141
5437
15952
20464
14274
6562
3771
3835
6665
9621
5253
-5276
-14027
-17370
-12672
-1014
5382
-1248
-12217
-17549
-13569
1437
19352
24988
15761
-33
-15457
-20141
-6425
14089
24207
21619
10490
-4449
-12262
-8042
-1085
1529
-312
-8796
-20438
-23353
-14703
-2314
9202
17136
17527
12339
6937
3237
2870
6257
8694
7196
3786
-346
-3960
-4819
-4525
-4339
-1692
1044
-1067
-4351
-4668
-5820
-8074
-6729
-3086
218
3810
4040
-941
-3186
1409
7918
14665
20201
18003
9006
1227
-3165
-2784
4297
8154
-1028
-14861
-22903
-25455
-20676
-8102
924
10
-3817
-5824
-3781
7183
21317
25487
19973
13129
7337
5204
8598
10159
4785
-2704
-9181
-12905
-8420
544
946
-8487
-16881
-17855
-10286
4462
17939
20679
12144
-1565
-11778
-9981
4000
20088
27201
21008
6352
-6829
-13728
-15905
-13938
-10017
-10949
-17779
-23215
-22514
-15221
-2425
10169
17709
21998
22137
14503
5366
2624
2818
3323
6933
8268
2046
-4260
-7104
-11200
-10312
1729
11247
7823
776
-5321
-14857
-20591
-14281
-3433
4030
7858
5232
-2646
-4842
2873
13547
22035
25449
20257
8788
-2300
-8240
-5738
2134
4103
-3668
-12653
-18276
-21986
-20512
-12146
-3590
652
2230
2010
2018
6782
15112
20678
21567
20464
18363
13405
4429
-5299
-10378
-9947
-6864
-2921
-1195
-5650
-14284
-20857
-20712
-10653
6355
18714
20247
15366
6275
-4115
-4280
8208
19744
23062
19329
5205
-13691
-20929
-17190
-14660
-10232
-2291
-4991
-17494
-21379
-15646
-9998
-148
14845
22651
21085
16866
8334
-2646
-4810
2146
7526
7576
3593
-4056
-11199
-13589
-11742
-5149
5198
10505
4986
-5275
-12527
-14873
-12526
-6424
1021
6693
7167
2381
-2075
-1309
4830
14423
22929
24835
20498
12985
2199
-8111
-10482
-7645
-8909
-13921
-17366
-19835
-20681
-14608
-2675
6701
9330
8830
9174
9471
9287
13289
21226
22884
15101
6757
-305
-9161
-11100
-2440
832
-7734
-14135
-15240
-18604
-16112
-340
14346
17368
14912
7517
-5520
-8982
4788
19270
23691
25355
23552
9060
-11459
-22262
-21170
-15164
-7979
-3601
-6688
-14343
-18769
-16561
-7911
6561
21886
29170
24731
13246
1095
-7508
-9478
-4635
2698
7976
9519
6269
-1345
-7527
-5709
2202
8283
9147
6458
-154
-11199
-20926
-22556
-17074
-9344
-1528
3874
4233
3708
8439
15876
20310
21841
20893
16059
10722
7328
403
-11005
-17922
-18342
-19748
-21110
-14533
-3032
3252
2954
1210
-299
-817
3751
14339
24091
26265
21105
11480
467
-5021
-283
7381
7009
-1583
-11263
-17731
-19490
-15575
-6678
4694
13996
15537
7413
-4948
-11043
-3927
10222
18924
21352
23013
17545
-1001
-20260
-28469
-29124
-22811
-7073
5184
2442
-4058
-3087
-888
-290
5787
16108
22281
21578
14424
1822
-10514
-16320
-14888
-9087
-2132
3839
7272
5634
63
-2725
-2139
-5177
-10075
-8982
-5481
-5929
-6154
-5686
-10871
-15394
-8169
4221
11052
15828
21734
22887
17894
11003
4240
633
2192
2496
-4583
-14923
-22332
-25887
-25158
-18879
-9464
-1824
2761
7027
10682
10382
9650
15383
22442
20765
13676
8431
3000
-1562
-60
196
-9386
-19949
-22445
-21053
-16156
-4038
8004
13154
15816
15690
7211
-2542
-2002
6447
14393
19641
21363
16081
2583
-13769
-23789
-24412
-20770
-14449
-3224
6693
7902
5391
4653
2026
-1414
1179
7497
11067
12361
11131
4124
-5101
-10260
-11315
-8919
-1263
9217
16758
18508
14469
6160
-3592
-12522
-18567
-19007
-13453
-5054
1455
1027
-7346
-15987
-15142
-4180
9086
18500
24816
29867
29174
18196
3583
-4366
-6158
-7451
-9034
-12117
-18779
-23792
-22027
-18407
-16639
-11074
734
12634
20253
24112
24894
23236
19417
12430
4520
1831
5348
7464
1936
-8402
-17297
-22906
-25418
-21902
-9958
6457
19313
22355
14595
1968
-6149
-5151
2083
10316
16439
19493
17950
8971
-5774
-17398
-19903
-16857
-12005
-3380
8654
18006
19462
12711
2336
-4674
-5147
-1392
3522
6838
6138
2744
-730
-4767
-8241
-7250
-2770
1795
8146
16288
19454
14356
4432
-7885
-19659
-24646
-21577
-15827
-10091
-3867
331
-195
-2791
-2272
2885
9777
15878
21572
25874
24633
16371
4530
-7256
-17031
-23627
-27425
-28723
-26086
-19695
-12552
-6854
-3077
-403
3825
10366
16167
20374
24589
25319
17540
5047
-3384
-4847
-3467
-5628
-14296
-24138
-26952
-22387
-15357
-6758
3657
11222
11786
7904
4859
4949
7571
11580
16149
20156
21556
17742
7144
-8013
-21185
-27387
-28245
-26374
-19005
-4395
10899
18838
18999
15610
10868
5122
-146
-2584
-1437
1185
2213
869
-811
-989
-627
-1744
-3121
-741
6376
13963
16956
13158
3424
-8638
-18326
-22567
-20783
-14955
-8799
-3811
1898
8426
12492
12757
11510
10971
11621
12668
12686
10883
6690
-849
-10439
-18282
-22586
-24041
-22278
-16578
-8133
684
6870
8426
7915
10122
15285
19380
19927
17730
14327
9514
2028
-6468
-11569
-12834
-14848
-19366
-22453
-20220
-12727
-3094
4944
9755
11942
12101
10824
9451
8383
7032
5927
6116
7541
9290
9217
4551
-4364
-13558
-19836
-22419
-21091
-16120
-8761
-269
8500
16590
22123
21863
14125
2600
-6440
-10281
-9785
-5905
214
5892
8153
6023
1781
-864
-1081
-1478
-3464
-5023
-4096
-1852
-1642
-4832
-8332
-8382
-5910
-4394
-3761
-990
4515
10071
13437
14800
14994
13191
8045
948
-4410
-6093
-5370
-4600
-5331
-7607
-10137
-11687
-11701
-9402
-4441
1411
5617
7899
10003
12557
13805
12099
8641
5988
4302
1500
-3148
-8115
-11629
-12429
-9929
-5723
-3434
-5146
-8560
-8944
-3953
3930
9920
11122
8099
3479
-216
-2108
-2511
-1107
3000
8903
13470
14150
10630
3633
-5891
-15792
-22726
-24364
-21002
-14373
-5852
3160
10186
12808
10699
5641
185
-3187
-2978
234
4351
7703
9662
9688
7171
2467
-2911
-7406
-10217
-11032
-9778
-7025
-4032
-1864
-886
-1234
-2798
-4683
-5680
-5125
-2508
2645
9327
14666
16330
14565
11148
7217
2890
-1556
-5322
-7961
-9559
-10033
-9500
-8980
-9103
-8784
-6683
-3019
1052
4571
6737
7133
6374
5722
5851
6341
6474
5989
4587
1977
-455
-170
2559
3680
296
-5808
-10764
-12361
-10503
-6164
-1280
1487
641
-2322
-4361
-3951
-1205
3863
10914
18293
23921
25679
21101
9616
-4928
-16689
-23040
-25525
-25431
-20842
-10174
3140
12768
15304
11481
3857
-3742
-6866
-3575
3817
11063
15210
15691
13525
10083
6134
1198
-5471
-12104
-14495
-11073
-5644
-2877
-3589
-6177
-9602
-12906
-14063
-11561
-6304
-147
6770
14920
22162
24756
21554
14674
6805
209
-3130
-3060
-2336
-4217
-8996
-13986
-16782
-17210
-16063
-13706
-10211
