Experimenting with Sensor Fusion
  • Experimenting with Sensor Fusion
Blog Sensor Fusion for Firefighters. Thermal Vision, Compass and Environmental HUD monitor with the Spartan-7
Join Experimenting with Sensor Fusion to participate - click to join for free!
  • Author Author: javagoza
  • Date Created: 3 Jan 2023 7:53 PM Date Created
  • Views 21305 views
  • Likes 9 likes
  • heads up display
  • thermal imaging
  • air quality sensor
  • humidity sensor
  • Environmental Monitor
  • experimenting with sensor fusion
  • video mixer
  • AMD XILINX
  • sp701
  • hdmi
  • xilinx
  • fpga
  • vivado
  • digilent
  • temperature sensor
  • pcam 5c
  • spartan-7
  • vitis hls
  • sensor fusion
javagoza
javagoza
3 Jan 2023
sensor fusion for firefighters thermal vision compass and environmental hud monitor with the spartan 7
By incorporating a low resolution thermal imaging overlay using the MLX90640 thermal array, we have already integrated all the sensors planned into the system.
Thermal vision, compass and environmental hud on the Spartan-7 FPGA
Table of Contents
  • Project Update
  • Fusion of Sensors
  • Viewing in the dark
  • FPGA. You got the power.
  • Video Mixer Configuration
  • MLX90640 I2C Communication
  • Incrementing MicroBlaze soft processor clock frequency
  • Enabling  Basic Floating Point Unit
  • Constraints file
  • Resources utilization after implementation
  • Block Design
  • MLX90640 I2C Driver
  • MicroBlaze Bare Metal App
  • Github repository
  • Next steps
  • The Complete "Sensor Fusion for Firefighters" Blog Series
  • Sensor Fusion for Firefighters. Introductory blog
  • Sensor Fusion for Firefighters. Getting Started with the AMD Xilinx SP701
  • Sensor Fusion for Firefighters. AMD Xilinx SP701 - MIPI Video Pipe Camera to HDMI Display
  • Sensor Fusion for Firefighters. Displaying heads-up video on the live feed
  • Sensor Fusion for Firefighters. Environmental monitor heads-up display on Xilinx Spartan-7 SP701 development board
  • Sensor Fusion for Firefighters. Compass and Environmental HUD monitor with the Spartan-7
  • Sensor Fusion for Firefighters. Thermal Vision, Compass and Environmental HUD monitor with the Spartan-7
  • Sensor Fusion for Firefighters. Summary Blog
Project Update
We are building our Sensor Fusion system in phases, we started by capturing the video image with the PCAM 5C camera and displaying it in real time on an HDMI display.
Later we added an overlay built in hardware with Vitis HLS that allowed us to display up to 16 digits of 7 segments scalable in width and height over the actual video image.
We then added environmental information from various sensors, a humidity and temperature sensor, and an air quality sensor. To display the environmental information we used the previously created virtual seven-segment display overlay.
We also wanted to provide orientation within the display so we created a compass overlay fed by a magnetometer sensor. To decrease the amount of resources needed for this overlay, it was merged with the virtual seven-segment display and also created with Vitis High Level Synthesis (HLS).
Fusion of Sensors
Our system already has a Pcam 5C, 5 MP Fixed-Focus Color Camera Module, an HDMI display, a Pmod NAV module, 9-axis IMU Plus Barometer, a Pmod HYGRO module, Digital Humidity and Temperature Sensor, a Pmod CMPS2 module, 3-Axis Compass, a SparkFun Environmental Combo Breakout module - CCS811 equivalent CO2 and total volatile organic compounds and BME280, humidity, temperature, and barometric pressure. And now also a SparkFun IR Array Breakout - 110 Degree FOV, MLX90640, 32x24 array of thermopile sensors, a low resolution thermal imaging camera.
Capturing the HDMI output with an HDMI Video Capture USB dongle. In the center of the screen, below the linear compass indicator, the low resolution thermal image captured by the thermal array sensor sensor is converted to a gray level image and overlayed.
Display of real-time thermal images overlaid on the video feed stream.
Thermal Vision HUD
Viewing in the dark
Thanks to the thermal array sensor we can have a low resolution thermal image that allows us to "see" in the dark or in adverse light situations.
A few months ago we participated in another design challenge about migrating from the Spartan-6 FPGA to the Spartan-7 FPGA. Our partition ended with building a low resolution thermal imager using the MLX90640 thermal array sensor, a VGA display and the Arty S-50 development board. See :
In that project we managed to get to a frame rate of 0.25 frames per second, which left us somewhat unsatisfied.
