Experimenting with Supercapacitors
  • Experimenting with Supercapacitors
Blog The SuperCap Rack
Join Experimenting with Supercapacitors to participate - click to join for free!
  • Author Author: dougw
  • Date Created: 31 Aug 2023 12:31 AM Date Created
  • Views 3635 views
  • Likes 13 likes
  • Comments 24 comments
  • cornell dubilier
  • SuperCap Magic Meter
  • experimenting with supercapacitors
  • capacitor test stand
  • supercap rack
The SuperCap Rack
dougw
dougw
31 Aug 2023
Intro
This is another installment in the Experimenting With Supercapacitors Design Challenge. I enjoy injecting creative design elements into any project, so while waiting for my PCB to be fabricated I thought I would address the handling issues with high energy capacitors with a little creativity. In particular I wanted to ensure the leads don't get shorted, which would degrade LiC devices that need to maintain at least a minimum charge, or high capacity devices that can deliver enough current to cause heat damage. At the same time I wanted to avoid applying stress to the capacitors such as when clamping them securely.
This blog covers 2 designs, one is a safe storage solution called the SuperCap Rack. The other one is a test stand to immobilize devices during testing without applying stress to the device under test (DUT). This multi-capacitor holder is simply called the Capacitor Test Stand.
The SuperCap Rack
The SuperCap Rack design criteria are pretty simple but there are a few of them:
  • It must safely hold all the supercapacitors supplied for the challenge and it would be nice to be able to store a few more.
  • It must prevent capacitor leads from shoring to each other or to any other capacitor leads, or in fact to any random metal in the area.
  • It must prevent the application of stress to the capacitors
  • The rack must be transportable between bench and storage location without capacitors falling out or moving enough to short out
  • The capacitors must be easily accessible
  • It must be easy to place capacitors in the rack
  • It should not take up too much space (the case supplied is very nice and it will be put to good use, but it is too big and not well suited to these requirements
The Capacitor Test Stand
The Capacitor Test Stand design criteria were slightly different:
  • It must hold each size of capacitor securely without applying stress to the DUT
  • It must perform the function of a third hand without risking hands touching leads
  • It must provide access to the capacitor leads for something like mini-grabber test leads
  • The capacitor must be held securely enough that it doesn't skitter away when trying to connect test leads
  • It must be stable enough that the weight and stiffness of test leads will not move it or tip it over
 This video provides a quick view of how all these criteria were met for both the SuperCap Rack and the Capacitor Test Stand:
Discussion & Conclusions
Both devices successfully met their design criteria. I am happy to have a nice compact storage system for supercapacitors since they don't get used on every project.
Using straws to keep each lead electrically isolated was a bit tedious, but actually took a lot less time than it would take to 3D print an equivalent structure, and the price was right. I like how the SuperCap Rack turned out. It met all my criteria and is very functional. The straw idea was probably about the tenth idea that I explored when coming up with this design, and similarly the capacitor test stand concept underwent several iterations before settling on this implementation. Fortunately I find that type of exercise to be enjoyable.
Next Steps
The SuperCap Magic Meter PCBs finally arrived so my next video will be on assembly of the Magic Meter shield.
Following that, I will have to get some software working and then I can do some capacitor testing.
Links
 The Magic of SuperCaps
 SuperCap Magic Meter Circuit
 The SuperCap Rack
 The SuperCap Magic Meter Shield
 SuperCap Meter Shield Functional Test
 SuperCap Magic Meter - Operational
 SuperCap Magic Meter - Experimenting with Supercapacitors
Experimenting with Supercapacitors Design Challenge
Cornell Dubilier Supercapacitor Technical Guide
Cornell Dubilier Supercapacitor Handling Guidelines
Challengers
Leaderboard
  • dang74
    dang74 over 3 years ago
    Impressed with your artistry Doug.  In a couple of years when we rewatch this video we will also be impressed that you were able to get a hold of plastic straws. Wink
  • dang74
  • javagoza
    javagoza over 3 years ago in reply to dang74
    Good point. In Europe, the sale of plastic straws has been banned since 2021.
  • misaz
    misaz over 3 years ago in reply to javagoza
    Date is country dependent. It is EU regulation, but every country have to implement it to their law yourself and for example in Czechia it became valid since 2022-10.
    dougw over 3 years ago in reply to dang74
    Plastic straws are disappearing everywhere. These are legacy stock - purchased years ago. I don't use straws for drinking - just for building.Relaxed
    beacon_dave over 3 years ago in reply to dougw
    Second hand drinking straw extrusion machines can make great 3D printer filament extruders.
    Might need to clear a bit of space in your lab though.
    https://www.kiwifil.shop/pages/the-story-of-kiwifil
    dougw over 3 years ago in reply to javagoza
    I haven't met anyone who likes cardboard straws yet.
    If you like drinks that need straws you can invest in a stainless steel straw.