-5428
772
6968
10170
9126
6376
5321
6487
8121
8943
8274
5119
194
-2363
579
5189
3487
-6843
-18830
-23674
-19198
-9918
-1510
2959
3340
1559
371
1565
4953
9024
12357
14783
17524
21080
22388
16268
1892
-13828
-22260
-21703
-17360
-13486
-9177
-2282
6196
13186
16437
14872
8399
-588
-7069
-6912
-460
8010
13845
14818
11707
7052
2772
-1352
-6363
-11545
-14429
-13603
-10454
-7818
-7808
-10771
-15004
-17346
-15408
-9594
-2093
5779
13738
20410
23386
21873
17363
11265
4084
-2381
-4956
-3248
-1857
-5703
-14025
-21151
-22706
-19083
-13240
-7332
-1951
3060
8117
13431
18197
20374
17957
11235
3863
487
1879
3252
-386
-7333
-10492
-6543
-817
-907
-7850
-16171
-20449
-18470
-9656
4650
18673
24328
18632
7345
-600
-1401
1828
4192
4218
4103
5871
8083
6825
16
-10091
-19066
-23810
-23117
-16583
-5381
6563
14842
18436
19528
19317
16209
8822
-1034
-9313
-12402
-8754
-62
8283
10176
4233
-4596
-10150
-10848
-9424
-8399
-7780
-6458
-3797
124
4185
5868
2873
-4075
-10748
-12434
-7448
2047
11945
18814
21401
20154
15632
8032
-1422
-9595
-13206
-11532
-6820
-2515
-1695
-5934
-13493
-18950
-17240
-8997
-19
5386
8439
12165
16256
18196
17694
16642
15188
11258
4582
-1656
-4705
-5783
-8018
-11883
-14398
-12804
-8110
-4624
-5785
-10281
-12679
-8494
1720
13507
22299
24986
19832
8106
-4460
-11225
-10743
-7299
-4955
-3669
-2127
-1204
-2579
-6100
-10609
-15362
-18465
-16006
-5920
8097
19268
24157
24362
22382
18295
10994
857
-9507
-16432
-17326
-12684
-5876
-347
2307
1437
-3207
-9489
-12593
-9631
-3407
1094
3052
5596
9739
12068
9245
2092
-5710
-10682
-10538
-4843
3699
10450
12783
11650
8702
4058
-1968
-7356
-10423
-11668
-11962
-10655
-7375
-4214
-3972
-6640
-9013
-7621
-1514
7133
14516
17999
18235
17967
18215
16799
11746
4660
-1265
-5331
-8845
-11751
-13146
-14513
-18403
-23477
-24764
-19749
-10995
-2360
4002
6801
5737
3557
4897
11626
20465
25689
23704
15278
4013
-6614
-14325
-17525
-15689
-10343
-4571
-1320
-1572
-3524
-4888
-6614
-11443
-17466
-17412
-7278
7905
19891
25782
27583
25746
17919
4611
-8336
-15723
-18404
-19750
-19817
-16550
-10104
-3091
1281
502
-4811
-9861
-9848
-4133
5212
15436
22245
21765
15355
8309
2992
-2275
-7385
-8725
-4582
2017
7618
12081
15849
16190
9496
-3042
-14541
-18447
-14866
-9379
-5823
-3515
-2186
-3924
-7736
-8816
-6087
-3389
-1597
2430
8892
14997
19931
22954
20827
12953
3828
-2584
-5569
-5392
-3976
-5100
-9878
-15564
-19496
-20365
-18178
-15501
-13395
-7151
5919
18947
24645
24157
19760
10580
877
-700
7137
17737
24461
21760
7487
-10642
-21799
-25075
-24622
-19029
-8014
927
3478
4572
7692
10162
9912
6540
73
-4157
860
11464
17468
18185
18933
16290
4409
-10410
-18342
-21027
-23520
-22213
-14068
-5791
-2659
-509
3338
4222
293
-3815
-4936
-2691
3822
12250
16834
16853
15344
10026
-1333
-11528
-13560
-10719
-6335
2240
11987
14009
8515
2917
-2362
-10288
-16827
-16991
-11853
-3608
5055
7491
967
-6897
-8511
-4905
498
6681
12408
16524
18461
16171
9814
5014
4292
2151
-4197
-9445
-10228
-8947
-7213
-6205
-9370
-15669
-18130
-14553
-9576
-4428
3388
11347
14060
12620
13091
17740
22554
22051
14670
4148
-4871
-10854
-12796
-7692
3315
9941
2736
-13019
-22589
-21120
-16750
-13552
-5439
8474
18163
18012
14424
13064
12349
10521
8457
5593
3122
5029
11641
16892
16699
10139
-2563
-19176
-30397
-31107
-23912
-13960
-6583
-1890
20
-603
-2961
-3683
-233
7006
15774
23553
26701
24223
19691
14778
6165
-5672
-14613
-18255
-18163
-13263
-5293
-2119
-4995
-6570
-6707
-10540
-12119
-3840
5910
7608
8145
13403
14677
7463
545
-1794
-3407
-2746
3702
10456
10975
6508
72
-6111
-7332
-3003
-15
-914
-628
510
-3197
-9049
-9126
-4796
-2674
-2086
296
1206
-2490
-5345
-763
8551
14069
12041
6797
4865
7653
10316
8519
4659
3446
2829
-3579
-15160
-23542
-23402
-16262
-5316
5653
11123
7922
-2165
-14081
-19382
-10904
5978
17593
21343
24379
23952
12226
-3183
-8413
-5605
-4585
-5176
-3800
-1527
2134
6558
3952
-8111
-19579
-24039
-23491
-14692
5117
23242
25754
15905
2295
-11506
-16892
-5584
12396
20680
20084
19149
15673
5626
-5752
-13473
-18838
-21996
-20142
-12658
-2336
5159
4247
-3145
-8473
-7994
-4991
-677
6926
16022
20894
17850
8802
307
-3062
-4274
-7530
-9848
-6871
-1132
3060
5399
5582
2131
-3133
-6151
-4529
1876
9035
9570
2431
-4156
-5090
-4179
-4314
-3175
-286
1141
-672
-3857
-4574
-1577
1057
1310
4739
12541
14456
6272
-1036
-1265
-2110
-6326
-5899
1518
9693
14175
12085
1379
-12387
-20722
-22075
-15953
529
19308
22772
7243
-12436
-23137
-22166
-11023
5386
19190
25902
24775
15409
834
-11931
-18531
-18652
-12622
-2498
7460
13340
11200
-122
-13067
-18772
-18514
-14932
-2904
15226
23183
14122
146
-8141
-9442
-2646
8318
12421
9893
12690
19681
17489
5285
-7183
-17172
-23200
-18212
-3849
6820
6903
-850
-13121
-23102
-20279
-5051
9938
17624
20830
19865
11741
558
-4111
135
5436
4958
1201
-1304
-4746
-11480
-16559
-15885
-12550
-8434
-1385
6710
11590
13004
9812
482
-5802
2184
16609
20355
12666
3383
-5773
-14841
-17352
-11955
-5789
-2244
-360
-1312
-3723
-2955
-410
-149
1344
7809
13495
13029
10334
9407
6984
-470
-9365
-11429
-3617
5229
3632
-7323
-17350
-21203
-18216
-6526
10096
19835
15526
1132
-13718
-17657
-5085
13894
23676
22619
17244
6828
-8485
-18709
-18414
-13993
-9322
-2215
4477
5041
-162
-8120
-16017
-17299
-7372
8078
20131
25079
20543
5201
-13642
-23071
-16912
-124
16117
22131
16859
6934
-1706
-6802
-7305
-4361
-573
4215
9352
8593
-1187
-13127
-20296
-21952
-16347
-2071
13268
19677
16124
6631
-4507
-9545
-3139
8730
17173
20390
17162
4583
-11573
-19695
-17702
-12418
-7369
-2577
-176
-1804
-5296
-6621
-2404
6736
14458
15307
11185
6464
1932
-2063
-2752
1060
5836
5609
-2077
-11291
-13181
-8232
-4927
-5634
-5247
-2409
341
3773
8385
10241
7921
5597
5832
6961
6443
1728
-6485
-10651
-5360
2229
1520
-7131
-16138
-20603
-17462
-4427
14002
26394
23848
7556
-11655
-20679
-14321
1342
15811
21203
14342
-1489
-16897
-23048
-18119
-6897
3383
7492
5031
-1492
-9625
-15187
-12443
-1095
11782
19703
20456
12546
-2746
-16587
-18503
-6752
10696
22205
19283
3466
-13433
-19733
-12790
2458
17663
23859
17245
2924