In that post I wrote that the project could be greatly optimized, that there was a lot of work assigned to the MicroBlaze software processor, such as image scaling or sensor data retrieval. On that occasion the images were 800*600 pixels (480,000 pixels) per frame. Now we are faced with a much bigger problem: the images on the screen are 1920 x 1080 pixels (2,073,600 pixels) per frame. A scheme like the one used on that occasion is unfeasible.
This time we knew the problem, we have learned a lot in these last few months so we decided to take a new look at that project and redo it from scratch, with the addition of a much higher screen resolution and running on parallel to the visualization of video in real time.
Optimizations we have implemented:
  • Increased MicroBlaze clock speed.
  • Use of the Video Mixer IP Hardware Video Scaler.
  • Increased MLX90640 refresh rate to 400 kHz
  • Dismissed MLX90640 sensor resolution.
  • Avoid interpolation and floating point arithmetic for temperature processing and scaling
  • Use of MLX90640 thermal array raw sensor data.
  • Use of MicroBlaze basic floating point unit enabled for compass math functions.
  • Rewrite the MLX90640 sensor access driver to take advantage of MicroBlaze interrupts.
After all these optimizations we have managed to have an image of 128 x 96 pixels (12,288 pixels) in gray scale with a frame rate of approximately 6 frames per second (fps).
We are using the Video Mixer IP to superimpose the different layers of the final image. We will add a new layer for the thermal image. From Vivado Block Design we reconfigure the Video Mixer IP adding a new layer with Memory interface.
The thermal image is drawn on screen overlayed using Video Mixer IP. We enable the scaling of the layer that will allow us to display the 32x24 pixel image that the sensor has in a 128X96 pixel image, which means a 4x scaling, the maximum that Video Mixer IP allows us.
The video format used is RGBX8. We have to take this into account when forming the image on DDR memory. This format uses 32-bit pixels, but only dedicates 24 to color depth. 8 bits are discarded but they must be taken into account to size the strides.
The MLX90640 sensor only has I2C communication and needs to be the only slave on the I2C bus. Vivado makes it easy for us. Again from the Vivado Block Designer we add an I2C IP Block and connect it to the AXI interconnect to be accessible from the MicroBlaze and connect the interrupt pin as well.
Initially for debugging we had to set the SCL clock frequency to 100 kHz as we didn't have the means to debug at 400 kHz. Once the communications were debugged we were able to adjust the frequency to 400 kHz without further changes.
SCL clock frequency to 400 kHz. Interrupt driven.
In an attempt to improve the response of our system we increased the frequency of the MicroBlaze soft processor from the 75 MHz that we have been using until now up to 100 MHz. This is the frequency that we have seen recommended by Xilinx employees in the forums for the Spartan- 7FPGAs.
To improve some of the operations performed with the information from the sensors we enabled the basic floating point unit of the MicroBlaze soft processor. The MicroBlaze's resource usage increased but we didn't see any substantial performance improvements either, among other things because we've tried as far as possible to avoid floating point calculations.
Constraints file
We are going to connect the IR Array MLX90640 sensor to two pins of the PMOD5 port of the SP701 board. We add the configuration to the constraints file.
Resource utilization has increased by enabling the basic floating point unit of the MicroBlaze soft processor.
Block Design
Here you can download the complete block design of the final solution:
MLX90640 I2C Driver
We start from the driver supplied by Melexis, https://github.com/melexis/mlx90640-library. Fortunately we only have to change the access to the I2C bus.
We make use of the interrupts enabled by the I2C driver of the I2C IP block.
Initially we used the function provided by the Melexis API driver to get a thermal image, but it is very time-consuming for the Microblaze and good performance is not possible. Just getting the data for the eeproom calibration takes two minutes and fifteen seconds. So we decided to work on the raw data to get an uncalibrated grayscale thermal image.
The bare metal application remains very simple. To the previous application we have only added the new driver for the Mexis MLX90640 thermal array sensor, the configuration of the new overlay layer of the video mixer and the generation of the thermal image in DDR memory with the data read from the sensor by I2C communication.
