Pi Chef Design Challenge
  • Pi Chef Design Challenge
Blog The Spice of Pi - Blog Doug 6
  • Author Author: dougw
  • Date Created: 21 Feb 2018 5:33 AM Date Created
  • Views 2166 views
  • Likes 9 likes
  • Comments 12 comments
  • doug wong
  • spice of pi
  • pi chef design challenge
  • pi chef
dougw
dougw
21 Feb 2018
It has been a heavy week of mechanical design and fabrication. The machine is not together yet, but I wanted to post a blog showing progress:
There are still a couple of pieces to design and print, but I have enough to start assembling the machine. Once I figure out how to ream the jar holes on the main platter a bit to make the fit of some of the jars just a little freer, I can work on assembling the rotation mechanism.
Design Challenge Links:
About the challenge
The other challengers
The kit
Terms & Conditions
Summaries by Charles Gantt
Project Links:
Blog Doug 1 - The Concept
Blog Glenn 1 - AIY Voice Kit Unboxing
Blog Doug 2 - The Block Diagram and Bill of Materials
Blog Doug 3 - Spice Jar Lift Mechanism
Blog Glenn 2 - Firmware Considerations
Blog Doug 4 - Carousel Design
Blog Doug 5 - Platter Rotation Mechanism
Blog Glenn 3 - Python GUI
Blog Doug 6 - Platter Printing and Main Bearing Chassis
    beacon_dave over 8 years ago in reply to dougw +4
    Alternatively take your vernier calipers ( or 3D print a hole gauge ) with you to the grocery store and selectively pick the narrower spice jars. ( If questioned, claim that that the recipe said that quantities…
    beacon_dave over 8 years ago +3
    Wow, that was a long print operation ! It looks very good though. How about something like a small brake cylinder hone tool for the reaming operation ? https://www.amazon.co.uk/Cylinder-Triple-Engine-Honing…
    genebren over 8 years ago +3
    Douglas, Wow! You really seem to have a handle on all this mechanical stuff. That was a really great overview of the progress you have made on your project. Great work, keep up the progress. That was one…
    DAB over 8 years ago in reply to dougw
    Hi Douglas
    If you have a wood bit large enough, it might work better than trying to sand the PLA.
    dougw over 8 years ago in reply to beacon_dave
    I was using an electric drill with the hone and sanding drum but you can't work it hard enough to generate heat as the PLA melts and messes up the operation.
    Mixed results - the print file was corrupted and stopped printing (after 2 days) before it was complete - there should be a top layer to make the platter stronger.
    I thought the printer CPU had just crashed so I reprinted the file, but it failed at exactly the same point 2 days later.
    Fortunately the partial platter looks fine and seems strong enough as is, because I ran out of plastic.
    PLA is very stable dimensionally - I haven't had any issues with warping.
    Sounds like you need a machine to automate that finishing process image
    What were the 'mixed results' from the reprint, as the first one looked as if it went really well ?
    Did you experience any material warping with that size of print ? Looking at the printing video though you appeared to have pretty good adhesion to the printer bed, so perhaps not.
    dougw over 8 years ago in reply to mcb1
    The jar diameters vary by about a millimeter, but PLA is pretty tough to sand down. About half the jars fit without much work, the other half were going to be a lot of work. I figured - let the printer do the work...
    mcb1 over 8 years ago in reply to dougw
    it took about 40 minutes to get one cylinder close to where I wanted it
    It was that bad .... It just shows there is little attention to sizing of those jars.
    I ended up modifying the file and reprinting
    That's a bit serious ... 2.7 days serious
    Have you measured the jars to see the range of diameters.?
    Obviously there are some other options if this was for production or you were making several of them.
    My thought would be 5 or six 'bumps' on the inside which would allow easier fine tuning, or sloppier but taller holes.
    Well done on the attention to detail, it is a key part of the whole design.