-10584
-18244
-18374
-11094
-91
7767
7389
-176
-8259
-9942
-3838
5799
13787
16820
13572
5779
-1739
-4750
-2674
2042
5690
5137
-124
-8044
-15676
-19344
-15861
-6615
2158
5544
3725
-340
-2808
433
9856
19436
21498
14092
2278
-6432
-7695
-3201
1694
3052
141
-5948
-12476
-15271
-11993
-4678
2431
6488
6943
4845
2524
2938
7594
14204
17456
13816
5066
-4166
-10671
-12796
-9297
-1492
4931
3518
-6720
-18984
-23132
-13987
3826
19427
23466
13345
-5076
-19181
-17622
-734
18567
26029
17365
-483
-16192
-21908
-17171
-7480
46
577
-5935
-14563
-18923
-15754
-5941
7170
18458
21767
13826
-1271
-12883
-11462
2847
19371
25642
17112
-655
-16634
-21223
-12523
2127
12025
11053
742
-11592
-17260
-12032
747
13324
18718
13480
-180
-13699
-17474
-8760
6672
19170
20765
10291
-4500
-12509
-8473
3831
15556
18479
10102
-4167
-15129
-17029
-10825
-2212
2567
883
-4876
-9855
-10160
-4701
4035
11250
13363
10120
4002
-816
-777
3441
7324
7272
2751
-4792
-11749
-13723
-10274
-5465
-2518
-1523
-1624
-1492
479
3519
4929
4443
4438
5958
8001
9453
9251
6879
3808
1853
200
-3315
-8612
-12703
-12048
-5814
1893
4197
-2157
-12665
-17788
-10466
6993
22934
25410
12542
-5952
-16339
-10794
6347
21304
22316
9142
-8552
-19545
-18055
-7184
3156
4552
-3192
-13749
-19849
-17026
-6232
5835
11772
9438
2522
-2746
-1250
7168
16282
18241
10574
-1841
-10755
-10640
-3121
4108
4004
-3714
-12858
-16301
-11633
-2596
4617
6419
3468
-1088
-3893
-3125
662
5304
8351
7877
3897
-435
-985
3156
8598
10642
6940
-487
-6264
-6248
-1698
2089
1018
-4520
-10282
-11451
-6798
-307
2235
-1282
-7303
-9545
-4182
6526
15438
16369
9487
1046
-2106
1775
8168
10396
5345
-4207
-12191
-13969
-9507
-2958
705
-634
-4949
-7748
-5561
1078
7767
9906
6790
2170
687
3519
7361
7870
4070
-903
-3406
-3052
-2640
-4457
-7230
-7396
-3538
1091
1171
-5259
-13804
-16518
-8714
6137
18268
19217
8890
-3821
-7882
741
15268
23442
17797
2115
-11614
-13428
-3929
6553
7268
-3781
-18495
-25653
-20086
-6414
5438
8298
2512
-5087
-6365
1972
15441
24943
23754
12621
-659
-7061
-3752
3362
5368
-986
-10498
-14757
-9963
-493
4988
1681
-6840
-12224
-8986
1057
10587
12659
6105
-3722
-9265
-6391
2796
11604
13785
8333
50
-4480
-2044
4734
9554
7782
260
-7951
-11984
-10563
-6542
-4512
-6822
-11449
-13994
-11441
-4201
4223
9553
10055
7802
6143
6464
7718
8115
6736
4199
1921
530
-507
-1701
-2913
-4058
-5482
-7349
-9090
-9673
-8414
-5640
-2385
608
3221
5300
6346
6124
5314
5256
6709
8813
9807
8786
6167
2605
-1454
-4919
-5809
-3015
1312
1998
-4618
-15263
-20341
-12526
4660
18212
17136
3359
-9245
-7895
6558
20525
21200
8838
-4377
-6892
1463
10625
10732
897
-11475
-18357
-17293
-11461
-5848
-3721
-5258
-7880
-7644
-2013
7271
14450
14259
7247
242
176
6937
13134
11400
1994
-7131
-8231
-1430
5723
5835
-1447
-9725
-12416
-8562
-2698
-133
-2419
-6735
-8945
-6953
-1901
3086
5481
5271
4639
5768
8568
10634
9764
6483
3688
3549
4925
4329
-199
-6579
-10482
-9682
-6371
-4894
-7217
-10903
-11618
-7406
-490
4967
6622
5558
4705
5898
8415
10002
9075
6153
3313
2160
2345
1880
-945
-5600
-9580
-10685
-8920
-6390
-5154
-5202
-5000
-3386
-535
2538
5330
8030
10289
11129
10184
8469
7593
7580
6305
2375
-2268
-3635
-150
4190
2996
-5236
-14128
-14822
-5144
6868
10105
1430
-10866
-14840
-6322
7332
14758
11372
2749
-1825
1653
9003
12726
9198
1151
-5711
-7596
-5233
-2605
-3206
-7502
-12625
-14332
-10767
-4233
680
764
-2573
-4314
-968
6090
11728
11545
6408
1508
1166
5299
9553
9299
4132
-2319
-5774
-4589
-1290
-148
-3198
-8799
-12810
-12051
-7403
-2665
-835
-1451
-1116
2548
7932
11143
10217
7356
6651
9331
12124
10823
5138
-619
-2006
741
2677
-740
-8722
-15817
-16963
-11878
-5000
-1029
-989
-2455
-2227
901
5414
9052
10560
10135
9206
8917
9017
8355
5715
1146
-3481
-6132
-6141
-4495
-3162
-3348
-4750
-6355
-6998
-5905
-3250
-56
2177
2620
2336
3364
6278
8831
7740
2724
-1847
-729
6176
12111
9288
-2778
-15356
-17992
-8763
3285
6672
-1468
-12760
-15913
-7714
4399
10237
6589
-429
-1991
4832
14825
19848
15778
5457
-4086
-7311
-3950
1358
2679
-2457
-10723
-15552
-12495
-3305
4858
5695
-483
-7239
-7677
-819
7334
9955
5723
-465
-1982
3178
10548
13856
10365
2937
-2377
-2032
2088
4845
1974
-6047
-14008
-16818
-13591
-7728
-3722
-2778
-2128
1011
6243
10317
10532
8267
7489
9951
13409
13695
8707
1148
-3988
-4537
-2670
-2105
-4569
-8311
-10119
-8971
-6381
-4387
-4055
-4230
-3222
-1031
2001
5181
7088
7409
6526
5351
5444
6677
7388
6043
2347
-1434
-3082
-3271
-3908
-6145
-9302
-10811
-8716
-4130
118
2518
2578
604
-1357
-1398
1760
7991
13075
12271
4999
-4250
-7166
-250
9857
13210
4688
-10246
-18357
-12315
2352
12794
9744
-3368
-13839
-12321
-534
11471
14906
9512
1775
-1909
756
7222
11759
10858
4552
-5610
-13936
-14139
-7624
-987
168
-5148
-11154
-10343
-1264
9289
12446
6756
-1517
-5294
-1640
6255
11869
10821
4409
-1993
-4298
-1692
3337
6230
4246
-2194
-8426
-8715
-4293
-41
921
-3986
-11827
-14738
-9737
-160
8377
11734
9361
4017
1250
4294
10609
15889
16275
9813
-819
-9129
-10019
-5148
-308
-321
-6597
-13969
-15714
-10614
-1675
4990
5556
2847
513
1606
7319
13246
15100
12020
5446
-113
-1257
1408
4647
4527
318
-5417
-9737
-10796
-8780
-5374
-2990
-2837
-3823
-4314
-2341
2424
7120
8580
5562
1794
2505
6266
8936
7654
1311
-4455
-2837
4249
7817
1361
-11076
-20210
-19104
-6277
8341
12665
6298
-4187
-11047
-9746
-1650
9889
18451
18875
12552
2621
-4342
-2223
5550
11283
7593
-5987
-18558
-22083
-16485
-4860
4383
4976
-243
-4893
-4300
1944
11124
18437
18037
10356
1878
-3482
-4701
-1401
3656
6436
6085
2514
-4178
-10046
-11157
-7140
-652
2723
338
-5481
-10820
-11267
-7163
-1830
3633
6780
7530
7968
6551
4557
4536
6575
11382
14645
11975
5184
-3859
-9778
-8602
-5573
-4591
-6637
-10990
-13300
-12793
-9575
-3410
2198
6629
8852
6138
3251
4677
9065
14325
16148
11868
4462
-2085
-5404
-5756
-4587
-2876
-3364
-7638
-12394
-13937
-11152
-4538
2020
4571
4754
4974
5452
6265
6043
6393
9841
11695
8236
1079
-6767
-9370
-4790
1439
1949
-7282
-18505
-22038
-17839
-5582
9995
17058
13963
5133
-5596
-11894
-9568
2243
17291
25320
23822
12469
-5428
-17658