#include <stdio.h>
#include "platform.h"
#include "xil_printf.h"
#include "xparameters.h"
#include "xiic.h"
#include "xil_exception.h"
#include "function_prototype.h"
#include "pcam_5C_cfgs.h"
#include "xstatus.h"
#include "sleep.h"
#include "xiic_l.h"
#include "xil_io.h"
#include "xil_types.h"
#include "xv_tpg.h"
#include "xil_cache.h"
#include "stdio.h"
#include "xv_mix_l2.h"
#include "xvidc.h"
#include "xff_monitor_gen.h"
#include "PmodHYGRO.h"
#include "PmodAQS.h"
#include "math.h"
#include "PmodCMPS2.h"
#include "mlx90640_api.h"
#define DDR_BASEADDR XPAR_MIG7SERIES_0_BASEADDR
#define DISPLAY_WIDTH 1920
#define DISPLAY_HEIGHT 1080
/* Memory Layers for Mixer */
#define XVMIX_LAYER2_BASEADDR      (0x84000000U)
#define XVMIX_LAYER_ADDR_OFFSET    (0x01000000U)
#define THERMAL_WIDTH 32
#define THERMAL_HEIGHT 24
// compass labels
#define YCMPSLABEL 730
#define CMPSLABEL_MARGINY 10
// compass scale
#define YCMPS1 770
#define CMPS_MARGINY 8
long map(long x, long in_min, long in_max, long out_min, long out_max);
void MLX90640_GetSensorRaw(uint16_t *frameData, int *result, int *minT, int *maxT);
int initMlx90640(void);
int loopMlx90640Gray(u8* mlx90640Image);
void initHeadsUpDisplay(XFf_monitor_gen* xv_ff_monitor);
uint16_t mlx90640Frame[834];
u8 mlx90640Image[768*4];
// Calibration data struct, track minimum, maximum, and average sample seen for
// each x/y/z channel
typedef struct {
	CMPS2_DataPacket max, min, mid;
} CMPS2_CalibrationData;
PmodCMPS2 cmps2;
CMPS2_CalibrationData myCalibrationData;
void CMPS2Initialize();
void CMPS2ClearCalibration(CMPS2_CalibrationData *calib);
void CMPS2Calibrate(PmodCMPS2 *InstancePtr, CMPS2_CalibrationData *calib,
		CMPS2_DataPacket data);
float CMPS2ConvertDegree(PmodCMPS2 *InstancePtr, CMPS2_CalibrationData calib,
		CMPS2_DataPacket data, int declination);
const int myDeclination = 1; // Magnetic declination for Zaragoza, Spain
const u8 chip_address = 0x30; // Pmod CMPS2 I2C chip address
/*************************** Global Variables ******************************/
#define U32TOBCD(u) ((((u/10000000)%10)<<28)| (((u/1000000)%10)<<24)|\
		(((u/100000)%10)<<20)  | (((u/10000)%10)<<16)|\
		(((u/1000)%10)<<12)    | (((u/100)%10)<<8)|\
		(((u/10)%10)<<4)|(u%10))
#define U16TOBCD(u) ((((u/1000)%10)<<12) | (((u/100)%10)<<8)|\
#define U8TOBCD(u) ((((u/10)%10)<<4)|(u%10))
#ifdef __MICROBLAZE__
#define TIMER_FREQ_HZ XPAR_CPU_M_AXI_DP_FREQ_HZ
#else
#define TIMER_FREQ_HZ 100000000
#endif
/************************** Constant Definitions *****************************/
#define PAGE_SIZE   16
#define IIC_BASE_ADDRESS	XPAR_IIC_2_BASEADDR
#define EEPROM_TEST_START_ADDRESS	0x80
#define IIC_SWITCH_ADDRESS 0x74
#define IIC_ADV7511_ADDRESS 0x39
typedef u8 AddressType;
typedef struct {
	u8 addr;
	u8 data;
	u8 init;
} HDMI_REG;
#define NUMBER_OF_HDMI_REGS  16
HDMI_REG hdmi_iic[NUMBER_OF_HDMI_REGS] = {
		{0x41, 0x00, 0x10},
		{0x98, 0x00, 0x03},
		{0x9A, 0x00, 0xE0},
		{0x9C, 0x00, 0x30},
		{0x9D, 0x00, 0x61},
		{0xA2, 0x00, 0xA4},
		{0xA3, 0x00, 0xA4},
		{0xE0, 0x00, 0xD0},
		{0xF9, 0x00, 0x00},
		{0x18, 0x00, 0xE7},
		{0x55, 0x00, 0x00},
		{0x56, 0x00, 0x28},
		{0xD6, 0x00, 0xC0},
		{0xAF, 0x00, 0x4},
		{0xF9, 0x00, 0x00}
u8 EepromIicAddr;		/* Variable for storing Eeprom IIC address */
int IicLowLevelDynEeprom();
u8 EepromReadByte(AddressType Address, u8 *BufferPtr, u8 ByteCount);
u8 EepromWriteByte(AddressType Address, u8 *BufferPtr, u8 ByteCount);
int initVideoSystem(void);
void initVideoMixer(XV_mix* xv_mix);
int startVideoSystem(void);
void initCompassMagnetometer(void);
void initPmodHygro(void);
void initPmodAQS(void);
void startVideoMixer(void);
/****************i************ Type Definitions *******************************/
/************************** Variable Definitions *****************************/
extern XIic IicFmc, IicAdapter, IicMlx ;	/*  IIC device. */
PmodHYGRO hygro;
PmodAQS aqs;
XV_mix xv_mix;
XFf_monitor_gen xv_ff_monitor;
 * Main function to initialize interop system and read data from AR0330 sensor
 * @param  None.
 * @return
 *   - XST_SUCCESS if MIPI Interop was successful.
 *   - XST_FAILURE if MIPI Interop failed.
 * @note   None.
int main() {
	int Status;
	float temp_degc, hum_perrh;
	CMPS2_DataPacket data;
	int hum = 0;
	int temp = 0;
	u8 buf[5];
	int eCO2 = 0;
	int counter = 0;
	float magXYd = 0;
	float n = 4.0; // average last 4 measurements
	// Video pipeline configuration
    Status = initVideoSystem();
	initVideoMixer(&xv_mix);
	initHeadsUpDisplay(&xv_ff_monitor);
	resetIp();
	EnableCSI();
	Status = startVideoSystem();
	// xil_printf("\n\rPipeline Configuration Completed \n\r");
    initCompassMagnetometer();
    initPmodHygro();
    initPmodAQS();
    // init display data to show e14 e14
	XFf_monitor_gen_Set_angle(&xv_ff_monitor,0) ;
	XFf_monitor_gen_Set_envData(&xv_ff_monitor,  0xFB14FB14);
    startVideoMixer();
    // Get initial Magnetometer data
	data = CMPS2_GetData(&cmps2);
	// start average with actual orientation
	float avgx = data.x;
	float avgy = data.y;
    // Start MLX90640 IIC communication
	Status = initMlx90640();
	if (Status != XST_SUCCESS) {
		xil_printf("MLX90640 IIC programming FAILED\r\n");
		return XST_FAILURE;
	xil_printf("MLX90640 IIC programming PASSED\r\n");
	while(1) {
        // get grayscale image from thermal array sensor
		loopMlx90640Gray((u8*)XVMIX_LAYER2_BASEADDR);
		// read magnetometer data
		// moving average for x magnetic component
		avgx = avgx - avgx/n;
		avgx = avgx + data.x/n;
		avgy = avgy - avgy/n;
		avgy = avgy + data.y/n;
		data.x = (u16)avgx;
		data.y = (u16)avgy;
		// recalibrate compass
		CMPS2Calibrate(&cmps2, &myCalibrationData, data);
		// get compass degrees
		magXYd = CMPS2ConvertDegree(&cmps2, myCalibrationData, data,
				myDeclination);
		// display compass with new data
		XFf_monitor_gen_Set_angle(&xv_ff_monitor, (int)(magXYd * 4)) ;
		if(counter% 100 == 0){
			// read temperature & humidity values
			temp_degc = HYGRO_getTemperature(&hygro);
			temp = (int) temp_degc;
			hum_perrh = HYGRO_getHumidity(&hygro);
			hum = (int) hum_perrh;
			AQS_GetData(&aqs, buf);
			eCO2 = (((int)buf[0]) << 8) | ((int)buf[1]);
			// display new temp and humidity values
			XFf_monitor_gen_Set_envData(&xv_ff_monitor, (U16TOBCD(eCO2)<<16) | (U8TOBCD(temp)<<8) | U8TOBCD(hum));
		++counter;
	return XST_SUCCESS;
void initHeadsUpDisplay(XFf_monitor_gen* xv_ff_monitor) {
	// Ff monitor
	XFf_monitor_gen_Config* XV_Ff_monitor_cfg;
	XV_Ff_monitor_cfg = XFf_monitor_gen_LookupConfig(
			XPAR_FF_MONITOR_GEN_1_DEVICE_ID);
	XFf_monitor_gen_CfgInitialize(xv_ff_monitor, XV_Ff_monitor_cfg);
	XFf_monitor_gen_Set_row(xv_ff_monitor, (u32) DISPLAY_HEIGHT);
	XFf_monitor_gen_Set_column(xv_ff_monitor, (u32) DISPLAY_WIDTH);
	XFf_monitor_gen_EnableAutoRestart(xv_ff_monitor);
	XFf_monitor_gen_Start(xv_ff_monitor);
	XFf_monitor_gen_Set_envData(xv_ff_monitor, 0x12345678);