-18683
-12273
-3745
238
-2485
-9757
-17932
-20461
-14572
-2432
12156
21574
20096
10172
-720
-5400
-2041
5601
12416
14011
8423
-1646
-10832
-14500
-9455
1974
11133
12041
4591
-6442
-13026
-12708
-8151
-1381
4479
7648
6518
-577
-8224
-10119
-4701
6092
14206
14649
10290
5184
4319
7210
8476
7827
4620
-1801
-7726
-11851
-13708
-12391
-9201
-5804
-5174
-6877
-6388
-3105
2697
9999
14003
13644
11534
8810
6239
4619
4014
3023
617
-2925
-7795
-12171
-13388
-12154
-10020
-7598
-5313
-3315
-951
2293
4241
4586
6827
11161
15499
17919
15969
10362
3099
-4808
-12058
-17753
-18798
-13351
-6157
-2943
-6182
-12680
-15204
-10724
-69
13298
22985
25606
20428
8321
-5358
-13478
-10540
2579
17356
24681
19394
3869
-12692
-22552
-22953
-16402
-7987
-671
2806
842
-3922
-7362
-6008
809
10472
19063
22253
19177
12191
2978
-5391
-9785
-9798
-5834
-235
3053
1953
-2663
-7131
-8014
-4653
1417
7433
11883
13865
10908
2733
-7134
-14903
-17536
-13344
-4165
5449
11566
11906
6550
-98
-2252
1918
9788
16582
18016
12296
993
-11421
-20135
-21659
-15768
-6947
272
3639
1366
-4569
-8577
-6942
622
10661
17876
19266
15111
8639
2880
-1664
-4341
-5172
-5592
-6146
-8036
-11647
-14507
-15364
-14199
-11068
-7084
-1551
7070
16977
23712
23435
17259
10306
5820
3799
981
-5596
-12488
-15111
-14165
-12032
-10549
-11042
-12879
-13306
-9070
349
12380
23462
29276
27083
17713
3818
-9846
-17079
-14899
-5519
5732
13402
14691
10218
2048
-7952
-17014
-20840
-16792
-7048
2902
8480
8450
4825
1180
-14
1229
3570
6270
9124
10426
7573
422
-8091
-14124
-14812
-9612
-529
9365
17189
19891
15568
6561
-2110
-7487
-9547
-9248
-7658
-6232
-6288
-8031
-10594
-11542
-7826
632
10515
18012
20982
19576
15310
10352
6304
2802
-712
-3792
-6627
-10135
-14127
-16290
-14624
-10343
-6306
-4450
-3976
-1010
6604
15321
19499
17625
12824
7898
3549
336
-1326
-1435
-557
-668
-4201
-11902
-20993
-26034
-23342
-13980
-2568
6516
11627
13236
13217
13343
13783
14585
15323
13136
5657
-5316
-15208
-19927
-17534
-10528
-6072
-8309
-13280
-15183
-11131
-552
12837
22350
25302
23139
15367
1715
-11908
-18295
-15969
-7005
5194
15682
21139
20455
12095
-2933
-17770
-25128
-23185
-13956
-1095
10485
17564
19009
13105
1282
-8517
-10093
-5611
248
5510
8716
8446
5383
795
-4603
-8001
-5766
1389
8832
12723
12892
11881
10247
4752
-6222
-17922
-23037
-19528
-11663
-4572
-885
-352
-733
81
2626
5776
8817
12844
17557
19829
17548
11718
4287
-4034
-12556
-19083
-21662
-19770
-14097
-6768
-541
2160
1242
465
2796
6319
8591
11136
15816
19692
18459
12208
3079
-7235
-15649
-19568
-19910
-19210
-18243
-16040
-12507
-8087
-2249
4813
11974
18333
22450
23541
23081
22018
17184
4627
-12022
-23509
-25935
-21449
-12986
-5514
-4236
-7634
-9390
-7663
-4272
3046
15667
26461
28010
20249
6761
-7448
-16602
-17966
-12754
-2823
9744
19752
21474
13972
308
-14114
-22818
-23359
-17976
-8761
3048
14699
21826
21434
14732
5680
-2792
-9849
-14233
-13362
-7405
-340
5179
8678
9192
6839
3289
-492
-3310
-2609
2912
10632
15482
14480
8451
32
-8563
-16213
-21129
-21427
-17768
-10470
1042
13149
21044
24122
22561
15672
6570
1197
137
-685
-1336
-879
-2388
-6066
-8924
-11385
-14344
-15504
-13234
-8933
-3246
4801
12834
17476
19456
19105
15076
8926
3188
-1771
-6278
-9516
-11174
-13545
-17331
-19335
-17979
-14593
-9518
-1693
8299
16491
19713
19549
19132
19343
18104
12202
1382
-10656
-18704
-19312
-14758
-11696
-13148
-14865
-12327
-7101
-1916
4442
12581
19219
20622
15200
4317
-6796
-12613
-12596
-8774
-1506
8142
17056
22062
20088
9654
-5301
-16685
-20857
-21151
-18823
-11022
1389
13126
20290
22821
20599
11732
-908
-10717
-15595
-15718
-10061
-298
8153
11597
12075
11188
7052
1472
-2294
-3771
-1365
4240
8314
8683
6215
1104
-7221
-15636
-19071
-18976
-17358
-10778
425
12198
21876
26579
25272
19092
9969
649
-7200
-11753
-12170
-9431
-3759
316
-2355
-7363
-9522
-10025
-10049
-8120
-2261
6220
14458
21179
23229
19580
14103
8169
1293
-6232
-13792
-18823
-20301
-19164
-15840
-12260
-9179
-5522
-1796
1745
5759
11261
17880
22225
23646
23113
17747
7860
-768
-5174
-7429
-10313
-14047
-18200
-21431
-19253
-10878
-1388
6164
11154
12240
8862
2655
-2905
-5029
-2988
1958
6887
10723
14512
17420
16943
11414
1888
-8007
-15324
-19198
-19722
-16439
-8811
901
8808
12943
13378
11032
6537
288
-6921
-13479
-15895
-12388
-6136
36
6634
13727
18921
19453
15089
7427
-421
-4113
-3737
-3036
-2640
-2304
-3888
-8125
-12812
-15285
-15539
-13686
-8664
-2034
4748
12526
20015
24279
23512
18096
10240
1151
-7747
-13526
-14823
-12420
-8937
-6800
-5663
-4985
-4527
-3599
-2556
-799
2789
7311
11721
14998
15876
14452
11659
8126
2974
-4335
-11260
-15686
-17276
-15236
-10623
-6309
-3688
-2360
-747
2571
7484
12432
15583
16699
15745
11734
6384
3151
2241
1314
-1707
-7599
-14821
-19711
-19260
-14341
-8187
-2329
2855
6238
6599
3726
-333
-2095
-328
3226
7004
11261
16257
20200
20136
14314
3794
-7634
-16344
-21268
-22388
-19057
-11344
-1706
5910
9019
8311
6168
3935
832
-4226
-9721
-11906
-8697
-1670
6296
13540
19016
21306
19528
14062
6284
-1573
-7438
-10910
-12657
-12591
-10222
-6596
-4107
-4129
-5977
-7988
-8645
-7082
-3363
1805
7752
13679
18040
19162
16647
11485
5074
-1167
-5934
-8746
-10157
-10698
-10233
-8708
-6698
-4800
-3183
-1951
-1112
-108
1824
4805
8135
10565
10624
7696
3282
81
-752
-540
-1071
-2614
-4113
-4525
-3703
-2439
-1682
-1509
-1337
-990
-625
209
2165
4620
5893
5425
4696
5501
7736
9081
6907
875
-6328
-11261
-12651
-11565
-9228
-6050
-2599
-87
627
-80
-1037
-1238
-385
1335
3991
7911
12489
15489
14603
9667
2667
-4275
-10102
-14252
-15930
-14358
-9685
-3485
1899
4916
5610
4662
2234
-1601
-5711
-8146
-7653
-4483
227
5466
10675
15165
17469
15875
10142
2438
-4035
-7480
-8336
-8067
-7560
-6702
-5159
-3320
-2257
-2620
-3752
-4231
-3176
-715
2573
6226
9828
12683
13835
12544
8892
3953
-808
-4294
-6033
-6145
-5283
-4481
-4561
-5482
-6451
-6665
-5929
-4566
-2771
-346
2784
5940
7881
7873
6374
4491
2950
1725
592
-258
-469
-203
-155
-824
-1903
-2767
-3360
-4178
-5353
-5988
-4813
-1676
1954
4276
4951
5357
6809
8797
9280
6656
1462
-3876
-6916
-6895
-4878
-2481
-689
191
113
-832
-2231
-3292
-3156
-1315
2105
6378
10567
13749
14917
13168
8299
1259
-6111
-11808
-14327
-13198
-9149
-3636
1818
6017
8110
7578
4333
-1048
-6967
-10958
-10980
-6944
-816
4962
9127
11732
13068
12714
9848
4660
-898
-4320
-4609
-2949
-1294
-713
-1151
-2178
-3640
-5502
-7327
-8185
-7236
-4456
-535
3834
8091
11391
12663
11302
7782
3465
-135
-2039
-2228
-1441
-609
-530
-1647
-3814
-6233
-7834
-7967
-6579
-3951
-657
2527
4876
5989
5972
5214
4116
2879
1456
-29
-1140
-1539
-1381
-1250
-1605
-2367
-3075
-3139
-2255
-771
482
672
-369
-1727
-1843
466
4810
8941
10073
6870
688
-5108
-7490
-5803
-2075
683
861
-923
-2848
-3604
-3415
-3356
-3720
-3289
-455
4958
11073
14919
14350
9539
2785
-3107
-6642
-8090
-8237
-7231
-4660
-471
4273
7460
7024
2698
-3546
-9006
-11859
-11958
-10281
-7364
-3170
2231
8247
12867
13597
10035
4228
-799
-2897
-2159
-399
563
373
-84
-440
-1158
-2887
-5716
-8041
-8022
-5733
-2182
1385
3630
4530
4920
4950
4293
2836
1074
-60
-143
503
1213
1352
795
-41
-614
-696
-786
-1313
-1675
-1368
-620
378
1381
2222
2722
2227
1008
-47
-778
-557
722
1513
878
-926
-2517
-2079
-179
1454
1971
567
-2399
-4693
-3820
490
5460
8872
9645
6224
317
-3919
-4751
-1880
3389
7495
7763
3604
-3048
-8363
-10270
-9520
-7712
-5102
-676
5478
12045
16358
14982
8263
-38
-6835
-9468
-6877
-1305
4596
9178
10717
8716
5207
2050
-1498
-6152
-10616
-13502
-13978
-11210
-5262
1999
7743
10454
10267
7570
3766
1675
2263
2977
1849
476
850
2569
3761
2534
-1525
-6937
-10946
-11255
-8851
-6255
-3496
184
3476
4748
4462
3615
2060
545
-232
-1034
-753
1387
3024
3125
1991
-244
-1626
-761
1161
2042
1009
-657
-2007
-2447
-1196
215
510
-485
-3057
-4012
-1556
753
1727
1961
597
-749
132
2381
2973
529
-2020
-2290
-203
4583
9530
10597
6663
-725
-6539
-6295
-927
6566
11928
10498
2591
-7349
-14617
-16268
-12860
-6743
-337
3862
5266
5597
5951
5564
3431
-392
-4580
-6976
-5619
299
9335
17619
20835
16799
7510
-2888
-11505
-15533
-14925
-14250
-14413
-12542
-8598
-2861
3851
8314
9028
6463
2396
41
1258
5428
9504
11037
10064
5965
405
-2832
-4750
-6739
-7328
-6835
-5532
-3202
-849
1422
3091
2635
477
-1076
-809
121
1260
2478
1436
-1601
-2959
-1695
298
1664
2473
2560
1817
2545
5559
7856
6868
2549
-2149
-4812
-5903
-5126
-3964
-4558
-4428
-2723
-947
508
-80
-1442
-1345
-1273
-280
2124
3633
3541
185
-5015
-6545
-1922
8773
19623
22924
18628
7028
-8294
-17445
-18807
-14464
-4354
5350
8243
3790
-2887
-5015
-4692
-6216
-8470
-11073
-11523
-6734
2212
13325
21381
23768
23205
15928
586
-12868
-17853
-15718
-10385
-5785
-4054
-6126
-8670
-7507
-4998
-3297
-1661
-1100
-1336
-226
4195
11858
18157
18832
13178
3004
-5880
-8605
-6144
-741
6513
12831
13478
7031
-2265
-10108
-13819
-10966
-3362
2480
1696
-3889
-9158
-12858
-14115
-9199
-513
4058
3513
3464
5756
7830
9587
11067
8786
3558
734
204
-1753
-5011
-5845
-2128
2276
2004
-3504
-11745
-17702
-14867
-3350
7716
9445
1226
-11129
-19872
-17963
-5728
8399
18849
24614
22490
10900
-5318
-19035
-23684
-14388
5841
22892
23522
10187
-4221
-12964
-18156
-22102
-24438
-24247
-19049
-6841
7581
17078
22732
28786
30778
20910
2207
-12264
-13147
-1908
12694
20227
15144
1784
-10785
-18507
-22078
-20020
-10521
1745
9085
8264
986
-6957
-8928
-5171
-1422
196
2029
5247
8581
11429
13812
13582
9189
3510
345
235
1991
5217
7679
4038
-5710
-14632
-20337
-24388
-23015
-12689
1499
11581
15019
12911
6249
-884
-2178
3545
12340
19945
23084
20036
12269
4550
-444
-5704
-13057
-18512
-17128
-8254
2327
5235
-3884
-18338
-26465
-24165
-14955
-1137
15148
27895
30732
21689
4280
-13757
-21586
-12469
5924
19212
22197
17307
6205
-9050
-21947
-26115
-22628
-15553
-6596
1101
4359
4578
5053
6640
7490
7578
9344
12152
14572
18636
24472
27157
21287
6033
-13129
-26918
-27493
-14854
2495
15639
19473
11710
-3976
-18341
-24038
-18963
-4438
13975
25560
21941
6945
-7593
-13931
-10167
2903
18764
26877
23610
14959
5941
-3594
-11775
-14657
-14059
-14680
-15793
-14292
-11296
-9327
-8085
-7149
-7352
-6915
-2255
6117
14271
20129
23572
23184
17492
8148
-138
-2986
318
4871
4726
-238
-5224
-8946
-14191
-21459
-26931
-27201
-19611
-3680
14776
25070
23212
13007
-1036
-14854
-18424
-5815
15329
29383
31630
25950
11382
-6357
-19582
-22932
-16892
-3341
11398
15682
3652
-15795
-28210
-26592
-13246
4342
17928
23532
22561
17356
10114
4270
1566
-290
-2239
-1579
2541
7184
10545
11429
6312
-6260
-20674
-29437
-28940
-18742
-1846
12506
14566
4485
-7631
-12688
-9180
-112
11657
22747
27799
22778
9533
-5288
-14458
-13053
-2144
8691
8917
-1647
-14733
-24469
-28767
-24936
-12992
863
10278
13461
10676
4126
-787
-506
3694
10490
19095
24740
22538
14379
5359
-1500
-3881
-2469
-4222
-13062
-22223
-25037
-23071
-16610
-2419
14010
20270
12831
-1801
-15973
-20789
-9458
10958
24796
27012
22856
13153
-3723
-21210
-28785
-21764
-3524
14387
17734
4145
-13774
-24296
-25342
-17452
-1778
15256
25430
24514
12449
-4054
-11648
-4471
7313
12614
13087
14024
14139
10683
4509
-2149
-6670
-7734
-8567
-12157
-14499
-10791
-4577
-3298
-8958
-16702
-18637
-10266
3903
15787
23414
27013
21772
6716
-7084
-8584
1023
13544
20839
16711
2798
-11092
-19315
-23656
-22572
-12380
864
5977
944
-7583
-12392
-8478
2765
12443
15459
15651
14382
8177
845
1146
8405
14650
15207
7436
-8909
-24284
-26884
-17691
-5159
6666
13087
6616
-9741
-21904
-21717
-11446
4684
20821
28836
25683
13833
-4127
-20993
-23551
-7980
12679
23457
19447
3454
-15675
-26087
-23638
-13485
108
13714
18606
9722
-4561
-12661
-11642
-3922
6386
12735
12223
9488
8500
8339
8821
9621
6241
-2696
-10206
-10630
-6357
-2087
-1458
-7067
-15533
-18744
-14651
-7578
1196
11334
16709
12700
3870
-2817
-3998
1910
12336
19129
17607
10640
440
-12301
-21389
-20228
-11574
-3069
1108
-710
-7531
-12885
-11530
-5724
1354
9664
15927
14689
7732
2255
1966
6841
14817
19203
13324
-310
-13188
-19218
-14916
-899
13161
14847
2626
-14220
-26308
-27668
-16783
693
16268
24877
23360
9167
-11637
-24228
-19935
-3062
15010
23106
16046
-1409
-17130
-23460
-19987
-7511
8411
18163
16109
4337
-9671
-19270
-18099
-4647
11930
22695