	XFf_monitor_gen_Set_angle(xv_ff_monitor, 10);
void startVideoMixer(void) {
	XV_mix_Set_HwReg_layerEnable(&xv_mix,(u32)0b111);
	/* Disable Interrupts */
	XV_mix_InterruptDisable(&xv_mix, XVMIX_IRQ_DONE_MASK);
	XV_mix_InterruptGlobalDisable(&xv_mix);
	/* Set autostart bit */
	XV_mix_EnableAutoRestart(&xv_mix);
	XV_mix_Start(&xv_mix);
void initPmodAQS(void) {
	xil_printf("\n\rAQS Init Started");
	AQS_begin(&aqs, XPAR_PMODAQS_0_AXI_LITE_IIC_BASEADDR, 0x5B); // Chip address of CS811 0x5A module IIC 0x5B PmocAQS
	xil_printf("\n\rAQS Init Done");
void initPmodHygro(void) {
	xil_printf("\n\rHYGRO Init Started");
	HYGRO_begin(
			&hygro,
			XPAR_PMODHYGRO_0_AXI_LITE_IIC_BASEADDR,
			0x40, // Chip address of PmodHYGRO IIC
			XPAR_PMODHYGRO_0_AXI_LITE_TMR_BASEADDR,
			XPAR_PMODHYGRO_0_DEVICE_ID,
			TIMER_FREQ_HZ // Clock frequency of AXI bus, used to convert timer data
	xil_printf("\n\rHYGRO Init Done");
void initCompassMagnetometer(void) {
	xil_printf("\n\rCMPS2 Init Started");
	CMPS2Initialize();
	CMPS2ClearCalibration(&myCalibrationData);
	xil_printf("\n\rCMPS2 Init done");
// Init Video System
int initVideoSystem(void) {
	int Status;
	Status = IicLowLevelDynEeprom();
		xil_printf("ADV7511 IIC programming FAILED\r\n");
		return XST_FAILURE;
	xil_printf("ADV7511 IIC programming PASSED\r\n");
	//Initialize FMC, Adapter and Sensor IIC
	Status = InitIIC();
		xil_printf("\n\r IIC initialization Failed \n\r");
		return XST_FAILURE;
	xil_printf("IIC Initializtion Done \n\r");
	//Initialize FMC Interrupt System
	Status = SetupFmcInterruptSystem(&IicFmc);
		xil_printf("\n\rInterrupt System Initialization Failed \n\r");
		return XST_FAILURE;
	xil_printf("FMC Interrupt System Initialization Done \n\r");
	//Set up IIC Interrupt Handlers
	SetupIICIntrHandlers();
	xil_printf("IIC Interrupt Handlers Setup Done \n\r");
	Status =  SetFmcIICAddress();
		xil_printf("\n\rFMC IIC Address Setup Failed \n\r");
		return XST_FAILURE;
	xil_printf("Fmc IIC Address Set\n\r");
	//Initialize Adapter Interrupt System
	Status = SetupAdapterInterruptSystem(&IicAdapter);
		return XST_FAILURE;
	xil_printf("Adapter Interrupt System Initialization Done \n\r");
	//Set Address of Adapter IIC
	Status =  SetAdapterIICAddress();
		xil_printf("\n\rAdapter IIC Address Setup Failed \n\r");
		return XST_FAILURE;
	xil_printf("Adapter IIC Address Set\n\r");
	Status = InitializeCsiRxSs();
		xil_printf("CSI Rx Ss Init failed status = %x.\r\n", Status);
		return XST_FAILURE;
	return XST_SUCCESS;
int startVideoSystem(void) {
	int Status;
	int pcam5c_mode = 1;
	Status = demosaic();
		xil_printf("\n\rDemosaic Failed \n\r");
		return XST_FAILURE;
	CamReset();
	//Configure Sensor
	Status = SensorPreConfig(pcam5c_mode);
		xil_printf("\n\rSensor PreConfiguration Failed \n\r");
		return XST_FAILURE;
	xil_printf("\n\rSensor is PreConfigured\n\r");