23306
14250
3180
-2039
1398
6616
5495
624
-4502
-7543
-7440
-8196
-10719
-13753
-14365
-11365
-9197
-5926
149
5546
9190
8585
5435
3346
3843
9352
14343
15037
12280
3662
-6442
-12953
-12883
-5786
578
3617
1832
-5349
-10738
-13173
-11295
-3815
4752
12184
12530
6221
644
-2734
96
6912
10802
10216
2757
-5951
-9331
-5938
5006
12984
9990
-1839
-17047
-23912
-18525
-4552
12043
20567
18767
8424
-6290
-14694
-12309
543
17285
25993
21724
4700
-15899
-26371
-22257
-6516
10012
16333
11206
-1305
-13262
-18605
-16489
-6874
5995
15054
15780
7473
-3271
-7450
-2495
8067
16245
15643
7896
-2261
-9098
-9439
-7172
-5538
-6917
-11189
-12771
-10876
-6257
-358
2905
5225
5531
3397
2783
3027
6970
12751
13379
9149
-327
-8715
-10289
-8392
-2469
1395
-278
-3700
-9974
-12437
-8969
-2346
7766
12478
11613
7190
-2225
-7455
-7356
-1182
9480
12752
8447
-3770
-17572
-19362
-11491
4783
21012
24737
16665
-3529
-22290
-26005
-16275
5533
23368
25905
15569
-5245
-21041
-24024
-13662
8178
22457
21211
5933
-16116
-26201
-21177
-4260
15277
22548
18774
5039
-11112
-16729
-12851
-1323
8382
8634
4142
-3704
-7200
-3389
2418
10149
13371
9802
2176
-7378
-10319
-7421
-3398
-547
-3431
-7725
-9725
-8989
-4263
716
5718
9657
9662
7976
5213
3569
4666
6095
6558
3668
-2322
-8568
-13015
-12751
-8231
-2695
378
-1022
-4861
-7235
-4154
4589
14729
20585
17700
7665
-3840
-9944
-7168
215
6052
4406
-5543
-16896
-22286
-15737
172
15157
20787
12562
-2879
-14230
-15338
-4645
9908
19487
19344
8169
-5427
-12879
-9705
2496
12414
13339
4682
-8171
-15226
-14202
-5680
5863
12529
11939
3156
-7908
-12587
-9410
-136
7402
8051
4039
-2297
-5685
-4311
687
8432
13035
11533
4387
-4955
-9415
-8233
-3829
57
-345
-3515
-8318
-12111
-11390
-6036
3099
10912
13072
10042
4207
444
163
2039
4629
4949
2513
-2581
-8526
-11393
-10208
-5427
-488
1204
54
-2785
-3887
-1558
3168
8781
11180
9024
3541
-2439
-4070
-1261
3569
6279
2877
-4198
-10765
-11570
-4315
5885
13362
12606
3674
-6459
-11945
-8212
2239
11516
14182
7194
-4303
-11981
-11701
-3034
6826
11101
8287
7
-6843
-8261
-4333
2928
7586
7404
3087
-2943
-5677
-4678
-1188
2816
4220
3703
1450
-1717
-3298
-3032
171
5051
8235
8500
4581
-1436
-5786
-6758
-3057
2429
5389
3906
-2228
-8397
-9874
-5573
3075
10470
12552
9174
2316
-2851
-3741
-1234
2450
3179
411
-3799
-7288
-7186
-4412
-1004
1618
1617
493
-315
-125
1851
3333
3181
1274
-2113
-4167
-4172
-2175
1209
3238
3347
1121
-2570
-4645
-4189
-668
4055
6504
5934
2223
-2198
-4475
-4218
-1177
2366
4064
3280
-99
-3154
-3619
-1224
3070
6028
6379
4362
927
-1535
-2258
-760
2175
3924
3304
109
-3514
-4751
-3436
-638
1215
758
-1192
-3504
-4089
-1923
2345
6799
8258
5677
625
-3731
-4727
-2902
-235
1179
510
-1447
-3987
-5753
-5712
-3754
-463
2281
3665
3966
3697
3509
2860
1774
750
-297
-1292
-2739
-4044
-3872
-2296
-93
1026
524
-197
-167
1212
3059
3838
3055
579
-2147
-3110
-1489
1967
4318
3292
-563
-4433
-4922
-1318
4126
7945
7520
3169
-2452
-5956
-5411
-1891
1748
2949
1316
-1331
-2928
-2514
-660
1280
2289
2048
1006
-31
-510
-370
76
567
1064
1486
1521
840
-394
-1480
-1770
-1250
-595
-532
-1162
-1974
-2231
-1490
23
1567
2300
1901
961
482
910
1639
1523
80
-1905
-3110
-2855
-1634
-577
-422
-1048
-1734
-1653
-409
1626
3375
3648
2058
-518
-2546
-2998
-1955
-249
1350
2513
3064
2798
1744
422
-301
171
1654
3239
3795
2595
-102
-2945
-4184
-2961
-262
1607
938
-1815
-4295
-4177
-1125
3045
5851
5828
3270
-186
-2615
-2796
-875
1694
3133
2569
571
-1464
-2498
-2461
-1867
-1146
-453
62
109
-424
-1122
-1265
-518
699
1521
1384
474
-517
-946
-635
37
436
86
-946
-1966
-2122
-1142
324
1154
739
-416
-1112
-568
855
1938
1671
99
-1768
-2772
-2387
-934
802
2090
2527
2081
998
-283
-1201
-1250
-280
1256
2385
2186
522
-1727
-3214
-3067
-1484
525
1901
2111
1286
34
-822
-612
700
2257
2780
1594
-666
-2448
-2514
-923
1150
2429
2405
1423
186
-686
-792
-2
1418
2769
3181
2176
94
-2003
-2912
-2055
57
2075
2665
1457
-620
-1980
-1537
503
2791
3761
2671
61
-2563
-3597
-2363
353
2739
3194
1543
-804
-2011
-1253
730
2374
2545
1274
-456
-1446
-991
716
2676
3647
2983
1173
-529
-1113
-564
325
813
767
409
-162
-969
-1707
-1676
-489
1202
2027
1195
-579
-1644
-1010
704
1956
1729
285
-1364
-2390
-2504
-1757
-444
758
950
-272
-2198
-3349
-2728
-725
1217
1832
958
-549
-1616
-1613
-587
840
1785
1538
83
-1761
-2810
-2278
-308
2098
3619
3313
1245
-1327
-2576
-1422
1417
3803
3936
2001
5
-127
1696
3811
4433
3139
848
-1201
-2255
-2114
-991
443
1150
408
-1394
-2832
-2599
-708
1503
2557
2003
559
-676
-1036
-514
420
1111
1004
2
-1339
-2109
-1762
-628
330
353
-505
-1523
-1924
-1377
-64
1463
2456
2253
786
-1116
-2148
-1491
444
2267
2648
1277
-964
-2660
-2796
-1384
558
1684
1199
-604
-2560
-3402
-2571
-536
1561
2664
2439
1387
382
44
434
1152
1636
1454
567
-553
-1164
-818
195
1044
1023
93
-1148
-1915
-1722
-690
447
781
-41
-1417
-2251
-1948
-887
66
390
154
-332
-839
-1162
-1094
-629
-111
39
-255
-669
-793
-441
285
1054
1405
1054
250
-288
-7
920
1735
1813
1174
322
-206
-133
462
1168
1468
1179
651
389
492
616
449
35
-407
-749
-833
-392
646
1789
2298
1985
1411
1181
1238
1128
783
623
864
1088
785
109
-199
306
1187
1495
732
-605
-1410
-979
240
1004
496
-793
-1573
-1120
71
1069
1534
1701
1636
1049
-19
-909
-1036
-631
-362
-391
-301
50
142
-459
-1332
-1609
-1043
-227
216
286
304
359
321
211
212
349
435
372
269
194
1
-474
-1152
-1736
-1922
-1510
-530
624
1323
1259
832
727
1104
1463
1401
1131
1078
1227
1250
1109
1087
1185
972
271
-406
-442
75
529
661
763
993
987
527
144
565
1667
2480
2309
1456
662
233
15
-54
140
455
387
-337
-1309
-1739
-1218
-70
962
1333
1102
845
1032
1405
1178
37
-1233
-1509
-703
34
-294
-1320
-1803
-1151
-9
649
498
-164
-960
-1554
-1549
-778
279
769
326
-590
-1279
-1489
-1373
-1075
-656
-291
-131
2
428
1007
1111
439
-404
-478
437
1619
2217
1977
1159
137
-684
-870
-242
813
1625
1825
1530
968
254
-421
-649
-179
686
1325
1398
1095
817
818
1127
1527
1587
957
-128
-856
-640
159
607
267
-377
-627
-362
43
362
678
1006
1126
914
582
423
487
639
806
970
1028
880
612
369
91
-374
-838
-794
-105
561
385
-570