	Status = vdma_hdmi();
		xil_printf("\n\rVdma_hdmi Failed \n\r");
		return XST_FAILURE;
	Status = vtpg_hdmi();
		xil_printf("\n\rVtpg Failed \n\r");
		return XST_FAILURE;
	WritetoReg(0x30, 0x08, 0x02);
	Sensor_Delay();
	return XST_SUCCESS;
void initVideoMixer(XV_mix* xv_mix) {
	XV_mix_Config* xv_config;
	xv_config = XV_mix_LookupConfig(XPAR_XV_MIX_0_DEVICE_ID);
	XV_mix_CfgInitialize(xv_mix, xv_config, xv_config->BaseAddress);
	XV_mix_Set_HwReg_width(xv_mix, (u32) DISPLAY_WIDTH);
	XV_mix_Set_HwReg_height(xv_mix, (u32) DISPLAY_HEIGHT);
	XV_mix_Set_HwReg_layerEnable(xv_mix, (u32) 0b000);
	XV_mix_Set_HwReg_layerStartX_0(xv_mix, (u32) 0);
	XV_mix_Set_HwReg_layerStartY_0(xv_mix, 0);
	XV_mix_Set_HwReg_layerWidth_0(xv_mix, (u32) DISPLAY_WIDTH);
	XV_mix_Set_HwReg_layerHeight_0(xv_mix, (u32) DISPLAY_HEIGHT);
	XV_mix_Set_HwReg_layerAlpha_0(xv_mix, 255);
	XV_mix_Set_HwReg_layerStartX_1(xv_mix, (u32) 0);
	XV_mix_Set_HwReg_layerStartY_1(xv_mix, 0);
	XV_mix_Set_HwReg_layerWidth_1(xv_mix, (u32) DISPLAY_WIDTH);
	XV_mix_Set_HwReg_layerHeight_1(xv_mix, (u32) DISPLAY_HEIGHT);
	XV_mix_Set_HwReg_layerAlpha_1(xv_mix, 255);
	XV_mix_Set_HwReg_layerStartX_2(xv_mix, (u32) DISPLAY_WIDTH / 2 - 16 * 4);
	XV_mix_Set_HwReg_layerStartY_2(xv_mix, YCMPS1 + 16);
	XV_mix_Set_HwReg_layerWidth_2(xv_mix, (u32) THERMAL_WIDTH);
	XV_mix_Set_HwReg_layerHeight_2(xv_mix, (u32) THERMAL_HEIGHT);
	XV_mix_Set_HwReg_layerAlpha_2(xv_mix, 255);
	XV_mix_Set_HwReg_layerScaleFactor_2(xv_mix, XVMIX_SCALE_FACTOR_4X);
	XV_mix_Set_HwReg_layerStride_2(xv_mix, THERMAL_WIDTH * 4);
	XV_mix_Set_HwReg_layer2_buf1_V(xv_mix, (u32) (XVMIX_LAYER2_BASEADDR));
//HDMI IIC
	u8 BytesRead;
	u32 StatusReg;
	u8 Index;
	int Status;
	u32 i;
	EepromIicAddr = IIC_SWITCH_ADDRESS;
	Status = XIic_DynInit(IIC_BASE_ADDRESS);
		return XST_FAILURE;
	xil_printf("\r\nAfter XIic_DynInit\r\n");
	while (((StatusReg = XIic_ReadReg(IIC_BASE_ADDRESS,
			XIIC_SR_REG_OFFSET)) &
			(XIIC_SR_RX_FIFO_EMPTY_MASK |
					XIIC_SR_TX_FIFO_EMPTY_MASK |
					XIIC_SR_BUS_BUSY_MASK)) !=
									XIIC_SR_TX_FIFO_EMPTY_MASK)) {
	EepromIicAddr = IIC_ADV7511_ADDRESS;
	for ( Index = 0; Index < NUMBER_OF_HDMI_REGS; Index++)
		EepromWriteByte(hdmi_iic[Index].addr, &hdmi_iic[Index].init, 1);
		BytesRead = EepromReadByte(hdmi_iic[Index].addr, &hdmi_iic[Index].data, 1);
		for(i=0;i<1000;i++) {};	// IIC delay
		if (BytesRead != 1) {
			return XST_FAILURE;
	return XST_SUCCESS;
 * This function writes a buffer of bytes to the IIC serial EEPROM.
 * @param	BufferPtr contains the address of the data to write.
 * @param	ByteCount contains the number of bytes in the buffer to be
 *		written. Note that this should not exceed the page size of the
 *		EEPROM as noted by the constant PAGE_SIZE.
 * @return	The number of bytes written, a value less than that which was
 *		specified as an input indicates an error.