-1311
-1023
15
871
1058
980
1288
2093
2844
2821
1722
-42
-1482
-1638
-360
1481
2637
2441
1205
-183
-954
-875
-261
296
416
251
283
718
1208
1294
982
656
498
293
-107
-460
-490
-368
-473
-791
-886
-572
-229
-223
-286
128
979
1519
1171
209
-604
-812
-465
233
1043
1509
1140
65
-804
-635
353
1119
1016
472
263
432
309
-457
-1305
-1384
-558
462
915
662
85
-415
-654
-520
55
925
1661
1825
1379
728
375
509
916
1242
1303
1207
1175
1269
1306
1053
522
18
-135
110
542
919
1157
1289
1342
1273
1004
488
-179
-683
-642
-33
612
660
114
-265
186
1202
1815
1474
642
175
334
668
729
554
366
198
11
-35
223
567
509
-40
-560
-524
-49
291
175
-240
-735
-1273
-1744
-1769
-1120
-214
197
-121
-662
-875
-826
-900
-1073
-900
-262
288
120
-697
-1509
-1844
-1787
-1547
-1045
-169
752
1099
654
-56
-299
133
806
1187
1124
818
498
259
94
-60
-298
-625
-860
-768
-353
47
105
-101
-142
297
1058
1675
1853
1698
1545
1619
1863
2015
1824
1287
708
449
554
666
447
50
13
627
1480
1808
1263
245
-530
-695
-400
13
399
805
1262
1629
1664
1266
635
189
229
633
913
641
-141
-932
-1176
-697
186
898
1023
626
199
245
805
1421
1589
1230
695
417
632
1336
2287
2970
2791
1576
-91
-1222
-1227
-392
483
791
442
-305
-1074
-1444
-1083
-87
923
1256
835
300
298
731
873
280
-605
-906
-352
354
347
-350
-829
-420
422
593
-300
-1369
-1358
-54
1450
1883
1001
-353
-1216
-1281
-820
-148
563
1038
845
-154
-1375
-1818
-1012
444
1438
1422
849
522
745
1208
1519
1573
1420
1057
537
133
155
636
1289
1781
1957
1859
1663
1588
1683
1655
1119
125
-709
-837
-435
-187
-426
-783
-743
-327
5
-42
-318
-444
-144
569
1327
1561
1048
280
-48
-29
-535
-1892
-2970
-2307
-90
1712
1531
-34
-1164
-1100
-695
-793
-947
-269
1099
2082
2079
1538
1041
485
-417
-1265
-1243
-216
950
1335
913
363
177
248
224
-19
-341
-507
-327
269
1151
1990
2437
2331
1708
741
-259
-862
-738
19
867
1220
913
241
-370
-697
-745
-629
-483
-389
-332
-227
-71
-17
-181
-414
-433
-193
36
78
128
402
603
166
-867
-1569
-1071
352
1551
1798
1435
1133
979
694
422
700
1568
2231
1942
920
78
-47
290
623
850
1150
1533
1744
1522
841
11
-440
-169
536
893
475
-164
-53
1029
2222
2528
1805
699
-103
-310
23
562
761
310
-414
-703
-390
-45
-111
-237
115
731
844
218
-530
-831
-840
-936
-1002
-696
-167
69
-70
-119
168
417
270
-4
75
510
925
1205
1501
1693
1407
706
227
361
717
771
694
975
1478
1529
997
594
812
1117
732
-124
-440
217
1140
1384
777
-192
-1048
-1493
-1310
-579
62
-72
-869
-1411
-1037
-91
557
521
166
56
414
1056
1558
1539
1041
630
827
1341
1260
208
-949
-991
204
1434
1525
563
-372
-459
158
748
767
262
-271
-309
236
859
872
113
-765
-903
-128
823
1023
224
-956
-1631
-1359
-387
649
1219
1174
703
129
-245
-236
118
476
446
-5
-435
-404
-17
186
-81
-505
-537
-71
487
667
369
-148
-504
-492
-209
-17
-168
-488
-461
193
1160
1706
1279
-37
-1451
-1899
-882
903
1995
1575
372
-93
735
1948
2276
1525
420
-271
-379
73
879
1634
1652
835
-281
-819
-639
-20
495
855
887
740
387
243
198
395
515
994
1413
2050
1412
The output was fed directly into the current shunt resulting in an expected ~200mA peak from a 10Vpp amplitude setting due to internal 50Ω source impedance.
To verify it was working, I measured the signal across the shunt with the Rohde & Schwarz RTM3004 oscilloscope – it’s there, clear as day!
The 1A range was used to optimise the number of bits used to digitise the signal. The noise level was optimised by using the 1MSa/s mode with a 128-sample average digital filter for a resulting 7812.5Hz sample rate. A simplified version of the previously presented Python code was used to log results as an ASCII number ranging from -4096 to +4095.
The log imported as a 16-bit ASCII value text file into GoldWave to create an audio file and the normalised to fill the full amplitude. The original audio and the recording from the CSA are attached to this post – surprisingly aside from a low-level of background noise, the voice is clearly intelligible and the speed is just about right too when setting 7800Hz sample rate!
Original Spectra
Play this audio clip
CSA Recording Spectra
This demonstrates that the CSA is quiet and fast – very capable of digitising voice-grade audio from a current waveform.
Experimenting with Current Sense Amplifiers – Key Learnings
Throughout this journey, I had the chance to learn about the MAX40080 Precision, Fast Sample-Rate, Digital Current Sense Amplifier. Below, I summarise some of the key learnings made throughout this journey:
  • The datasheet provided is quite dense and key facts are often easily overlooked while writing driver code to use the IC. The information is often present or easily derived through experimentation, as examples online are relatively limited – Mikroe offers code only for their platforms.
  • The MAX40080 interoperates on an I2C bus but is also SMBus capable, thus expects packet error check (PEC) byte transmissions – this needs to be explicitly disabled otherwise writes will be NAK’d. Disabling PEC reduces bus traffic which can improve performance, but at the risk of silent data corruption.
  • The CSA supports sample rates as high as 1MSa/s but the bus limitations mean that high sample rates are mostly useful for producing cleaner values through averaging (digital filter).
  • Bus rates up to and including 3.4MHz High Speed (HS) mode are supported, however, this is a speed that is rarely seen in most microcontrollers as it is a current-mode bus. The implementation in the Mikroe Current 6 Click features a level translator which itself is limited to 1MHz (Fast Mode +) operation. Achievable bus rate depends on the driving strength of the microcontroller and signal integrity of the connection.
  • The datasheet implies sample rates up to 18.75kSa/s for a 1MHz bus or 60kSa/s for a 3.4MHz bus, however, the real sample rate achievable will be limited by the processing speed of the host as it usually cannot turn-around transactions continuously. Implementations using FPGAs may be more suited to extracting the maximum performance from the CSA.