 * @note		one.
	u8 SentByteCount;
	u8 WriteBuffer[sizeof(Address) + PAGE_SIZE];
	u8 Index;
	 * A temporary write buffer must be used which contains both the address
	 * and the data to be written, put the address in first based upon the
	 * size of the address for the EEPROM
	if (sizeof(AddressType) == 2) {
		WriteBuffer[0] = (u8) (Address >> 8);
		WriteBuffer[1] = (u8) (Address);
	} else if (sizeof(AddressType) == 1) {
		WriteBuffer[0] = (u8) (Address);
		EepromIicAddr |= (EEPROM_TEST_START_ADDRESS >> 8) & 0x7;
	 * Put the data in the write buffer following the address.
	for (Index = 0; Index < ByteCount; Index++) {
		WriteBuffer[sizeof(Address) + Index] = BufferPtr[Index];
	 * Write a page of data at the specified address to the EEPROM.
	SentByteCount = XIic_DynSend(IIC_BASE_ADDRESS, EepromIicAddr,
			WriteBuffer, sizeof(Address) + ByteCount,
			XIIC_STOP);
	 * Return the number of bytes written to the EEPROM.
	return SentByteCount - sizeof(Address);
 * This function reads a number of bytes from the IIC serial EEPROM into a
 * specified buffer.
 * @param	BufferPtr contains the address of the data buffer to be filled.
 * @param	ByteCount contains the number of bytes in the buffer to be read.
 *		This value is constrained by the page size of the device such
 *		that up to 64K may be read in one call.
 * @return	The number of bytes read. A value less than the specified input
 *		value indicates an error.
 * @note		None.
	u8 ReceivedByteCount;
	u8 SentByteCount;
	u16 StatusReg;
	 * Position the Read pointer to specific location in the EEPROM.
	do {
		StatusReg = XIic_ReadReg(IIC_BASE_ADDRESS, XIIC_SR_REG_OFFSET);
		if (!(StatusReg & XIIC_SR_BUS_BUSY_MASK)) {
					(u8 *) &Address, sizeof(Address), XIIC_REPEATED_START);
	} while (SentByteCount != sizeof(Address));
	 * Receive the data.
	ReceivedByteCount = XIic_DynRecv(IIC_BASE_ADDRESS, EepromIicAddr,
			BufferPtr, ByteCount);
	 * Return the number of bytes received from the EEPROM.
	return ReceivedByteCount;
void CMPS2Initialize() {
	CMPS2_begin(&cmps2, XPAR_PMODCMPS2_0_AXI_LITE_IIC_BASEADDR, chip_address);
	usleep(10000);
	CMPS2_SetSensor(&cmps2);
	usleep(10000);
	CMPS2_SetOutputResolution(&cmps2, 0b00);
void CMPS2ClearCalibration(CMPS2_CalibrationData *calib) {
	calib->max.x = 0x8000; // Center point of 0x0000 -> 0xFFFF
	calib->max.y = 0x8000;
	calib->max.z = 0x8000;
	calib->min.x = 0x8000;
	calib->min.y = 0x8000;
	calib->min.z = 0x8000;
	calib->mid.x = 0x8000;
	calib->mid.y = 0x8000;
	calib->mid.z = 0x8000;
		CMPS2_DataPacket data) {
	if (data.x > calib->max.x) calib->max.x = data.x; // Track maximum / minimum
	if (data.y > calib->max.y) calib->max.y = data.y; // value seen per axis
	if (data.z > calib->max.z) calib->max.z = data.z;
	if (data.x < calib->min.x) calib->min.x = data.x;
	if (data.y < calib->min.y) calib->min.y = data.y;
	if (data.z < calib->min.z) calib->min.z = data.z;
	calib->mid.x = (calib->max.x >> 1) + (calib->min.x >> 1); // Find average
	calib->mid.y = (calib->max.y >> 1) + (calib->min.y >> 1);
	calib->mid.z = (calib->max.z >> 1) + (calib->min.z >> 1);
		CMPS2_DataPacket data, int declination) {
	int tx, ty;
	float deg;
	if (data.x < calib.mid.x)
		tx = (calib.mid.x - data.x);
	else
		tx = (data.x - calib.mid.x);
	if (data.y < calib.mid.y)
		ty = (calib.mid.y - data.y);
	else
		ty = (data.y - calib.mid.y);
	if (data.x < calib.mid.x) {
		if (data.y > calib.mid.y)
			deg = 90.0f - atan2f(ty, tx) * 180.0f / 3.14159f;
		else
			deg = 90.0f + atan2f(ty, tx) * 180.0f / 3.14159f;
	} else {
			deg = 270.0f - atan2f(ty, tx) * 180.0f / 3.14159f;
		else
			deg = 270.0f + atan2f(ty, tx) * 180.0f / 3.14159f;
	deg += declination;
	while (deg >= 360)
		deg -= 360;
	while (deg < 0)
		deg += 360;
#ifdef DEBUG
	printf("%d, ", (int)deg);
	printf("%d,", data.x);
	printf("%d,", data.y);
	printf("%d", data.z);
	printf("\n\r");
#endif
	return deg;
int initMlx90640(void) {
	int Status;
	xil_printf("\n\r******************************************************\n\r");
	Xil_ICacheDisable();
	Xil_DCacheDisable();
	xil_printf("\n\r**                         MLX90640                ***\n\r");
	//Initialize Mlx IIC
	Status = InitIICMlx90640();
		xil_printf("\n\r MLX 90640 IIC initialization Failed \n\r");
		return XST_FAILURE;
	xil_printf("MLX 90640 IIC  Initialization Done \n\r");
	Status = SetupMlxInterruptSystem(&IicMlx);
		xil_printf("MLX 90640 Interrupt System Initialization Failed \n\r");
		return XST_FAILURE;
	xil_printf("MLX 90640 Interrupt System Initialization Done \n\r");
	//Set up MLX 90640 IIC Interrupt Handlers
	SetupIICMlxIntrHandlers();
	Status =  SetMlxIICAddress();
		xil_printf("\n\rMLX 90640 Address Setup Failed \n\r");
		return XST_FAILURE;
	xil_printf("MLX 90640 IIC Address Set\n\r");
	// Start IIC MLX90640
	Status = start_MLX90640IIC();
		xil_printf("\n\rMLX 90640 Start Failed\n\r");
		return XST_FAILURE;
	xil_printf("MLX 90640 IIC Started\n\r");
	MLX90640_SetRefreshRate(0x33, 0x04);
	MLX90640_SetResolution(0x33,0x00);
    return XST_SUCCESS;
int loopMlx90640Gray(u8* mlx90640Image) {
	int newMinT = 999999;
	int newMaxT = -999999;
	static int minT = 999999;
	static int maxT =  -999999;
	int mlx90640Raw[768];
   //	xil_printf("MLX 90640 IIC Started\n\r");
	MLX90640_GetFrameData(0x33, mlx90640Frame);
    MLX90640_GetSensorRaw(mlx90640Frame, mlx90640Raw, &newMinT, &newMaxT);
   // if(newMinT<minT) {
    	minT = newMinT;
  //  if(newMaxT>maxT) {
    	maxT = newMaxT;
	enable_caches();
    int pixelAddr = 0;
    int offsety= 0;
    for(int i = 0; i < THERMAL_HEIGHT; i++) {
    	 for(int j = 0; j < THERMAL_WIDTH; j++) {
        	u8 index = map(mlx90640Raw[(THERMAL_WIDTH - j -1)+offsety], minT, maxT, 0, 255);
     		mlx90640Image[pixelAddr+1] = index;
     		mlx90640Image[pixelAddr+2] = index;
     		mlx90640Image[pixelAddr+3] = index;
     		mlx90640Image[pixelAddr+0] = 0x00;
     		pixelAddr+=4;
    	 offsety += THERMAL_WIDTH;
//	xil_printf("Flush cache %d\r\n");
	Xil_DCacheFlushRange((unsigned int) (&mlx90640Image),  THERMAL_WIDTH * THERMAL_HEIGHT * 4);
	enable_caches();
	return XST_SUCCESS;
long map(long x, long in_min, long in_max, long out_min, long out_max) {
  return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
    float irData;
    *minT = 999999;
	*maxT = -999999;
    for( int pixelNumber = 0; pixelNumber < THERMAL_WIDTH * THERMAL_HEIGHT; pixelNumber++)
            irData = frameData[pixelNumber];
            result[pixelNumber] = (int16_t)irData;
            if(result[pixelNumber] > *maxT ) {
            	*maxT = result[pixelNumber];
            if(result[pixelNumber] < *minT ) {
            	*minT = result[pixelNumber];
Drivers:
Github repository
Code repository for the project:
https://github.com/javagoza/XilinxSP701SensorFusion/tree/main/ff_thermal_hud
Next steps
We are already working on obtaining 360 degree thermal panoramas aided by a differential wheeled robot.
Thermal Vision Scanner
    dougw over 3 years ago
    Looks like a beast of a robot.