  • In continuous sampling mode, the FIFO status register will indicate zero data and overflow flag in case of an overflow, thus checking both the data count and overflow flag is necessary. However, an alternative is to “hammer” the FIFO data register instead and check for bit-15 (data valid) being set, accepting any reading that has this bit set. This will only work as long as you can poll the FIFO data register faster than the sample rate (as it will not alert you to an overflow condition).
  • The CSA is capable of being used as a measurement device to perform current profiling of loads, offering 12-bits + sign resolution, practical sample rate of 7.8kSa/s achieved, high-side and low-side sensing compatibility at a voltage up to 36V, and two range capability (1A, 5A in the case of the Current 6 Click). A change of shunt resistor can enable different current ranges.
  • Its architecture appears especially suitable for over-current protection roles, where the unit can flag an interrupt when such a threshold condition is crossed with its 64-cell FIFO providing a small amount of data recording and low-power modes suited for battery operation. It is also capable of low-sample-rate operations and single-measurement modes.
  • While it could be possible to use this to profile a battery charge or discharge scenario given its bidirectional current sensing, it seems much more sensible to use a dedicated colomb-counter/gas-gauge chip to do this rather than burden the host with a CSA like this.
  • While the datasheet sports rather optimistic accuracy figures of 0.2% gain error and 5µV offset, the maximum error values are perhaps less exciting. Furthermore, the user must not neglect the impact of the shunt resistor tolerance and thermal coefficient effects on the solution accuracy – in testing, gain errors ranged from 0.11 to 1.15% and offsets from 0.4-3.7mA in current, and 36.3mV in voltage.
  • The CSA is available in two footprints – one 1.7mm x 1.3mm WLP which uses BGA technology and might be more difficult for prototyping, and one 3mm x 3mm TDFN, both of which are exceptionally small in size.
  • The Mikroe Current 6 Click has an enable line which needs to be bought high to allow the chip to operate. This is connected to GPIO8 on the first socket of the Pi 3 Click Shield.
  • All floating connections may be a curse – don’t assume it is safe by default as it caused periodic measurement dips in my case which may be due to equalisation discharges when the accumulated charge reached a critical threshold.
  • If all you require is current measurement, the connection of the V+ and GND lines on the Click may not be necessary at all. The converse also seems to be true in case you require voltage measurement only.
  • In my application, the ~7.8kHz sampling rate provided a key boost in visibility of current consumption behaviour compared to traditional power supply logging which achieves about ~10Hz. This is quite valuable in some cases as it can identify periods of radio transmissions and changes in operating modes, although it is perhaps not ideal for sleep-current measurement given the limited granularity (4095-steps, 1A range).
  • Professional solutions, such as the Rohde & Schwarz FastLog 500kHz mode available in their NGM/NGU series power supplies/SMUs take this further and provide even more detail and are easier to use. However, given the price, I feel having this CSA could certainly help give some SMU-like capabilities to a basic lab power supply.
  • The solution is quiet enough that even a ~200mA peak audio signal being driven into the CSA could readily be resolved back into audio with a fairly low noise floor.
  • Given that it performs so well in applications requiring relatively high sample rates, it is expected that the CSA would perform equally well at lower sample-rate requirements. The 500Sa/s mode, for example, does permit operation on even 100kHz I2C buses.
  • It should be noted that the “Voltage and Current” operating mode can only operate in the 500Sa/s or individual reading mode due to switching speed, but it does not take simultaneous voltage and current readings, instead taking ten current readings, followed by one voltage reading, thus voltage readings are “repeated” ten times to form the paired values. Because of this limitation, the most valuable mode would be continuous sampling of current only for higher sample rates with a high averaging filter to reduce noise.
Conclusion
The MAX40080 on the Current 6 Click proved to be quite a useful tool when it comes to upgrading the current measurement capability of a basic power supply. While it doesn’t quite measure-up to a full digitising power supply/source-measurement unit in both sample rate and low-current resolution as configured, it is quite inexpensive and the ~7.8kHz achieved sample rate is quite revealing with regards to the operational status of the blood pressure monitor tested, compared to the default 6-10Hz sample rate achievable from the metering built-in to such power supplies.
The quietness, linearity and speed were again tested by recording audio from a current waveform fed from a signal generator. The background noise floor was a minor hiss, with the audio easily and clearly intelligible. That was not my expectation given the “difficulty” in ensuring the unit could maintain its sample rate given the limitations in performance of both Python and the Raspberry Pi running Linux - a full multitasking OS.
While these experiments demonstrated the higher-sample-rate capabilities of the unit, lower sample rates are also possible with trivial changes to the code. However, I would suspect that most users will be interested in the higher sample rates, where a consideration of the limitations of the I2C bus clock speed and data processing time need to be taken into account.
In the end, I also gave C a quick try with misaz's library but didn't find any sample rate performance advantage on my Raspberry Pi 3 B hardware, so perhaps an FPGA that supports HS mode with a direct 1.8V level connection free of level shifters would be the ideal configuration for this IC. Had they equipped it with SPI, that may have made utilisation of the high sample rates more realistic.
Throughout this journey, I have learned a lot about the implementation and use of the Analog Devices (formerly Maxim) MAX40080 and the Mikroe Current 6 Click, which I have summarised in a series of key points. Perhaps the most unexpected one was the need to ground the Raspberry Pi – without it, my measurements were all over the place!
Thanks to element14, Analog Devices (the new home of Maxim Integrated) and Mikroe for selecting me as one of the sponsored challengers in the Experimenting with Current Sense Amplifiers Design Challenge and giving me the opportunity to investigate and demonstrate the Current 6 Click implementation.
This is part of the Experimenting with Current Sense Amplifiers Design Challenge – A Current-Sensing PSU Upgrade Blog Series:
  • Blog #1: A Current-Sensing PSU Upgrade - Introduction
  • Blog #2: A Current-Sensing PSU Upgrade - Unboxing
  • Blog #3: A Current-Sensing PSU Upgrade – Setting Up
  • Blog #4: A Current-Sensing PSU Upgrade – Accuracy & Noise Performance
  • Blog #5: A Current-Sensing PSU Upgrade – Arduino Gets Involved, Ground to Raspberry Pi … Alien Signal Identified!
  • Blog #6: A Current-Sensing PSU Upgrade – PSU Logging, CSA & FastLog Comparison, a Sound Check & an Overall Summary
  • misaz
    misaz over 4 years ago
    I tried using sensor at higher speed than 400 kHz but at 1 MHz I started receiving bit and CRC errors frequently, so I have done all my experiments at 100 kHz or 400 kHz speeds. I do not have oscilloscope so I cant investigate how does the level shifter affect signal integrity, but I think 3.4 MHz are possible only with direct connection. Second issue is that it is very hard to find I2C driver supporting this speed. I checked datasheets of all my MCUs and all supports max speed of 1 MHz. I considering trying some overclocking of MCU which do officialy do not support this, but when I have seen many errors at 1 MHz, I decided to spend time with something less complicated and more usefull. I have prepared support for changing speed in my C library but it requires platform specific implementation and lot of testing, so I have not commited it publicly yet.
  • Gough Lui
    Gough Lui over 4 years ago in reply to misaz
    The level shifter used is only suitable for 1MHz operation as the HS mode is completely different in terms of bus topology as a current mode bus.
    In my particular setup, 1MHz seemed stable - although I did not use PEC, I noted that bit errors usually cause 0 bits to turn to 1 bits which would show up as reading noise. I did not see a change of result with lowering bus speed when using a common sampling rate supported by both (500Sa/s). In fact, I could reach 1.025MHz with it seeming to still function, and had sporadic burst errors at 1.05MHz when overclocking the I2C bus.
    In the end, operation at such speeds is highly dependent on the signal integrity features of your design and the drive strength of your devices and how they compare with the selected pull-up resistors and bus capacitance. I could only achieve 900kHz with the Arduino MKR WiFi 1010 using a short jumper wire, for example.
    To make things a bit better, I did entertain the thought of changing the pull-up resistances to smaller values as that is usually recommended. However, seeing the signal on the oscilloscope had me confident this was not required as the edges were nice and not "slow" to rise which would be helped by reducing the pull-up resistance values.
    My project really centered on the "high sample rate" aspect of the CSA, hence the obsession with speed. In the end, the I2C bus only goes so fast ...
    - Gough
  • Gough Lui
    - Gough
